Problema inchidere / deschidere centralizata - Golf 5 / Jetta
gordonFreeman
Pai da dar cel de inchide centralizata nu e acolo... e sus la manerul de deschidere a usii
corect - mea culpa - la generatia anterioara e acolo.
Aceeasi problema am si eu. De 2 zile, nu imi mai functioneaza inchiderea / deschiderea din cheie. Pur si simplu nu a mai mers. Deodata. Trebuie mereu sa o deschid bagand cheia in butucul usii. AM pus-o pe tester si mi-a dat urmatoarele erori.
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 76 7D
VIN: WVWZZZ1KZ7B014110   Mileage: 206410km/128257miles
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
37-Navigation -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 70EF364B6356C89E643-8025
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 - -
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004099297
   Coding: 018B8F2700041500001400001400000000097F075C
   Shop #: WSC 00046 000 180224
   VCID: 2B55E1278AF0EB46111-807E
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 310506 020  0501
   Coding: 00038805
   Shop #: WSC 00046
01504 - Bulb for License-Plate Light (X)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 191
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                        OFF
                    Voltage: 12.25 V
                        OFF
                        ON
                        OFF
                        OFF
                        OFF
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
   Component:    KSG PQ35 G2  020 0202
   Revision: 00020000    Serial number: 00000000000000
   Coding: 009002005103087F2D0484056008CF01E0FCA0
   Shop #: WSC 00046 000 172032
   VCID: 8305E987C2E04306091-80D6
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
00896 - Trunk Lock Unit (F256)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 4
                    Fault Frequency: 10
                    Reset counter: 202
                    Mileage: 200064 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:31:25
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 N    HW: 1K0 959 702 N
   Component: Tuer-SG         005 0963
   Coding: 0000436
   VCID: 3A7BD46375AA42CE9A7-806F
00110 - Right Mirror Turn Signal Lamp (L132)
End   ---------------------------------------------------------------------
fa o resincronizare a telecomenzii, cu VCDS-ul, pe 46-convenienta, in 10-adaptation
Am sa incerc si asa. Dar merge cu o singura cheie ? Am doar una.
Modificat de dudu
Nu mai da Quote mesajului anterior! Citeste Regulamentul! Mersi!
da, merge cu o singura cheie - pui contactul cu ea, dupa ce bagi la Adaptari, apesi butonul de incuiat/descuiat de pe telecomanda, pt o secunda,
Am sa incerc si asa, dar pb este ca va mai dura ceva timp pana ajung la tester. Pana atunci deschid manual ;)
Modificat de dudu
dupa cateva cautari am gasit acest topic legat de inchidere deschidere din cheie, am cumparat un golf 5 de curand si am observat ca daca inchid masina din cheie pasagerul din dreapta poate deschide usa iar eu nu, iar la o scanare cu vag-comul am gasit urmatoarele erori :
3 coduri defecte: 00097-Motor inchidere centrala fata-Safe- -V162- pasager
00929 -Unitate inchidere centrala-F221-pasager 008 -semnal neplauzibil
00944 -Oglinda incalzita pasager-Z5- 012 - Defect de circuit electric
Ce vrea sa insemne asta ? trebuie schimbat actuatorul sau sa rupt vre-un cablu metalic ceva ?, pe langa asta cand inchid usa se aude ceva in ea ca si cum se loveste actuatorul de partile metalice
Inseamna ca trebuie desfacuta broasca si reconditionate motorasele.
  • am si eu o problema la un golf 5 2008 usa de la sofer nu se inchide nu se deschide restu merg perfect imi da urmatoarea eroare
      Address 42: Door Elect, Driver       Labels: 1K0-959-701-MIN3.lbl
    Control Module Part Number: 1K0 959 701 M    HW: 1K0 959 701 M
      Component and/or Version: Tuer-SG         006 1211
               Software Coding: 0000180
                Work Shop Code: WSC 00028 028 00001
                          VCID: 387FCE6B4BA650DE6C3-806D
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
                002 - Lower Limit Exceeded
    poate a mai avut cineva problema rog sa ma ajute
F l o r i n
jos yala si verific-o pe direct, daca lucreaza sau nu.
daca nu lucreaza, trebuie reconditionata.
daca lucreaza, atunci problema este la calculatorul de usa.
