Polo 9N si 9N3 - Scanarea cu VCDS - coduri de eroare si remedierea lor
octav59
Am masurat compresia ,pe cil1 e 10 iar pe 2 si 3 e 14 ,deci cred ca trebuie sa dau chiulasa jos sa vad supapele, la ce costuri sa ma astept,supape,garnitura si planare chiulasa?
  • Replies 506
  • Al Bundy
    95
  • ionel.d.2007
    48
  • SergiuD
    17
  • cernescui
    11
Va salut.
Pentru codurile de mai jos ma ajuta cineva cu o parere avizata?
                Address 03: ABS Brakes       Labels:
Control Module Part Number:
  Component and/or Version:
           Software Coding:
            Work Shop Code:
                      VCID: 55ABF0F0BF1A496
5 Faults Found:
01314 - Engine Control Module
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            003 - Mechanical Failure - Intermittent
00285 - ABS Wheel Speed Sensor; Front Right (G45)
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            013 - Check DTC Memory - Intermittent
Verifica inelele de la rotile la care apare mecanical failure.
Salutare! De doua zile nu mai porneste Polo (9N3), in sensul ca dau la automat degeaba ca nu porneste. Bateria e schimbata acum doua luni (Varta Silver de 74 parca). Mentionez ca am alarma aftermarket montata acum doi ani. Am pus testerul pe masina si mi-a dat urmatoarele erori:
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 D
   Component: 00BP BN-SG.         1S34
   Coding: 25742
   Shop #: WSC 00788
   VCID: 3C7330C304AB
2 Faults Found:
01598 - Drive Battery Voltage
            07-10 - Signal too Low - Intermittent
01054 - Power Supply Relay; Terminal 30 (J317)
            28-00 - Short to Plus
Pe celelalte module este totul curat, fara erori.
Ma puteti ajuta cu ceva sfaturi? Multumesc!
Possible Cause:
Loose contact.
Corrosion at plug connections.
Short circuit in the wiring to the interior lights.
Possible Solutions:
Test wiring.
Check connectors.
Replace relay (J317).
Symptoms:
Engine not starting.
Possible Cause:
Battery discharged.
Battery defective.
Possible Solutions:
Charge Battery.
Check/Replace Battery.
Bateria ai schimbat-o acum 2 luni avand aceleasi simptome sau din alte motive?
Detin un Vw polo 9n3 1.2 12v cod motor BME,imi poate spune cineva unde este localizata mufa de intrare Vag Com?
deasupra la maneta de deschidere a capotei motorului, daca te apleci o vei observa este mov
Multumesc mult :) revin cu urmatoarele coduri :
   Coding: 25742
   Shop #: WSC 31414
   VCID: 3C7C839A2CBCB1F83DD
2 Faults Found
00900 - Fuse for Signal Horn (S194)
            37-10 - Faulty - Intermittent
Precizez ca claxonul merge,ma poate ajuta cineva ? va rog frumos
Contact imperfect in blocul de sigurante la cea pentru claxon sau la conectori,iar pentru releul J317 s-a scris citeva posturi mai sus ce e de facut.Verificat fire,conectori,schimbat releul.Cel mai probabil,ramine releul cuplat.Cind am modificat luminile interioare,parca aveam si eu eroarea asta.
Multumesc mult.
Si releul J317 sti unde este localizat? e cumva cel de alimentare baterie?
Releul J317 este in interiorul centralei electrice (J 519). Ai montata alarma aftermarket?
Da am alarma aftermarket dar numai merge sa stricat un buton la telecomanda.
Am desfacut un panou in stanga jos la volan sunt mai multe relee dar nu il vad pe j317.
Ti-am spus ca J 317 este localizat in interiorul centralei electrice (J 519). J 519 este modulul in care intra peste 10 cuple. Poze: post-10189-0-07837200-1378636429_thumb.j si post-10189-0-00328200-1378636453_thumb.p si post-10189-0-80223500-1378637528_thumb.p
Pentru eroarea 01054: sterge eroarea, trece comutatorul de lumini interioare pe pozitia oprit ( nu mai folosi pozitia automat-aprinderea luminii la deschiderea usii) si verifica dupa o perioada daca iti mai apare eroarea stocata.
Daca eroarea nu iti mai apare trebuie sa refaci legaturile la alarma. Cum ? Nu stiu. Si la mine este la fel. Eu am alarma 2 way, montata in service specializat pe alarme.
Modificat de ionel.d.2007
De ce nu scoti mufa de la alarma si inchizi cu cheia,dupa care verifici sa vezi ce erori ai.Daca le mai ai...
Am rezolvat cu eroarea la caxon am schimbat siguranta.
O sa ma duc sa schimb alarma veche 2007 cu una noua,sper sa numai imi dea eroare.
Multumesc mult pt. sfaturi :D
Buna seara,
Va rog un sfat . Ce tb sa fac ?
