Afişează tot conţinutul publicat în ultimele 637 zile.
Salutare! Ma puteti ajuta va rog cu aceasta eroare: Address 19: CAN Gateway Labels: 3Q0-907-530-V1.clb Control Module Part Number: 3Q0 907 530 AC HW: 3Q0 907 530 C Component and/or Version: GW MQB High 518 5388 Software Coding: 030100040B087300EF00025E080F00010001000000000000000000000000 Work Shop Code: WSC 12345 123 12345 ASAM Dataset: EV_GatewNF 013026 (VW37) ROD: EV_GatewNF_VW37.rod VCID: 70E58D02ABA31A0D72-8024 1 Fault Found: 131593 - Multifunction Module U1301 00 [009] - No Communication at Second Databus Connection [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 91 Mileage: 126682 km Date: 2026.09.06 Time: 11:43:48 Terminal 30 power supply: 12.1 V Terminal 15: On Eroarea a aparut dupa ce am inlocuit CAN Gateway din seria 5Q0 cu unul mai nou din seria 3Q0. Am montat si acel modul(4B) in sperata ca voi scapa de eroare, insa tot nu am reusit sa scap de ea.. ;SW:3Q0-907-530-AC HW:3Q0-907-530-C --- CAN Gateway ;Component:GW MQB High 518 5388, Coding:030100040B087300EF00025E080F00010001000000000000000000000000 ;EV_GatewNF,013026,EV_GatewNF_VW37.rod ;Sunday,06,September,2026,11:55:39:00009 ;VCDS Version: Release 22.10.0 Data version: 20221026 DS344.0 ;VCID: 70E58D02ABA31A0D72-8024 IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3 IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3 IDE00002-Transport mode,not active ,1 IDE00820-MAS01172-Activating and deactivating all development messages-Development messages,not active ,1 IDE00820-ENG98891-Activating and deactivating all development messages-Reserved,0 ,1 IDE01211-Static current measuring mode,not activated ,1 IDE01457-Energy management deactivation stage,Mode not active ,1 IDE01459-Energy management heat output control status,Mode not active ,1 IDE01844-Increase idle speed request,Mode not active ,1 IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3 IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3 IDE01860-Generator specified voltage value variable,10.6 V,1 IDE01996-SFT00001-Installation list: specified installations-Engine Electronics,coded ,32 IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,Not coded ,32 IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32 IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32 IDE01996-SFT00008-Installation list: specified installations-Climate Control Module,coded ,32 IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32 IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32 IDE01996-SFT00014-Installation list: specified installations-Media Player 1,Not coded ,32 IDE01996-SFT00019-Installation list: specified installations-Distance Regulation,coded ,32 IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics,Not coded ,32 IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32 IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systems,coded ,32 IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32 IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32 IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,1 ,32 IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32 IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32 IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32 IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,Not coded ,32 IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32 IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32 IDE01996-SFT00043-Installation list: specified installations-Steering column lock,Not coded ,32 IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32 IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32 IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,Not coded ,32 IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,coded ,32 IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32 IDE01996-SFT00064-Installation list: specified installations-A/C compressor,Not coded ,32 IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32 IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32 IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32 IDE01996-SFT00075-Installation list: specified installations-Multi-function module,coded ,32 IDE01996-SFT00075-Installation list: specified installations-Multi-function module,coded ,32 IDE01996-SFT00081-Installation list: specified installations-Electric drive,Not coded ,32 IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32 IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,coded ,32 IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32 IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32 IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32 IDE01996-SFT00096-Installation list: specified installations-Trip recorder,Not coded ,32 IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32 IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32 IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,coded ,32 IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,Not coded ,32 IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,Not coded ,32 IDE01996-SFT00118-Installation list: specified installations-Parking aid,coded ,32 IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32 IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32 IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,Not coded ,32 IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,coded ,32 IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32 IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,Not coded ,32 IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system,Not coded ,32 IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics,Not coded ,32 IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics,Not coded ,32 IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management,Not coded ,32 IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door,Not coded ,32 IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door,Not coded ,32 IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32 IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32 IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger,Not coded ,32 IDE01996-SFT00202-Installation list: specified installations-Sunroof control module,Not coded ,32 IDE01996-SFT00204-Installation list: specified installations-Starter generator,Not coded ,32 IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2,Not coded ,32 IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32 IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32 IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32 IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32 IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32 IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32 IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32 IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32 IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32 IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32 IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32 IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32 IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32 IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32 IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32 IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32 IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32 IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32 IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32 IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32 IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32 IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32 IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32 IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32 IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32 IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32 IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32 IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32 IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32 IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32 IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32 IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32 IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32 IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32 IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32 IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32 IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32 IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32 IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32 IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32 IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32 IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32 IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32 IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32 IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32 IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32 IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32 IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32 IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32 IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32 IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32 IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32 IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32 IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32 IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32 IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32 IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32 IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32 IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32 IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32 IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32 IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32 IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32 IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32 IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32 IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32 IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32 IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32 IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32 IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32 IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32 IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32 IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32 IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32 IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32 IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32 IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32 IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32 IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32 IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32 IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32 IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32 IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32 IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32 IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32 IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32 IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32 IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32 IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32 IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32 IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32 IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32 IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32 IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32 IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32 IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32 IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32 IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32 IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32 IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32 IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32 IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32 IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32 IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32 IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32 IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32 IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32 IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32 IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32 IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32 IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32 IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32 IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32 IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32 IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32 IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32 IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32 IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32 IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32 IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32 IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32 IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32 IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32 IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32 IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32 IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32 IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32 IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32 IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32 IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32 IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32 IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32 IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32 IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32 IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32 IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32 IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32 IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32 IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32 IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32 IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32 IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32 IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32 IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32 IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32 IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32 IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32 IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32 IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32 IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32 IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32 IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32 IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32 IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32 IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32 IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32 IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32 IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32 IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32 IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32 IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32 IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32 IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32 IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32 IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32 IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32 IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32 IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32 IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32 IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32 IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32 IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32 IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32 IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32 IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32 IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32 IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32 IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32 IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32 IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32 IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32 IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32 IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32 IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32 IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32 IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32 IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32 IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32 IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32 IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32 IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32 IDE02332-Deactivate production mode,0 ,3 IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah,15 IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15 IDE03256-MAS06107-Battery adaptation-Battery manufacturer, ,15 IDE03256-MAS06108-Battery adaptation-Battery Serial Number, ,15 IDE03903-Production process data 1,00 00 ,2 IDE04159-Deactivation of start/stop function,Mode not active ,1 IDE04186-Battery terminal recognition,connected ,1 IDE04330-Transfer of release code for a SWaP function,00 ,1 IDE04331-Selection of release codes for a SWaP function,FF FF FF FF ,4 IDE06530-Distance left for deactivation of static current measuring mode,2 ,1 IDE06541-Distance left for deactivation of transport mode,50 ,1 IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4 IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4 IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4 IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4 IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4 IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4 IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated ,4 IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4 IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4 IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4 IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4 IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4 IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4 IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4 IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4 IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,not activated ,4 IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4 IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4 IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,activated ,4 IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4 IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4 IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4 IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4 IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated ,4 IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,not activated ,4 IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4 IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4 IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4 IDE07838-Counter for inconsistent states,42 ,2 IDE08348-Start/stop start voltage limit,7.6 V,1 IDE08624-MKE Check box,activated ,1 IDE10735-Number requests autonomous recharging,3 ,1 IDE10736-Cyclization limitation request battery service,0 ,1 IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3 IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3 IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3 IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3 IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3 IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3 IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3 IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3 IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3 IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3 IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3 IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3 IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3 IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,activated ,3 IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,activated ,3 IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,activated ,3 IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3 IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3 IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3 IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3 IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3 IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3 IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,activated ,3 IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,activated ,3 IDE11689-48V-System: locking,regular operation ,1 IDE13756-Diagnosis filter: activation,not active ,1 IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production,200 km,2 IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service,20 km,2 MAS16372-Security version number,3 ,2 SFT271921-IDE02583-Multifunction steering wheel control module-Steering wheel Tiptronic switch,not installed ,3 SFT271921-MAS02311-Multifunction steering wheel control module-Steering wheel heating button,not active ,3 SFT271921-MAS04733-Multifunction steering wheel control module-Two-stage,Unknown (3),3 SFT271921-MAS06614-Multifunction steering wheel control module-Variant,ACC ,3 SFT271921-MAS09758-Multifunction steering wheel control module-Temperature sensor,not installed ,3 SFT271921-MAS13892-Multifunction steering wheel control module-Platform,Unknown (3),3 SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function,active ,3 SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function,active ,3 SFT271921-ENG258379-Multifunction steering wheel control module-clamp behaviour,active with terminal 58 ,3 SFT271921-ENG260738-Multifunction steering wheel control module-FoD ACC,activated ,3 SFT271921-ENG258784-Multifunction steering wheel control module-FoD Travel Assist,activated ,3 SFT271921-ENG262857-Multifunction steering wheel control module-Kombi_02_gueltig,active ,3 ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12 ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,40 ,12 ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12 ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12 ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,10000 ms,12 ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12 ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12 ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12 ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,2000 ms,12 ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,10000 ms,12 ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports,Mode not active ,4 ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4 ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4 ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC),Mode not active ,4 ENG137075-EM_heating_power_quota_adjustment,1000 W,1 ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1 ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1 ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1 ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics,activated ,32 ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics,activated ,32 ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics,not activated ,32 ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side,activated ,32 ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Module,activated ,32 ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric,activated ,32 ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,activated ,32 ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1,activated ,32 ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Distance Regulation,activated ,32 ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics,activated ,32 ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not activated ,32 ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering column electronics systems,activated ,32 ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster,activated ,32 ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating,activated ,32 ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface,activated ,32 ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,activated ,32 ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant,activated ,32 ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2,activated ,32 ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics,activated ,32 ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,activated ,32 ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation,activated ,32 ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock,activated ,32 ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,activated ,32 ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics,activated ,32 ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side,activated ,32 ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance,activated ,32 ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,activated ,32 ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor,activated ,32 ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics,activated ,32 ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering,activated ,32 ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,activated ,32 ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32 ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32 ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive,activated ,32 ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics,activated ,32 ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control,activated ,32 ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,activated ,32 ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,activated ,32 ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1,activated ,32 ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder,activated ,32 ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS),activated ,32 ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,activated ,32 ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system,activated ,32 ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics,activated ,32 ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit,activated ,32 ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid,activated ,32 ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1,activated ,32 ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display,activated ,32 ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management,activated ,32 ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systems,activated ,32 ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module,activated ,32 ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator,activated ,32 ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system,activated ,32 ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics,activated ,32 ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics,activated ,32 ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management,activated ,32 ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door,activated ,32 ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door,activated ,32 ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,activated ,32 ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,activated ,32 ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger,activated ,32 ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module,activated ,32 ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator,activated ,32 ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,activated ,32 ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,activated ,32 ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,activated ,32 ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,activated ,32 ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,activated ,32 ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,activated ,32 ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,activated ,32 ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,activated ,32 ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,activated ,32 ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,activated ,32 ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,activated ,32 ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,activated ,32 ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,activated ,32 ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,activated ,32 ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,activated ,32 ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,activated ,32 ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,activated ,32 ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,activated ,32 ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,activated ,32 ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,activated ,32 ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,activated ,32 ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,activated ,32 ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,activated ,32 ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,activated ,32 ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,activated ,32 ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,activated ,32 ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,activated ,32 ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,activated ,32 ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,activated ,32 ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,activated ,32 ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,activated ,32 ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,activated ,32 ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,activated ,32 ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,activated ,32 ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,activated ,32 ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,activated ,32 ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,activated ,32 ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,activated ,32 ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,activated ,32 ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,activated ,32 ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,activated ,32 ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,activated ,32 ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,activated ,32 ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,activated ,32 ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,activated ,32 ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,activated ,32 ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,activated ,32 ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,activated ,32 ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,activated ,32 ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,activated ,32 ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,activated ,32 ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,activated ,32 ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,activated ,32 ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,activated ,32 ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,activated ,32 ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,activated ,32 ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,activated ,32 ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,activated ,32 ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,activated ,32 ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,activated ,32 ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,activated ,32 ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,activated ,32 ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,activated ,32 ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,activated ,32 ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,activated ,32 ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,activated ,32 ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,activated ,32 ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,activated ,32 ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,activated ,32 ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,activated ,32 ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,activated ,32 ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,activated ,32 ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,activated ,32 ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,activated ,32 ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,activated ,32 ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,activated ,32 ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,activated ,32 ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,activated ,32 ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,activated ,32 ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,activated ,32 ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,activated ,32 ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,activated ,32 ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,activated ,32 ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,activated ,32 ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,activated ,32 ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,activated ,32 ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,activated ,32 ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,activated ,32 ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,activated ,32 ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,activated ,32 ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,activated ,32 ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,activated ,32 ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,activated ,32 ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,activated ,32 ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,activated ,32 ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,activated ,32 ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,activated ,32 ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,activated ,32 ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,activated ,32 ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,activated ,32 ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,activated ,32 ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,activated ,32 ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,activated ,32 ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,activated ,32 ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,activated ,32 ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,activated ,32 ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,activated ,32 ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,activated ,32 ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,activated ,32 ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,activated ,32 ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,activated ,32 ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,activated ,32 ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,activated ,32 ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,activated ,32 ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,activated ,32 ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,activated ,32 ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,activated ,32 ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,activated ,32 ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,activated ,32 ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,activated ,32 ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,activated ,32 ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,activated ,32 ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,activated ,32 ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,activated ,32 ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,activated ,32 ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,activated ,32 ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,activated ,32 ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,activated ,32 ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,activated ,32 ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,activated ,32 ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,activated ,32 ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,activated ,32 ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,activated ,32 ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,activated ,32 ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,activated ,32 ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,activated ,32 ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,activated ,32 ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,activated ,32 ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,activated ,32 ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,activated ,32 ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,activated ,32 ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,activated ,32 ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,activated ,32 ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,activated ,32 ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,activated ,32 ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,activated ,32 ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,activated ,32 ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,activated ,32 ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,activated ,32 ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,activated ,32 ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,activated ,32 ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,activated ,32 ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,activated ,32 ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,activated ,32 ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,activated ,32 ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,activated ,32 ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,activated ,32 ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,activated ,32 ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,activated ,32 ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,activated ,32 ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,activated ,32 ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,activated ,32 ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,activated ,32 ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,activated ,32 ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,activated ,32 ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,activated ,32 ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,activated ,32 ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,activated ,32 ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,activated ,32 ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,activated ,32 ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,activated ,32 ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,activated ,32 ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,activated ,32 ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,activated ,32 ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,activated ,32 ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,activated ,32 ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,activated ,32 ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,activated ,32 ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,activated ,32 ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,activated ,32 ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,activated ,32 ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,activated ,32 ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,activated ,32 ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,activated ,32 ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,activated ,32 ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,activated ,32 ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,activated ,32 ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,activated ,32 ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,activated ,32 ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,activated ,32 ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,activated ,32 ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,activated ,32 ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,activated ,32 ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Powertrain data bus ,2 ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2 ENG152379-MV-EM_adaption_48V_zero_potential,regular operation ,1 ENG137850-MVK_Warning,regular operation ,1 ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1 ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1 ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8 ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8 ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8 ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8 ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8 ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8 Elapsed Time: 00:34 Multumesc!
https://vwforum.ro/topic/138432-scanarea-cu-vcds-erori-aparute/
