cascadoru
Am fost am verificat...
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_mapsOFF
ENG122230-ENG122343-Dashboard_Display_Configuration-call_pictureOn
ENG122230-ENG122341-Dashboard_Display_Configuration-coverartOn
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_modeRLE
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolutionresolution_1
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_modeOFF
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon0
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_mostOFF
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_modeH264
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolutionresolution_1
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_modeMOST_streaming
ENG122230-ENG122342-Dashboard_Display_Configuration-stationartOn
Nimic nou.
Cu ability_switch_nav_maps ON, am buton in navi dar nu merge. Iar pe Cluster vad compasul.
Cu ability_switch_nav_maps OFF dispare butonul, iar pe cluster am o "eroare" ca harta este activa pe Navi
Am atasat si cateva poze.
https://drive.google.com/file/d/1hx9b89OzgknER-Hthdrf5aWOgexZiT6v/view?usp=sharing
https://drive.google.com/file/d/1S0H-VD3tRbZpuCWubecXmsNMQXY5xYZu/view?usp=sharing
https://drive.google.com/file/d/1lD5KRBmCOg6jZxVL3UG_fXQFK1ze1ki0/view?usp=sharing
https://drive.google.com/file/d/18r6pq4ErnT-6fXMWVBYhmCXPccaze71D/view?usp=sharing
Modificat de dragosmp
salut, ma puteti ajuta si pe mine cu o informatie?
Am facut retrofit la AID pe un GTE si imi arata in loc de autonomia bateriei (coltul stanga jos langa power-metru :) ) - trip-ul. Nu imi dau seama ce am setat gresit (nu am setat) de nu imi afiseaza informatia. Thanks
@mottanu
Tine apasat butonul de reset lung, vor aparea mai multe optiuni, una dupa alta. Nu mai retin cred ca atunci cand apare range, eliberezi butonul. Scrie si in manual.
@dragosmp, poate mai ai nevoie de alte setari in headunit. Zi-mi ce ai nevoie si verific la mine.
Modificat de Manuel N.
Atentie la quote! Se sanctioneaza - citeste regulamentul. First/last warning!
"Tine apasat butonul de reset lung, vor aparea mai multe optiuni, una dupa alta. Nu mai retin cred ca atunci cand apare range, eliberezi butonul. Scrie si in manual.?"
reset la?
la Navi am dat reset când am scris opțiunile. la AID nu știu cum se da reset.
nu am manual și AID este pus de 3 zile.
Am urmat toți pașii găsiți pentru retrofit. problema e legata doar de harta, pictogramele in Audio și phone merg.
in cluster am setat Display_depict... Variant 2 și cam atât.
Pagina 37 din 626 in manualul meu.
sa nu fie vreo diferenta de software intre instrument cluster si navigatie. Nu stiu ce sa zic :|
@dragosmpcand am făcut eu retrofit am pățit la fel și am uitat o bifa de MOST parca pe 5F. De fapt nu era scris în tutoriale
@BTeopoti te rog sa ma ajuti cu un export de adaptation 5F si 17.
Initial si eu am avut problema cu MOST din 5F bit 19 si nu intelegeam de ce nu am semnal pe fibra.
Ulterior dupa ce am codat 5F bit 19 am reusit sa am Logo Radio, Cover ART si Calller etc.
17 are Setat Display Depiction si Version 2 si 3 ... face la fel
Doar harta nu merge. tu ai MIB2STD sau PRO ? Pentru ca nu gasesc exact daca Dashboard_Display_Configuration-ability_switch_nav_maps trebuie sa fie ON sau OFF. Nu merge oricum :)
@dragosmp
Eu am MIB2high si AID din fabrica, ai aici adaptarile din 17 si 5F, vezi daca reusesti sa gasesti unde e problema.
adpmap-17-3G0-920-791-B_WVWZZZ3CZHE059764-20191116-1627.CSV
adpmap-5F-3G0-035-043-D_WVWZZZ3CZHE059764-20191116-1638.CSV
@OviVal Mersi.
In 5F culmea il setasem prima data ca la tine. Dar fiind MIB2High cred ca eu am nevoie de ability to switch maps. Din ce am gasit pe net MIB2STD nu stie harta in ambele locuri.
Iar in 17 am 2 3 chestii in plus de la GTE.
In ultimul setup acum, am inconita sa mut Hartile dar nu e disponibila.
Restul pare totul activ.
tramite-mi longcodingurile de la tine
Am atasat.
Acum singuru care ramane in dubiu este "fastlist"...  Am setat zoom pe auto, am dat reset la navi si nimic.
