suzu
Multumesc de explicatii lupo_bv , stii cumva se poate face ceva pt misfire sa nu mai declanseze limp mode?
Am si eu o rugaminte la voi si anume sa ma ajutati cu interpretarea a doua erori! Am pe 14 Identificare la RAR(pentru inmatriculare) si nu as vrea sa ma duc si sa-mi zica sa revin! Erorile sunt:
 "Friday,10,July,2015,10:07:14:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Mileage: 108350km-67325mi   Repair Order:
Readiness Status: 0000 1001
Exhaust Gas Recirculation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s): Passed
Air Conditioning: Passed
Seconday Air Injection: Failed or Incomplete
Evaporative Emissions: Passed
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
Si codurile:
VIN: WVWZZZ3BZ1P283273   Mileage: 108350km/67325miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 3B0 906 018 F
   Component: 1,6l/2V SIMOS3  00HS0002
   Coding: 06021
   Shop #: WSC 00028
   VCID: 23450907B1202306A91-5000
   WVWZZZ3BZ1P283273     VWZ7Z0A3588299
2 Faults Found:
17811 - EGR System
            P1403 - 35-10 - Regulation Deviation - Intermittent
16804 - Catalyst System; Bank 1
            P0420 - 35-00 - Efficiency Below Threshold
Readiness: 0000 1001
Orice sfat este binevenit! Multumesc anticipat!
Ceva sugestii ptr martor airbag aprins?
                Address 15: Airbags       Labels: 1K0-909-605.lbl
Control Module Part Number: 1K0 909 605 A    HW: 1K0 909 605 A
  Component and/or Version: 0L AIRBAG VW8   022 0500
           Software Coding: 0012364
            Work Shop Code: WSC 01371 785 00200
                      VCID: 2A51730CFE3F
2 Faults Found:
00532 - Supply Voltage B+
        002 - Lower Limit Exceeded - Intermittent - MIL ON
01217 - Side Airbag Igniter; Driver Side (N199)
        001 - Upper Limit Exceeded - Intermittent - MIL ON
Sterge-le si vezi daca mai apar.
Modificat de spido
Dupa o perioada de condus reapare doar codul asta............am pus amnadoua codurile in ideea ca poate sunt legate erorile.
Modificat de karlosss
Desfa airbag sofer,verifica mufele,curata-le cu un spray de contacte.Ar trebui sa fie totul ok dupa.Nu uita sa stergi din nou eroarea dupa interventie.
e vb de airbag din scaun , nu din volan, nu?
Da,airbag scaun sofer.Verifica mufe/conectori si da-le un spray contacte.
Buna seara.
Am scanat azi masina, dupa ce imi aparuse cheek-ul, si am urmatoarele erori:
-P0480
Cooling fan 1 control circuit
-P2211
NOx sensor heater sensor circuit hight input bank1
Masina este golf 5 1.6 FSI, 6 trepte, 2004
Am vreo sansa ca a2a eroare sa NU fie sensoru de noxe?
Multumesc anticipat.
NU.
este clar de la senzorul NOX>
Stie cineva cum as putea anula limp mode-ul?
Remedind pb care l-au generat-vacum / geometrie variabila etc
vezi ca e benzina motorul lui... nu prea are componentele enumerate  :icon_thumleft:
Multumeasc @Al Bundy !
Prima eroare ce poate sa fie?:(
Pot sa anulez sonda a2a lambda pentru a nu imi mai aparea in bord eroarea de la senzorul NOX?din ce am citit pe unele forumuri ar fi o idee si asta..., nu as vrea sa il schimb acum pentru ca este destul de scump si nu am banii acum....si ma sacaie beculetul ala aprins...:p
Siguranta arsa sau motor ventilator defect.
