Probleme ABS+ESP
eugenus
DAca difera lungimea sirului mai adaugi 00.
Buna seara.
Ce pompa de ABS se poate adapta pe un Golf 5 PLUS 2006 pentru a putea inlocui IC-ul cu unul de generatie mai noua (alb-negru) ?
Se poate adapta (sa fie 100% functionala) o unitate cu ESP, eventual cea recomandata in paginile anterioare?
VIN: WVWZZZ1KZ6W590451   License Plate:
Mileage: 176640km-109759mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72 76 7D
VIN: WVWZZZ1KZ6W590451   Mileage: 176640km-109759miles
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 R    HW: 028 101 222 0
   Component: R4 1,9L EDC G010SG  7001
   Revision: 12345678    Serial number: VWZBZ0E0278640
   Coding: 0000071
   Shop #: WSC 01392 785 00200
   VCID: 326B7CEDADFEF2D20F-8066
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8D25D96EAC2FBAF0-806A
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 BD
   Component: ClimatronicPQ35 090 0808
   Shop #: WSC 00000 000 00000
   VCID: 6ADBA48D45AE7A1277-803E
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000002314860
   Coding: A1890F2700041800000A00000F00000000095D035C
   Shop #: WSC 12345 785 00200
   VCID: 2B5561898AD4A31A4C-807E
   Subsystem 1 - Part No: 5M0 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer VW359  012  0403
   Coding: 00065493
   Shop #: WSC 12345
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 R    HW: 1K0 909 605 R
   Component: 1D AIRBAG VW8   018 2200
   Revision: 02018000    Serial number: 0038MD05B2F-
   Coding: 0012612
   Shop #: WSC 01372 785 00200
   VCID: 3B7551C97AB4339ADC-806E
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 634 0070
   Coding: 0000042
   VCID: 76E380FD0116AEF2E3-8022
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K0 920 862 KX
   Component: KOMBIINSTRUMENT VDD 4312
   Coding: 0003103
   Shop #: WSC 10101 599 68949
   VCID: 0A1BC40D65EEDA1297-805E
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 26031400F16263
   Coding: 350002
   Shop #: WSC 12345 123 12345
   VCID: 76E380FDC116AEF2E3-8022
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 4312
   Shop #: WSC 10101 599 59615
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H05 0010
   Serial number: VWZAZ2L3315449
   Coding: 000002110200000000010000
   Shop #: WSC 00015 115 12345
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS.rod
   VCID: 60CFC6A57B923042A9-8034
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1K0 959 701 K
   Component: Tuer-SG         024 2379
   Coding: 0000180
   VCID: 366340FD4196EEF223-8062
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 336579E952E4FBDA04-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 18C802487F2D840548CF01E010CC
   Shop #: WSC 10808 599 12345
   VCID: 79F98BC13008C18A8E-802C
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Coding: 0000180
   VCID: 377D4DF9469C17FA38-8062
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
   Part No: 1K0 959 703 F
   Component: Tuer-SG         021 2431
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 F
   Coding: 0000144
   VCID: 34677AF557EAFCE21D-8060
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 24 Einparkhilfe     0101
   VCID: 2D516F91B4C0AD2A52-8078
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
Multumesc Florin.
Am gasit doua coduri : 1K0 907 379 AF / 1K0 614 117 AE  si  1K0 907 379 AQ / 1K0 614 117 AJ. Se potriveste vreuna?
Buna. Am aceeasi problema ca si majoritatea de aici. S-au aprins in bord becurile de ABS, ESP, becul de frana de mana palpaie si suna, becul cu volanul, becul cu motorul, vitezometru merge doar cand vrea si acul de combustibil la fel.
Electricianul mi-a spus ca modulul de ABS trebuie schimbat. Am modul cu codurile 1K0907379AD si 1K0614517BD. Nu gasesc nicaieri acelasi modul second. Cu ce modul se poate inlocui astfel incat sa fie la fel conductele si sa poata fi recunoscut cat mai usor de masina la codare? Multumesc.
