Se afişează conţinutul cel mai apreciat din 14.11.2015 în toate secţiunile
  1. Metabond Megasel Plus - certificat TUV http://metabond.ro/uploads/ckfiles/files/T%C3%9CV%20Megasel%20Plus%202015.pdf Metabond Meganele Plus - certificat TUV http://www.metabond.ro/uploads/ckfiles/files/T%C3%9CV%20Megalene%20Plus%202015.pdf Metabond Eco - certificat TUV http://metabond.ro/uploads/ckfiles/files/T%C3%9CV%20ECO%202015.pdf Metabond LLX 5w30 nu este fabricat de Metabond ci de TOTAL LUBRIFIANTS. De fapt cam toate uleiurile lor sunt facute de TOTAL LUBRIFIANTS. Megasel, megalene si eco sunt produse de Metabond Magyarország Kft. 9030 GYŐR, Csonkaér út 5. Atat Amsoil cat si Redline folosesc 2-etilhexil-nitrat si 2-etilhexanol pentru cetan boost. Orice aditiv de calitate atat keropurul din Rompetrol cat si aditivii din Mol Evo sau OMW maxx motion contin cel putin unul din cei 2 compusi din megasel pentru cetan boost. Avem asa : 2-ETHYL HEXYL NITRATE SYNONYMS Nitric acid, 2-ethylhexyl ester (CAS Name) 3-Nitroxymethyl-heptane (IUPAC Name) USES Cetane improver (Fuel additive) ASPECT Colourless clear liquid. Pungent, fatty, fruity ester odour. Si mai avem 2 etilhexanol Almost all 2-ethylhexanol is converted into the diesters bis(2-ethylhexyl) phthalate (DEHP), a plasticizer. Because it is a fatty alcohol, its esters tend to have emollient properties. For example, the sunscreen octocrylene contains a 2-ethylhexyl ester for this purpose. It is also commonly used as a low volatility solvent. 2-Ethylhexanol can also be used as an octane booster when reacted with nitric acid.
  2. Daca e doar 2% in plus, clar merita.. macar ai leduri :-)
  3. Sa o stapanesti sanatos :). Nu am nicio indoiala ca ST ul se va comporta admirabil. In cazul meu nu se justifica pretul in plus pt spatiul oferit pentru ca nu am nevoie de el. Plus ca atunci cand am configurat eu masina era un timp de asteptare se 6 luni pt ST.
  4. Da, revin cu detalii dupa cum am promis....de 3 zile urmaresc stopul, NU s-a mai aburit, se pare ca purfixul meu a dat rezultate! Iata cum arata.... Spor la treaba pentru cine vrea sa incerce!!! ;)
  5. Salut, Revin cu un update. Eu am folosit metabond eco pe un passat din 2000 motor 1,9 tdi atj. Sunt foarte foarte multumit. Motorul se simte ca are mai multa putere... La detalii mecanice si ce va urma nu ma pricep, dar pentru moment sunt foarte multumit.
  6. Uleiul 5W30 Castrol Edge FST LL Boost with Titanium este indicat pentru ambele motorizari Benzina/Diesel :salut:
  7. Am revenit si cu raspunsul primit de la porsche bucuresti nord: "merg amandoua, dar noi va recomandam 507 00 pentru ca aveti filtru de particule". Adaugand acest raspuns la cele citite aici o sa merg pe Castrol Edge FST 5W30, sau alt ulei care cu norma 507 00 . Multumesc frumos de ajutor
  8. Pentru cei ce vor mai avea probleme, un mic ajutor: Asa arata capetele, rupte: Se demonteaza capetele si pastrati ghidajul negru din plastic (cel rupt). Am folosit 2 suruburi cu saibe.A trebui sa scurtez suruburile. Incepem montarea: Dupa ce am fixat plasticul, am prins unul din capete pana aproape de finalul curesei surubului(tinand contra in partea opusa cu un patent). In partea opusa se armeaza arcul, iar apoi se strange surubul initial pana la capat. Dupa care Plasticul ramas se monteaza simplu, totul fiind GATA.
