Sisteme audio si de navigatie (Tiguan 5N & 5N2)
alexabv
Extrem de scump calculatorul acela... exista solutii aftermarket cu touchscreen poate mai ieftine... ala e prea scump :)
da e foarte scump dar stabil, fata de majoritatea jucariilor (m-am lamurit cu xcarlink care e instabil )
in schimb cei ce l-au testat au redescoperit problemele din win.
Satellite Radio!
e clar, ptr piata lor.
Modificat de Michael
Nu este numai pe piata lor, pe configurator la noi apare optiunea "Receptor digital radio DAB" la 163 euro, insa nu-mi dau seama abrevierea DAB ?! :D
Asta l-am intrebat si eu pe reprezentantul VW PBN, si mi-a trimis un mail, din care copiez urmatoarele randuri
Digital Audio Broadcasting
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Countries with DAB, DAB+ or DMB broadcasts. (Source:WorldDMBForum country profile)
Digital Audio Broadcasting (DAB), also known as Eureka 147, is a digital technology for broadcasting radio stations, used in several countries, particularly in Europe . As of 2006, approximately 1,000 stations worldwide broadcast in the DAB format[1].
The DAB standard was designed in the 1980s, and receivers have been available in many countries for several years. Proponents claim the standard offers several benefits over existing analogue FM radio, such as higher-fidelity audio, more stations in the same broadcast spectrum, and increased resistance to noise, multipath, fading, and co-channel interference. However, listening tests carried out by experts have shown that the audio quality on DAB is lower than on FM due to the fact that 98% of stereo stations in the UK, Denmark, Norway and Switzerland (which are the only countries where DAB sales have taken off) are using bit rates levels that are too low.[2][3][4]
An upgraded version of the system has now been developed, called DAB+. The new standard, the full details of which were published in 2007, is not backward-compatible with the original standard. The vast majority of existing DAB receivers and those on sale in the shops will not be able to receive DAB+ radio services when they are launched; however, a range of DAB+-upgradeable receivers are now available in the shops. Several countries are expected to launch DAB+ broadcasts over the next few years, including the UK[5], Australia, Italy, Germany, Switzerland and Malta, and podcast services using the DAB+ format will be launched in the UK in 2008[6]. There is also a great deal of interest in using DAB+ in Asian countries, such as China .
DAB+ is approximately three times more efficient than DAB due to the adoption of the AAC+ audio codec[7]. This means that it will allow broadcasters to provide far higher audio quality or far more radio stations than with the older version of DAB, or, as is most likely, a combination of both higher audio quality and more radio stations will be provided. Reception quality will also be more robust on DAB+ than on DAB due to the addition of Reed-Solomon error correction coding.
Am si o lista tot de la el cu DAB counties. Nu are legatura cu receptia prin satelit, din cate inteleg eu :D
l-am intrebat si u are legatura cu receptia prin satelit. Dupa cum se vede in poza, SUA nu are receptie DAB si nici Romania. Asa ca eu nu am inclus receptorul DAB in Tiguanul meu, care nu stiu cand va veni...
Interesant de ce il mai pun totusi, daca aici nu se poate receptiona :D
DAB - Digital Audio Broadcasting sau emisie audio digitala. Posturile de radio emit atat analogic (toate) cat si digital (unele). In acest moment, aparatele pe care le aveti pe masina receptioneaza semnal analogic. Cu DAB veti putea receptiona (si) semnal digital. Avantaje: receptia este mai buna (comparativa cu CD-urile audio) iar semnalul nu prezinta distorsiuni, ca in analogic, atunci cand e mai slab. Totusi, daca semnalul este prea slab, receptia digitala inceteaza si esti transferat automat pe receptie analogica. De vreo cativa ani (nu prea multi) sunt si in Bucuresti posturi care emit digital. In concluzie, daca vreti sa ascultati la un nivel calitativ ridicat posturile de radio, alegeti optiunea DAB. Sper ca nu am gresit in explicatia mea de nespecialist...
