  2. corad0
    Trebuie instalat si antivirus? 🫣
  3. cristi511
    Anvelope de iarnă 2023/2024
    Dot 3425, made in Spain.
  4. spido
    Da,dar nu a specificat acest lucru. Ca s-ar fi facut distributie..
  5. sandumbogdan
    Citisem astfel de erori cu missfire la alte persoane dupa schimbarea distributiei.
  6. spido
    Supape,variator axa came.
  7. szintyjanos
    Buna Am un Golf VII cu motor 1.5 TSI, si tot imi re-apare eroarea 10591 - Cylinder1 - P0301 - Misfire detected si mai nou si 10593 - Cylinder1 - P0303 - Misfire detected, in ciuda faptului ca am schimbat toate bujiile (desi, cf service nu era inca momentul) si am schimbat si bobina de incudctie pe cilindrul 1, insa eroarea reapare de fiecare data, iar dimineata la prima pornire, imi da si eroarea pe bord de Start-Stop not function. A mai intampinat cineva aceasta situatie? Ce sfaturi as putea primi? Masina este programata pentru o diagnoza la reprezentanta din Timisoara. Address 01: Engine (J623-DADA) Labels:. 04E-907-309-V1.clb Part No SW: 05E 906 018 AL HW: 05E 907 309 Component: R4 1.5l TFS H22 6084 Revision: 81H22000 CVN: E96C3F02 Coding: 012500322304190830000000000000000000000000000000 Shop #: WSC 00028 028 00071 ASAM Dataset: EV_ECM15TFS01105E906018AL 003002 ROD: EV_ECM15TFS01105E906018AL.rod VCID: 6FE78E7EB69D05F723-803A VINID: 9E69EAAAA465A9B805146006180226032C 3 Faults Found: 10591 - Cylinder 1 P0301 00 [032] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 107679 km Date: 2025.10.03 Time: 07:17:29 Engine RPM: 998.50 /min Normed load value: 5.5 % Vehicle speed: 0 km/h Coolant temperature: 16 °C Intake air temperature: 9 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.580 V Unlearning counter according OBD: 35 Outside temperature: 7 °C Absolute intake pressure: 59 kPa abs Engine torque: 16.9 Nm Fuel: tank fill level: 24.0 l Oxygen sensor B1: sensor 1: specified value: 1.0000 Particulate filter: loading stage: 0 Overrun cut-off-Bits 0-7: 0 10593 - Cylinder 3 P0303 00 [032] - Misfire Detected Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Mileage: 107754 km Date: 2025.10.07 Time: 07:14:47 Engine RPM: 1102.50 /min Normed load value: 5.5 % Vehicle speed: 0 km/h Coolant temperature: 15 °C Intake air temperature: 10 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.320 V Unlearning counter according OBD: 35 Outside temperature: 6 °C Absolute intake pressure: 67 kPa abs Engine torque: 17.4 Nm Fuel: tank fill level: 15.0 l Oxygen sensor B1: sensor 1: specified value: 1.0000 Particulate filter: loading stage: 0 Overrun cut-off-Bits 0-7: 0 37073 - Engine Misfires Detected on Startup (First 1000 Revolutions) P0316 00 [032] - - Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 107679 km Date: 2025.10.03 Time: 07:18:15 Engine RPM: 795.00 /min Normed load value: 9.0 % Vehicle speed: 0 km/h Coolant temperature: 25 °C Intake air temperature: 10 °C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.660 V Unlearning counter according OBD: 35 Outside temperature: 8 °C Absolute intake pressure: 27 kPa abs Engine torque: 27.4 Nm Fuel: tank fill level: 24.0 l Oxygen sensor B1: sensor 1: specified value: 1.0000 Particulate filter: loading stage: 0 Overrun cut-off-Bits 0-7: 0 Multumesc
  8. szintyjanos
    Jurnal DSG6
    Buna As avea si eu 2 intrebari, nu prea stiu ce as putea face, legat de schimbul de ulei din cutia DSG: 1. Am apelat la reprezentanta, si mi s-au spus urmatoarele: " in urma verificarii seriei de sasiu in sistemul nostru, conform planului de service dat de producator, va confirm ca uleiul este longlife, la modelul detinut uleiul la cutia de viteze nu se inlocuieste, doar se verifica nivelul si se completeaza" Teoretic ar fi trebuit schimbat uleiul la 60-80000km, si dupa aceea din 40 in 40000, momentan am 107000, insa la reprezentanta nu vor sa o schimbe, doar impreuna cu baia atf. A mai schimbat cineva uleiul din cutia DSG? Ce ar fi de urmarit? 2. A inceput sa apara un zgomot cand schimba din a IV-a in a V-a, fara sa fie in sarcina, ca si cand anvelopa fluiera la mplecarea de pe loc. Interesant este ca, in sarcina nu face acest lucru (adica daca apas putin mai tare de accel;eratie), respectiv cand schimba din a V-a in a IV-a tot nu se aude nimic. Va multumesc pentru orice sfat.