Aseara m-a sunat un prieten cu o skoda roomster - nu mai porneste. Am ajuns azi pe la el si intradevar nici macar nu mai invarte motorul. La punerea contactului se aprind becurile in bord, dar cand dau la demaror, moare tot. I-am facut o scanare :
Monday,20,July,2015,18:15:19:58836
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: TMBMC25J775058691 License Plate:
Mileage: 67080km-41681mi Repair Order: bc30mai
Chassis Type: 5J (5J - Skoda Roomster (2006 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBMC25J775058691 Mileage: 67080km-41681miles
Address 01: Engine Labels: 03C-906-024-BXW.lbl
Part No SW: 03C 906 024 R HW: 03C 906 024 F
Component: MARELLI 4HV 0894
Revision: --H05--- Serial number: SKZ7Z0G4213785
Coding: 0000071
Shop #: WSC 73430 790 00000
VCID: 2D5B6241B7F4EA49F4D-5178
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 6R0-907-37x-ASR80.lbl
Part No SW: 6R0 907 379 D HW: 6R0 907 379 D
Component: MABS 8.0 front H05 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0002067
VCID: 3F8728096D9868D9561-515A
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 5J0 907 044 A
Component: CLIMAtronic SK25 0608
Shop #: WSC 00000 000 00000
VCID: 285593559816CF6107B-515A
00576 - Terminal 15
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q2 937 049 F
Component: 0000 BN-SG. 2S36
Coding: 17422
Shop #: WSC 00000
VCID: 3F8728093D9868D9561-513C
2 Faults Found:
01598 - Drive Battery Voltage
27-00 - Implausible Signal
07-00 - Signal too Low
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: QE AIRBAG VW51 Q1 0010
Coding: 20805
Shop #: WSC 73430
VCID: 2C5D6F45DCEEE341E33-513C
2 Faults Found:
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
32-10 - Resistance Too High - Intermittent
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 5J0-920-xxx-17.clb
Part No: 5J0 920 810 B
Component: KOMBIINSTR. V2823466
Coding: 17101
Shop #: WSC 73430
VCID: 254B9A61BF04D2093CD-513C
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 0007 GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 73430
VCID: 70E5BB353046C7A19FB-513C
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER V2823466
Coding: 17101
Shop #: WSC 73430
VCID: 254B9A61BF04D2093CD-515A
TMBMC25J775058691 SKZ7Z0G4213785
Address 44: Steering Assist Labels: 6Q0-423-156.clb
Part No: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10140
Shop #: WSC 73430
VCID: 6FE7B8492D78D859861-515A
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 5J0 959 433 A
Component: 05 Komfortgerát 0001
Coding: 00019
Shop #: WSC 00000
VCID: 31637E31FBCC8EA9D05-4B18
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No SW: 5J0 035 161 HW: 5J0 035 161
Component: Radio FO3 010 0024
Revision: 00010000 Serial number: SKZ7Z3G0045718
Coding: 0000200
VCID: 5FC7C8898DD848D9361-513C
No Faults Found
or DTCs not supported by controller
or a communication error occurred
End-------------------------(Elapsed Time: 04:00)--------------------------
Dupa banuiala mea ar fi bateria de vina, dar nu sunt sigur. E posibil sa fie si altceva? Am incercat sa o pornim cu cabluri de curent de la masina mea dar nu am reusit, cablurile cam prapadite, dar dadea semne de viata motorul in sensul ca invartea dar foarte putin. Ne-am uitat pe la sigurantele de pe baterie, toate bune, am scos bornele la baterie si le-am curatat, dar tot degeaba. Deci, e bateria sau altceva?
Schimba-i bateria dupa care va porni.Sterge erorile dupa.
Mersi mult, o sa vedem maine.
salutam cu respect,
am nevoie de ajutorul vostru...
Tuesday,21,July,2015,16:49:56:40973
Chassis Type: 9N (9N - VW Polo (2002 > 2010))
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ6D038013   Mileage: 82220km/51089miles
   Part No: 03C 906 013 B
   Component: MED7.5.11           4884
   Coding: 00071
   Shop #: WSC 10103
   VCID: 1B3531EE8905CDC6611-5198
   WVWZZZ9NZ6D038013     VWZ7Z0E2410877
7 Faults Found:
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 35-00 -
16686 - Cylinder 2
            P0302 - 35-00 - Misfire Detected
16685 - Cylinder 1
            P0301 - 35-00 - Misfire Detected
18322 - Pressure Sensor for Brake Boost (G294)
            P1914 - 35-10 - Implausible Signal - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
            P0106 - 35-10 - Implausible Signal - Intermittent
16687 - Cylinder 3
            P0303 - 35-00 - Misfire Detected
16688 - Cylinder 4
            P0304 - 35-00 - Misfire Detected
   Part No: 6Q1 937 049 D
   Component: 00AF BN-SG.         1S34
   Coding: 25758
   Shop #: WSC 31414
   VCID: 3C77D2722CCBAAFE88B-5198
   Part No SW: 6Q0 035 152     HW: 6Q0 035 152
   Component: Radio BVX       005 0010
   Revision: 00005000    Serial number: VWZ1Z5E4637351
   Coding: 0020200
   Shop #: WSC 31414 790 00001
   VCID: E7DDDD1ED5CD5926B59-517A
00856 - Radio Antenna
            011 - Open Circuit
End   ---------------------------------------------------------------------
Si care ar fi cerinta de ajutor ?
Sterge-le si vedem care reapar.
erorile pe cei 4 cilindri pot fi cauzate de aceasta eroare ?
schimba senzorul - asta daca nu este sparta coroana... sa speram ca nu.
Salutare, am schimbat senzorul de pe cutie si....degeaba, cum am turat-o peste 3000 rot., s-au aprins iar martorii ABS si ESP,in bord.Maine ma duc sa verific cablajul iar daca nu rezolv nimic, cred ca trebuie sa dau jos cutia.. :(  si cine stie ce costuri ma mai asteapta......
Vorbim de senzorul de viteza ? la modelul tau, nu trebuie sa dai jos cutia - are capac la planetara stanga pe unde poti accesa/schimba coroana.
Da este vorba despre senzorul de viteza vehicul, de pe cutie.Am lasat masina pe mana unui electrician auto, pentru ca s-ar putea sa fie ceva electric: cu motorul oprit, valoarea aratata de senzorul de viteza este 0Km/h iar daca pornesti motorul, arata 7km/h, chiar daca mergi cu masina, arata tot 7km/h.Senzorul este nou, cablajul arata ok, nu stiu ce poate fi........
  • Aerofan pinned this topic
