ID.3 - detalii pre lansare
Raf
Internal VW memo says production capacity in Zwickau is currently being increased to 1500 units per day
Din punctul meu de vedere, explicatia ar putea fi legata de intarzierile pe care le-au avut fata de clientii care au facut precomenzi. NU cred ca in prezent, in contextul actual, au explodat comenzile de masini, sa fim seriosi. Toti producatorii sufera in prezent.
cumva Corona a pus accentul pe electrice. numarul lor a crescut fata de anii precedenti exponential. nu stim daca ar fi crescut la fel, fara corona, dar deja sunt tari unde electrice au depasit fosile
https://www.zf.ro/companii/cerere-tot-mare-inmatricularile-masini-electrice-au-urcat-64-primele-doua-luni-2020-cele-mari-vanzari-le-renault-96-masini-electrice-zoe-inmatriculate-primele-doua-luni-19002302
https://insideevs.com/news/419150/global-plugin-car-sales-march-2020/
cert e ca ID3 1st deja are comenzi multe, si oamenii e asteapta.
dar suma acea era doar o..rezervare. nu as privi-o ca pe o precomanda, pentru ca se putea renunta fara probleme la rezervare, nu ca la o precomanda cand implica taxe sau costuri pierdute.
interesant ca asta nu este 1st edition...
..tot nu i-au pus piston automat la capota...facepalm..
speram sa aiba si sound de la motor in video..
Sunetul se aude aici:
@kolfleading Stiu. Mai voiam :)
Modificat de Rave
Sunetul este produs de un generator cu difuzor, nu este cel real produs de motor si angrenaje.
Este montat in dreapta fata, sub far.
de activat traducerea la subtitrari pt a intelege ce zice.
An Instagram follower has been to see the VW #id3 in Munich and sent pics. Looking really good in the flesh
I went into an ID3 showroom today and this is how much legroom I had sitting in the rear. (I'm 1,83m tall and the front seats was also adjusted to my size.) Headroom was barely enough when I sat up completely straight, sitting normally I had a good amounth of headroom
@kolfleading hai cu rabdarea:
https://www.volkswagen-newsroom.com/en/press-releases/emission-free-mobility-for-all-sales-of-id3-start-on-july-20-6229
From July 20, the ID.301 can be ordered through dealerships in many European countries
Seven pre-configured models and two battery sizes available
All models eligible for full subsidy of €9,480 in Germany
Discounted charging fees at We Charge for ID.3 buyers
Sales Board Member Stackmann: “We are realizing our vision of enabling emission-free mobility for all.”
In premiera, VW ID3 Review detaliat, inclusiv condus:
- motor spate, tractiune spate
- dimensiune exterioare de golf, spatiu interior de passat
- afiseaza si procent la baterie vezi poza
- scrie clar ca max 80% incarcare pt optimizarea bateriei
- nu are gura ventilatie in spate !
- plastic dur pe usi pe toate zonele
- jante uriase 18 - 20 inch, din pacate (care nu sint nici cele mai eficiente energetic nici cele mai comode la gropi)
- incepe sa se vanda in varianta cu bateria medie (aprox 400km autonomie) ceea ce inseamna ca nu va fi f ieftin
Asta cu ieftin, este relativ...
In ro cu toste reducerile este undeva la 27, prima varianta, de 204 cai.  Mie mi se pare un pret ok.
Poti vedea (si calcula) timpii 0 - 100 si 50 - 100 in filmul de mai jos, cam de pe la minutul 25:00
Am pus poza cu rezultatele.
Modificat de kolfleading
il vazusem dar nu mi-a dat prin cap sa scad timpul de 0-50 din 0-100, abia acum cand ai pus tu am realizat ca merge si asa :). tks.
Modificat de mandelu
