Golf Alltrack 1.8 TSI
CristiALF
Nu e nici o baliverna de marketing. Ai aici UOA pentru uleiul nou:
https://www.oil-club.ru/forum/topic/34484-mobil1-esp-5w-30-svezhee-new-2018/
Again Mobil1 produces advanced, high-tech oil unlike any other brand of oil. The main changes compared to the old ESP Formula are - cleaner and more synthetic base oils, even higher detergent / neutralizing properties, even more stock before drawdown, even more fuel economy. The oil has good thermal stability at high temperatures. Due to molybdenum, low viscosity, esters, provides even greater fuel economy. Due to the synthetic base oils has a decent low-temperature characteristics and does not save in the cold. To protect the engine from wear there is a whole arsenal - molybdenum, anti-wear additives ZDDP, Esters, thermostable base, I suspect also not a simple polymer thickener + boron-based anti-wear additives. The only negative, if it is of course the correct data - the ash content is too high.
7.5xR18/ET45
Primele sunt Ronal R57 si sunt diamond cut (si sunt un pic ingrijorat de cum rezista in timp jantele diamond cut....)
Celelalte sunt Speedline-uri Corse, SL5 Vincitore.
Ca jante, al doilea model arata mai bine. Ca si combinatie jante/masina, totusi prima varianta e preferata mea dintre cele doua
Diamont cut rezista cu un pic de extra-atentie, doar ca odata zgariate nu se reconditioneaza usor/ieftin
Primele aduc a stea mercedes iar al doilea set seamana a BBS ch pe un golf 3. No offence!
Primele par solide, de zici ca vei face doar offroad cu ele, al doilea set, par prea slim, de stat in ambuteiaj in mamaia, vara!
Subscriu la ce a zis cineva mai sus, se poate mai bine de atat! :)
Daca e de ales strict intre cele doua, votez pentru primele.
Modificat de ct_act
On 3/10/2019 at 12:12 PM, CristiALF said:
am luat si un nou extinctor to de la Brady (atentie, expira dupa 1 an - am aflat si eu acum..).
eu am luat din Auchan, valabilitate 5 ani
13 hours ago, CristiALF said:
Ceva pareri ? :)
Eu as alege primul model
Acestea mi s-au parut cele mai interesante de pe site-ul Ronal, care site e foarte misto ca iti pui masina si vezi exact cum arata.
Nu am cautat inca si la alti producatori, oricum nu e ma grabesc.
Am gasit pe site la Borbet acelasi sistem de configurare (foarte bun). Din pacate, doar modelul Y pare cat de cat ...desi janta este 18J in acest caz. Restul modelelor nu dau bine....
 Pentru restul chibitilor :) , astept sugestii ... dar vedeti si voi ca e altceva o janta pusa pe masina fata de poza generica.
Merci, din pacate nu am reusit sa pun masina mea ca si referinta , nu cred ca se poate..
Pai da, sunt o mie de tipuri de jante AM, dar as lua ceva cat de cat brand mai cunoscut daca ar fi (Borbet, Oz, Ronal, etc).
OE cred ca doar Dartford/Sebring imi surad momentan (si care sa fie si pe dimensiunea mea), nici nu le stiu pe toate evident. Talladega sunt de G6/Jetta, nici gand sa imi pun asa ceva, nu imi plac oricum.
In weekend am vazut niste Dartford-uri, dar 850 EUR pentru niste SH-uri (chiar daca in stare buna), mi se pare mult in conditiile in care imi iau jante noi AM de acesti bani (sau chiar mai putin).  Sunt f f scumpe jantele OE SH de VW, mai scumpe decat cele de Audi, Mercedes sau BMW :wacko:
Modificat de CristiALF
Nice.:icon_thumright:  Când speli mașina înainte de decontaminare iți recomand sa folosești detergent de vase in loc de șampon. In felul asta degresezi mai bine și înlături orice urma de ceara rămasa de la aplicări anterioare. De asemenea ti-as recomanda chiar înainte sa aplici ceara sau sealant-ul sa stergi tot lacul cu IPA 50%.
Tu crezi ca mai am eu ceva ceara ramasa de 1.5 ani ? Sa fim seriosi..nu mai e nimic de mult timp, heheee...
Am mai gasit un configurator foarte bun. Primele sunt 7.5J, celelalte sunt 8J. ET-ul difera putin fata de cel 45 de referinta (42 la primele, 40 la cele 8J). Nu prea gasesc nici aici modele care sa ma dea pe spate insa si care sa dea bine pe configurator :(
Zilele trecute am bifat ceva cu multi de 3.
Azi a fost o zi a suferintei dar am bifat prima mea operatiune :): 2 spalari, 2 decontaminari si o aplicare de Fusso Coat. Vreo 8-9 ore in total, cu o mica pauza.. Incepator fiind, ma declar multumit de rezultat, desi sunt rupt de oboseala :) Ma asteptam ca masina sa fie mult mai contaminata.
Momentan suntem plecati in vacanta:
    • cascadoru
    • adrian001
