Adaptare "Steering Angle Sensor"
cristian_wushu
Verifica continuitatea firelor de la senzorul de placute.
Cum fac asta ?Este circuit normal inchis sau deschis la placute ?
Normal inchis.
am verificat si senzorii de pe placute si sunt OK.
Nu senzorii de la placute fac probleme ci mufele lor. Daca ai masurat direct in mufa senzorului nu ai rezolvat nimic. Trebuie masurat dupa mufa mama a instalatiei masinii. Daca nici acolo nu apare problema trebuie sa incepi de la ceasuri, trecand prin toate mufele.
  • 8 months later...
salut  ma numesc cezar si am o mare problema cu masina mea,,,am facut astazi un test vag.si mi-a dat urmatoarele...
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
VIN: WVWZZZ1JZ3B140401   Mileage: 212740km/132190miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 DD
   Component: 1,9l R4 EDC 0000SG  1518
   Coding: 00002
   Shop #: WSC 07803
   WVWZZZ1JZ3B140401     VWZ6Z0C0002168
3 Faults Found:
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
            P1144 - 35-10 -  -  - Intermittent
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-00 -  -
16955 - Brake Switch (F): Implausible Signal
            P0571 - 35-10 -  -  - Intermittent
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379 M
   Component: ESP FRONT MK60      0102
   Coding: 0019458
   Shop #: WSC 00012 000 00000
3 Faults Found:
01435 - Brake Pressure Sensor 1 (G201)
            008 - Implausible Signal - Intermittent
00526 - Brake Light Switch-F
00778 - Steering Angle Sensor (G85)
            003 - Mechanical Failure
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 02 AIRBAG VW5       0003
   Coding: 12338
   Shop #: WSC 00028
01317 - Control Module in Instrument Cluster (J285)
poate cineva sa imi spuan ce inseamna toate erorile astea..va multumesc
-schimba switch-ul de frana
- verifica daca G85 este montat corect - recalibreaza-l
- recalibreaza g201
- verifica cablaj sau inlocuieste debitmetru
.... cam asta spun erorile tale - la rece - altfel, diagnoza este doar un pas spre rezolvarea problemei, pana nu faci cateva verificari, demontezi, verifici.... nu are mare valoare.
Buna,
Am un Golf 4 1.9 SDI. Dupa o problema cu cap-ul de planetara pe stanga care l-am schimbat am observat ca directia merge ciudat si pozitia volanului sa modificat putin. Am vorbit cu un mecanic care mia zis ca trebuie refacuta geometria, lucru pe care urmeaza sa il fac saptamana viitoare (trebuie sa schimb si un pivot si flansele de la amortizore pe fata). Bun problema este ca azi dimineata sa aprins martorul EPS iar la scanarea cu VAG-COM imi apare:
Control Module Part Number: 1C0 907 379 E
  Component and/or Version: ESP FRONT MK60      0104
           Software Coding: 0019458
            Work Shop Code: WSC 01317 785 00200
                      VCID: 2C5C27848C71ED78AD4
Doar planetara am schimbat-o acum vreo 10 zile altundeva nu sa intervenit. Credeti ca se rezolva cu geometria sau e dus senzorul respecitv si trebuie inlocuit si adaptat?
Modificat de Mishu77
Da, fa geometria, vezi sa ai volanul drept cand pleci de la ei.
Vb dupa aia.... dar o sa isi revina.
Mishu77
Intra in blocul de masuratori, misca volanul  si vezi daca ai valori pe G85.
Am urmatoarea problema pe un Golf 4
Am avut 2 errori pe el care nu se stergeau:
0778- Steering Angle Sensor (g85 )
Mechanic failure
Lateral Acceleration Sensor (G200)
Electrical Fault in Circuit
Unghiul de fuga nu este facut , recunosc.
Probleme sunt in felul urmator:
-ESP nu s-a aprins niciodata in bord,si nici nu  functioneaza din buton,desi masina are , cred ca e manarit de cel care a adus masina din Germania probabil...
- Dupa ce am schimbat uleiul servo la vreo 2 -3 zile am pus VAG COM de curiozitate, am dat auto scan, erase DTCs , si a disparut Erroarea cu senzorul G200 , care nu se stergea deloc inainte, si au ramas doar :
   Part No: 1C0 907 379 E
   Component: ESP FRONT MK60      0104
   Coding: 0011266
   Shop #: WSC 00046 615 12345
2 Faults Found:
            004 - No Signal/Communication
Prima inteleg ca e din cauza geometriei rotilor , dar sa mi dea no signal/comunication tot din cauza asta , sau am sucit prea mult pe loc cand s-a schimbat uleiul  de la servo?