Nu e de la yala clar, are fire rupte in mansonul dintre usa si stalp.
F l o r i n
e posibil ca eroarea sa nu aibe legatura cu functionalitatea yalei - pe usa respectiva a zis ca ii functioneaza totul, mai putin incuiat/descuiat.
oricum, trebuie sa verifice daca se sterge eroarea, daca e permanenta, daca sunt firele ...sau nu.
nu se sterge eroarea am sa incerc la fire  sau dau fata de usa sa umblu la yala
usa nu se inchide nu se deschide (din cheie sau butonul din interior) dar butonul din interior lucreaza inchis deschis doar cu celelante 3 usi
merge doar cu cheia din exterior
multumesc pt ajutor
F l o r i n
daca nu se descuie/incuie nici de pe butonul din interior - verifica intai cablajul. Asteptam sa ne zici ce ai descoperit
da baieti multumesc mult pt sfat intradevar era firul rosu galben rupt sa rezolvat in 10 minute
daca aveti probleme in zona mea va ajut cu orice cu multa placere
Modificat de amdmarian
Deci ?
Asta pentru cine stiu eu .....
Ofer o inghetata celui/celor care imi zic rezolvarea la urmatorarea problema:
-Golf V 2.0 TDI 140 CP,2004,nu reusesc sa deschid usile din spate.
Initial nu se deschidea cea din dreapta spate atat din interior cat si din exterior si cea din stanga se deschidea doar din interior,m-a "ajutat" un prieten care a rasucit cheia in lacasul de blocaj copii cred ca invers iar acum nu mai pot deschide de pe nici-o parte usile spate...
Ce-i de facut ?
incearca sa bati pe exterior si pe interior in zona yalei, in aceelasi timp sa actionezi butonul de descuiat. Din pacate nu exista o solutie standard in cazul tau... tine de fiecare defect... se cauta solutii.
Salut, nu stiu daca e locul bun pt problema mea .
Am o problema de inchidere la portbagaj (golf 5 variant).
Acum cateva zile am incercat sa deschid ,dupa ce am deschis din telecomanda , am apasat pe butonul usii si se aude un clik repetatat, sacadat ,rezultatul e ca nu se deschide deloc . Trebuie deschis de la interior. eu cred ca e switch_ul.
Am demontat  panoul usii , sa vad ce e pe acolo ( doar  de curiozitate ).
Cand e usa deschisa si apas pe buton nu face niciun zgomot.
Are cineva ceva ideii ??
Va salut!
De ceva vreme nu mai pot deschide de la distanta usa de la sofer. Trebuie musai sa bag bag cheia in broasca. La actionare in broasca functioneaza corect si inchiderea si deschiderea masinii. Inchiderea de la distanta functioneaza de asemenea corect. La scanare am urmatorul pocinog:
2 Faults Found
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Este posibil sa fie acel microswitch de la broasca?S-a mai confruntat cineva cu asa ceva? Multumesc, numai de bine!
Prima data desfaci mansonul dintre usa si stalp si verici daca nu ai fir/fire intrerupte.
Vezi ca s-a mai discutat pe aceasta tema :D
si a doua oara desfaci broasca si refaci lipiturile pe placa si cureti colectorul motoraselor.
Ok. Multumesc de raspuns. Am uitat sa precizez ca am facut deja asta. Am avut doua intrerupte si le-am rezolvat. Erau de la difuzoare. Am verificat intre timp si microswitch-ul si e ok. E pe inchis cand e inchisa usa si pe deschis cand e deschisa :). Cand deschid remote desi se aude un zgomot in interiorul actuatorului nu se deschide usa.
atunci e clar... desfaci broasca si refaci lipituri si cureti motorasele.
  • R_a_z_v_a_n a închis acest topic