Salutare! Ma puteti ajuta va rog cu aceasta eroare: Address 19: CAN Gateway Labels: 3Q0-907-530-V1.clb Control Module Part Number: 3Q0 907 530 AC HW: 3Q0 907 530 C Component and/or Version: GW MQB High 518 5388 Software Coding: 030100040B087300EF00025E080F00010001000000000000000000000000 Work Shop Code: WSC 12345 123 12345 ASAM Dataset: EV_GatewNF 013026 (VW37) ROD: EV_GatewNF_VW37.rod VCID: 70E58D02ABA31A0D72-8024 1 Fault Found: 131593 - Multifunction Module U1301 00 [009] - No Communication at Second Databus Connection [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 91 Mileage: 126682 km Date: 2026.09.06 Time: 11:43:48 Terminal 30 power supply: 12.1 V Terminal 15: On Eroarea a aparut dupa ce am inlocuit CAN Gateway din seria 5Q0 cu unul mai nou din seria 3Q0. Am montat si acel modul(4B) in sperata ca voi scapa de eroare, insa tot nu am reusit sa scap de ea.. ;SW:3Q0-907-530-AC HW:3Q0-907-530-C --- CAN Gateway ;Component:GW MQB High 518 5388, Coding:030100040B087300EF00025E080F00010001000000000000000000000000 ;EV_GatewNF,013026,EV_GatewNF_VW37.rod ;Sunday,06,September,2026,11:55:39:00009 ;VCDS Version: Release 22.10.0 Data version: 20221026 DS344.0 ;VCID: 70E58D02ABA31A0D72-8024 IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3 IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3 IDE00002-Transport mode,not active ,1 IDE00820-MAS01172-Activating and deactivating all development messages-Development messages,not active ,1 IDE00820-ENG98891-Activating and deactivating all development messages-Reserved,0 ,1 IDE01211-Static current measuring mode,not activated ,1 IDE01457-Energy management deactivation stage,Mode not active ,1 IDE01459-Energy management heat output control status,Mode not active ,1 IDE01844-Increase idle speed request,Mode not active ,1 IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3 IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3 IDE01860-Generator specified voltage value variable,10.6 V,1 IDE01996-SFT00001-Installation list: specified installations-Engine Electronics,coded ,32 IDE01996-SFT00002-Installation list: specified installations-Transmission Electronics,Not coded ,32 IDE01996-SFT00003-Installation list: specified installations-Brake electronics,coded ,32 IDE01996-SFT00006-Installation list: specified installations-Seat adjustment: passenger's side,Not coded ,32 IDE01996-SFT00008-Installation list: specified installations-Climate Control Module,coded ,32 IDE01996-SFT00009-Installation list: specified installations-Electronic central electric,coded ,32 IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32 IDE01996-SFT00014-Installation list: specified installations-Media Player 1,Not coded ,32 IDE01996-SFT00019-Installation list: specified installations-Distance Regulation,coded ,32 IDE01996-SFT00020-Installation list: specified installations-Wheel Damping Electronics,Not coded ,32 IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32 IDE01996-SFT00022-Installation list: specified installations-Steering column electronics systems,coded ,32 IDE01996-SFT00023-Installation list: specified installations-Instrument cluster,coded ,32 IDE01996-SFT00024-Installation list: specified installations-Auxiliary/parking heating,Not coded ,32 IDE01996-SFT00025-Installation list: specified installations-Data Bus OBD Interface,1 ,32 IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32 IDE01996-SFT00032-Installation list: specified installations-High beam assistant,Not coded ,32 IDE01996-SFT00033-Installation list: specified installations-Battery management 2,Not coded ,32 IDE01996-SFT00034-Installation list: specified installations-All-wheel drive electronics,Not coded ,32 IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32 IDE01996-SFT00038-Installation list: specified installations-Convertible top operation,Not coded ,32 IDE01996-SFT00043-Installation list: specified installations-Steering column lock,Not coded ,32 IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32 IDE01996-SFT00050-Installation list: specified installations-Differential lock electronics,Not coded ,32 IDE01996-SFT00054-Installation list: specified installations-Seat adjustment: driver side,Not coded ,32 IDE01996-SFT00060-Installation list: specified installations-Lane change assistance,coded ,32 IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32 IDE01996-SFT00064-Installation list: specified installations-A/C compressor,Not coded ,32 IDE01996-SFT00066-Installation list: specified installations-Driver's door electronics,coded ,32 IDE01996-SFT00068-Installation list: specified installations-Power steering,coded ,32 IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32 IDE01996-SFT00075-Installation list: specified installations-Multi-function module,coded ,32 IDE01996-SFT00075-Installation list: specified installations-Multi-function module,coded ,32 IDE01996-SFT00081-Installation list: specified installations-Electric drive,Not coded ,32 IDE01996-SFT00082-Installation list: specified installations-Passenger's door electronics,coded ,32 IDE01996-SFT00085-Installation list: specified installations-Headlamp range control,coded ,32 IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32 IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32 IDE01996-SFT00095-Installation list: specified installations-Information electronics 1,coded ,32 IDE01996-SFT00096-Installation list: specified installations-Trip recorder,Not coded ,32 IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring System (TPMS),Not coded ,32 IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32 IDE01996-SFT00108-Installation list: specified installations-Rear view camera system,coded ,32 IDE01996-SFT00109-Installation list: specified installations-Rear lid electronics,Not coded ,32 IDE01996-SFT00117-Installation list: specified installations-Emergency call module and communication unit,Not coded ,32 IDE01996-SFT00118-Installation list: specified installations-Parking aid,coded ,32 IDE01996-SFT00128-Installation list: specified installations-Battery control additional memory 1,Not coded ,32 IDE01996-SFT00130-Installation list: specified installations-Head-Up-Display,Not coded ,32 IDE01996-SFT00140-Installation list: specified installations-Hybrid Battery Management,Not coded ,32 IDE01996-SFT00165-Installation list: specified installations-Front sensor for drivers assistant systems,coded ,32 IDE01996-SFT00166-Installation list: specified installations-Microphone control module,Not coded ,32 IDE01996-SFT00169-Installation list: specified installations-Structure-borne sound actuator,Not coded ,32 IDE01996-SFT00183-Installation list: specified installations-Interface for access/start system,Not coded ,32 IDE01996-SFT00187-Installation list: specified installations-Rear drivers side door electronics,Not coded ,32 IDE01996-SFT00188-Installation list: specified installations-Rear passenger side door electronics,Not coded ,32 IDE01996-SFT00189-Installation list: specified installations-High-voltage battery charging management,Not coded ,32 IDE01996-SFT00190-Installation list: specified installations-Left rear sliding door,Not coded ,32 IDE01996-SFT00191-Installation list: specified installations-Right rear sliding door,Not coded ,32 IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32 IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32 IDE01996-SFT00198-Installation list: specified installations-High-voltage battery charger,Not coded ,32 IDE01996-SFT00202-Installation list: specified installations-Sunroof control module,Not coded ,32 IDE01996-SFT00204-Installation list: specified installations-Starter generator,Not coded ,32 IDE01996-SFT00207-Installation list: specified installations-Lane Change Assistant 2,Not coded ,32 IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32 IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32 IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32 IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32 IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32 IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32 IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32 IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32 IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32 IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32 IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32 IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32 IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32 IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32 IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32 IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32 IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32 IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32 IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32 IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32 IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32 IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32 IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32 IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32 IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32 IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32 IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32 IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32 IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32 IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32 IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32 IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32 IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32 IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32 IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32 IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32 IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32 IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32 IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32 IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32 IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32 IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32 IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32 IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32 IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32 IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32 IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32 IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32 IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32 IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32 IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32 IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32 IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32 IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32 IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32 IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32 IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32 IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32 IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32 IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32 IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32 IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32 IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32 IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32 IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32 IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32 IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32 IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32 IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32 IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32 IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32 IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32 IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32 IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32 IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32 IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32 IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32 IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32 IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32 IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32 IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32 IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32 IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32 IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32 IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32 IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32 IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32 IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32 IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32 IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32 IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32 IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32 IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32 IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32 IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32 IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32 IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32 IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32 IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32 IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32 IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32 IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32 IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32 IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32 IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32 IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32 IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32 IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32 IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32 IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32 IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32 IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32 IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32 IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32 IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32 IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32 IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32 IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32 IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32 IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32 IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32 IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32 IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32 IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32 IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32 IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32 IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32 IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32 IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32 IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32 IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32 IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32 IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32 IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32 IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32 IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32 IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32 IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32 IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32 IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32 IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32 IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32 IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32 IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32 IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32 IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32 IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32 IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32 IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32 IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32 IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32 IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32 IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32 IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32 IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32 IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32 IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32 IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32 IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32 IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32 IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32 IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32 IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32 IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32 IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32 IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32 IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32 IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32 IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32 IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32 IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32 IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32 IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32 IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32 IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32 IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32 IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32 IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32 IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32 IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32 IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32 IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32 IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32 IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32 IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32 IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32 IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32 IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32 IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32 IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32 IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32 IDE02332-Deactivate production mode,0 ,3 IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah,15 IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15 IDE03256-MAS06107-Battery adaptation-Battery manufacturer, ,15 IDE03256-MAS06108-Battery adaptation-Battery Serial Number, ,15 IDE03903-Production process data 1,00 00 ,2 IDE04159-Deactivation of start/stop function,Mode not active ,1 IDE04186-Battery terminal recognition,connected ,1 IDE04330-Transfer of release code for a SWaP function,00 ,1 IDE04331-Selection of release codes for a SWaP function,FF FF FF FF ,4 IDE06530-Distance left for deactivation of static current measuring mode,2 ,1 IDE06541-Distance left for deactivation of transport mode,50 ,1 IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4 IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4 IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4 IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4 IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4 IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4 IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated ,4 IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4 IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4 IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4 IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4 IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4 IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4 IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4 IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4 IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,not activated ,4 IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4 IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4 IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,activated ,4 IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4 IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4 IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4 IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4 IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated ,4 IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,not activated ,4 IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4 IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4 IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4 IDE07838-Counter for inconsistent states,42 ,2 IDE08348-Start/stop start voltage limit,7.6 V,1 IDE08624-MKE Check box,activated ,1 IDE10735-Number requests autonomous recharging,3 ,1 IDE10736-Cyclization limitation request battery service,0 ,1 IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3 IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3 IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3 IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3 IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3 IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3 IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3 IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3 IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3 IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3 IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3 IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3 IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3 IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,activated ,3 IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,activated ,3 IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,activated ,3 IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3 IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3 IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3 IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3 IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3 IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3 IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,activated ,3 IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,activated ,3 IDE11689-48V-System: locking,regular operation ,1 IDE13756-Diagnosis filter: activation,not active ,1 IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production,200 km,2 IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service,20 km,2 MAS16372-Security version number,3 ,2 SFT271921-IDE02583-Multifunction steering wheel control module-Steering wheel Tiptronic switch,not installed ,3 SFT271921-MAS02311-Multifunction steering wheel control module-Steering wheel heating button,not active ,3 SFT271921-MAS04733-Multifunction steering wheel control module-Two-stage,Unknown (3),3 SFT271921-MAS06614-Multifunction steering wheel control module-Variant,ACC ,3 SFT271921-MAS09758-Multifunction steering wheel control module-Temperature sensor,not installed ,3 SFT271921-MAS13892-Multifunction steering wheel control module-Platform,Unknown (3),3 SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function,active ,3 SFT271921-MAS19104-Multifunction steering wheel control module-Alarm horn wake-up function,active ,3 SFT271921-ENG258379-Multifunction steering wheel control module-clamp behaviour,active with terminal 58 ,3 SFT271921-ENG260738-Multifunction steering wheel control module-FoD ACC,activated ,3 SFT271921-ENG258784-Multifunction steering wheel control module-FoD Travel Assist,activated ,3 SFT271921-ENG262857-Multifunction steering wheel control module-Kombi_02_gueltig,active ,3 ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12 ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,40 ,12 ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12 ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12 ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,10000 ms,12 ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12 ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12 ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12 ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,2000 ms,12 ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,10000 ms,12 ENG137060-ENG113874-EM_energy_management_warning_displays-Battery reports,Mode not active ,4 ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4 ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4 ENG137060-ENG98711-EM_energy_management_warning_displays-State of Charge (SOC),Mode not active ,4 ENG137075-EM_heating_power_quota_adjustment,1000 W,1 ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1 ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1 ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1 ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Electronics,activated ,32 ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Electronics,activated ,32 ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brake electronics,not activated ,32 ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat adjustment: passenger's side,activated ,32 ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Climate Control Module,activated ,32 ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Electronic central electric,activated ,32 ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,activated ,32 ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player 1,activated ,32 ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Distance Regulation,activated ,32 ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Damping Electronics,activated ,32 ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not activated ,32 ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering column electronics systems,activated ,32 ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Instrument cluster,activated ,32 ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary/parking heating,activated ,32 ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Data Bus OBD Interface,activated ,32 ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,activated ,32 ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High beam assistant,activated ,32 ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery management 2,activated ,32 ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All-wheel drive electronics,activated ,32 ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,activated ,32 ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Convertible top operation,activated ,32 ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering column lock,activated ,32 ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,activated ,32 ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Differential lock electronics,activated ,32 ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat adjustment: driver side,activated ,32 ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane change assistance,activated ,32 ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,activated ,32 ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-A/C compressor,activated ,32 ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Driver's door electronics,activated ,32 ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Power steering,activated ,32 ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,activated ,32 ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32 ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multi-function module,activated ,32 ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Electric drive,activated ,32 ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Passenger's door electronics,activated ,32 ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlamp range control,activated ,32 ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,activated ,32 ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,activated ,32 ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information electronics 1,activated ,32 ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Trip recorder,activated ,32 ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring System (TPMS),activated ,32 ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,activated ,32 ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Rear view camera system,activated ,32 ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Rear lid electronics,activated ,32 ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Emergency call module and communication unit,activated ,32 ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking aid,activated ,32 ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery control additional memory 1,activated ,32 ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head-Up-Display,activated ,32 ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Hybrid Battery Management,activated ,32 ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front sensor for drivers assistant systems,activated ,32 ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone control module,activated ,32 ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Structure-borne sound actuator,activated ,32 ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Interface for access/start system,activated ,32 ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Rear drivers side door electronics,activated ,32 ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Rear passenger side door electronics,activated ,32 ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High-voltage battery charging management,activated ,32 ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Left rear sliding door,activated ,32 ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Right rear sliding door,activated ,32 ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,activated ,32 ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,activated ,32 ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-High-voltage battery charger,activated ,32 ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Sunroof control module,activated ,32 ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter generator,activated ,32 ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,activated ,32 ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,activated ,32 ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,activated ,32 ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,activated ,32 ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,activated ,32 ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,activated ,32 ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,activated ,32 ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,activated ,32 ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,activated ,32 ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,activated ,32 ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,activated ,32 ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,activated ,32 ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,activated ,32 ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,activated ,32 ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,activated ,32 ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,activated ,32 ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,activated ,32 ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,activated ,32 ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,activated ,32 ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,activated ,32 ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,activated ,32 ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,activated ,32 ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,activated ,32 ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,activated ,32 ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,activated ,32 ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,activated ,32 ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,activated ,32 ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,activated ,32 ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,activated ,32 ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,activated ,32 ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,activated ,32 ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,activated ,32 ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,activated ,32 ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,activated ,32 ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,activated ,32 ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,activated ,32 ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,activated ,32 ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,activated ,32 ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,activated ,32 ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,activated ,32 ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,activated ,32 ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,activated ,32 ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,activated ,32 ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,activated ,32 ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,activated ,32 ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,activated ,32 ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,activated ,32 ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,activated ,32 ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,activated ,32 ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,activated ,32 ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,activated ,32 ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,activated ,32 ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,activated ,32 ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,activated ,32 ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,activated ,32 ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,activated ,32 ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,activated ,32 ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,activated ,32 ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,activated ,32 ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,activated ,32 ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,activated ,32 ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,activated ,32 ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,activated ,32 ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,activated ,32 ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,activated ,32 ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,activated ,32 ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,activated ,32 ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,activated ,32 ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,activated ,32 ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,activated ,32 ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,activated ,32 ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,activated ,32 ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,activated ,32 ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,activated ,32 ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,activated ,32 ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,activated ,32 ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,activated ,32 ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,activated ,32 ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,activated ,32 ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,activated ,32 ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,activated ,32 ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,activated ,32 ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,activated ,32 ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,activated ,32 ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,activated ,32 ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,activated ,32 ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,activated ,32 ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,activated ,32 ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,activated ,32 ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,activated ,32 ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,activated ,32 ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,activated ,32 ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,activated ,32 ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,activated ,32 ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,activated ,32 ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,activated ,32 ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,activated ,32 ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,activated ,32 ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,activated ,32 ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,activated ,32 ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,activated ,32 ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,activated ,32 ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,activated ,32 ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,activated ,32 ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,activated ,32 ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,activated ,32 ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,activated ,32 ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,activated ,32 ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,activated ,32 ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,activated ,32 ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,activated ,32 ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,activated ,32 ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,activated ,32 ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,activated ,32 ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,activated ,32 ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,activated ,32 ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,activated ,32 ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,activated ,32 ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,activated ,32 ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,activated ,32 ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,activated ,32 ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,activated ,32 ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,activated ,32 ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,activated ,32 ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,activated ,32 ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,activated ,32 ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,activated ,32 ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,activated ,32 ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,activated ,32 ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,activated ,32 ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,activated ,32 ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,activated ,32 ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,activated ,32 ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,activated ,32 ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,activated ,32 ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,activated ,32 ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,activated ,32 ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,activated ,32 ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,activated ,32 ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,activated ,32 ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,activated ,32 ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,activated ,32 ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,activated ,32 ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,activated ,32 ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,activated ,32 ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,activated ,32 ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,activated ,32 ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,activated ,32 ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,activated ,32 ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,activated ,32 ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,activated ,32 ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,activated ,32 ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,activated ,32 ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,activated ,32 ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,activated ,32 ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,activated ,32 ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,activated ,32 ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,activated ,32 ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,activated ,32 ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,activated ,32 ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,activated ,32 ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,activated ,32 ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,activated ,32 ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,activated ,32 ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,activated ,32 ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,activated ,32 ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,activated ,32 ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,activated ,32 ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,activated ,32 ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,activated ,32 ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,activated ,32 ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,activated ,32 ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,activated ,32 ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,activated ,32 ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,activated ,32 ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,activated ,32 ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,activated ,32 ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,activated ,32 ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,activated ,32 ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,activated ,32 ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,activated ,32 ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,activated ,32 ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,activated ,32 ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,activated ,32 ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,activated ,32 ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,activated ,32 ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,activated ,32 ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,activated ,32 ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,activated ,32 ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,activated ,32 ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,activated ,32 ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,activated ,32 ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,activated ,32 ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Powertrain data bus ,2 ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2 ENG152379-MV-EM_adaption_48V_zero_potential,regular operation ,1 ENG137850-MVK_Warning,regular operation ,1 ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1 ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1 ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8 ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8 ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8 ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8 ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8 ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8 Elapsed Time: 00:34
Salut, Am un B8 din 2016 si as vrea sa ii pun lumini ambientale dar doar pe trimurile de la portiere (vreau doar lumina alba) si sa pot regla intensitatea din setari. Se poate facea asa ceva? Cam ce costruri ar fi? -
Scuze, nu am vazut postarea ta. Legaturile sunt facute cu pinii originali in mufa de la maneta (avea pini in toate locasurile goale), fire luate dintro alta instalatie auto demolata, mufa de la centrala a fost cumparata noua, iar pini am avut eu. Si da, am pus si dioda. Firul spre ECU e dus direct, nu am mai trecut prin mufa intermediara T11a.
Am pe masina radioul RCD 300, original din fabrica cod de la VCDS 5M0 035 186 A - nu i-am vazut codul, masina cea din semnatura, nu am nici o eroare pe nici un modul, inclusiv la radio, dar cand pornesc masina se inchide pentru scurt timp daca radioul este pornit si porneste imediat, are asa o pauza de 2-3 secunde pana porneste motorul. Imi dau seama ca se intampla pentru ca scade tensiunea, dar bateria este incarcata, scade pe la 10.6-10.9Vcc, asa face si faca scade pe la 11.6Vcc. Asa a facut dintotdeauna, de cand am cumparat-o. Este normal sa faca asa sau sa ma apuc sa verific cel putin condensatoarele electrolitice ale radioului RCD 300?
50 de ani de GOLF GTI organizat de PIA. Super eveniment cu o organizare ireprosabila realizata de domnul Mirea Ionut. Am ajuns ieri in jurul orelor 08:00 la PBV unde am stat de vorba cu mai multi baieti (va salut daca cititi topicul ) De acolo, am mers frumos in formatie de cate 10 masini catre PBN unde am stat pana pe dupa-amiaza.