Marius, citeste un pic posturile anterioare.....este deja postat.
Posteaza si rezultatele diagnozei.
Va salut, in urma unor probleme cu modulul abs am decis schimbarea lui cu unul cu seria BJ si DE pe partea mecanică, eu avand pe masina AE si BE, esp MK60EC1 cu codarea 113B400D092A00FE881002E8901F0042B500, masina in cauza fiind un Golf 5 2.0 bkd DSG 2008... Din ce am înțeles pe paginile din urma ar mai trebui sa adaug cateva grupe de 00 00 la noua codare, dar nu știu câte... Si mai am o intrebare, ce înseamnă acel HHC?
Modificat de GeDOc
hill hold control
Buna ziua
Am schimbat o pompa abs be si ce soft cu de si bj soft. Mecanicul a zis ca dupa ce scris codurile s-a blocat masina. A pus pompa originala a masinii disparuse becurile abs  si frana de mana, dupa ce  a facut un test drive s-au reaprins. Ce sfaturi imi dati.?
Sa mergi la cineva care se procepe sa codeze o pompa ABS mk60 ec1.
Modificat de Al Bundy
Se pare ca mecanicul meu nu se pricepe. Cunosti pe cineva care a mai facut codarea din bacau sau apropriere?
Daca ai fi de acord  as aduce masina la tine numai sa imi spui  daca te pot contacta telefonic. Multumesc
Va salut! In drum spre mare mi s-au aprins martorii abs si esp. Cand am ajuns la hotel am constatat ca protectia discului de la roata dreapta spate era desprinsa si a cazut pe axul rotii, facand si o zgarietura pe janta( este mancata de rugina si s-a rupt din prinderi). Am reusit sa o fixez temporar acolo, doar ca la scanate mi-a dat urmatoarele 2 erori:
00287 -abs wheel speed sensor, rear righr (g44) -008 implausible signal intermittent
00287 -abs wheel speed sensor, rear righr (g44) -003 mechanical failure intermittent
La citirea parametrilor senzorilor celelalte roti au valori egale, iar la roata dreapta spate nu ramane constant, se schimba intr-o fractiune de secunda.
Ce credeti ca ar putea fi? Senzorul abs sau inelul abs. Ma gandesc ca acea protectie de tabla ar putea sa fi afectat acel inel, deoarece era cazuta chiar pe ax si se freca de a el.
Mulțumesc anticipat!
E de la inel magnetic. Senzorul e ok
Mulțumesc pt informatie. O sa ma documentez cum se inlocuieste ca ma sacaie martorii din bord. Vine la pachet si cu etrier blocat tot la aceeasi roata! Upss..
Salutare tuturor,
A incercat cineva sa resofteze pompa de abs 1k0 907 379 AD/CD?
Daca da, vindeca erorile?
S-a mai scris prin topic, erorile sunt de natura hardware, nu soft, deci resoftarea nu prea are rost in majoritatea cazurilor. Urmeaza recomandarile date prin topic referitor la codurile cu care poate fi inlocuita pompa si totul se va rezolva la costuri decente.
Modificat de vwmkv
Mersi vwmkv!
Am citit in topic deci stiu care e procedura, din cate am inteles de la cei patiti, au mai scapat si cu un update si voiam sa stiu daca au fost cauzuri si printre useri vwforum.
Buna seara, de vreo 3 zile mi s-au aprins 3 becuri in bord: ABS, ESP si frana de mana. Am fost la un tester si mi s-a aprins urmatoarea eroare: 01130 - Functii ABS. | 008 - semnal neplauzibil. Ma poate ajuta cineva cu un sfat?
