Hai sa invatam cum sa folosim VCDS
RoSonic
New beta update: 17.12.0.
Citat:
Beta 17.12.0 adds the following improvements:
Additional Info for some Fault Codes from UDS modules
... most often "Missing Message" type codes. Example (the third line, in boldface, is new):
0314 - Function Restricted due to Missing Message(s)
  U1111 00 [009] - -
  [Sensor fuer Luftfeuchte aussen: kein Signal / Kommunikation]
  Confirmed - Tested Since Memory Clear
Right now this data will most often appear in German, but it should become translatable at some point.   This new data is only available with current generation (HEX-NET or HEX-V2) interfaces.
New ODX data (DS285.1) to support the above.
... as well as some fixes for sub-system ("slave") modules descriptors.
New protocol option for HEX-NET & HEX-V2 Interfaces
... "Char Int 2k" replaces Char Int and controls interbyte timing in Kline-KWP2000. Makes VCDS compatible with Polo/Fabia ABS on virtualized K-line.
Automatic re-enabling of buttons that launch LCode and VC-Scope
... previously it was necessary to back out one level beyond the screen from which these were launched from if one wanted to re-launch them after they were closed.
Graphing and Logging are now available simultaneously
... when VCDS is used with a current-generation (HEX-NET or HEX-V2) interface.
New versions of Niels Ezerman's VCDSScan toolbox and LCode utilities
Fixes for sporadic "Invalid" values when reading grouped UDS measuring values.
Over a dozen new UDS addresses.
New & improved Label Files.
Am un golf 5 din 2004 si ma tot macina faptul ca mi-ar trebui o interfata de vcds sa ma "joc" putin prin mintea masinii.
Intrebarea: Ce varianta de vcds ar trebui sa achizitionez pt aceasta masina, nu stiu ce face o varianta sau alta. Nu vreau sa imi cumpar o versiune care nu am la ce sa o folosesc, imi trebuie ceva cu care pot sa cotrobai la masina mea.
Daca ma puteti ajuta cu un sfat, va multumesc!
una originala de la ross-tech.
Va readuc aminte ca aici se discuta doar despre interfete originale si atat.
Pentru erori si interpretarea lor exista topicuri dedicate atat in aria TDI cat si in Motoare pe benzina.
Va multumesc pentru intelegere! :)
The Current version is:
Release 18.1.0
Data Version 20180122
Release 18.2.0
Data Version 20180212
Buna ziua! Imi puteti spune ce pasi ar trebui urmati pt. o instalare fara probleme a unei interfete? Am inteles ceva in legatura cu antivirusul si internetul care trebuie oprite. Va multumesc anticipat!
Instalezi interfata, next-nex/Finish.
Apoi instalezi antivirus si lasi si internetul pornit ca sa isi faca update.
Succes!
La un Touran din 2004 cum as putea modifica cu VAG COM -ul timpul de bipait al centurii la 5 sec si apoi sa se opreasca daca nu este pusa centura ? Acum am martor in bord si pipaie 1 min.
La un audi A4 B8 2011 ,vreau sa activez si eu lock/unlock sound si sa imi apara si pe mmi aceasta optiune de activare si dezactivare
Nu merge. Nu iti poate apare in mmi. La fel de bine poate sa nici nu functioneze-blink and horn.
Am alarma de fabrica, semnalele se aprind la armare si dezarmare, eu vreau si sunet...
Am inteles ce vrei. Eu iti spuneam ca nu se poate activa astfel incat sa poata fi operata din mmi. Cred ca am fost suficient de clar. BTW-topicul acesta nu este ptr codari. Vezi sectiunea dedicata din aria a4.
Salutare, aveti idee de ce nu pot accesa sectiunea de loggin a ceasurilor sa pot face anumite adaptari la GOLF 4? Imi este comunicata eroarea "Login lost due to dropped session" in momentul in care introduc codul de acces comunicat de catre VCDS. Va multumesc.
nu ai ce activari sa faci, la Golf 4, sa necesite cod de login.
Salut.  Am incercat sa codez un RCD300 cu mp3 sa mearga pe aux , am modificat in coding ultima cifra 0 cu 1 si mi-a dat eroare diag pe el :-? ce trebuie facut .
Nu ti-a dat eroare. Cand accesezi unitatea pe ecran apare diag. Asa e normal. Codul ti l-a salvat?
Da, dupa am pus pe 0 la loc si a revenit la normal
identitate78
Ma puteti ajuta cu un cod pentru 09-Centrala Electrica>Security access 16?
Nu imi apare acel pop-up galben care arata codul asa cum se intampla la alte module.
F l o r i n
ce sa faci cu el ?
identitate78
Am niste setari pe are nu le-am facut pentru rain closing si care se gasesc in Security Access.
Poate reusesc sa fac sa mearga...Sunt cele de mai jos:
https://www.golfmk7.com/forums/showthread.php?t=10980
Merci
Multumesc @F l o r i n
Modificat de identitate78
F l o r i n
Din pacate, BCM uri diferite, nu are legatura ce ai gasit entru Golf 7
Nu ai asa ceva la BCM ul tau, nu exista cod de securitate care sa te ajute in acest sens
Cine ma poate ajuta, unde pot vedea in VCDS incarcarea DPF-ului (am masina din semnatura)? Si ce valori sunt normale? *multumesc anticipat*
De asemenea in Advanced, pentru Engine de ex., este Test Ouput si un drop down. Pot sa rulez un test de acolo? (de ex. egr)
