RNS MFD2
moto_marius
Mersi nrobert.Dar cum se face update si unlock la versiunea cu cd stie cineva? Ca la versiunea cu dvd am vazut si stiu dar la cd inca nu am vazut .
Va salut. Detin si eu o skoda octavia 2 combi(break) din 2006  https://www.google.ro/search?q=skoda+octavia+2+combi+2006&source=lnms&tbm=isch&sa=X&ei=tj0KU_zYAei_ygONvICACw&ved=0CAcQ_AUoAQ&biw=1280&bih=923#facrc=_&imgdii=_&imgrc=YnSginpbPYSEIM%253A%3Bi0rX3dRfqU4ghM%3Bhttp%253A%252F%252Fwww.octinfo.com%252Flargepic%252Foctavia2%252Fo2_combi_1st_front.jpg%3Bhttp%253A%252F%252Fpelayo97.blogspot.com%252F2012%252F06%252Fskoda-octavia-history.html%3B1866%3B1319. Problema este ca am si eu aceasta problema cu navigatia. Am tot sunat si am inteles ca nu exista cd/dvd pentru romania. Ok, am inteles, de unde aflu daca MFD2-ul meu este cu cd sau cu dvd? Am magazia de cd cu 6 cd https://www.google.ro/search?q=skoda+octavia+2+magazie+de+cd&source=lnms&tbm=isch&sa=X&ei=CT4KU_65MIO6ygOe-YEY&ved=0CAcQ_AUoAQ&biw=1280&bih=923#facrc=_&imgrc=5ETfSwxo0J_m-M%253A%3BElYpKWGYSCQTwM%3Bhttp%253A%252F%252Fwww.pieseauto.ro%252Fpoze%252Fmagazie-cd-skoda-octavia-2-originala%252Fmagazie-cd-skoda-octavia-2-originala-1264710afc00805eb4-800-600-1-95-1.jpg%3Bhttp%253A%252F%252Fwww.pieseauto.ro%252Fmagazie-cd%252Fskoda%252Foctavia%252Fmagazie-cd-skoda-octavia-2-originala-1133628657.html%3B756%3B600  exact ca asta, cu acelasi suport. In suport vad doua goluri, ce se mai poate monta?  daca va uitati aici https://www.google.ro/search?q=skoda+octavia+2+magazie+de+cd&source=lnms&tbm=isch&sa=X&ei=CT4KU_65MIO6ygOe-YEY&ved=0CAcQ_AUoAQ&biw=1280&bih=923#q=mfd2&tbm=isch&facrc=_&imgdii=_&imgrc=_NyWuPZTDFiRbM%253A%3BWgm0sR963mAuoM%3Bhttp%253A%252F%252Fdataton.net%252Fvw%252Fnav%252Fmfd2_dvd-CD_screen.jpg%3Bhttp%253A%252F%252Fwww.golfmkv.com%252Fforums%252Fshowthread.php%253Ft%253D95382%3B794%3B480  dupa cd 6 apare AUX. La mine apare Cd interior: care nu functioneaza si tind sa cred ca trebuie sa il curat cu in cd cleaner, uneori detecteaza cd/dvd nu stiu exact ce e cu navigatie de germania, vad toata germania iar uneori nu. Ma rog..deci care este motivul pentru care acolo dupa cd 6 apare AUX si la mine CD int? Si, daca selectez butonul aux https://www.google.ro/search?q=skoda+octavia+2+magazie+de+cd&source=lnms&tbm=isch&sa=X&ei=CT4KU_65MIO6ygOe-YEY&ved=0CAcQ_AUoAQ&biw=1280&bih=923#q=mfd2&tbm=isch&facrc=_&imgdii=_NyWuPZTDFiRbM%3A%3B6RUQNHYEtq04iM%3B_NyWuPZTDFiRbM%3A&imgrc=_NyWuPZTDFiRbM%253A%3BWgm0sR963mAuoM%3Bhttp%253A%252F%252Fdataton.net%252Fvw%252Fnav%252Fmfd2_dvd-CD_screen.jpg%3Bhttp%253A%252F%252Fwww.golfmkv.com%252Fforums%252Fshowthread.php%253Ft%253D95382%3B794%3B480 unde o fi mufa de iesirre audio sau tv? Daca o luam logic, ar trebui sa se poata monta in spatele mfd2  un cablu aux corect? Poate sa imi ofere cineva o schema, unde si ce fel de cablu?