Auzi, Danny :)
Intr-adevar, la glof V, frecventa oricarui post de radio selectat 'fugea' dupa un anumit timp si receptia devenea distorsionata- trebuia in continuu sa invart rotita ptr selectia frecventei ptr a avea parte de un sunet bun. Daca aceasta este solutia gasita de cei de la VW, este bine, trebuie sa includ optiunea in comanda. Tot ceva in genul acesta, transferul avea loc si dupa id-ul posturilor de radio cand eram pe drum intre localitati, de ex puteam asculta in continuu postul de radio X. Nu te informeaza nimeni ce inseamna acest DAB exact. Multumesc ptr lamuriri.
In alta ordine de idei, ma intrebam daca ar fi utila acea priza de 230 V. Sta cineva cu laptop-ul in masina? Pe teren accidentat? Glumesc
Completare: DAB este disponibil doar pentru cei care opteaza si pentru sistemul audio RCD 510.
Pai sigur, trebuie sa fim pregatiti :D
Am mai gasit ceva, dupa cum am citit, RNS 510 nu permite vizualizarea DVD-urilor in timpul miscarii masinii. Pe internet se vand adaptoare care permit tocmai acest lucru (e bun si ptr colegul care vrea Toareg :D )
4460 TV-free adapter for VW with navigation system MFD2 and RNS 510 (16:9)
Most serial navigation systems deactivate the monitor while driving. But that is exactly the time when your passengers intent to kill some time with a video game or the kids want to watch a movie.
With the TV-free adapter exactly this is possible while driving.
cateva site-uri:
http://www.dension4u.de/shop/product_info....roducts_id=1699
http://www.kufatec.de/shop/product_info.ph...ug---Play-.html
http://cgi.ebay.de/VW-Navi-MFD3-RNS-510-TV...5QQcmdZViewItem
... si stiu ca este off topic, dar astia nu sunt normali cu taxa asta de prima inmatriculare. (In ce tara sa emigram?)
Dupa cum am citit, RNS 510 nu permite vizualizarea DVD-urilor in timpul miscarii masinii. Pe internet se vand adaptoare care permit tocmai acest lucru.
La drumuri lungi, e o chestie binevenita pentru pasagerul fata si, intr-o oarecare masura, chiar si pentru cei din spate. Ma intreb daca exista si solutii de conectare a TV tunerelor la RNS 510. Modificat de Michael
  • 5 weeks later...
Accepta RCD510 si carduri SDHC sau doar SD?
Sunt curios daca a testat cineva treaba asta deoarece vreau sa-mi cumpar un card SDHC de 8 sau 16GB si nu stiu daca-l accepta RCD-ul.
Buna seara @nistoras, am citit si eu sursele pe care le am la dispozitie (asa mai invat si eu :Driver:, iar raspunsul este ... urmatorul (asta este ce am gasit eu):
Oficial, NEGATIV, citeste max. 2 GB.; sursa: instructiunile de utilizare ale RCD510: suporta max. 2 GB si nu suporta card-uri SDHC. "Sunt suportate numai carduri SD (Secure Digital Memory Cards) si carduri MMC (Multimedia Cards) cu dimensiunile de 32 mm x 24 mm x 2,1 mm, avand capacitatea de pana la 2 GB."
Insa, neoficial, suporta carduri de pana la 4GB. surse: 1.un dealer VW din Germania care i-a furnizat aceasta informatie unui client. 2. Unul in Germania a facut testul cu un card SDHC Transcend TS4GSDHC6 Secure Digital 4GB Class 6 si a functionat, afisand in intregime datele memorate si a citit toate melodiile.
Nu am gasit informatii despre incercari cu carduri cu capacitate mai mare. Comentariile, care sunt pertinente de altfel, sunt ca au inclus o tehnologie depasita, acum in 2008, cand la sfarsitul anului ne asteptam sa apara pe piata carduri cu capacitati de 32 GB.