Ramane sa mai testez dupa ce iau masina din service. In timp ce ma jucam cureaua de accesorii s-a facut bucati si de frica sa nu intre in distributie am bagat cutteru in ea :)
Maine o duc sa le schimb pe amandoua.
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps needed to be set to OFF for NavMaps to work in my AID.
That's because you have Discover Pro rather than Discover Media;
Discover Pro can display the map on both the infotainment display and the AID at the same time.
adpmap-17-3G0-920-794-D_WVWZZZ3CZHE056504-20210101-1455.CSV adpmap-5F-3Q0-035-874-B_WVWZZZ3CZHE056504-20210102-1225.CSV
@dragosmpnu le am salvate dar incearca si ce ti-ai mai propus , vezi si cu switch_maps si daca tot nu merge iti trimit si ce am eu (p.s. nu le am la dispozitie si trebuie sa le scanez cu urmatoarea ocazie)
Coding:
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 D
   Component: KOMBI         403 4191
   Coding: 07A509986E84000800897E271402000000000000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 043 D    HW: 5NA 035 043
   Component: MU-H-N-EU     H54 1367
   Serial number: A848D0KS073892
   Coding: 02840201FF0000005111000100080A001F0100E401200400DF
Uite ca am gasit si adaptarile:
adpmap-5F-5NA-035-043-D_WVWZZZ3CZFE517273-20200917-1429-2.CSV
Eu am OFF ability_switch_maps si am MIB2.5 cu AID si merge sa vad in paralel si pe instruments si pe nav.
Modificat de BTeo
MiB 2.5 sau MiB 2 Pro stiu ca merge harta simultan
Deci eu trebuie sa il am ability_switch_maps. doar ca e greyed out. Azi cand am dus masina in service am descoperit ca am nevoie si de config pe ACC.
ACC merge corect dar afiseaza o masina pe display, dar nu la distanta corecta.
Copie coding-ul de la mine sau de la OviVal. Eu il am de la el.
Aceeasi problema am avut si eu cu afisarea in mod corect a distantei la ACC. S-a rezolvat prin codingul corect pe Instruments. L-am copiat de la OviVal si l-am adaptat la mine.
Modificat de BTeo
@BTeo @OviVal ma ajutați cu un export de pe canalu 13 va rog.
the missing parameter for my coding was this:
In control group 13, Adaptive Cruise Control, enable FPK_Functions via Adaptations.
aceasta funcție ar rezolva afișarea corecta a distantei la acc pt aid. in teste funcționează ok, dar mașina indiferent de distanta ea e prezenta pe display foarte aproape.
O sa testez abia mâine după ce termina distribuția de făcut.
aceiasi problema o avea @BTeo daca nu gresesc.
Tocmai ce am comparat l codingurile si nu am gasit nimic care sa influenteze afisajul nav
adpmap-13-3Q0-907-572-B_WVWZZZ3CZHE059764-20191116-1634.CSV
Modificat de OviVal
Nici mie nu mi se părea nimic deosebit
Dar cu toate astea, am copiat complet codingul de la tine si a mers :)
Da, cred ca e acel FPK inclusiv în coduri instruments. Cu vcds original apare in experimental coding dar nu știam ce e
Modificat de BTeo
testez mâine seara cu odis. poate apare exact ce sunt. am și o chinezărie de vcds 20.04 dar încerc sa îmi pun baza în odis. revin mâine seara dacă am timp după ce iau mașina din service
Slabe sanse cu odisul offline. Mai mari sanse ai cu vcds-ul original.
Am constatat ca desi o valoare este corecta in codare/adaptare, o simpla rescriere a acelei valori va face functionala functia dorita care anterior nu era “on”. De ce ... 🤷‍♂️ dar functioneaza. Asa cum a spus si @BTeo
Am intalnit situatii la MQB, unde codezi cu vcds original, dar degeaba. Codezi cu odis offline (recodezi) si rezolva problema.
Deci, trebuie incercat.
Varianta cu recodare, chiar si cu aceeasi valoare,  acolo unde suporta, se aplica si la platformele mai vechi....si da rezultate,  cateodata
Adaug aici o informatie care poate candva o sa ajute pe cineva.
Am facut update la camera din parbriz A5 de la soft 121 la soft 171 aparut in 2019 ( ├── [ 22M Sep 19 2019] FL_3Q0980653_0171.frf )
In urma updateului nu se mai salva setarea anterioara cu lane assist la fiecare pornire de motor - sa fie on chiar daca in adaption era trecut on. Mentionez ca avand aceleasi setari, cu softul vechi mergea.
