alinica2001
esti la limita sa iei limp, dc inca nu il ai o sa fie destul de curand
LOG 003-010-011 alexaandru15
Parerea mea e ca la tine sunt probleme de geometrie imbacsita sau deteriorata (blocata), s-au in cazul mai usor actuator cu probleme, dar poate isi mai dau cu parerea si alti colegi mai priceputi.
Modificat de deztgmures
Salut, am si eu o problema cu un passat b5.5 1.9 tdi 101cp, masina nu mai trage. Am facut un Log, sper sa ma lamuriti, tuurbina a fost schimbata noua, nu are 40 km si a mers perfect.Multumesc
Imi cer scuze ca l am postat astfel insa nu am reusit sa atasez documentul.
Friday,23,November,2012,17:24:39:10074,VCDS Version: Beta 11.2.0,Data version: 20110305
038 906 019 EM,,1.9l R4 EDC 0000SG 1368,
Marker,Group A:, Not Running,,,,Group B:,'010,,,,Group C:,'011
,,,,,,,MAF,Atmos. pressure,Intake air press.,Throttle,,Engine speed,Spec. intake press.,Actual intake press.,D.cycle MAP
,TIME,,,,,TIME,800-1100,sensor -f96-,1900-2150,100%,TIME,2850-3150,1900-2150,1900-2150,55-75%
Marker,STAMP,,,,,STAMP, mg/str, mbar, mbar, %,STAMP, /min, mbar, mbar, %
,,,,,,0.34,534.1,999.6,989.4,100.0,0.00,1281,999.6,989.4,49.8
,,,,,,1.03,543.9,999.6,1040.4,100.0,0.66,1323,1642.2,1009.8,20.3
,,,,,,1.69,568.4,999.6,1071.0,100.0,1.36,1428,1703.4,1050.6,19.9
,,,,,,2.36,573.3,999.6,1091.4,100.0,2.04,1491,1744.2,1091.4,19.9
,,,,,,3.05,578.2,999.6,1122.0,100.0,2.71,1617,1785.0,1111.8,19.9
,,,,,,3.73,592.9,999.6,1152.6,100.0,3.38,1701,1825.8,1142.4,19.9
,,,,,,4.42,592.9,999.6,1183.2,100.0,4.06,1806,1876.8,1162.8,20.7
,,,,,,5.10,617.4,999.6,1224.0,100.0,4.77,1911,1938.0,1203.6,19.9
,,,,,,5.80,637.0,999.6,1275.0,100.0,5.46,2016,1948.2,1244.4,20.7
,,,,,,6.50,661.5,999.6,1336.2,100.0,6.16,2142,1948.2,1305.6,25.9
,,,,,,7.19,686.0,999.6,1397.4,100.0,6.82,2268,1948.2,1366.8,27.9
,,,,,,7.87,720.3,999.6,1479.0,100.0,7.52,2394,1948.2,1428.0,30.3
,,,,,,8.56,769.3,999.6,1581.0,100.0,8.23,2541,1948.2,1519.8,32.7
,,,,,,9.25,788.9,999.6,1652.4,100.0,8.90,2709,1948.2,1621.8,36.7
,,,,,,9.91,788.9,999.6,1693.2,100.0,9.56,2835,1948.2,1683.0,37.5
,,,,,,10.58,784.0,999.6,1723.8,100.0,10.24,3003,1948.2,1723.8,37.5
,,,,,,11.26,798.7,999.6,1764.6,100.0,10.93,3150,1948.2,1744.2,37.5
,,,,,,11.96,793.8,999.6,1805.4,100.0,11.63,3297,1948.2,1795.2,36.3
,,,,,,12.66,788.9,999.6,1815.6,100.0,12.29,3444,1948.2,1815.6,35.1
,,,,,,13.33,788.9,999.6,1836.0,100.0,12.98,3570,1948.2,1825.8,33.9
,,,,,,13.98,784.0,999.6,1866.6,100.0,13.66,3696,1948.2,1846.2,32.3
,,,,,,14.66,779.1,999.6,1887.0,100.0,14.34,3822,1948.2,1876.8,31.5
,,,,,,15.36,774.2,999.6,1897.2,100.0,15.00,3927,1948.2,1887.0,31.9
,,,,,,16.05,769.3,999.6,1917.6,100.0,15.68,4053,1938.0,1907.4,35.5
,,,,,,16.72,754.6,999.6,1948.2,100.0,16.38,4179,1917.6,1927.8,38.3
,,,,,,17.38,744.8,999.6,1948.2,100.0,17.06,4263,1907.4,1948.2,39.8
,,,,,,18.06,715.4,999.6,1917.6,100.0,17.73,4368,1866.6,1938.0,41.8
,,,,,,43.91,504.7,999.6,999.6,0.0,44.26,1638,999.6,999.6,52.6
,,,,,,44.60,499.8,999.6,999.6,0.0,44.94,1596,999.6,999.6,52.6
,,,,,,45.30,499.8,999.6,999.6,0.0,45.63,1575,999.6,999.6,52.2
,,,,,,45.97,504.7,999.6,999.6,0.0,46.34,1554,999.6,989.4,52.2
,,,,,,46.66,499.8,999.6,989.4,8.6,47.02,1533,999.6,989.4,51.8
,,,,,,47.35,514.5,999.6,999.6,13.3,47.69,1512,1009.8,989.4,51.8
,,,,,,48.05,519.4,999.6,989.4,14.5,48.37,1491,1009.8,999.6,51.4
,,,,,,48.72,499.8,999.6,989.4,14.5,49.05,1470,1009.8,989.4,50.6
La tine nu este presiune sufucienta. Poate la montaj nu s-a pus bine vreun furtun la turbo sau ai probleme cu vacuum, N75 sau actuator.