Totusi avem la dispozitie acel AUX-IN ptr. conectare mp3 (nu stiu daca mp4) play-ere.
Si pentru cei care stiu germana atasez si manualul RNS 510: http://www.dump.ro/download.php?file=Bed-Anleitung_RNS_510[1].pdf&id=YjgzYmVmYzZjY2I5NWNlZjA1ZjI3ZTYwOGE1ODk2ZWM=&download=true
numai bine tuturor!
"Insa, neoficial, suporta carduri de pana la 4GB. surse: 1.un dealer VW din Germania care i-a furnizat aceasta informatie unui client. 2. Unul in Germania a facut testul cu un card SDHC Transcend TS4GSDHC6 Secure Digital 4GB Class 6 si a functionat, afisand in intregime datele memorate si a citit toate melodiile."
@nistoras, ia un card de 2 GB si mergi la sigur, am citit acuma ca unul a incercat la RNS 510 un card 4GB SDHC Sandisk - Nu a functionat, RNS-ul afisand o eroare de cartela.
Vin si eu cu o intrebare. RCD 510 (pret cu TVA 276 EUR - conform brosurii din Oct. 2007) are touchscreen si slot de card? Intreb asta deoarece in brosura nu scrie ca ar avea. Acestea sunt prezente numai la RCD 510 Dynasound. Multumesc.
Numai bine
Fata de RCD 300 (standard la toate versiunile de echipare), potrivit listei de preturi din ianuarie 2008, RCD 510 vine in plus cu touchscreen color, SD card reader si CD changer pentru 6 CD-uri.
Later edit: Avand in vedere ca in topicul "Dotari, optionale, accesorii" s-a discutat destul de mult despre sistemele audio si de navigatie de pe Tiguan, m-am gandit ca ar fi bine sa deschid un topic nou pe aceasta tema iar discutiile respective sa continue aici.
crysty92crystyann
Am comandat si eu Volkswagen Tiguan si cand am facut comanda am ales radio Cd modelul RCD 300...in brosura cu dotarile de serie scrie ca RCD 300 are functie MP3 dar un prieten are acelasi model la Passat si mi-a spus k lui nu ii merg mp3'urile!!! Vreau sa stiu si eu daca RCD 300 are functie mp3 sau nu ... Mersi anticipat :D :)
RCD300 citeste MP3 la modelele MY2008. Cel putin asa este la Golf, banuiesc ca e la fel la toate modelele.Ce model e Passatul?
crysty92crystyann
passatu e model 2007...la tiguan am facut comanda in februarie 2008
... ce am mai citit - nu vreau sa va induc in eroare- este ca ar citi totusi orice card de 4 GB, daca a fost in prealabil formatat pe PC cu FAT32.
Intai sa va povestesc cate ceva despre RNS 510:
Dc nu am ales acest sistem, sincer nu ii vad utilitatea in cazul in care 80%-90% din timp este petrecut in oras. Sa ajung de acasa pana la munca cred ca si legat la ochi daca nu este trafic pot sa fac asta, sa merg in centru, sa ies la o terasa, in club sau la cumparaturi iarasi nu cred ca ma ratacesc, ca o sa existe la un moment dat nu stiu ce intamplare, situatie sau ocazie cand trebuie sa ajung pe nu stiu ce strada aflata pe cine stie ce coclauri este singura data cand ii vad utilitatea in oras, dar sa fim seriosi cand trebuie sa ajungi undeva, nu te gaseste asa la semafor ca trebuie sa ajungi pe strada Plugusor si vai ce ma fac ca nu stiu unde este. In general cand trebuie sa ajungi in anumite locuri deja te interesezi cam pe unde vine, puncte de reper eventual consulti si o harta inainte sa pleci. Bun asta este navigatia in oras si utilitatea ei dupa parerea mea, cand iesi din Bucuresti este o alta mancare de peste, dar sa fim seriosi de cate ori plecati pe undeva in 90% din cazuri este vb de mare sau munte, drumuri extrem de cunoscute, pana si km la care sunt camerele de luat vederi le-am invatat, ca o sa existe nu stiu ce cazuri in care trebuie sa ajungi la o locatie noua, hai sa fim seriosi nu te aflii in drum spre munte si zici hmmm ia sa mergem noi la nu stiu ce manastire si vai nu stiu drumul, ok nu cunosti drumul, orice sofer are o harta in masina te uiti si aia este, dar in general daca vrei sa ajungi undeva in 90% din cazuri stii si cum (drumul).
