RNS 310 / 315 - Amundsen
mark21
Salut. CAN ul 7N0 907 530AN se potriveste pe un golf 5 din 2004 pe care vreau sa pun un RNS 315 3C8 035 279 AX ?
Can ul e fabricat in 2013 iar RNS ul in dec 2014
Modificat de kamarad
Da se potriveste.Trebuie montat si facute adaptarile in functie de ce ai pe masina.
Ejakab , cum ai rezolvat problema ? De ce se auzea sacadat ?
Din pacata nu stiu, inca nu sa rezolvat problema. Nu a mai aparut de la ultima postare, dar cred ca nu s-a rezolvat problema singur.
Ultima scanare arata o eroare la navigatie, dar este ceva problema la interpretare.
Friday,05,June,2015,11:45:04:30570VCDS -- Windows Based VAG/VAS EmulatorVCDS Version: 12.12.3.0Data version: 20140822VIN: WVWZZZ1KZAM660471   License Plate:Mileage: 192900 km   Repair Order: ----------------------------------------------------------------------------------------------------------------------------------------------------------------Chassis Type: 1K (1K0)Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 61 62 72 77         VIN: WVWZZZ1KZAM660471   01-Engine -- Status: OK 000003-ABS Brakes -- Status: OK 000004-Steering Angle -- Status: OK 000008-Auto HVAC -- Status: OK 000009-Cent. Elect. -- Status: OK 000010-Park/Steer Assist -- Status: OK 000015-Airbags -- Status: OK 000016-Steering wheel -- Status: OK 000017-Instruments -- Status: OK 000019-CAN Gateway -- Status: OK 000025-Immobilizer -- Status: OK 000037-Navigation -- Status: Malfunction 001042-Door Elect, Driver -- Status: OK 000044-Steering Assist -- Status: OK 000046-Central Conv. -- Status: OK 000052-Door Elect, Pass. -- Status: OK 000056-Radio -- Status: OK 000061-Battery Regul. -- Status: OK 000062-Door, Rear Left -- Status: OK 000072-Door, Rear Right -- Status: OK 000077-Telephone -- Status: OK 0000 -------------------------------------------------------------------------------Address 01: Engine (J623-CAYC)       Labels: 03L-906-023-CAY.clb   Part No SW: 03L 906 023 DQ    HW: 03L 906 023 A   Component: 1,6l R4 CR td H23 9638     Revision: --H23---    Serial number: 00000000000000   Coding: 00114036030401080000   Shop #: WSC 00066 000 00195   ASAM Dataset: EV_ECM16TDI02103L 003011   ROD: N/A   VCID: 78F998A2C3A421DEA3D-802DNo ASAM data for: "EV_ECM16TDI02103L" (VW36 *) No fault code found.Readiness: 0000 0000-------------------------------------------------------------------------------Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ   Component: ESP MK60EC1   H30 0107     Revision: 00H30001       Coding: 113B200D092800FA880F04EB901A0051310000   Shop #: WSC 00066 000 00000   VCID: 7AFD82AAF5A833CED59-802FNo fault code found.-------------------------------------------------------------------------------Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb   Part No SW: 5K0 907 044 BT    HW: 5K0 907 044 BT   Component: Climatronic   H15 0709     Revision: 00003001       Coding: 0000000003   Shop #: WSC 00066 000 00185   ASAM Dataset: EV_Climatronic A01006   ROD: EV_ClimaAutoBasis_SE36.rod   VCID: 7EF58EBAE1801FEEE91-802BNo fault code found.-------------------------------------------------------------------------------Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb   Part No SW: 5K0 937 084 B    HW: 5K0 937 084 B   Component: BCM PQ35 B    011 0028     Revision: BA011001       Coding: 00180E3A982D02C040000080400000E403000088625D856264C087000001   Shop #: WSC 00066 000 00000   VCID: 316F6586685E3096243-8064   Subsystem 1 - Part No: 1K1 955 119 F  Labels: 1KX-955-119.CLB   Component: Wischer 10021  21  0512    Coding: 009795No fault code found.-------------------------------------------------------------------------------Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb   Part No SW: 1K9 919 475     HW: 1K9 919 475    Component: PARKHILFE 8K  H07 0001     Revision: --------    Serial number: 90330935309218   Coding: 100002   Shop #: WSC 00066 000 00000   VCID: F8F918A24BA4A1DE23D-80ADNo fault code found.-------------------------------------------------------------------------------Address 15: Airbags (J234)       Labels: 5K0-959-655.clb   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D   Component: AirbagVW10    037 0606     Serial number: 003FKRA1Y20Q     Coding: 00003137   Shop #: WSC 00066 000 00000   ASAM Dataset: EV_AirbaVW10SMEVW360 A01011   ROD: EV_AirbaVW10SMEVW360.rod   VCID: 3B7347AEB212CAC68EF-806E   Crash sensor for side airbag; driver side:    Subsystem 1 - Part No SW: 1KM 955 557     HW: 1KM 955 557    Component: S.Sens.Fahr.V  H01 ----    Serial number: 3572MSME0851644DZZZY   Crash sensor for side airbag; passenger side:    Subsystem 2 - Part No SW: 1KM 955 557     HW: 1KM 955 557    Component: S.Sens.Beif.V  H01 ----    Serial number: 3582MSME5254134EZZZW   Crash sensor for side airbag; rear driver side:    Component: S.Sens.Fahr.H  --- ----    Serial number: 3511HSME0F0C781EZZZ    Crash sensor for side airbag; rear passenger side:    Component: S.Sens.Beif.H  --- ----    Serial number: 3521HSME3231171FZZZFNo fault code found.