Modificat de petraru_iulian
Buna seara, am mai postat si in alt topic dar se pare ca am ales locul gresit, vin inaintea voastra cu o problema cumva ciudata, eu detin un vw Touran 2008 BXE 1.9l care firesc e echipat cu suspensii standard insa la scanare pe adresa 03 ABS Frane imi da eroarea 01310 - Modul comandã pentru nivel vehicul -J197-  004 - lipsã semnal/nu comunicã. Stiu ca nu am acest modul pe masina dar nu stiu cum sa ma scap de el ca sa nu imi mai apara eroarea. Nu am acces la optiunea cu long coding sa vad daca am modulul bifat acolo si simt ca m-am lovit de o fundatura. Daca ajuta la ceva, banuiesc ca problema se trage de cand am incercat un cluster maxidot si i-am dat si cateva chei masinii. De atunci nu mai am nici control on/off la butonul ESP. Atasez si un scan VCDS in speranta ca va ajuta sa trageti o concluzie si va rog pe cei experimentati sau care ati intampinat aceeasi problema sa ma ajutati cu rezolvarea. Masina functioneaza normal dar ma zgarie pe creier eroarea. Multumesc anticipat pentru orice act de bunavointa.
Log-WVGZZZ1TZ8W006419-256290km.txt
Modificat de ionutz2008
Salut ionutz2008, la tine e vorba de o codare incorecta a gatewayului, poti sa revii la codarile initiale daca accesezi Debug din fisierul tau unde ai instalat VCDS-ul. Despre martori aprinsi trebuie sa faci setarile de baza pentru senzori pe adresa 03.
@petraru_iulian in cazul tau verifica cablajul care pleaca din unitatea abs, iar daca nu gaseti nimic, unitatea ABS de inlocuit.
Modificat de Torque
Ionut nu are de ce sa faca setarea de baza la senzorii aferenti modulului ABS ...ci doar sa.rezolve problemele de codare.
I-am sugerat sa faca setari de baza numai daca are martori de ABS si ESP aprinsi, am tras singur concluzia cand a zis ca a pus contactul cu alte ceasuri de bord.
Ionut, daca n-ai martori aprinsi in bord ABS/ESP e corect ce a zis Florin, nu e nevoie de setari de baza.
nu e vb de martori ci de erorile stocate. Ce are el pe abs,  nu necesita setare de baza senzori
Scuze de intarziere, am primit interdictie 4 zile pentru ca am incalcat regulamentul in ceea ce priveste postarea aceluiasi subiect in doua topic-uri diferite. Multumesc domnu' Florin de raspuns, cum ati spus si dv, si eu banuiesc ca e problema de codare la adresa 03, insa ori e ceva in neregula la VCDS-ul meu ori eu nu stiu sa-l folosesc pentru ca am acces doar la coding-ul ala din 7 cifre iar codul 0021190 corespunde caracteristicilor masinii mele. Acum intreb, adresa 03 ABS nu are si long coding, si daca da, trebuie vreun cod de securitate ca sa faca optiunea accesibila ? Nu am experienta in domeniu dar ma gandesc ca daca eu nu am acel modul J197 pe masina insa el figureaza in software inseamna ca a fost cumva activat ceea ce inseamna ca se poate si dezactiva ca sa nu ma mai bantuie, dar nu stiu daca e doar lipsa mea de experienta sau nu ma ajuta nici VCDS-ul. Daca imi scapa ceva varog sa ma ajutati cu ce stiti.
@Torque, multumesc pentru implicare, nu am martori aprinsi in bord pt ca am facut setarile de baza la senzori, masina se comporta normal doar ca acum nu mai pot comuta ESP OFF din buton si banuiesc ca coding-ul ar rezolva-o. Nu ma ajuta nimic din Debug pentru ca la momentul in care am comis-o cu clusterul nu aveam VCDS-ul deci nu am ce recupera. In ce priveste eroarea de pe GATEWAY, cred ca e din cauza sistemului cu navigatie aftermarket, banuiesc ca toti care isi pun chinezarii pe masina se lovesc de incompatibilitate cu canbus-ul.
Cu respect.
