suzu
valeeeeu....:(
Scoate mufa la egr si vezi daca mai face.
treabuie sa fac o scanarare la foaia pe care mi-au dat-o baietii unde am pus pe tester  . problema e in felul urmator , azi am fost la un baiat foarte bun si a verificat masina de la inceput . bujii, fise , bobina , clapeta , pompa benzina , filtre etc . nimic pana cand a decis sa faca un test de compresie  pe fiecare cilindru in parte .
cilindru 1 - 14 bari
cilindru 2 - 15 bari
cilindru 3 -  9 bari
cilindru 4 - 16 bari
deci problema e de la cilindru 3 . urmeaza sa dea chiulasa jos si sa vada valvele poate nu se inchid corect .
   Sunday,24,March,2013,14:50:41:37412
VCDS Version: Release 11.11.0
Data version: 20111111
am facut scanarea asta dupe ce mi sa curatat clapeta ,la senzorul g71 i sa dat cu spray wd-40,si bobina 2 a fost pusa la 3 iar la 2 una noua
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ3D147046   Mileage: 130650km/81182miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 03E 906 033 L
   Component: 1.2l/4V SIMOS3  00HS4726
   Coding: 00071
   Shop #: WSC 31414
   VCID: 29538C00D3E23D6
   WVWZZZ9NZ3D147046     VWZ7Z0C6669097
7 Faults Found:
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
            P0106 - 35-10 - Implausible Signal - Intermittent
16555 - Fuel Trim; Bank 1
            P0171 - 35-10 - System Too Lean - Intermittent
16687 - Cylinder 3
            P0303 - 35-10 - Misfire Detected - Intermittent
16686 - Cylinder 2
            P0302 - 35-10 - Misfire Detected - Intermittent
16891 - Idle Control System RPM
            P0507 - 35-10 - Higher than Expected. - Intermittent
17658 - Fuel Level too Low
            P1250 - 35-00 -
Readiness: 0000 0000
Address 03: ABS Brakes        Labels: 6Q0-907-37x-ABS2.lbl
   Part No: 6Q0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0001097
   Shop #: WSC 31414 000 00000
   VCID: 468927BC32BCF2E
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC        Labels: None
   Part No: 6Q0 907 044
   Component: CLIMAtronic PQ24    0201
   Shop #: WSC 00000 000 00000
   VCID: EFE72218FD86936
3 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
            000 -  -  - Intermittent
01271 - Positioning Motor for Temperature Flap (V68)
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 C
   Component: 00 BN-SG.           1S33
   Coding: 25742
   Shop #: WSC 31414
   VCID: 3B7F4648297EBF6
2 Faults Found:
00906 - Horn (H1)
            28-10 - Short to Plus - Intermittent
01598 - Drive Battery Voltage
            07-10 - Signal too Low - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 K
   Component: 0M AIRBAG VW51 0P   0006
   Coding: 12365
   Shop #: WSC 31414
   VCID: 2C5D7514DC1028E
00532 - Supply Voltage B+
Address 17: Instruments        Labels: 6Q0-920-xxx-17.lbl
   Part No: 6Q0 920 800 P
   Component: KOMBI+WEGFAHRSP VDO V16
   Coding: 01131
   Shop #: WSC 00000
   VCID: 3A71434C264486E
No fault code found.
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 09 GATEWAY  CAN    1S33
   Coding: 00014
   Shop #: WSC 31414
   VCID: F0E52164B0B88CE
Address 44: Steering Assist        Labels: 6Q0-423-156.lbl
   Part No: 6Q0 423 156 R
   Component: LenkhilfeKYO        V913
   Coding: 10140
   Shop #: WSC 31414
   VCID: 3E794F5C3A6CAAE
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 6Q0 959 433 E
   Component: 3L Komfortgerát     0002
   Coding: 00259
   Shop #: WSC 31414
   VCID: 3D7B4850376AB16
   Subsystem 1 - Part No: 6Q2959802A
   Component: 3L Tõrsteuer.FS TFK 0004
   Subsystem 2 - Part No: 6Q2959801A
   Component: 3L Tõrsteuer.BF TFK 0004
   Subsystem 3 - Part No: 6Q0959811A
   Component: 3L Tõrsteuer.HL TFK 0004
   Subsystem 4 - Part No: 6Q0959812A
   Component: 3L Tõrsteuer.HR TFK 0004
End   ---------------------------------------------------------------------
daca ma puteti ajuta cu ceva sfaturi multumesc
Vad ca si pe 3 si pe 2 ai erori sterge si vezi ce mai apar.
Salutare. Am si eu o mica problema cu masina. Am un a6 din 1999, motor 1.9 tdi, Cod AFN,  Merge sa ma conectez si sa citesc erorile de pe orice, mai putin ENGINE. Imi da eroare ca nu ma pot conecta. Precizez ca e facut immo off direct pe ECU, si au fost schimbate ledurile din rosu in alb pe IC. Care ar putea fi problema de nu pot scana ENGINE? Astept pareri si idei care mi-ar fi de folos pt. rezolvare :(. Multumesc
Din nefericire nu mai imi merge mufa corespunzator si nu am reusit sa fac o scanare normala, ci numai ce se vede in poza.
Ma puteti ajuta cu descifrarea?
Va multumesc.
post-100209-0-11938200-1364902327_thumb.