Plecarile in afara Romaniei, acuma chiar vine momentul in care sistemul de navigatie este de un real folos, desi in mare marte pana si aici te descuri dupa indicatoare, trebuie sa ajungi in Grecia pai ce o fi asa complicat Ruse, Pleven, Sofia dupa care depinde de destinatia din Grecia. In fine cert e ca navigatia cand iesi din tara, mai ales pe un traseu pe care nu ai mai fost, iti da un sentiment de incredere (te aflii pe drumul cel bun), mai vezi unde gasesti o benzinarie(asta numai daca este actualizat softul)mai vezi un radar(tot daca ai softul actualizat), in principiu este util pentru iesirile din tara. Insa va intreb sincer chiar merita 2000 EU un sistem de navigatie? Pai la 400-500 EU va luati un sist de navigatie portabil performant, nu o sa aiba display asa mare insa va garantez ca o sa-si faca treaba mai bine decat sistemul de fata. Dc? Pai hai sa vedem, sisteml RNS 510 este o bijuterie tehnologica, softul din cate am inteles este facut de cea mai buna firma in domeniu dar exista si un dar; la un moment dat e posibil ca sistemul sa-ti arate ca esti in camp dar tu esti pe drum(inatamplari concrete aflate de la altii), este posibil ca ce-ti afiseaza sa arate ca mergi pe langa drum sau paralel cu drumul pe care te aflii, hartile nu sunt foarte actualizate si sincer nici nu vad cum se poate face acest lucru. Cei de la VW sa va cheme la actualizat harti ori de cate ori apare ceva nou, sa fim seriosi mai ales la noi in Romanica, din cate am citit nu prea poti sa umblii la inf softului si chiar daca poti nu ai de unde sa iei harti noi pt ca hartile de la alte softuri sau sisteme nu se potrivesc, deci cam ce primesti aia e(se poate clona imaginea si muta pe alt hdd(harti + soft) dar sa fim seriosi cine vrea sa faca asta?).
Un sist de navigatie portabil este alta mancare de peste, softurile la noi in general sunt pe sistem american gen Mio sau TomTom, bine asta daca te duce capul sa cumperi un sist bun la care sa poti sa si umblii, pentru ca sunt foarte multe care cum le iei asa le ai(vezi ex de mai sus). Nu sunt expert insa am fost nevoit sa invat cum se pun hati noi pe un Mio si sincer nu a fost deloc complicat, iar cu ocazia asta am invatat o multime de smecherii, se pot lua hati cu radare, restaurante, benzinarii si multe altele dar exista forumuri specializate pentru asa ceva trebuie doar sa ai curiozitatea sa cauti si placerea sa citesti.
Acum sa revenim si la celelalte avantaje ale RNS, player divx/dvd: daca vrei sa agati pustoaice si sa le vrajesti la un film in fata blocului sau cand esti la pescuit sa te uiti la film in loc sa stai cu batul in apa este o optiune, dar sa fim seriosi acuma, cine-si permite o astfel de masina are o casa un televizor, majoritatea au cate o plasma sau un lcd modest(40'' ;) ) acasa, nu sta sa vrajeasca pustoaice la film in masina, o duce in Mall la un film, nu sta in parcare si cumpara popcorn de la benzinarie, dar in fine exista cazuri si cazuri (am vazut o florareasa cu 2 puradei intr-un Phaeton, asa ca nimic nu ma mai uimeste si sa nu credeti ca exagerez, era daia cu salba la gat si banuti la frunte, 7 fuste, slapi si daca mai asteptam putin cred ca vedeam cum scoate florile din prtbagaj de la racoare).