De asemenea erroarea apare si pe 19 : Can-Gateway la fel, No Signal / Communication.
Modificat de AndreyBz
Intai trebuie refacut senzorul G200. Dupa aia, mergem mai departe.... trebuie vazut de ce G85 nu comunica....
stefanos_lovin
Salut, mi-au iesit si mie la scanare urmatoarele erori, ma poate ajuta cineva? Este nevoie doar de o recalibrare sau schimbare a senzorului G85....Masina e noua din 2008 si doar 33333 km la bord
System Test Plan
Lre6000 - (01744) Ignition/Starter Switch (terminal P) , Lre6000 - (00884) Ignition/Starter Switch D
(terminal X) , Lre6000 - (00883) Ignition/Starter Switch (terminal S) , Lre6000 - (00576) Terminal 15
Ignition/starter switch -DTbf6000
- (00121) Entry light front, right
Entry light front, right -W32Tfa6000
- (00120) Entry light front, left
Entry light front, left -W31Lkh6000
- (00778) Steering angle sensor
Steering angle sender -G85-
Steering Angle Sensor -G85-, basic setting
03 - Brake electronics - (00778) Steering angle sender -G85
Adaptation -J500 internal steering angle sensor
F l o r i n
No, fa si tu o scanare cu un VCDS sau VAS, sa vedem exact cum apar erorile.... asa mai rau ne chinui sa cautam. E posibil sa mearga setarea de baza la G85..... dar pune un scan mai bun, pt un raspuns exact.
stefanos_lovin
cred ca asa e mai bine, am si PDF-ul in atasament
ABS Mark 70 from 06. 2008
1K0907379AF
MABS MK70M
Coding 16641
Dealer number 73430
1K0907379AF
H32
0104
1 Event(s) detected
00778 014
--G85 faulty
sporadic
Steering column electronics
1K0953549BF
J0527 051
Coding 12
Dealer number 73430
1K0953549BF
00883 012 \
Ignition/Starter Switch (terminal SI)
fault in electrical circuit )
sporadic
00884 012
Ignition/Starter Switch O (terminal S)
Electric power steering
1K1909144M
EPS_ZFLS KI.067 H08
Dealer number 73430
1901- 1 Event(s) detected
00778 014
faulty
sporadic
G85.PDF
F l o r i n
Da, e bun  cel cu VAS - fa setarea de baza la G85 sa vedem daca isi revine.
stefanos_lovin
Setarea de baza, adica recalibrarea senzorului G58 conform procedurii din prima pagina a postului (volan maxim stanga, maxim dreapta...etc)?
F l o r i n
in primul rand trebuie sa aplici procedura pentru masina ta, nu e valabila cea pentru platforma veche.
Poftim procedura.... dupa care faci limita de forta la servodirectie - procedura a doua, postata de mine
Steering angle sensor (G85)
Requirements:
Start the engine.
Rotate the wheel one turn to the right and then a turn to the left.
Drive a short distance in a straight line on level ground no faster than 20 km / h (just a few
meters).
As soon as you stop the wheel easily without changing the position of the
steering wheel (wheel straight).
Keep the steering wheel is not turned on.
Do not extinguish the engine.
Voltage in the system at least 12.0 V.
[select]
[03 - Brake Electronics]
[Coding-II - 11] or (if unavailable Coding-II)
[security Access - 16]
Enter 40168, provides access to the basic setting.
[Do it!]
[basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON / OFF / Next]
When properly performed basic setting, field 2 should indicate "OK".
[Done, Go Back]
To make sure that the basic setting done correctly, check the sensor again.
[Measuring Blocks - 08]
Group 004
[Go!]
Check box 1, the value must be between -1.5 and 1.5 °.
[Done, Go Back]
[Close Controller, Go Back - 06]
Marginal
adaptation of the steering
(The engine still in motion)
Hold the steering wheel to the straight ahead position (± 10 °) for a minimum
of 5 seconds.
Turn the wheel to
the left until it stops and hold
at the end of the second.
Turn the wheel to
the right until it stops and hold
Straighten the steering wheel and stick to the
straight ahead position (± 10 °).
Turn off the engine and ignition.
Turn on the ignition.
