Probleme cu instrumentele de bord la Sharan
AudiPerformance
Monday,08,October,2018,11:45:26:49450
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 17.1.3.0
Data version: 20170203 DS267.2
www.Ross-Tech.com
VIN: WVWZZZ7NZBV026024   License Plate:
Mileage: 132990km-82636mi   Repair Order:
Chassis Type: 7N (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 25 37 42 44 46 4F 52 53 55
          56 61 62 69 72 77
VIN: WVWZZZ7NZBV026024   Mileage: 132990km-82636miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 G    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H24 9979
   Revision: 44H24---    Serial number:
   Coding: 001D003A042401080000
   Shop #: WSC 22972 182 00000
   ASAM Dataset: EV_ECM20TDI01103L906018G 003011
   ROD: EV_ECM20TDI01103L906018G.rod
   VCID: 2E5364DE71D66F314B-807A
3 Faults Found:
4815 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [167] - -
          MIL ON - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 132997 km
                    Date: 2018.10.08
                    Time: 21:27:36
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 9 C
                    Intake air temperature: 10 C
                    Ambient air pressure: 970 mbar
                    Voltage terminal 30: 11.920 V
                    Unlearning counter according OBD: 40
                    Requested transmission torque: 1000.0 Nm
                    Limitation: accelerator pedal: 126.6 Nm
                    Cruise Control System (CCS): status-Bit 0: 11101110
                    selected gear-Bit 0: 00000000
                    Engine control module reset status-Bit 0: 00000000
                    Engine control module reset status-Bit 8: 00000000
                    Transmission torque intervention status-Bit 0: 00000000
                    Transmission torque intervention status-Bit 8: 01010000
                    Calculated reducing transmission intervention torque: 1000.0 Nm
14413 - Implausible Data Received from ABS Control Module
          U0415 00 [039] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 132997 km
                    Date: 2018.10.08
                    Time: 21:27:32
5250 - Function Restriction due to Faults in Other Modules
          U1113 00 [039] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 132997 km
                    Date: 2018.10.08
                    Time: 21:27:32
                    ACC target acceleration: 0.000 m/s
                    ACC control module received status-Bit 0: 00000011
                    Active brake system error status-Bit 0: 00000000
                    Status of ACC/CCS acceleration interface-Bit 0: 00000011
                    Acceleration: 0.000 m/s
                    Engine status: COENG_READY
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 054 R    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2603
   Revision: 05351112    Serial number: 00001012110833
   Coding: 0000020
   Shop #: WSC 00020 000 90108
   VCID: 25419BF2EC202C69BA-8070
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 21:37:57
Address 03: ABS Brakes        Labels: 7N0-614-109.clb
   Part No SW: 7N0 614 109 M    HW: 7N0 614 109 M
   Component: J104   C3 450M VD0B 0009
   Revision: --H07---    Serial number: 00000003614472
   Coding: 0000000
   Shop #: WSC 00020 790 00000
   VCID: 377D41BA468CAEF918-8062
6 Faults Found:
01044 - Control Module Incorrectly Coded
            000 -  -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 11
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 21:35:17
             Freeze Frame:
                    Speed: 0.0 km/h
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 11.75 V
                    Bin. Bits: 00000000
                    Count: 212
                    Hex Value: 0x0000
03201 - Adaptation Overboost
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 11
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 21:35:17
01423 - Lateral Acceleration Sensor (G200)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 11
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 21:35:17
01279 - Longitudinal Acceleration Sensor (G251)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 11
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 21:35:17
00810 - Sensor 1/2 for Brake Pressure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 11
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 21:35:17
01542 - Yaw Rate Sensor (G202)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 11
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 21:35:17
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 G    HW: 5K0 907 044 G
   Component: Clima-Sharan  H11 0104
   Revision: 00002001
   Coding: 0000000009
   Shop #: WSC 00020 999 00000
   ASAM Dataset: EV_ClimatronicSharan A01005
   ROD: EV_ClimaAutoSharaBasis.rod
   VCID: 2F6D79DA76DC663940-807A
No fault code found.
