Golf 6/Jetta - Probleme ABS/ESC + ambreiaj
TrIcK
Recommended Posts
acum, depinde cat de bine au facut/izolat legaturile - in teorie, daca ai cumparat cablajul pana in pompa, trebuia sa iti scoata si bage pinii, direct in mufa pompei
Link to comment
Share on other sites
Am inteles
Pai atunci sa speram ca va fi ttul in regula
Pe viitor cunoasteti vreun mecanic bun?
Link to comment
Exista o arie dedicata pentru prestări servicii.
Link to comment
Salutare ,
Se da : Golf 6 , 2009 . 2.0 tdi 110cp
Am ramas fara baterie, intr-un weekend, dupa mult ascultat muzica, jucat cu vcds, etc.
Am "luat curent" cu cabluri de la cineva si masina a pornit .
Masina face preponderent drumuri de 10-15 km in oras.
Problema dupa cateva zile:
Motor oprit in mers, era la relanti , masina scoasa din viteza. Martori, Abs , ESP, Frana de mana, Spirala,  aprinsi, 3 beepuri.
La cheie n-a vrut sa porneasca (simptom ca si cum baeria ar fi fost moarta)
L-am pornit din inertia masinii (ca si cum ar fi fost impinsa). masina a functionat fara pb.
Erori pe scanare:
Spoiler
Wednesday,01,February,2017,17:55:51:32264
VCDS Version: Release 11.11.3
Data version: 20120401
                Address 03: ABS Brakes       Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 AD    HW: 1K0 907 379 AD
  Component and/or Version: ESP MK60EC1   H35 0106
           Software Coding: 113B200D09280000881404E4901E00423000
            Work Shop Code: WSC 01357 011 00200
                      VCID: 74EDC209D7A00E9
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 80
                    Mileage: 172328 km
                    Time Indication: 0
                    Date: 2023.14.27
                    Time: 16:27:43
             Freeze Frame:
                    Count: 2
                    Count: 3
                    Count: 4096
                    Count: 128
                    Count: 29184
                    Count: 768
                    Count: 0
                    Count: 0
Wednesday,01,February,2017,17:54:13:32264
                Address 01: Engine       Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 LF    HW: 03L 906 022 G
  Component and/or Version: R4 2,0L EDC 0000SG  6177
           Software Coding: 0000071
            Work Shop Code: WSC 44024 142 50033
                      VCID: 74EDC20917A00E9
2 Faults Found:
000256 - Mass Air Flow Sensor (G70)
               P0100 - 000 - Supply Voltage - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 172328 km
                    Time Indication: 0
                    Date: 2023.14.27
                    Time: 16:27:07
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 6.92 V
                    Load: 100.0 %
                    Load: 100.0 %
                    Mass Air / Rev.: 710.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
000257 - Mass Air Flow Sensor (G70)
               P0101 - 000 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 172328 km
                    Time Indication: 0
                    Date: 2023.14.27
                    Time: 16:28:24
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Voltage: 6.16 V
                    Load: 100.0 %
                    Load: 100.0 %
Readiness: 0 0 0 0 0
A doua manifestare a problemei:
Motor oprit in mers, tot la relanti , scos din viteza.
martori aprinsi: Abs, ESP, Frana de mana, 3 beepuri. FARA martor Spirala.
Masina nu a pornit la cheie. A pornit din inertie dar greu si scuturat (parca in 3 cilindrii) pana am turat putin, apoi si-a revenit.
Erori scanare :
Spoiler
Friday,03,February,2017,09:46:26:32264
                Address 44: Steering Assist       Labels: 1Kx-909-14x-44.clb
Control Module Part Number: 1K0 909 144 E
  Component and/or Version: EPS_ZFLS Kl. 69     2501
           Software Coding:
                      VCID: 2C5D1A698F10169
00750 - Warning Lamp
            013 - Check DTC Memory - MIL ON
             Freeze Frame:
                    Fault Status: 11101101
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 172456 km
                    Time Indication: 0
                    Date: 2024.14.01
                    Time: 09:12:41
             Freeze Frame:
                    Voltage: 12.00 V
                        DU
                    Temperature: 14.0°C
                    RPM: 0 /min
                    Speed: 12.0 km/h
                    Speed: 12.0 km/h
                    Count: 0
Dupa fiecare episod s-a intamplat dupa ce in seara precedenta am stat putin si am incercat sa codez stopurile led GTI.
Masuratori baterie: motor oprit : 12.4 , Motor pornit 14,1 .
Dupa fiecare episod masina functioneza normal .
Poate fi bateria? Desi din masuratori pare OK.  O sa o pun in weekend pe redresor.
Edited by Xtremu
Link to comment
pare a fi bateria care nu mai tine curent.
Link to comment
Merci de raspuns.
O sa o inlocuiesc.
Ce mi se pare ciudat e ca motorul s-a oprit in mers. de fiecare data la 2-3 minute de la pornire.
Din cate stiu motoarele diesel nu mai au nevoie de baterie pt a functiona dupa pornirea initiala. Corecteaza-ma daca gresesc.
Link to comment
Astea mai noi au nevoie - injectoarele sunt comandate electronic, senzori, etc.
ceea ce zici tu, e valabil pentru motoarele diesel vechi.
Link to comment
Am inlocuit volant si ambreiaj la G6 2009 (CBDC -110Hp) .
Dupa inlocuire masina accelereaza mai greu ca inainte. Am breiajul e mult mai moale (ceea ce e f bine) dar prinde cam sus si nu este asa progresiv ca inainte.