Daca te uiti cu 2 posturi mai sus, vezi cum iti dai seama daca e cu cd sau dvd. Mfd2 nu are iesire video, are doar intrare.
salut florin mfd2 cu MUTE pe mijloc este varianta cu DVD, iar cel cu TELE este varianta CD
@ exit_paint
 1. iesirea/ intrarea aux se afla pe spatele MFD2 in partea stg, acolo se poate lega un cablu canal stg/dr si ground pentru semnal audio de pa o sursa externa gen iPod, pentru semnal video ai nevoie de un modul de conversie care costa in jur de 140e pe ebay iar cu acesta poti cupla camera video pt parcare.
2. pentru tv este necesar de asemenea un modul dedicat ce vine cu un cablu de by-pass ce se monteaza exact in locul cablurilor existente in partea dr din spatele MFD2, pretul variaza in functie de brand/calitate-analog/digital,  insa orientativ se plaseaza intre 50 - 300 e.
pentru camera de marsarier, nu trebuie neaparat modul de conversie, depinde de camera pe care o folosesti, exista si camre care se conecteaza direct la mfd2 fara modul de conversie.
corect butonul cu MUTE pe mijloc este varianta cu DVD,
 Am un VW Touran 2004 cu NAvi RNS MFD 2 si nu stiu unde sa caut intrarea pentru surse auxiliare. am cautat in cotiera, in torpedo ... nimik :tuktuk:
no, pe semne nu are....
Salut.
Octavia 2, navigatie mfd 2 cd.
Am citit forumul si totusi am o nelamurire legata de redarea mp3-iului. In principiu doresc sa bag stik-ul in usb si sa-mi citeasca de acolo.
Pentru asta am nevoie de:
1.Inrefata DMC   sau
2.Cablu MDI-USB  sau
3.Ambele
Multumesc anticipat !
Interfata - poti sa bagi stick, card.
cablu  aux - un aux.
Salut, am si eu probleme cu acest RNS MFD2. Am versiunea cu CD si buton de AUX. In torpedou am un cablu de aux care functioneaza doar daca apas de 2x pe butonul CD. Problema e ca nu imi citeste decat cd-ul cu navigatia original, cd-urile cu track nu, scrise de mine. Cand am cumparat masina, tipul avea 2 cd-uri in torpedou cu muzica, nici pe acelea nu mi le citeste, trebuie sa fac cumva sa le vada si sa nu mai apara "cd-error"? Ma gandesc ca daca el le avea, mergea. Si in plus, unde este magazia acestei masini? Ca in torpedou nu este si nici in cotiera. Multumesc anticipat!
Nu toate mfd2 citesc cd audio... . Si la fel nu toate masinile au magazie :), daca ai acel au-in probabil ca e conectat la intrarea de cdc si nu poti sa ai si magazie.
Multumesc foarte mult Florin. Sunt destul de multe de facut si cred cea mai grea parte e schimbare climatronicului si a modulului de parktronic (sistemul e oroginal, senzori fata+spate). Mi se pare foarte ciudat ca un Stream sa faca aceste lucuri si varianta mai buna si mult mai scumpa sa nu.