Daca vrei ajutor, ar trebui sa raspunzi la intrebarile adresate.
Tempomat montat pe Lupo 3L 1.2 TDI cu cutie robotizata (asa zis automata). Asa a fost cumparata masina de afara (probabil acolo s-a montat tempomatul).
Da, este foarte adevărat și ce spui tu @Cristi_V cu punctul de fierbere, nu doar cel de îngheț. Mă gândesc că înainte să completeze cu acel litru de apă distilată (au pus doar apă distilată, nu și antigel din ce reiese din fișa de care am făcut vorbire) au verificat proprietățile lichidului de răcire pentru că, după cum am spus, am cerut și revizie nu doar schimbul de ulei. Am înțeles! Trebuie cerut un test și în funcție de ce se constată să se procedeze în consecință. Nu mai sunt iernile care erau odată de crăpau pietrele, dar nici să ne culcăm pe o ureche că nouă nu ni se întâmplă că-s iernile blânde. Lichidul de răcire la ce perioadă de timp/km rulați se schimbă? -24 e aproape jumătatea lui -38, însă bănuiesc că depinde de ce și cum recomandă producătorul.
Este garantie? Daca da, la oricare.
Se verifica cu densimetrul si se regleaza proportia in functie de temperatura dorita. Nu se completează cu antigel ci cu lichid de răcire adica amestec antigel-apa distilata în proporțiile dorite 50-50 pentru -38C sau 40-60 pentru -24C. Temperaturile pot diferi in functie de antigelul utilizat. In general, in caz de urgenta, daca nu ai amestec, se completeaza, provizoriu, cu apa distilata dar apoi te duci la service. Nu contează numai temperatura de îngheț ci și cea de fierbere.
In general eu stiu ca se completeaza cu antigel. Asa mi-au completat si la alte marci. Teoretic daca s-a pus apa distilata, s-a modificat punctul de inghet. Dar poti face testul cum ai zis. Eu am avut o problema la o alta masina acum ceva ani si fiind pe drum am pus apa plata, ca nu gasisem antigel G11 ce aveam in masina. Pusesem cam 2 litri, dupa cand am facut testul, rezista inca la -27 de grade.
Evident ca a crescut temperatura de inghet a amestecului. Am patit-o si eu sa imi completeze cu antigel la revizie, cateva sute de ml, desi nu am avut martor aprins, iar antigelul era la acelasi nivel de cand am masina.
Care reprezentanță Škoda / VW din București considerați că are cei mai meticuloși diagnozisti pe climatizare pentru o problemă recurentă de pierdere de freon și diferențe de temperatură stânga-dreapta la un Superb iV plug-in hybrid — Avia Motors (Pantelimon sau Militari), Metrotehnica sau rețeaua Porsche (PBV1 / PBN)?
Buna seara dragi colegi! Baloo "se simte" foarte bine dupa revizia majora pe care a primit-o, fiind folosit zilnic. Porneste "la sfert", desi bujiile incandescente si cele 2 baterii nu stiu daca au fost schimbate vreodata, in teancul facturilor de servisare din istoric nu au fost mentionate. Toate facturile pe care le are masina sunt legate de service anual, ulei+filtre, o servisare AC, discuri si placute fata, o inlocuire valva EGR si anvelope schimbate in 2020. In rest, masina e originala, de aici am preluat-o eu la 92 000 km in 2023. In prezent avem parcursi 135 000 km. Viata celor 2 baterii+incarcarea au fost verificate si sunt optime, s-a facut diagnoza generala si masina se prezinta perfect. Toate fluidele si filtrele au fost schimbate (ulei motor+ service complet cutie de viteze+diferentialul Quattro) lichid frana, antigel, anvelope, discuri frana+placute spate noi schimbate anul trecut, sistemul complex de AC a fost servisat/igienizat + freon, verificat compresor+etansari, inlocuit becuri xenon, inlocuit traseu conducte spalatoare faruri si... cam atat. Masinoiul a fost pregatit din nou de "mancat pe paine" 5000 de KM traversat 2 tari de la N la S si invers (UK-Franta si retur) + plimbari/explorari pe Riviera Franceza (Coasta de Azur). Asa cum v-am obisnuit, imi place sa merg in concediu la final de august, inceput de septembrie deoarece trece "valul de turisti" vorba vine, peste tot e rezervat FULL pana la final de septembrie, dar vremea e perfecta, rar sare temperatura de 32 de grade si Mediterana e "calaie". Copiii incep scoala astfel "galagia" dispare si putem sa ne relaxam in voie. Este a 3-a excursie pe care o fac la bordul Phaetonului in Sudul Frantei, speram si vara viitoare sa ajungem pe aici. ❤️ Am facut asigurari de calatorie, am rezervat cazare tot la camping in Ramatuelle, in "inima" rurala a Saint-Tropezului, langa plaja, am verificat asigurarea RCA+asigurarea de recovery valabile in Europa, sticker UK pe bara, taxa de poluare pentru Franta o aveam platita din anii trecuti, inca am stickerul pe parbriz. Am rezervat feribotul dus-intors, am rezervat hotelurile pentru popas, la dus in Dijon la Holliday Inn, la intoarcere B&B in Reims, strategic, cam la 2 treimi din drum, sa nu fiu nevoit sa stau mai mult de 10 ore pe autostrazi intr-un singur sens, luand in considerare tot felu' de neprevazute. As putea sa fac drumul dintr-o bucata, sa castig inca 2 zile de concediu, dar imi ajung 2 saptamani, imi place sa ma relaxez, sa plec "cu timp", sa nu ma grabesc, sa ajung la o ora decenta la hotel, sa pot sa stau pe terasa sa savurez o haleala si o bere buna, sa ma odihnesc si a 2-a zi iar la drum spre