Si ca sa inchei cu dezavantajele am vazut RNS de vanzare pe net, si unul urla ca este sistemul lui de navigatie furat acum 2-a saptamani, pai sa-mi sparga unul geanul si sa-mi fure 2000 euro, asta da bucurie, nu stiu in ce masura o sa acopere casco aceste pagube sau de cate ori, dar sincer mai mult deranj decat utilitate.
Acum avantaje, poate singurul avantaj al RNS este camera spate, un lucru folositor desi daca ai RNS ai si senzori ca sa nu mai zic park-asist, dar este folositoare trebuie sa recunoastem si se pare ca nu mere pe alte sisteme acum ma refer la sistemul RCD510 pe care urmeaza sa-l descriu mai jos.
RCD 510, acelasi look ma refer la display cu touch-screen color la fel ca si la RNS, practic ii lipsesc 2-3 butoane, sistemul de navigatie, hdd si dvd.
Navigatie am descris mai sus dc una portabila este mult mai avantajoasa, unde mai pui ca o poti lua si pe alta masina in caz ca nu mergi cu a ta sau o mai poti da la un prieten.
Hdd - sa fim seriosi ce tinem pe el inafara de filme si muzica? de filme am vb mai sus ramane muzica.
DVD- pt filme am scris mai sus parerea mea, pt muzica este o treaba sa ai hdd si dvd, practig 30gb si inca 6 dvd cu muzica ai luat toata muzica cu tine, asta in caz ca citeste dvd cu mp3 si nu doar cd, dar sa fim seriosi cata muzica poti sa asculti la un drum 300-400 melodii hai sa zicem 1000. Pai hai sa facem un calcul simplu, pe un cd intra 300 melodii pe 6 cd-uri cat intra in magazia de la RCD intra 1800, asta inseamna in medie cam 5400 minute de muzica 90h de condus. Cred ca un sofer de tir este posibil sa asculte toata muzica la un drum dus intor asa mai lung putin Romania - Franta sau ceva de genul asta. Ehh daca la 1800 melodii cu ce muzica asculti in general mai adaugi si un card de 2gb adica inca 900-1000 bucati cu muzica de actualitate, incepi sa-ti dai seama ca probabil odata la un an trebuie sa-ti faci griji ca ai terminat toata muzica pe care o ai in masina(daca ai ascultat doar mp3 fara radio) iar aici am refer strict la ce ai infipt in sistem(6cd + card) nu luam in calcul varianta in care poti sa ai o cutie cu 10 cd-uri mp3 la tine pentru ca deja ajungem la niste calcule astronomice.
Da sunt economist si foarte realist, tocmai din acest motiv am stat putin sa ma gandesc si sa calculez inainte sa fac gresala de a alege RNS in loc de RCD si bine am facut pt ca altfel eram mai sarac cu 2000eu acuma bine (1600 cat este diferenta inte ele, hai 1800 ca mai puneam si camera spate)
RCD500 din puctul meu de vedere este obligatoriu pentru aceasta masinuta, 200-300 euro cat costa nu este un capat de tara, da se pot cumpara sisteme mult mai bune la banii astia dar sa fim seriosi 1 arunci sistemul vechi 100-150eu iar 2 o sa platesti montajul de o sa te usture la vw. Am impresia ca nu ai voie decat la ei in perioada de garantie si daca stau bine sa ma gandesc nu cred ca or sa monteze alt sistem decat cele de la vw pe masina, deci tot la banii aia ajungi ba chiar mai scump cu un montaj si diferenta de bani de la unul la celalalt.