  9. Ssoulstream
    am cerut oferte de la mai multi, inclusiv pbv1. ofertele variaza in functie de discount-ul de dealer, dar diferentele intre kodiaq si tayron sunt cam de 4000 euro pt configuratii asemanatoare.
  10. lupo_bv
    Probleme cutie de viteze manuală
    Sub capacul lateral este pinionul pt tr. 5. Problema nu este neaparat datul cutiei jos, cred ca mai mult de 500 lei nu ar trebui sa coste, nu este complicat dacă ai elevator. In curte sa faci tu operatiunea asta este complicat, eu am schimbat kitul si m-am injurat singur. Eventual cu ocazia asta schimbi kitul de ambreiaj daca are uzura. Problema este ca trebuie demontată cutia. O poti trimite la Campia Turzii daca mecanicul nu stie sa remedieze problema.
  11. sandumbogdan
    Total gresit cap-coada. Distributia se verifica la 300 mii km, nu se schimba la 180 mii, nici macar la 300 mii nu se schimba ci doar se inspecteaza. Apoi sa o schimbi ulterior din 30 in 30 mii in nici un caz. La Hyundai aveau probleme mari cu consumul de ulei deci nu sunt de preferat motoarele lor turbo fata de cele de la VW. Mie mi se pare destul de logic. Axele sunt blocate exact ca de curea deci daca ar fi asa de sensibila pozitia atunci si miscarea curelei dintate ar afecta pozitia lor. Singura varianta in care ar putea justifica acea scula ar fi daca ar fi diferiti marimea si numarul de dinti de pe curea dar nu este cazul, toate curelele au acelasi numar de dinti si aceeasi marime deci nu are nici un sens acea ajustare fina care este mult prea fina pentru tolerantele curelei din cauciuc.
  12. Adi_vw
    Chinezu' strikes again Exista si varianta mai ieftina care nu necesita calculator. https://www.aliexpress.com/item/1005007130451855.html
  13. draganuta
    Ultima versiune de SW este SW0332, dar la tine trebuie facut initial update la SW:0178, dupa care la SW:0278 (pt. MIB3 OI cu SW:0268, SW:0270, SW:0272, SW:0274, SW:0276, SW:0278, SW:0300, SW:0302, SW:0304, SW:0306 se face update la versiunea SW:0308 si ulterior la SW:0332). Update-ul de la SW:0178 la SW:0278 va duce la pierderea navigatiei, care trebuie refacuta. Fiecare update dureaza aprox. 3 ore. Ce versiune de SW este la OCU <Address 75: Telematics (J949)> ? Versiunea SW0332 este atasata (parola se trimite pe Message doar la membri). Nu stiu daca am si celelalte versiuni intermediare (trebuie sa le caut). MIB3 FW 332 updt.txt
  14. Seba_Tour
    Buna ziua, In caz ca ajuta pe cineva, ieri am facut inspectia de 30.000km si schimb de ulei + filtru ulei pentru Superb 4 2.0TDI 150 la Autoclub Timisoara. Cost: 1401 ron O zi frumoasa,
  15. suflo
    Retrofit Golf 7: Montare comenzi / volan multifunctional
    Am Mid, si cautat in VCDS, si am gasit setarea asta pe SteringWheel, si l-am activat. si nu a dat eroare. Deci fara activare online, zici ca nu ar merge? si care ar fi solutiile? multumesc anticipat
  16. Nenciu Victor
    poti argumenta?