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 5K0 937 087 M    HW: 5K0 937 087 M
   Component: BCM PQ35 H    011 0046
   Revision: BE011001
   Coding: 40180A3B89251AC0400800C0740009E443551408636D2562E480870000C1
   VCID: 3F8D299AAEBC96B9D0-806A
   Subsystem 1 - Part No SW: 7N1 955 119 A    HW: 7N1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110910  31  0032
   Serial number:         110913184537
   Coding: 000D9D
   Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
   Component: RLFS  021 0022
   Serial number: Y11M01D17h17m13s21S1
   Coding: 0380BB
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20431101803537
   Coding: 11830D
   Shop #: WSC 31526 143 180368
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_SK46.rod
   VCID: 3C775E96B7AA8DA1F5-8068
5 Faults Found:
13637393 - Databus
          U1123 00 [009] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 11
                    Mileage: 132997 km
                    Date: 2018.10.08
                    Time: 00:24:59
13637392 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 11
                    Mileage: 132997 km
                    Date: 2018.10.08
                    Time: 00:24:59
13637395 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 132997 km
                    Date: 2018.10.08
                    Time: 00:24:59
13637396 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 11
                    Reset counter: 11
                    Mileage: 132997 km
                    Date: 2018.10.08
                    Time: 00:25:04
13637397 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 10
                    Reset counter: 11
                    Mileage: 132997 km
                    Date: 2018.10.08
                    Time: 00:25:04
Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
   Part No SW: 7N0 959 655 B    HW: 7N0 959 655 B
   Component: VW10Airbag015 H07 0013
   Serial number: 003GFPEYVT50
   Coding: 003135
   ASAM Dataset: EV_AirbaVW10TS6VW428 A01002
   ROD: EV_AirbaVW10TS6VW428.rod
   VCID: 3E73549EA1B69FB1DB-806A
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.V  --- ---
   Serial number: 3493ETS609F2051139DP
   Coding: 000000
   Crash sensor for side airbag: front passenger side:
   Subsystem 2 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.V  --- ---
   Serial number: 3503ETS60F9FA5E13DDE
   Coding: 000000
   Crash sensor for side airbag: rear: driver side:
   Subsystem 3 - Part No SW: ---            HW: ---
   Component: S.Sens.Fahr.H  --- ---
   Serial number: 3513ETS600F725413DDN
   Coding: 000000
   Crash sensor for side airbag: rear: passenger side:
   Subsystem 4 - Part No SW: ---            HW: ---
   Component: S.Sens.Beif.H  --- ---
   Serial number: 3523ETS60F1D25E139D,
   Coding: 000000
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: ---            HW: ---
   Component: F.Sens.Fahr  --- ---
   Serial number: 35540TS6048DA7113DDO
   Coding: 000000
Address 16: Steering wheel (J527)       Labels: 5K0-953-569.clb
   Part No SW: 5K0 953 501 BA    HW: 5K0 953 569 H
   Component: LENKS.MODUL   009 0136
   Revision: FF010039    Serial number: 20101229100195
   Coding: 198A240000
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS.rod
   VCID: 6ADBA8CE8DBEC31157-803E
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H06 0022
   Coding: E20000
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 132997 km
                    Date: 2018.10.08
                    Time: 00:09:36
                    UBat: 14.80 V
                    MC1 interner Fehlercode: 0
                    MC2 interner Fehlercode: 0
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 7N0 920 870 A    HW: 7N0 920 870 A
   Component: KOMBI         H20 0420
   Serial number: 00000000000000
   Coding: 140F00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW25.rod
   VCID: 306F7AA66BE279C159-8064
Address 18: Aux. Heat        Labels: 1K0-815-071.clb
   Part No: 7N0 963 271 A
   Component: Zuheizer        051 2630
   Revision: 00051000    Serial number: 09022126000000
   Coding: 0000041
   VCID: 326B70AEADEE4BD12F-8066
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 D    HW: 1K0 907 951
   Component: J533  Gateway H35 0614
   Revision:   H35       Serial number: 140111F1000999
   Coding: 468002
   VCID: 31697FA268E870C956-8064
Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H20 0420
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 B
   Component: RNS-MID       H11 5238
   Revision: AB001001    Serial number: VWZ6Z7J6064091
   Coding: 04000400040000820011
   Shop #: WSC 05314 123 12345
   VCID: 377D41BA868CAEF918-8062
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V15  8522
03138 - Input AUX IN
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 23:37:44
Address 42: Door Elect, Driver (J386)       Labels: 7N0-959-793.clb
