Inlocuire volan standard cu volan Passat CC
Ace83
Postez in numele unui prieten cu un passat cc din 2009 cumparat acum 3 zile.Pe masina are volan cu comenzi dar nu merg.SS-wvwzzz3cz9e561854 Va rog sa imi spuneti daca masina a avut acest volan din fabrica si daca da cam care ar fi cauzele.La scanarea cu VAG COM nu a avut nici o eroare.
da-mi un auto scan, sa vad ce are acum pe masina.... nu are imp ce a fost de fabrica - poate s-a facut retrofit la volan multifunctional.
Chassis Type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 72
VIN: WVWZZZ3CZ9E561854
01-Engine -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QC    HW: 03L 907 309
   Component: R4 2,0L EDC 0000SG  6208
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 18688 807 673512
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes        Labels: 3C0-614-109-C4.lbl
   Part No SW: 3C0 614 109 T    HW: 3C0 614 109 T
   Component: J104    C4 440 V2   0013
   Revision: --025---    Serial number: 00000785769766
   Coding: 0002322
   Shop #: WSC 05311 000 00000
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 AJ    HW: 5K0 907 044 AJ
   Component: Climatronic   130 0305
   Revision: 00002001
   Coding: 0000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_Climatronic_VW46.rod
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
   Component: Bordnetz-SG     H54 2602
   Revision: 00H54000    Serial number: 00000009431569
   Coding: E3E20F8B00041A3247978F0017000000000BFB4764400165170000000000
   Shop #: WSC 05124 123 12345
   Part No: 3C8 955 119
   Component: Wischer 270109 022  0602
   Coding: 00046997
   Shop #: WSC 05124
   Part No: 1K0 955 559 AH
   Component: RLS     240309 054  0402
   Coding: 00209133
   Shop #: WSC 05124
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 H    HW: 5N0 959 655 H
   Component: J234__30A VW10 HI   1916
   Revision: 20013000    Serial number: 003E1P4V48LP
   Coding: 0012353
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 AT    HW: 3C0 953 549 AT
   Component: J0527               0030
   Revision: 00034000    Serial number: 3C5953507CE
   Coding: 0000003
   Shop #: WSC 05314 000 00000
01044 - Control Module Incorrectly Coded
            000 -  -  - Intermittent
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 870 C    HW: 3C8 920 870 C
   Component: KOMBI         H05 0110
   Serial number: 00000000000000
   Coding: 140D00
   Shop #: WSC 05314 115 12345
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
   ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
Address 19: CAN Gateway        Labels: 3C0-907-530.lbl
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P09318059B
   Coding: F9817F06000202009002
Address 25: Immobilizer        Labels: 3C0-959-433-25.lbl
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 20526 124 87164
   Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1T0 959 701 L    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1533
   Revision: 71009005    Serial number: 00000776098119
   Coding: 0004279
Address 44: Steering Assist        Labels: 5Nx-909-144.lbl
   Part No SW: 5N1 909 144 J    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.075 0503
   Revision: 1AH02250    Serial number: 00090200136402
   Coding: 0000258
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 00910A0001860E763604941570084F0B607C01
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1T0 959 702 L    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1533
   Revision: 71009005    Serial number: 00000516498204
   Coding: 0004278
Address 53: Parking Brake        Labels: 5N0-907-801.lbl
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 B
   Component: J540 EPB3  VW-10498 0003
   Revision:   010       Serial number: 00000000031915
   Coding: 0000056
Address 55: Xenon Range        Labels: 5M0-907-357-A.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 3491016
   Part No: 1K0 941 329
   Component: AFS-Lst.-Modul l    0003
   Coding: 00000053
   Component: AFS-Lst.-Modul r    0003
   Coding: 00000053
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3I4229335
   Coding: 0500040004
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
   Part No SW: 3C8 959 703 B    HW: 1K0 959 795 Q
   Component: J388   TUER-SG HL   0309
   Revision: 43004101    Serial number: 00000000842841
   Coding: 0000144
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 3C8 959 704 B    HW: 1K0 959 794 Q
   Component: J388   TUER-SG HR   0309
   Revision: 43004101    Serial number: 00000000827471
   Coding: 0000144
End   ---------------------------------------------------------------------
Calculatorul de coloana volan - Nu suporta volan multifunctional - cu comenzi adica..... volanul este pus de forma.
Vrea sa ii mearga comenzile ? atunci trebuie alt calculator de coloana - un Highline - 3C0 953 549 AJ sau 3C0 953 549 AH (al lui este midline) plus cablajul din volan - daca nu are acum cablajul pt comenzi.
o intrebare , am cumparat un volan de passat cc cu cod 3C8 419 091 BF , ce cod de cablaj trebuie pt acest tip de volan ? cel 1K0 971 584 C nu se potriveste , oare 3C8 971 584 F este bun ?
post-74460-0-09968200-1380654960_thumb.j
Modificat de atti206
Cel cu 1K0....C era la tine pe masina ?
Si nu merge pe airbagul nou ?