Stream afiseza grafic, si nu optic, iar peste Stream este RCD 510 si nu MFD 2.
no, fiind un post de mai mult de 7 luni.... afiseaza grafic - optic.... cum vrei sa ii zici - ca doar nu o sa afiseze color o unitate monocrom... parerea mea. Modulul de parcare trebuie sa fie cu OPS...nu exista altfel de modul ...adica unul care sa afiseze grafic si altul optic....
presupun ca poate nu scriu unde trebuie problema mea, insa poate este cineva cu suflet care a patit stie, si imi poate raspunde, am un passat b6 care dupa ploile torentiale din aceasta perioada am gasit apa sub mocheta de la sofer, acum nu stiu pe unde intra insa coincidenta face ca acum 3 luni in loc de radio track am montat un mfd2, zilele astea am obs ca se incinta atat de tare incat porneste coolerul de racire de la navigatie si o tine tot asa la nesvarsit chiar si cnd opresc motorul, m-am gandit ca este pe duca, am montat alta navigatie mfd2 si acelasi lucuru dupa 5 minute de mers cu masina porneste ventilatorul de racire al navigatiei, am obs ca o data a pornit fara ca navigatia sa fie pornita, AICI ESTE PROBLEMA, sunt de acord porneste ca este pornita si de la caldura se raceste cu ventilatorul, dar de ce porneste si cnd nu este pornita si merg cu masina fara sa ii dau drumul la navigatie , sa fie scurt undeva din cauza apei? pt ca 2 navigatii defecte refuz sa cred. VA ROG CEL CARE DORTESTE SI STIE SA MA AJUTE. va multumeesc
Salut, am si eu probleme cu acest RNS MFD2. ...................
Ai descoperit care este problema sau stie cineva ? Intreb pt ca si eu patesc ceva oarecum similar pe RNS 300:
- CD original cu track-uri imi citeste;
- CD original cu mp3- uri imi citeste;
- CD uri facute de mine acum vreo 2 ani cu mp3- uri mi le citeste fara probleme,
insa nimic din ce scriu acum nou CD mp3 nu mai citeste. Innebunesc !
N-am schimbat inscriptorul sau viteza de scriere, etc.... La PC mi le citeste, deci nu sunt cu eroare..
Nu inteleg de ce , nu inteleg...
Modificat de Andrei26IS
Cu siguranta s,a modificat un protocol in scrierea CD-urilor tale.
Incearca cu poweriso sa le faci. E usor de folosit. Cu cdburnerxp sau cu nero mai poti incerca, doar ca la nero alegi tipul de cd cu mp3, nu data. Incearca niste cd-uri scrise de prieteni si daca iti merg, iti zic ei cu ce le fac si sub ce procedura.
E o eroare "umana" la tine. Ori writeru e pe duca, ori din setari
Am si eu o problema cu RNS MFD2 la un VW JETTA (motor2.0 170 cp an fabricatie 2007). Am modelul cu MUTE pe mijloc.
Zilele trecute mi-a aratat ca a trecut in modul TELEPHONE. Nu se mai aude nici o melodia, nu merge nici radio, si nici nu mi se opreste deloc RNS MFD2(nici macar cand scot cheia din contact). Mentionez ca nu am optiunea asta, nu am nici un buton (sau nu l-am gasit eu).
I-am facut un upgrade la firmware si degeaba.
Are cineva vreo idee cum pot scapa de problema asta ?
Am intrat si in meniul de la MAXI DOT si la audio este si acolo PHONE. dar nu merge schimbat, sau nu stiu eu.
Modificat de Laur1989
ai umblat cumva pe la codari ? ... pe Can, etc ?
daca nu, atunci  lasa-l fara alimentare o perioada de timp, dupa care verifica iar.
Nu am umblat la codari, etc. L-am lasat o noapte fara alimentare si degeaba. Am schimbat rns mfd2 cu un alt model de rns(510 cred) si ala merge perfect. L-am bagat din nou pe ala al meu si tot nu merge bn.
deci, clar aparatul este problema.... nu am mai intalnit cu acest comportament, pana acum.
Am o problema cu MFD2-ul meu. Acesta nu porneste cand pornesc masina si trebuie sa apas manual pe butonul de On/Off pentru a porni incinta. Din cand in cand se mai intampla sa porneasca si cand pun contactul, dar foarte rar (sub 5% din totalul pornirilor). Are cineva idee ce as putea sa ii fac pentru a porni de fiecare data cand pun contactul?
Multumesc mult.
fa o scanare, sa vedem ce erori gasesti stocate.... dupa ce-l pornesti din buton, se opreste cand scoti cheia din contact ?
  • Ex member pinned this topic