Cu toate ca era aceeasi codare ca in trecut, schimbarea apare la byte 14 si codarea trece de la A1 la A9 (Se activeaza Perso HC Last setting) - setari luate de pe un forum skoda.
Dupa modificarea in A9, totul e ok.
Alte probleme intalnite la retrofituri (fiind masina 2015):
- in urma retrofitului la AID pictograma ACC cu masina nu se deplasa si ramanea blocata; s-a rezolvat cu codarea mentionata anterior rescrisa complet. Pacat ca am aflat de asta dupa ce am schimbat si senzorul ACC din sigla cu ultima varianta disponibila cu E la final si a trebuit sa fac si recalibrare la reprezentanta.
- in urma retrofitului la camera high si activarea functionarii acesteia ca si camera high, nu mai functiona pictograma de parcare cand apasam pe butonul de parking (nu mai vedeam masina pe ecran cu liniile ajutatoare). De asemenea aveam si o eroare pe 6C: 13705478 - Databus U1121 00 [009] - Missing Message [message Parkhilfe_01 not received]. S-a rezolvat prin inlocuirea GW cu ultima varianta AM (cred ca se poate si prin update de soft dar nu bag mana in foc)
- tot in urma retrofitului la camera high noua aveam eroare 10489856 - No Basic Setting  . S-a rezolvat prin printarea la dimensiuni reale a unui template de calibrare si calibrarea cu ODIS ( vezi aici )
- am activat si pedestrian assist dar din pacate nu mai retin pasii.. m-am jucat cu VCDS original, am salvat codarile vechi si am facut modificari in Instruments, ACC si camera A5 (Atentie, merge doar pe 653; 654 nu suporta) si in adaptions pe 5F pe BAP pedestrian. Nu este dificil ci trebuie bifat ce apare legat de pedestrian (doar pe instruments apare "collision warning" fara cuvantul in sine "pedestrian"). Fiindca modulele comunica, o bifa pe unul din module duce la "Incorrectly coded" pe celelalte. Ideea e sa salvati setarile vechi si sa folositi doar interfata originala. Cand ma apropiam de o trecere a dat avertizare in bord cand a trecut pietonul prin fata masinii, aceasta fiind in deplasare.
- retrofit TPMS direct - nu au fost probleme. Dupa montare roti de iarna/vara, trebuie de mers mai mult timp si isi ia automat senzorii.
- am incercat sa pun ultimul volan cu buton "View". Nicio eroare doar ca nu functiona butonul - nu se schimba nimic in AID. Am renuntat si l-am pus pe cel vechi inapoi.
Multumesc tuturor pt ajutor, eu am incheiat ce mi-am dorit ca retrofit pe masina :)
Modificat de BTeo
Am luat mașina in seara asta.
ACC cu AID se rezolva într-adevăr cu FPK
Byte 4 Bit 3. FPK_Functions,0 = not installed/1= installed
Cu Odis E sunt vizibile toate valorile. am preferat sa nu dau copy paste datorita dotărilor.
Singura problema rămâne harta, posibil sa fie o problema între software-ul de 5F și 17.
Pedestrian Assist nu pot sa zic ca îmi doresc bifa, este activ, în timp ce codam FPK a trecut cineva prin fata și mi-a apărut iconita de mașina.
Mai am un ultim experiment de făcut și anume sa iau un mib2 high Hărman sa îl pun... as pierde DAB atât dar l-am folosit 5minute în viata mea.
Conform unor forumuri de afara dacă codurile Swap și fec sunt de fabrica atunci când fac component protection pot sa migrez și codurile.
Am codat 5F nu activează butonul de migrare hărți. am copiat long coding din filele primite.
Revin după ce încerc cu alta unitate.
@BTeo @dragosmp
Copy-Paste pe long coding nu prea e indicat, masinile pot avea optionale diferite. Mai indicat e sa introduci codul intr-un calculator HexBin ( pe win il ai deja in calculatorul de sistem) si asa vezi care bit sunt bifati si care nu.
Atasez un exemplu cu codurile de pe 17 si 5f de la masinile noastre
Long Coding helper-Comparatie 17 si 5f-1.pdf
Revin cu update... între timp am pus pe masina un Mib2 High Harman
Codat tot ce aveam pe masina, înlocuit fibra de test.
codat cu vcds original.
nimic.
scos unitatea mib2 high pusa pe alta mașina cu AID a pornit din start.
Tind sa cred ca ceasurile sunt de vina, ori nu suporta hărți (ca modelul 790) ori au un bug.
Multumesc pt fisiere, mai încerc dacă găsesc ceva.
Ce cod au ceasurile?
    • Emi99