   Part No SW: 7N0 959 793 E    HW: 7N0 959 793 A
   Component: TSG FA        H04 0400
   Revision:             Serial number: 0000111545263
   Coding: 01150620D000411011
   VCID: 44872676C75AF5618D-8010
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.325 0802
   Revision: 1AH03729    Serial number: 00110050265201
   Coding: 0000258
   VCID: 3B755D8A7AA48A99FC-806E
3 Faults Found:
02546 - Steering Limit Stop
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
             Freeze Frame:
                    Fault Status: 11100101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 11
                    Time Indication: 0
             Freeze Frame:
                        Term 15 On
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 4.0
                    Voltage: 12.00 V
00778 - Steering Angle Sensor (G85)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 11
                    Time Indication: 0
01316 - ABS Control Module
            013 - Check DTC Memory - MIL ON
             Freeze Frame:
                    Fault Status: 11101101
                    Fault Priority: 6
                    Fault Frequency: 11
                    Reset counter: 11
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 00:25:05
             Freeze Frame:
                        Term 15 On
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    (no units): 4.0
                    Voltage: 11.90 V
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 1K0 907 951
   Component: EZE_2         H35 0614
   Coding: 050B0500
   VCID: 6FEDB9DABE5C263900-803A
   Subsystem 1 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H02 0220
   Serial number: 0123456789ABCDEFGHIJ
   Subsystem 2 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H02 0220
Address 52: Door Elect, Pass. (J387)       Labels: 7N0-959-792.clb
   Part No SW: 7N0 959 792 E    HW: 7N0 959 792 A
   Component: TSG BF        H04 0400
   Revision:             Serial number: 0000111544587
   Coding: 01150620DE00411011
   VCID: 4385256AC254F259B4-8016
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 D    HW: 3AA 907 801 D
   Component: J540 EPB4  VW-53083 0006
   Revision:   H18       Serial number: 00000000135514
   Coding: 0024067
2 Faults Found:
             Freeze Frame:
                    Fault Status: 01110101
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 237067 km
                    Time Indication: 0
                    Date: 2011.04.26
                    Time: 00:00:23
             Freeze Frame:
                    Voltage: 11.80 V
                    Count: 101
                    Speed: 0.0 km/h
                    Hex Value: 0x1240
                    Hex Value: 0x0001
                    Hex Value: 0x0101
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 237067 km
                    Time Indication: 0
                    Date: 2011.04.26
                    Time: 00:00:23
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 D    HW: 5M0 907 357 D
   Component: AFS-Steuergeraet    0149
   Revision: 00H04000    Serial number:
   Coding: 3555545
   VCID: 35614BB25C805CE90A-8060
   Subsystem 1 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0001
   Coding: 00000054
   Subsystem 2 - Part No: 1T0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0001
   Coding: 00000054
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 11
                    Mileage: 132997 km
                    Time Indication: 0
                    Date: 2013.02.28
                    Time: 23:37:44
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H35 0614
   Coding: 030B185A
   VCID: 71E9BFA2A86830C916-8024
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370264470
Address 62: Door, Rear Left (J388)       Labels: 7N0-959-794.clb
   Part No SW: 7N0 959 794 E    HW: 7N0 959 795 A
   Component: TSG HL        H03 0400
   Revision:             Serial number: 0000111617334
   Coding: 010004200000411001
   VCID: 45813B72CC60CC699A-8010
Address 69: Trailer
Cannot be reached
Address 72: Door, Rear Right (J389)       Labels: 7N0-959-794.clb
   Component: TSG HR        H03 0400
   Revision:             Serial number: 0000111414535
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 5N0 035 730 D    HW: 5N0 035 730 D
   Component: Telefon       009 0511
   Revision: --------    Serial number: 35909603093156
   Coding: 020000000100000000010000
   ASAM Dataset: EV_UHVPremi A01005
   ROD: EV_UHVPremi_A01.rod
   VCID: 295997C2483808099E-807C
End-------------------------(Elapsed Time: 03:56)--------------------------
Address 03,7N0 614 109 M,recoded (Short coding),from,0000000,to,0002048,(00020/790/00000),
Address 03,7N0 614 109 M,recoded (Short coding),from,0000000,to,0000000,(00020/790/00000),
Address 44: DTCs cleared
Address 53: DTCs cleared
Address 02: DTCs cleared
Scuzati dacă am facut off topic sau am ocupat prea mult spatiu.