-------------------------------------------------------------------------------Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ   Component: J0527           053 0111     Coding: 0000004   Shop #: WSC 00066 000 00000   VCID: 83037F4EC262F20606F-80D6No fault code found.-------------------------------------------------------------------------------Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb   Part No SW: 5K0 920 860 J    HW: 5K0 920 860 J   Component: KOMBI         H04 0308     Serial number: 00000000000000   Coding: 170F00   Shop #: WSC 00066 000 00147   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052   ROD: EV_Kombi_UDS_VDD_RM09_VW21.rod   VCID: 33636F8E9A42028656F-8066No fault code found.-------------------------------------------------------------------------------Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb   Part No SW: 1K0 907 530 AF    HW: 1K0 907 951    Component: J533  Gateway   H17 0233     Revision:   H17       Serial number: 1521J09C1800E2   Coding: E9A07F06400602042002   Shop #: WSC 00066 000 00000   VCID: 6BD3B7EE4AF29A465EF-803ENo fault code found.-------------------------------------------------------------------------------Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb   Part No SW: 5K0 953 234     HW: 5K0 953 234    Component: IMMO          H04 0308     Serial number:                  Coding: 000000   Shop #: WSC 00000 000 00000   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod   VCID: EADD32EA0D08034EA59-80BFNo fault code found.-------------------------------------------------------------------------------Address 37: Navigation (J794)       Labels: None   Part No HW: 3C0 035 270    Component: RNS310        H15 0227     Serial number: VWZ1Z2K9114961   Coding: 000004010400000000000000   Shop #: WSC 01383 790 50316   ASAM Dataset: VW_RNS310 Unknown   ROD: EV_VWRNS310UDS.rod   VCID: 55A7F11634763CB698B-80001 Fault Found:1048659 - Function Restricted due to Missing Message(s)           U1111 00 [008] - -          Intermittent - Confirmed - Tested Since Memory Clear             Freeze Frame:                    Fault Status: 00000001                    Fault Priority: 6                    Fault Frequency: 1                    Reset counter: 214                    Mileage: 181299 km                    Date: 2051.14.24                    Time: 12:55:28-------------------------------------------------------------------------------Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb   Part No SW: 3C0 959 701 C    HW: 3C0 959 793 A   Component: TUER-SG FT    002 0307     Revision: 12101005    Serial number: 0000253115   Coding: 0200B4   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_DCU42BroseDriveSide A03004   ROD: EV_DCU42BroseDriveSide.rod   VCID: 285988E25384715EF3D-807D   Slave Driver:    Subsystem 1 - Part No SW: 1K0 959 703 AG    HW: 1K0 959 795 R  Labels: 1K0-959-70X-GEN4.CLB   Component: J388__TSG-HL  006 1401    Serial number: 00000004601053         Coding: 000090No fault code found.-------------------------------------------------------------------------------Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb   Part No: 1K0 909 144 J   Component: EPS_ZFLS Kl. 69     3001     Revision: 00H17000       Shop #: WSC 02069 000 90108   VCID: 316F6586A85E3096243-8064No fault code found.-------------------------------------------------------------------------------Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb   Part No SW: 3C0 959 702 C    HW: 3C0 959 792 A   Component: TUER-SG BT    002 0307     Revision: 14101005    Serial number: 0000385684   Coding: 0201B4   Shop #: WSC 01383 790 50316   ASAM Dataset: EV_DCU52BrosePasseSide A03004   ROD: EV_DCU52BrosePasseSide.rod   VCID: 295F8DE6488E4856EC3-807C   Slave Passenger:    Subsystem 1 - Part No SW: 1K0 959 704 AG    HW: 1K0 959 794 R  Labels: 1K0-959-70X-GEN4.CLB   Component: J389__TSG-HR  006 1401    Serial number: 00000004604777         Coding: 000090No fault code found.-------------------------------------------------------------------------------Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb   Part No SW: 1K0 907 534     HW: 1K0 907 951    Component: Batt.regelung H17 0233     Revision: --------    Serial number: 1521J09C1800E2   Coding: 030B085A   Shop #: WSC 00066 000 00000   VCID: E8D948E21B04315EB3D-80BD   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A   Component: J367-BDM  H07 0125 No fault code found.-------------------------------------------------------------------------------Address 77: Telephone (J738)       Labels: 1K8-035-730.clb   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D   Component: Telefon       H08 6900     Revision: 00008000    Serial number: 00000328813714   Coding: 412120   Shop #: WSC 00066 123 12345   VCID: 2A5D72EA4588434EE59-807FNo fault code found.End   ---------------------------------------------------------------------
Numai bine,
ejakab
eroarea aceea e posibil sa nu fie legata de problema ta - adica nu prea ne lamureste cu nimic... este o problema de comunicatie cu unitatea.