Wait 5 seconds.
Steering light should
go out. If not, do a short
test drive.
stefanos_lovin
ok, multumesc foarte mult, am sa procedez conform celor postate de tine.
stefanos_lovin
Salut Florine, am facut o recalibrare a lui G85 dar se pare ca problema cu becul galben de servo ramane, dar nu intodeauna, ci numai cand iau viraje stranse gen sens giratoriu, dupa o repornire a motorului becul stingandu-se. Am observat ca becul se aprinde mai ales la viraj aprox maxim dreapta, problema ca imi dau seama imediat cand urmeaza sa se aprinda deoarece pierd controlul volanului pt cateva clipe, acesta raspunzand mai greu. Am inteles ca trebuie sa fac o verificare/calibrare de geometrie. Poate afecta asa de mult o geometrie acest senzor G85 sau e doar o problema de comunicare intre mai multe module. Am observat dupa iarna care am trecut cand am luat o bordura ca la peste 120 km/h imi trepideaza volanul, deci ceva s-a intamplat in iarna asta, culmea e ca a inceput sa se aprinda in luna martie dupa ce am schimbat cauciucurile de iarna cu cele de vara. Astept o parere....o zi buna.
F l o r i n
sa nu avem probleme pe la caseta..... fa o scanare a masinii, sa ne uitam peste ea.
floro_st205
:tuktuk:
ieri am umblat pe la volan la un passat 5.5 (2004 ,2.5 tdi ,bau ,cutie automata) petru a monta cruise control cu comenzi pe volan (n-am reusit) . dupa remontare mi-a aparut pe bord "eroare abs" (indicatorul galben) iar cand masina incepe sa se miste  se aprinde intermitent si indicatorul de la frana de mana . mentionez ca  am lucrat cu bateria pusa ,nush ce a fost in capul meu .
la scanare i-mi da asta :
passat.txt
si nu pot adapta G85 cu procedura din primele pagini
dati-mi un sfat
F l o r i n
Pentru ca ti-a pierdut codarea la pompa ABS.
Intai recodeaza pompa ABS, dupa care faci setarea de baza la G85.
Volanul cu comenzi, se poate face sa mearga, nu-i stres....
floro_st205
am recodat pompa abs si adaptat G85-ul . functioneaza totul .
multumesc
stefanos_lovin
Salut Florine. Am facut si geometria la masina din semnatura. Tot mi se aprinde becul de servo si mi se inmoaie volanul. Am observat ca se stinge daca opresc si pornesc motorul pt cateva secunde. Deci sa le luam in ordine: Mi s-a spus prima oara ca e posibil sa se aprinda becul de servo in bord din cauza tensiunii pe baterie; am facut testul VAS al bateriei si mi-a iesit peste 80%, recunosc ca nu am simtit nevoia sa schimb bateria...Apoi am facut o recalibrare basic settings a lui G85 si la fel. In cele din urma am facut si o geometrie la roti si se poate observa din atachament ca nu au fost probleme grave, un pic de reglaj la puntea fata si doar atat (dupa 5 ani de cand am masina). Ce mai ramane sa mai fac in afara de schimbarea casetei de directie? Am observat ca dupa ce am plecat de la geometrie se intarise un pic volanul iar dupa cativa metri parcursi iar mi s-a apris becul si deci iar o inmuiere a volanului....Este cam nasol sa pierzi controlul volanului cand ti-a lumea mai draga si totodata periculos pt cei din trafic. Nu imi mai ramane decat sa fac si proba cu alta baterie poate totusi imi face figuri bateria cu toate ca am monitorizat tensiunea si nu a scazut sub 12V mai putin cea din momentul ignition cand nu ai cum sa o monitorizezi si e normal sa scada pana la un anumit nivel dupa care sa creasca. Erorile scoase sunt aceleasi din atachament cod
00778 014
Steering angle sender-G85
 faultysporadic
si
Mai arunca te rog o privire pe atachamente poate ne scapa ceva....
De la ce poate fi in afara de caseta de directie pe care mi se pare absurd sa o schimb dupa doar 5 ani si 33000 km parcursi.
Si mai aveam o intrebare: este obligatoriu la recalibrare G85 sa mergi cativa metri cu masina cu o viteza de max 20km/h, deoarece mie recalibrarea mi-a facut-o cu masina stationata.
O zi buna!
Geometrie.pdf
ScanG85.PDF
Modificat de stefanos_lovin