Si eu vreu sa-mi shimb volanul si atunci sa stiu ce cablaj imi trbe si mie.
Oare cum pot vedea ce cablaj am, fara sa desfac volanul !?
atti206, ala cu F in coada e bun pentru volanul tau
salut tu ai cablaj 1K0....C , cred ca poti folosi cablajul actual cu volanul di poza 1 , si pt volanul din poza 2 cum am eu trebuie alt cablaj
post-74460-0-99128900-1380657359_thumb.j
post-74460-0-70272700-1380657387_thumb.j
Am inteles.
Merge cablajul la volanul care are calculatorul de butoane separat, si nu merge pe cel ce are calculatorul intr-unul din butoane !
Sa traiti.
Ms.
ok ,cu cablajul am lamurit oare un cod de airbag stie cineva la cod volan 3C8 419 091 BF? , codul acesta 3C8 880 201 T/J/K in coada e ok?
intrebare airbag de T5 se potriveste pe volanul de B7/CC? cod airbag : 7E0 880 201 G
Etka il da doar la Transporter/campobil.
un coleg de pe forum imi poate spune la cati Nm se strange piulita din mijlocul volanului  ? multumesc
Salut. atasez un log dupa schimbarea calc volan pentru activare volan multifunctional.
Comenzile merg ok , toate, dar au aparut o gramada de erori, care nu se sterg si senzorul G85 nu se aceseaza/calibreaza in nici un fel.
Un sfat va rog. Multumesc anticipat
Log-VALIULTIMA-WVWZZZ3CZAP059004.txt
Incearca cu o interfata originala. Verifica pinii de la calc de coloana, sa fie ok.
daca tot nu iese, ai o problema de compatibilitate....
Ce calc ai avut inainte ?
Salut.  Chin mare cu volanul multifunctional.
Am asa : passat b6 an 2010 - WVWZZZ3CZAP059004
DSG, pilot automat, computer bord, display multifunctional, RNS 510
calc coloana volan  5K0 953 569 R( apare ca si Higline dar nu merge codat volanul)
volan 3C8 419 891 BE E74
comenzi volan  3C8 959 537 D si 3C8 959 538 G
airbag  3C8 880 201 J
cablu   3C8 971 584 F
Am schimbat calculatorul coloana volan cu unul cu codul 5K0 953 569 E ( merg toate comenzile de pe volan , dar  acesta nu are senzorul G85 inclus in el) apar erori leg de acesta .
Poate cineva sa ma ajute cu un cod de calc coloana volan compatibil ?
Multumesc anticipat.
Modificat de 15WMW
cablu   3C8 971 584 F
3C0 953 549 AJ sau 3C0 953 549 AH ,  tu cred ca ia calc coloana volan de golf
ps. daca citeai pe aceaste pagina cu cateva posturi mai sus aflai raspunsul,
atti, are generatia noua de calculator, pe spira volan. Eu zic ca nu sunt compatibile cele doua calculatoare
15WMW - tu ai calculatorul de coloana volan in manete, adica este in grupul manete+spira+calculator volan.
Tie iti trebuie: 3C9 953 501 BN
Merg si codurile zise de Atti, dar pentru cei care au calculatorul de coloana, mai jos de manete, sub coloana, asa am si eu.
Incepand cu Passat B6 2010, s-a folosit "calculator coloana + manete + inel + volan + airbag" generatie noua, ce urma a fi pus pe Passat b7.
Si ai mai multe repere pe masina care sunt de passat b7.
Am un Passat CC din 2009 la care i-am montat comenzi pe volan. I-am cumparat volan cu comenzi tot de Passat CC, i-am schimbat cablajul din volan care mai are o conexiune in plus fata de cel vechi, i-am schimbat modulul coloana directie (am pus de highline), am facut codarea corespunzatoare pe Steering wheel si nu functioneaza comenzile pe volan, mai nou nici claxonul. Am urmatorul cod de defect pe calc coloana volan:
Saturday,02,November,2013,11:22:49:37412
VCDS Version: Release 11.11.0
Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
Control Module Part Number: 3C0 953 549 AE HW: 3C0 953 549 AE
Component and/or Version: J0527 0020
Software Coding: 0000303
Work Shop Code: WSC 80093 222 69422
VCID: 6FE7A2187E86136
01426 - Controls in Steering Wheel (E221)
004 - No Signal/Communication
Modul de control al butoanelor de pe volan se afla chiar in butoane sau e integrat in calc de coloana?
Am pus un volan cu comenzi de Golf V (are modulu integrat in volan) si cu acestea functioneaza. Nu stiu unde sa mai caut. Mai trebuie facuta vreo codare si in alta parte?
In attachement este un Auto Scan complet al masinii
New Text Document.txt
Pai dupa codul 3C9 953 501 BN imi gaseste ansamblu de manete , nu cred ca este cea ce trebuie.
Stiti cumva daca calc coloana volan 5K0 953 569 H are senz g 85 inclus in el si daca se potriveste.
Ce ar trebui sa caut : calc lin 1.3 sau lin 2 . Multumesc