De asemenea, am obervat , la coborarea unei pante ca :
 Frana de motor, am lasat ambreiajul compet -> Masina a pus frana de motor in 2 etape ca si cum ambreiajul ar fi alunecat putin sau nu as fi debreiat complet.
Am mai ,avut un episod in treapta a 3-a la rece, pe accelerare,  a inceput de imi vibreze masina.
Am apasat si lasat  ambreiajul si comportamentul a disparut.
Kitul a fost cumparat de la Volksman si montat in service autorizat.
Este posibil ca montajul sa nu fie facut corect?
Edited by Xtremu
Link to comment
On ‎11‎/‎10‎/‎2016 at 4:27 PM, Al Bundy said:
NU, ia un 1K0 907 379 BJ (din VCDS)
1K0 907 379 BJ nu gasesc prin dezmembrari, ce alta terminatie s-ar mai potrivii ? (cea originala e 1K0 907 379 AE)
Link to comment
Se pare ca am gasit un modul 1k0614517de  /  1k0907379BJ
Sigur se potriveste in loc de 1K0 614 517 B (si un mare F1+)  + electronica 1K0 907 379 AE ??
multumesc!
Link to comment
On 11/6/2016 at 7:28 PM, Al Bundy said:
Solutia: schimbarea modulului ABS.
Va salut din nou.
Stie cineva cum se "calculeaza" codul pentru unitatea ABS 1K0 907 379 BJ  ?
unitatea veche 1K0 907 379 AE avea codul: 113B200D09220001881304E5901C00423500
Seria sasiu: WVWZZZ1KZ9P407813
Link to comment
Ziceam mai demult ca am ceva probleme cu kitul ambreiaj , montat acum aprox 1 luna.
Vibratii la pornitul de pe loc, Uneori alunecare.
Azi dimineata am pornit motorul si am iesit din masina pt scurt timp. Si WTF! ma apropiu de ea si imi dau seama ca VOLANTUL trancane.
Kit nou Sachs achizitionat de la @volksman montat in service autorizat.
Dupa parerea mea exista 2x variante:
1. Kit defect din fabricatie. Putin probabil...dar vedem.
2. Mecanicul a montat doar ambreiajul sau alte piese sau montaj defectuos. Din cate stiu kitul este cu autoreglaj.
Ma gandesc sa merg la alt service si sa fac o expertiza/constatare. De acolo in colo vedem ce e de facut.
A mai avut cineva experiente de genul cu kit nou , defect din fabrica?
Edited by Xtremu
Link to comment
Daca este cineva curios, asa arata electronica unui modul ABS 1K0 907 379
Daca se gandeste cineva ca e ceva reparabil la el , gen YouTube , nu e nimic de reparat la el :) (pierdere de timp)
Link to comment
merita verificat de cine se pricepe
daca e arsa vreo rezistenta sau vreun condensator se poate gasi si inlocui foarte usor
mai greu cu integratul
Link to comment
NU stiu ce poti repara TU pe acolo, cand eroarea este ABS- implausible signal.
Link to comment
Nimic, modulul a "plecat" la reciclat.
L-am desfacut din curiozitate, si am postat pentru alti curiosi, pentru ca nu am gasit pe internet nici o poza cu interiorul ei...
Iti multumesc pentru ajutor, modulul BJ s-a potrivit perfect, a acceptat codarea veche cu 00 in plus la sfarsit. ?
Link to comment
     stie cineva care ii problema? Imi scartie si foarte tare franele pe spate,jantele se incalzesc foarte tare....
Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 143B600D092200FC281406E490210042300000
   Shop #: WSC 00066 000 00000
   VCID: 78F5F639CBC86A9
01435 - Brake Pressure Sensor 1 (G201)
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 172
                    Mileage: 232597 km
                    Time Indication: 0
             Freeze Frame:
                    Count: 0
                    Count: 32768
                    Count: 4608
                    Count: 281
                    Count: 48981
                    Count: 0
                    Count: 65280
                    Count: 2048
Link to comment
Ai de schimbat modulul de ABS, dar nu cred ca asta e si cauza scartaielilor.
Link to comment
placutele de frana raman stranse pe discuri
deci verdictul este batut in cuie,trebuie schimbat modulul?
cam cat costa manopera si modulul?
Link to comment
@klaus123 eu am gasit modul la 300ron + manopera m-a costat 500.
Link to comment
Salut @tuchbr,ai avut aceleasi simptome la masina?Adica iti ramaneau placutele blocate pe disc,scartaituri la viteze mici,jante incalzite?Imi poti spune,te rog,unde ai gasit modulul cu 300 ron,multumesc!
Link to comment
@klaus123  salut, eu am avut problemele descrise anterior in acest topic. Vezi aici.
Modulul l-am gasit din dezmembrari, am gasit doar doua, unul la 300, altul la 1400. (am avut noroc si rabdare, am cautat luni de zile pana am gasit).
Link to comment
probabil vorbesc prostii,dar cum naiba un sistem care se ocupa cu anti blocarea rotilor mie imi blocheaza franele?
Link to comment
Ai citit cu atentie ce am scris eu ?
Link to comment
cu foarte mare atentie,dar trebuie sa fie foarte mare coincidenta sa apara aceste probleme deodata,eroare ABS,aprindere martor ABS in bord +frane blocate+scartait roti si sa nu fie legatura intre ele,zic si eu..Eu am si alta problema de o saptamana cu masina asta pacatoasa,apa in portbagaj si balta in spatele pasagerului din dreapta poate intr-un fel sau altul ca asta sa fie cauza defectiunii ABS -ului?Sa fii ajuns apa pe unde nu trebuie?
Link to comment
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
  • Recently Browsing   0 members
    • No registered users viewing this page.