Ai pierdut codarea la pompa ABS - si setari de baza, la senzori.
Daca ai o scanare mai veche, folosesti codarea de acolo - daca nu ai...mai greu.
Dupa recodarea pompei, faci setarile de baza la senzori - G85, G200, G202, G251 (cei care iti apar in erorile stocate)... dupa care limit stop pentru servodirectie
Nu am o scanare mai veche.....care e procedura ca s o aflu
e mai complicat - trebuie compusa dupa seria VIN ... sau online la reprezentanta
Bună ziua,am un Seat alhambra din 1999 motor 1,9 afn și nu se mai aprind luminile la ceasuri, menționez că am probat cu alt bloc de lumini și cu alte ceasuri și tot nu merg
Modificat de neloxxl
  • 11 months later...
On 15.05.2013 at 20:39, dore982 a scris:
salutare la toti colegi,am vazut ca aveti si voi aceiasi problema ca mine,cu ceasurile de bord la 2001-2003 ,si al meu face la fel cind iau contactu se reseteaza tot acul la turometru ramine pe la 800 rpm si nu se inchide corect usa la sofer,chesti interesanta este ca am montat pe masina un dvd auto jvc si de cind iau contactul mai dureaza vreo 20 secunde pina se opreste radio in tot acest timp ceasurile de bord functioneaza cum se opreste radio pa nu mai apare nimic nici pe ceasuri si nici usa sofer nu se inchide,am reusit sa fac diagnoza numai cu radio pornit daca scot radio afara nu am curent la mufa iso pe vag com imi da led usa sofer inchidere centrala in scurt la masa intrmitent ,si releu incalzire parbriz fata scurt la masa intermitent,bineinteles si esp sta aprins din cauza ca nu se alimenteaza numai cind pornesc radio,ati rezolvat ceva cu problema asta ca eu nu ii dau de cap, firele nu au nici pe dracu la usa ca le-am purecat numai daca e undeva prin bord vreo problema,eu ma gindesc serios chioar sa vind masina , am lipit la cabluri pe la haion pe la usi ca erau rupte dar acu nu mai stiu ce dracu sa caut, daca ati gasit problema scrieti va rog frumos un mesaj privat sau pe forum ca este folositor si pentru alti colegi care probabil o sa aiba aceiasi problema.
colegu ai rezolvat ceva in legatura cu problema de la sharan ,acum am aceiasi problema ca si tine si nu ii dau de cap .
Salut un coleg care a gasit rezolvare la problema ?
Verifica alimentarile din mufa ceasului. Îți lipsește plusul permanent. Verifica întâi siguranțele
Salutare la toata lumea. Am o mica problema daca ma poate ajuta cineva as fi recunoscător . Pe scurt "m am jucat" putin cu vcds ,nu prea avand experiența cu el, si am dezactivat afisajul din bord . Are ideea cineva cum pot sa l activez inapoi ? Am umblat pe la codari si am uitat sa memorez ce cod era anterior. Masina este un sharan 2010 7m .
Cum adica l-ai dezactivat?
Adică nu mai afișa nimic era negru ( range ,consum etc) dar am rezolvat . Făcusem o codare si am uitat codarea inițială dar am rezolvat .
Modificat de vdragos
Quote inutil