...asa cred si eu ca am probleme cu geometria dar poate isi mai da cu parerea cativa colegi poate imi zic ce si cum :)
La mine LIMP-ul se manifesta numai pe treapta 4-5-6 adica la a 4 imi ia limp 3600 rpm ;la a 5 imi ia la 3300 rpm; iar a 6 la 2950 rpm
Modificat de alexaandru15
Ce spuneti? Tot normal?
Nimeni? :)
Modificat de Alungatu
Ma poate ajuta cinva cu erorile acestea?
Cele de pe Usi reapar imediat dupa o inchidere/deschidere din telecomanda. Mentionez ca toate functioneaza bine.
Thursday,06,December,2012,17:50:17:32264
VCDS Version: Release 11.11.3
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Control Module Part Number: 1K0 959 702 P HW: 1K0 959 792 L
Component and/or Version: J387 TUER-SG BT 1131
Software Coding: 0000180
Work Shop Code: WSC 05311 000 00000
VCID: 3C7D2A297F70869
2 Faults Found:
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 39
Reset counter: 172
Mileage: 169377 km
Time Indication: 0
Date: 2012.11.29
Time: 17:21:24
00106 - Signal Central Locking SAVE/LOCK Passenger Side
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 254
Reset counter: 212
Mileage: 169576 km
Time Indication: 0
Date: 2012.12.04
Time: 08:44:39
Thursday,06,December,2012,17:51:23:32264
Address 77: Telephone Labels: 3C0-035-729.lbl
Control Module Part Number: 3C0 035 729 G HW: 3C0 035 729 G
Component and/or Version: Telefon 7609
Software Coding: 0016041
VCID: 2757E54596F6351
00992 - Consumption Cut-Off Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 2
Reset counter: 198
Mileage: 169377 km
Time Indication: 0
Date: 2012.11.29
Time: 17:32:02
Salut ,am un passat 1,8 T benzina si la rece cand accelerez mai tare motorul nu se tureaza liniear ,ezita ,numai dupa ce se incalzeste functioneaza normal masina cu lipsa un pic de putere , porneste foarte usor la prima cheie,am curatat clapeta de acceleratie (era curata de fap)si partea electrica de la ea,filtrul de aer era curat , la diagnoza nu am avut nici o eroare,si face aceleasi probleme am scos furtunul de aer care intra clapeta si motorul merge super ,putere ,acceleratie , tot .Nu cunosc traseul aerului pana la clapeta si ce implica acest lucru. mentionez ca masina are 285.000km si pierde putin ulei Va rog reply
Am o Skoda Octavia Tour Sport, remapata la TCM, cu aprox 150.000 km si preventiv inainte de iarna (masina merge perfect, insa din cand in cand, ii mai fac cate un test) i-am facut un log in mers cu full throttle, rezultand datele din fisierul atasat. Persoana care m-a ajutat cu programul pt log mi-a spus ca in afara de debitmetru, care are valori prea mari, toate sunt ok, cu ocazia asta facandu-i si o diagnoza la relanti, unde injectoarele au iesit perfect. V-as ruga sa-mi spuneti daca valorile respective pot indica o problema care necesita inlocuirea sau schimbarea debitmetrului (eventual si/sau a altor piese) sau se poate sa fie asa datorita remaparii. Multumesc,
PS: daca n-am postat unde trebuie, rog un moderator sa mute postul in topicul potrivit. Multumesc
Modificat de Flaviu
probabil datorita editarii ulterioare nu a ramas sus. sper ca acum s-a pastrat. multumesc
le: vad ca nu reusesc sa atasez fisiere. trebuie facut ceva "magic" cu interfata asta noua?
le2:am reusit in final- se pare ca nu se pot atasa fisierele .csv
LOG-01-003-010-011-oktavia 1.xls
Modificat de Flaviu
arata foarte bine logul, nu sunt probleme de nici un fel
Buna
Am facut doua loguri pentru un VW Touran. Problema este lipsa de putere la schimbarea vitezelor 4-5 sau 5-6 si din cate imi dau seama nu se mai aude turbina la accelerat brusc.
Puteti sa ma ajutati cu interpretarea?
http://limelinx.com/4pfc
http://limelinx.com/bp404
Razvan
Salut Razvan, sa stii ca nu am putut descarca log-urile tale prin link-urile pe care le-ai atasat.
Am facut un log, ce concluzii se pot trage?
Masina in principiu merge bine, am ajuns si la 200 km/h, doar ca uneori are mici ezitari in sarcina si mici neregularitati la relanti.
turbo passat BMP.xls
Multumesc pt raspuns, nu m am exprimat corect turbina a a fost schimbata cu una noua si a mers perfect 40 000 de km nu 40. O sa fac o inspectie la furtune, daca imi puteti spune cum se verifica si vacumul ar fi perfect. Multumesc inca o data.
EsTeTicu- din log rezulta ca: turbo, egr, maf, sunt in parametrii normali.
deztgmures imi poti spune si mie te rog unde ai vzt la logul meu ca ar fi turbina sau actuator blocat...adica sa stiu sa-mi dau si eu seama in logurile urmatoare...multumesc
Buna
Oare poare cineva sa ma ajute cu o interpretare a logurilor? Problema este lipsa de putere in momentul in care trec din viteza 4-5 sau 5-6. Motorul pare subturat desi pe bord turatiile se mentin. Schimb viteza la 3000 de ture (VW Touran 2.0 TDi).
Razvan
LOG-02-003-010-011.pdf
LOG-01-003-010-011.pdf
Logurile par chiar f ok...Mai asteapta si alte parerei, insa nu cred ca ai vreo problema
  • Marian featured this topic
    • Fiulian