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN:    Mileage: 97540km/60608miles
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS.lbl
   Part No SW: 6Q0 907 379 AF    HW: 6Q0 907 379 AF
   Component: ABS 8.0 front   H04 0002
   Coding: 0002085
   Shop #: WSC 31414 790 00001
   VCID: 810374A0DB12956
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
Address 08: Auto HVAC        Labels: 6Q0-820-045.lbl
   Part No: 6Q0 820 045
   Component: Klimaanlage        X0840
   VCID: EAD1330C966476E
01596 - Motor for Outside/Recirculated Air Flap (V154)
            41-00 - Blocked or No Voltage
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 6Q0 035 152     HW: 6Q0 035 152
   Component: Radio BVX       006 0010
   Revision: 00006000    Serial number: VWZ1Z5E4681193
   Coding: 0020200
   VCID: E7D74A38D5764B6
   Part No: 6Q0 035 152
No Faults Found
erorile de mai sus.
nu inteleg ce este blocat.
butonul de recilculare este apris continuu. daca il apas se stinge cateva secunde si se aprinde iar.
erorile de mai sus.
Rog o parere mai pertinenta pentru aceste erori. Cea cu releul mi-a sarit din prima in ochi.
Address 01     -------------------------------------------------------
   Controller: 03E 906 033
   Component: 1,2l/4V SIMOS3  00HS4340
   Coding: 00071
   Shop #: WSC 31414
5 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
            P0116 - 35-10 - - - Intermittent
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
            P0420 - 35-10 - - - Intermittent
17811 - EGR System: Regulation Divergence
            P1403 - 35-10 - - - Intermittent
16825 - EVAP Emission Control Sys: Incorrect Flow
            P0441 - 35-10 - - - Intermittent
17925 - Main Relay (J271): Electrical Malfunction
            P1517 - 35-10 - - - Intermittent
Readiness: 0000 0000
-> Releul acela pare a fi defect sau un contact imperfect
  • Power Supply Relay for Engine Control Module (J271 or J363) faulty
  • Wiring between Engine Control Module (J220) and Power Supply Relay for Engine Control Module (J271 or J363) faulty
Address 08     -------------------------------------------------------
   Controller: 6Q0 820 045
7 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
            30-10 - Open or Short to B+ - Intermittent
            30-00 - Open or Short to B+
            29-10 - Short to Ground - Intermittent
            28-10 - Short to B+ - Intermittent
            41-10 - Blocked or No Voltage - Intermittent
-> Erorile astea sunt bonus. Clima si ventilatoarele nu sunt pornite.
Address 09     -------------------------------------------------------
   Controller: 6Q1 937 049 B
   Component: BORDNETZ-SG.        1S31
   Coding: 17567
   Shop #: WSC 64785
            07-10 - Signal to Low - Intermittent
-> asta se poate sa fie de la fosta baterie pe care a schimbat-o acum 2 zile.
Mai multe informatii despre cum se manifesta problema:
Masina cumnatei uneori nu mai porneste, iar problema se manifesta aleator insa din ce in ce mai des in ultima perioada. Mergem cu masina, o parcam.. stai 5 minute dupa care dai la cheie si nu mai porneste. Sau mergi cu ea, o opresti si cand dai din nou la cheie nu mai porneste.
Daca o lasi sa stea juma de ora si dai la cheie porneste.
L/E: Am gasit aceeasi eroare si la alti colegi in postarile de la scanari si m-am lamurit ca de la releu ni se trage. O sa duca masina in service sau unde o sa vrea sa o repare.
Modificat de netsonic
mariusbbb - problema ta e relativ usor de rezolvat daca te pricepi putin la surubarit sau altcineva si te scapa de multi bani cat ar fi un servo-motoras nou
s-a discutat mult, in sectiunea fabia in special, am folosit functia search:
http://vwforum.ro/topic/38702-problema-cu-incalzirea-habitaclu-la-fabia/page-11?hl=%2Bv154#entry2119868
netsonic - influenta mare la pornire si in functionare o pot avea si celelalte erori aparute legate de: G62, EGR si EVAP.
erorile de mai sus.
erorile de mai sus.
Motorasul de recirculare are probleme, posibil ceva rotite din servomecanism duse.
Au intrat ceva gunoaie sub grila stergatoarelor? Sau in ce sens era blocata?
multumesc mariusbbb pentru precizari.
Celelate erori le avem in ea de ani de zile si nu am avut probleme cu ea. Acum ca le-am sters acestea nu au mai reaparut. Am facut aseara special 3 ture cu masina in care am verificat live tensiunea la baterie si ceilalti parametrii ce mi s-au parut relevanti. De asemenea am oprit si repornit motorul, ca sa vad daca iar face figuri si din nou nimic. Nu mai logheaza nimic.. nici la releu.. nici la egr si nici la restul, cu exceptia la HVAC (clima) care ramane neschimbat.
  • Vizitator changed the title to Polo 9N si 9N3 - Scanarea cu VCDS - coduri de eroare si remedierea lor