destinatia finala. Am incarcat "o tona" de bagaje, nevasta-mea isi ia toata "casa" dupa ea, vorba aia, avantajul unei masini mari! Pe langa bagajele "aferente", am pus si scaunele de plaja pliabile+umbrelele de plaja si LA DRUM spre feribot, cand "se crapa" de ziua, speram sa ajung la Dover pe la 10 pentru traversarea Canalului Manecii spre Franta. Am lasat orasul aglomerat in spate, o poza facuta cu o zi inainte de plecare: Am "urcat" pe autostrada la 5 AM, am prins rasaritul pe autostrada: Freza mea de dimineata pana sa opresc sa iau o cafea😄: O sa va arat o poza cu bagajele scoase din masina, la o urmatoare postare de la cazare, asa arata portbagajul in care au intrat scaunele+umbrelele de plaja, 2 trollere mari, 2 trollere de avion (cabina), geanta FRIGO, o sacosa maricica, si o punga in care am luat 1 litru antigel, 1 litru apa deionizata si 1 litru de ulei, "just in case", am avut o gramada de bagaje si in spate: Auzeam la radio ca aeroporturile sunt full, intarzieri, probleme, cateva poze de langa Heathrow, am prins ora de varf, dimineata, am stat vreo 20 de minute in coloana, nevastamea a facut niste poze avioanelor care decolau din minut in minut: Si un Airbus A380, Queen of the Sky: Trafic "de tot felu"...cateva poze random de pe traseu in UK, am vazut sute de supercaruri, am reusit sa surprind cateva, vor urma altele si din Franta, stay tuned: Oare ce avea de transportat? Mai vazusem unul similar din sens opus, transporta un IAHT! Si un Revuelto: Asa a "picat" numarul: Altii care mergeau la camping, am vazut sute de rulote, camper vanuri, tent box, caiace pe masini etc: Camper TRUCKS "camion": Electrice: Mai putin electrice: Am alimentat si am resetat KM, 384 km/h facuti de la resetare, 900 KM range, am reusit sa fac 1200 km cu un plin, mai aveam 150 km range, 110-120 km/h setat pe pilot automat, mers relaxat, consum mediu: Dupa 500 de KM, am ajuns la vama franceza in DOVER spre CALAIS, am asteptat vreo ora, fiind foarte aglomerat, am pus Phaetonul la "incarcat" desi mai aveam 700 km range, glumesc, pauza de pipi si cafea: Traseul pana la feribot: Am urcat pe Ferry, "Bon voyage!" See you in France! Va urma!
Salut! O întrebare. La ultima revizie pe care am făcut-o la mașină, acum vreo două luni (schimbul de ulei și o verificare), mi s-a completat antigelul cu un litru de apă distilată. Nu știu de ce că eu verific periodic și nu era vasul gol, ci nivelul unde trebuia sa fie. E trecut în fișa de lucru pe care am primit-o la deschiderea comenzii acel litru de apă. E vorba de reprezentanță. Întrebarea e dacă prin asta s-a diluat antigelul crescându-i punctul de îngheț? Revizia a trecut, urmează alta la anul, și voiam să știu dacă e ok la iarnă. Urmează să merg cu mașina la service pentru a chestiune de garanție și mă gândeam să cer o verificare a proprietăților lichidului de răcire. Podibil ca întrebarea să nu facă obiectul topicului, iar dacă e unul pe subiect rog moderatorii să mă îndrume acolo.
Salutare ! noutăți legate de egr și filtrul de particule ?
Foarte mare consumul , eu cu rulota in spate ( 1350 kg ) am avut 10-11L/100 km consum .
Salut dacă tot ai schimbat deja întinzător/alternator/role/fulie și tot rupe, pe T5 2.0 TDI merită să verifici dacă ai kitul după TPI 2041442 (curea scurtă + întinzător modificat + scuturi), nu doar piese «ca alea vechi». Am rulat cazul pe Diaglo: https://diaglo.ai/report/DX-2013-VW-TRANS-H9W4D — uită-te la verdict. Alinierea rolelor/fuliei rămne de confirmat vizual.
- Săptămâna asta
Toro a ajuns prin Grecia. Zona de nord, Tracia. Am facut si cateva plimbari prin zona. Foarte spectaculos a fost un drum pe deasupra cheilor Nestos-ului. Drum ingust, de cca. 4 m, asfaltat ca-n palma, in cea mai mare parte (95%), plin de serpentine, urcusuri si coborari. Si cu niste privelisti suprebe. E de facut numai pentru aceste privelisti. Destul de lung, vreo 30 km.
Am legat la pinul 76 si am eroarea 17977 - tempomat semnal implauzibil. In grupurile de masura, in 066, când am contactul pus și maneta pe ON, configurațiile sunt: Câmpul 4 = 10000000 ➡️ Confirmă că pe pinul pe care l-am ales pentru manetă (Pinul 76) intră un semnal fix de 12V (Main Switch ON). Câmpul 2 = 11001000 (Pedale libere) / 11001111 (Pedale călcate). Am masurat semnalele ce ajung la ECU de la pedale, in pinii 39, 55 si 56 si totul este corect. In Centrala electrica nu vede deloc semnalele de la maneta. Nici in ECU nu le vede. Gandesc ca e posibil ca circuitul in care intra semnalele de la maneta in Centrala sa fie ars/dus cu sorcova si de aceea ECU raporteaza eroarea respectiva, dupa ce face crosscheck-ul. Am gasit alta centrala, cu D la urma, dar mufa XS3 difera fata de cea actuala, deci nu o pot folosi. Este posibil ca BBU sa foloseasca alte legaturi direct la ECU?
adrian001 a postat în topic iniţiat de Larves din Motoare pe benzina
Poate e american mecanicul 😛, ~87 PSI = 6 bari -
EEXCALADE a postat în topic iniţiat de Larves din Motoare pe benzina
80/90 bari 😀 nu exista astfel de presiuni . Nu stii ce sa masurat . Cere test de compresie ,nu se poate face cu motorul pornit -
6 bari la relanti, 80/90 bari accelerata