  17. R_a_z_v_a_n
    @Teodor2025 te rog renunta sa mai citezi postarea anterioara. Nu faci decat sa dublezi inutil un post. Multumesc
  18. Teodor2025
    Multumesc mult. Ceva de genul asta credeam si eu. Sa dau cutia jos nu merita. E exclus. Am incercat asa cum zici si nu am reusit. Am dat jos si capacul lateral al cutiei in speranta ca voi avea acces la levierul acela. Nu am insa. Ok. Mi se parea greu de crezut ca un surub montat din exterior ar putea avea influenta asupra functionarii cutiei. Vad ca m-am inselat. Multe multumiri oricum. Respecte!
  19. yo8rze
    Adaptarea senzorului de rotire a volanului
    Mulțumesc, Florin! Scuze, dar nu știu ce înseamnă FL. O să caut să apelez la cineva care a mai făcut treaba cu ceasurile... Cât despre calibrarea senzorului G85 am respectat instrucțiunile de mai jos, fără succes însă... ,, Sensor for Steering Angle (G85) Prerequisites: Start the vehicle. Drive in a short distance straight line on a level surface at a speed not higher than 20 km/h. While driving turn the steering wheel one turn to the right and one turn to the left. When having the steering wheel straight again stop the vehicle with the wheels pointed straight. Ensure that the steering wheel is not moved again. Keep the engine running and do not switch off the ignition. System voltage at least 12.0 V. [Select] [03 - Brake Electronics] [Security Access - 16] Enter 40168, to enable the basic setting. [Do it!] [Basic Settings - 04] Group 060 [Go!] Activate the Basic Setting. [ON/OFF/Next] After a successful basic setting, one of the fields should say "OK". [Done, Go Back] To make sure the basic setting was successful, check the sensor again. [Measuring Blocks - 08] Group 004 [Go!] Check field 1, the value has to be between -1.5 and +1.5 °. [Done, Go Back] [Close Controller, Go Back - 06] Note: After successful basic setting, the Steering Limit Stop needs to be adapted too." O să mai execut odată procedura, poate îmi iese.. 😊
  20. AndreyPH
    Salut @draganuta! Cred ca este prima versiune cu care a iesit din fabrica, nu a stat nimeni de ea pana acum sa-i faca update. 😕
  21. F l o r i n
    Probleme portbagaj [Passat CC]
    Ai 2 cleme de plastic si restul clipsuri metalice. Trebuie sa îndepărtezi si plasticul din zona in care intra balamaua, e tot clipsat
  22. F l o r i n
    Manetele nu te ajuta cu nimic. In primul rand, pt verificare compatibilitate manete, trebuie sa verifici ce calculator coloana ai pe masina. Dupa montaj, trebuie conexiune online cu serverul VAG, pt a activa pilotul automat
  23. F l o r i n
    Nu mai indică nivelul de combustibil
    Ai umblat la pompa de carburant sau cum a aparut problema?
  24. F l o r i n
    Sa tragi si firele de can de la modul confort la ceasuri
  25. F l o r i n
    Ceasurile de FL sa le montezi pe non FL, nu te ajuta sa citești pinurile. Trebuie sa citești zonele immo intai. Dupa aceea trebuie deblocat eeprom la ceasurile noi, ca să poti scrie noile informații. Trebuie sa scrii manual vin, cs, immo, chei in noile ceasuri....si ai nevoie de cipuri noi la chei. Pentru cealaltă problemă ti-au scris deja colegii.
  26. F l o r i n
    VW CC 3.6 VR6
    Foarte tare motorizarea, sa o stăpânești sănătos!