Va recomand RCD510 display color, afisaj mare cu touch-screen, magazie 6 cd si slot de memorie, mai mult nu cred ca trebuie unui utilizator modest care nu umbla la agatat sau la fite.
Btw daca tot suntem aici sa nu va indemne pacatul sa va luati Dinaudio high-quality audio system, sa fim seriosi cati dintre noi asculta muzica de opera sau simfonica, pentru ca la hip-hop sau dace nu o sa aveti basi in plus. Vreti putre sau bas? va orientati la un sistem serios cu statie de amplificare, subwoofer, niste boxe seriose, faceti un calcul ce sistem va puteti monta cu 12-15milioane parca atat costa Dinaudio cand am facut eu configuratia. Acum daca vreunul dintre voi vrea sa asculte muzica simfonica la 620W nu pot sa ma ... in gusturile omului, cred ca varsta zice totul aici iar eu am momentan doar 27, am timp sa ascult si simfonica cu babuta mea dar poate mai pe la 50-60-70 desi daca ma intrebi acuma o sa zic niciodata, dar dehh cine stie....
Sper ca nu am fost prea plictisitor si ca informatiile sa va ajute in alegerea optiunii potrivite.
Eu am RNS510, nu pot sa zic ca nu sunt de acord cu tine, dar, vezi cum arata o imagine pe RNS510 si cum arata aceasi imagine pe un RCD510. Sistemul de navigatie are o rezolutie muuult mai buna decit simplul sistem audio.In rest,navigatia este cu adevarat utila in vest,unde fara navigatie nu se descurca nici bastinasii (Viena,Munich,Stuttgart,etc) in rest, eu am luat-o pentru aspect si SD-Card (cind am luat masina inca nu era disponibil RCD-ul).
Salut. Sunt utilizator de RCD 510, si sunt foarte multumit de produs. OK, daca ar fi sa imi cumpar masina din nou tot nu as alege RNS-ul din cauza costului mare (1,600 EUR in plus mi se pare mult...), desi urasc sa stau cu fire atarnate de bord ca in prezent, cand pun navigatia externa si detectorul... De asemenea, am DVD player portabil pentru kinderi pe care il prind pe una din tavitele din spate si stau cuminti la drum lung (alt fir dupa ce se termina bateriile).
Am avut insa ocazia sa ascult putin "zgomot de fond" de la un sistem Dynaudio, si pot sa va spun ca este o oarecare diferenta. Eu personal nu cred ca este neaparat nevoie sa ajungi la 50-60 de ani pentru a aprecia "La mamma morta" cantata de Maria Callas, si, credeti-ma, suna altfel pe Dynaudio. De asemenea, cred ca atunci cand alternezi "Welcome home (Sanitarium)" cu "Vreau sa va doara", sau "Fur Elise" cu "Symphony of destruction", poti sa te bucuri altfel de drum si sa treci mai usor peste stresul provocat de soferi disperati, aglomeratie si alti factori "perturbatori". Inainte sa cumpar Tiguanul am incercat putin un Outlander cu Rockford Fossgate, si fara sa fiu cine stie ce cunoscator, mi se pare peste Dynaudio, si, evident, mult peste RCD. Totul cred ca depinde de ceea ce isi doreste fiecare de la masina. Pot fi oameni care dau 6,000 EUR pe un Logan si pun un sistem audio de 5,000 EUR (sau mai mult) pe el, pentru ca asta apreciaza. Si sunt altii care isi cumpara BMW X3 si lasa RadioCD-ul standard pe el, pentru ca este suficient. O sa ma opresc aici pentru ca nu vreau sa se transforme postul intr-un flame.
  • Doomy changed the title to Antena GPS (Tiguan 5N & 5N2)
  • Doomy a deschis acest topic