E un protocol uds . trebuie urmati cativa pasi si eroarea se va sterge .
In rest e codata corect .
eroarea mai apare si pe 01 cand se corecteaza km si se intrerupe comunicatia .
Modificat de skodita100
Am verificat siguranta la tablou, poate era oxidat un pic. De atunci nu a mai aparut.
Deci pot sa sterg mesajul de eroare? Care sunt pasii de urmat?
Kilometrii sunt reali, am verificat la dealer.
Salut.As vrea sa fac un upgrade de la RNS 310 la RNS 510.Masina mea este un Seat Leon din 2010 si as vrea sa stiu de ce as avea nevoie in afara de sistem.Trebuie sa renunt la modulul bluetooth de sub scaun?
Modificat de alexspider93
Nu mai trebuie nimic
Poti lasa modulul de sub scaun.Se poate adapta pe 510.Montare pe masina si adaptare cu vcds.
Cum se poate seta pe afisaj modelul de masina care apare la senzorii de parcare?
cu VCDS-ul se poate, altfel nu ai cum
Imi puteti spune pasii de urmat pe vcds va rog?
cauta la codari sau activari pe modulul de senzori.
Si-a cumparat cineva harta de RNS315 V6 sau V7? Sunt interesat daca are macar orasele mari acoperite complet sau doar Bucuresti? Am vazut o poza aici in topic cu Bucurestiul acoperit bine dar in restul tarii nu da nimeni informatii concrete.
Va multumesc!
Salut ,imi puteti recomanda pe cineva care repara rns 310? Am o mica problema ,nu porneste. Totul e conectat corespunzator ,am schimbat siguranta din casetofon si nimic. Dead.
Ai verificat daca se alimenteaza? In conectorul de pe masina trebuie sa ai 2 + si o masa.
Da ,am facut proba cu un rcd 300. Merge fara probleme..
Atunci-la doctor cu el...ti-as recomanda dar nu stiu pe nimeni din pacate.
a fost pentru un scurt moment la un nene ,l-a desfacut ,s-a uitat un pic in el ,mi-a spus ca e are ceva pe placa de baza ,a zis ca se rezolva dar el nu se baga. In continuare astept recomandari din partea voastra ,sau daca vi s-au mai intamplat chestiuni de genul. Multam !
din pacate, fiind o problema electronica - nu e obligatoriu sa fie o problema comuna, din pacate.
iti pot recomanda un service ok aici in Bucuresti, pentru RCD-uri, RNS-uri in general repara cam orice.
http://www.rns510.ro/Contact.html si http://olx.ro/oferta/decodari-radio-casetofoane-orice-tip-pe-loc-zona-crangasi-ID2MUYh.html
Modificat de george99xxx
Multumesc pentru raspunsuri ,george ,am vorbit cu cei de la rns510.ro ,mi-au spus ca pentru ei este posibil sa fie "munca degeaba" si ca nu se incurca cu rns 310 ei fiind specializati pe rns 510 si nu ii condamn deloc ,am cautat piese ,scheme ,diagrame ale placii de baza ptr rns 310 si nu am gasit deloc. In schimb am gasit placa de baza pentru un rns 315 blaupunkt  dar nu sunt sigur ca pot sa fac o frankstainerie din astea 2...
nicio sansa
codrutcraciun17
Salut, am si eu o problema, am un golf 5 an fabricatie 2004, din fabrica are un Blaupunkt travelpilot dx r4 si as vrea sa il schimb cu un rcd 300 sau un sistem audio pionner. Vreau sa stiu daca se potriveste mufa sau trebuie altceva.
Modificat de codrutcraciun17
Buna ziua!Eu am pe Skoda Octavia 2 o navigatie RNS315 dar nu are decat Europa de vest pe ea de unde as putea instala Romania si Europa de est?Va multumesc.
Modificat de Ultra2
  • Ex member pinned this topic
  • Aerofan a deschis acest topic