Modificat de alecsutzyu
Activeaza si tu softul macar si fa o poza cum trebuie.
Salut baieti,
 am instalat recent un dispozitiv Xcarlink si am o eroare in radio care revine. Functional totul este ok dar nu stiu ce inseamna eroarea. Ma puteti ajuta?
Adresa 56: Radio Eticheta: fara
Numar VAG: 1K0 035 186 P
Componenta comandata: Radio BVX 017 0023
Codare: 0040400
Atelier: WSC 01279 785 00200
VCID: 336EF13F52A56E80EC5
1 cod a gasit
01044 - Modul de comanda: codare incorecta
000 - -
Ai codat si radio ca avand CD changer ?
ma poate ajuta cineva cu problema mai sus mentionata? Macar pareri.
Ti s-a mai raspuns: dupa ce ai facut IMMO of te-ai mai putut conecta?
4 Faults Found:
000568 - Manifold Pressure / Boost Sensor (G31): Signal too High
               P0238 - 000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 51698 km
                    Time Indication: 0
                    Date: 2099.14.29
                    Time: 18:17:31
             Freeze Frame:
                    RPM: 639 /min
                    Load: 16.1 %
                    Speed: 0.0 km/h
                    Temperature: 78.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.097 V
000152 - Intake Air Temperature Sensor 2 (G299): Signal too Low
               P0098 - 000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 51698 km
                    Time Indication: 0
                    Date: 2099.14.29
                    Time: 18:17:31
             Freeze Frame:
                    RPM: 639 /min
                    Load: 16.1 %
                    Speed: 0.0 km/h
                    Temperature: 78.0°C
                    Temperature: 42.0°C
                    Voltage: 14.097 V
000290 - Throttle Position Sensor (G69): Signal too Low
               P0122 - 000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 51698 km
                    Time Indication: 0
                    Date: 2099.14.29
                    Time: 18:18:46
             Freeze Frame:
                    RPM: 654 /min
                    Load: 23.1 %
                    Speed: 0.0 km/h
                    Temperature: 80.0°C
                    Temperature: 41.0°C
                    Voltage: 14.224 V
000546 - Angle Sensor 2 for Throttle (G188): Signal Too Low
               P0222 - 000 -  -  - Intermittent
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 1
                    Mileage: 51698 km
                    Time Indication: 0
                    Date: 2099.14.29
                    Time: 18:18:46
             Freeze Frame:
                    RPM: 654 /min
                    Load: 23.1 %
                    Speed: 0.0 km/h
                    Temperature: 80.0°C
                    Temperature: 41.0°C
                    Voltage: 14.224 V
nu, nu am facut asta. Fii bun si da-mi cateva sfaturi pe PM unde trebuie sa intru in VCDS si ce trebuie sa fac. Mersi
Intri pe radio si il codezi ca avand CD changer.
alecsutzyu
Daca steri erorile apar din nou?
Si masina merge ok ?
Acum merge bine masina, dar inainte sa apara erorile astea, pur si simplu nu mai vroia sa traga in a6a la 120km.
Imi cer scuze in prealabil daca am postat gresit, dar nu am gasit un loc mai sugestiv decat acesta, Rog un moderator sa mute postul daca este nevoie.
Am achizitionat un Vag Commander cu CAN, deoarece aveam nevoie de a afla PIN-ul cu care pot adapta cip-uri noi la imobilizatorul masinii.
Masina: audi a3 8p din 2004 2.0 BKD.
Dupa ce am scos pin-ul de acolo am intrat in meniul de adaptare chei si m-am jucat putin pe acolo. Pana acum toate bune pana cand pornesc motorul, de fiecare data primesc un mesaj:
care imi spune ca in timp ce masina stationeaza trebuie sa apas pedala de frana daca vreau sa schimb vitezele.
Acest mesaj ramane pentru 5-10 secunde dupa care dispare.
Poate cineva sa ma ajute sa scap de acest mesaj?
am o mare problema
dupa aproximativ 15km de mers (30minute) imi da eroare sonda lambda dinaninte de calatilzator 'Circuit Malfunction Intermittent"
iar dupa un timp isi revine si incepe din nou sa fluctueze tensiunea (masurat in vcds)
In momentul cand a aparut eroarea masina nu mai trage cum trebuie, tensiunea ramane la 0.45V iar STFT la 0% (in vcds)
ce sa fac?sa iau alta sonda?
Modificat de CrackerX
Parca ai mai avut erori pe sonda...
A venit primavara e timpul de o schimbare...
Asta daca nu mai ai si altele, gen egr clapeta....
CrakerX
Ai curatat contactele sondei cu spray contact? Poti masura si rezistenta sondei cum este expus pe forum.
Ca sa fii sigur 100% poti curata mufele si contactele de la ECU tot cu spray contact. Nu ai ce strica.
Daca o schimbi, ia neaparat una OEM.
le`am curatat pur si simplu nu este nici un fel de mizerie.
La ECU n`am curatat si nu cred ca are rost...cum masor rezistenta sondei?de fapt ce valoare trebuie sa aiba?
Parerea mea este ca pur si simplu se intrerupe contactul in sonda...
Ambele mufe arata exceptional, fara fire intrerupte..etc
care mesaj ?
  • Aerofan pinned this topic
