Polo 9N si 9N3 - Scanarea cu VCDS - coduri de eroare si remedierea lor
octav59
lordkiller4ever
Salut, am o problema. Polo 9n 2003 1.4 TDI 75CP, masina nu mai trage cum trebuie .... am scanat cu VCDS Version: Release 10.6.0, mai jos se vede ca nu am destula presiune ....
Address 01: Engine (045 906 019 AP)
22:35:53 Group 002: Idling Speed (See label file for #1&3)
3129 /min Engine speed
29.0 % Throttle Position 0%
0 0 0 Operating Cond/AC speed/throttle/AC
65.7
  • Replies 506
  • Al Bundy
    95
  • ionel.d.2007
    48
  • SergiuD
    17
  • cernescui
    11
Salutare, am scanat si eu masina din semnatura si am resuit sa strang citeva erori, care nu inteleg de ce nu s-au sters, asa ca apelez evident la vastele voastre cunostinte in domeniu :
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: VSSZZZ5PZ5R059687 Mileage: 92640km/57563miles
01-Engine -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door,Rear Left -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
Address 01: Engine Labels: Redir Fail!
Part No SW: 06F 906 056 BA HW: Hardware No
Component: MED9.5.10 G00 7001
Revision: 00000000 Serial number: SEZ7Z0D2788324
Coding: 0000072
Shop #: WSC 06402 785 00200
16825 - Can't Decode, CODE File Not Loaded!
P0441 - 008 - Can't Decode, CODE File Not Loaded! - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 5P0 907 044 C
Component: ClimatronicPQ35 005 0202
Shop #: WSC 00000 000 00000
00716 - Can't Decode, CODE File Not Loaded!
000 - Can't Decode, CODE File Not Loaded! - Intermittent
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001328061
Coding: 818C8F2700041000001E00000000000000007F0B5C
Part No: 5P0 955 119 A
Component: Wischer SE359 012 0402
Coding: 00056272
Shop #: WSC 00000
3 Faults Found:
00987 - Can't Decode, CODE File Not Loaded!
012 - Can't Decode, CODE File Not Loaded! - Intermittent
00526 - Can't Decode, CODE File Not Loaded!
01502 - Can't Decode, CODE File Not Loaded!
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 5P1 035 152
Component: Radio BNO 0029
Coding: 0040400
00856 - Can't Decode, CODE File Not Loaded!
011 - Can't Decode, CODE File Not Loaded!
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 5P0 919 283
Component: 06 Einparkhilfe 0101
Shop #: WSC 10125 599 69511
2 Faults Found:
01547 - Can't Decode, CODE File Not Loaded!
009 - Can't Decode, CODE File Not Loaded!
006 - Can't Decode, CODE File Not Loaded!
Va multumesc anticipat !
divinewind,
era pentru mine link-ul de mai sus? daca da mai bagat in ceata :)
Scuze, nu am vazut raspunsul tau. Cauta numarul de la eroari in linkul trimis de mine si vei gasi sfaturi despre remediere la toate alarmele. Interfata ta nu este intalata corect.
Pina la urma m-am dus in alta parte si am mai scanat-o odata, si e ok, am doar eroare la un senzor de parcare si atit!
apropos cel suparat ca ce legatura are comutatorul de pedala frana cu martorul bujii...sa stii ca pe comutator pedala de frina se afla inca in inrerupator in interiorul lui care actioneaza in momentul cind apesi frina reduce la jumatate injectia pentru injectorul principal...normal ca are treaba cu motorul martor bujii....ce nu intelege tipul?nu te uita la swich asa pur si simplu vezi ca are 4 pini 2 sunt folositi pe stop frina...da plus la becuri frina iar celelalte 2 fire duc la comp unde ii zice cind frinezi tu sa reduca consumul de motorina......asta este valabil doar pentru diesel......bafta tuturor
Vad ca au fost sterse si nu au mai aparut.
Buna! Am un polo 9N din 2002 si am de ceva vreme in bord martor aprins la motor si la servodirectie. Mecanicii din jur nu prea stiu ce e de facut. Am schimbat deja prima sonda lambda, bujii, dar tot acolo e martorul. La servodirectie nu am nici o problema; nu merge greu, nu suna, doar martor activat. Cele doua coduri care apar sunt: P0420 si P0134. Sper sa ma ajutati, multumesc anticipat.
Prima e din cauza catalizatorului, nu mai e eficient.
Salut in urma scanarii am si eu urmatoarele erori la motor ma poate ajuta si pe mine cineva cu niste sfaturi pt remedierile lor ???
AG-COM Version: Release 311.2-N
Control Module Part Number: 045 906 019 AQ
Component and/or Version: 1,4l R3 EDC 0000SG 1555
Software Coding: 00002
Work Shop Code: WSC 00788
Additional Info: WVWZZZ9NZ3Y017121 VWZ7Z0B5266094
2 Faults Found:
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-00 - -
ECU nu vede ca altrenatorul incarca : ori nu incarca ori e un fir rupt intre alternator si ECU, fiind polo merg pe varianta 2.
Turbina nu dezvolta destula presiune, furtun spart sau altceva.
Vad ca a mai avut un user problema cu pressure dar nu stiu cum a rezolvat-o :(
Revin cu o scanare completa a masinii
VAG-COM Version: Release 311.2-N
Chassis Type: 9N1 - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 045 906 019 AQ
Component: 1,4l R3 EDC 0000SG 1555
Coding: 00002
Shop #: WSC 00788
2 Faults Found:
P1556 - 35-00 - -
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0001097
Shop #: WSC 00788
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 08 -------------------------------------------------------
Controller: 6Q0 820 045
Component: Klimaanlage X0840
3 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to B+ - Intermittent
29-00 - Short to Ground
00819 - High Pressure Sensor (G65)
07-00 - Signal to Low
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S32
Coding: 09228
Shop #: WSC 00788
01054 - Power Supply Relay: Terminal 30 (J317)
28-00 - Short to B+
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Q0 920 800 M
Component: KOMBI+WEGFAHRSP VDO V12
Coding: 01132
Shop #: WSC 44725
No fault code found.
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 00 GATEWAY CAN 1S32
Coding: 00014
Shop #: WSC 00788
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 00788
Address 56 -------------------------------------------------------
Controller: 6X0 035 152 B
Component: Radio BNO 0006
Coding: 00001
Shop #: WSC 00788
End -------------------------------------------------------
lordkiller4ever
P1556 - 35-00 - -
de la alternator pleaca 2 fire ...au fost taiate ... am remediat ..dupa un o luna 2 am verificat iar ... aceeasi eroare... am duso la verificat in servis unde au descoperit intercooleru spart ...din cauza carcasei care freca pe intercooler (carcasa a intrat in 2 cm in intercooler, probabil nu mai statea fixa ) ....... verifica cele 2 fire sa nu fie intrerupte si intercooleru ...succes
Modificat de lordkiller4ever
Am fost azi la un mecanic si mia zis ca eroare este de la injectoare sa schimb injectorul 1 si injectorul 2 :)))
Hal de mecanici ce avem in tara asta x(((
Buna ziua,
Sunt posesorul unui VW Polo 1,4 16V, 55Kw, cod motor BBY, din 2002 si am o intreaga poveste cu probleme. Intr-o zi nu a pornit la prima cheie, ci abia la a 6-a sau a 7-a. Am considerat ca e din cauza benzinei (de la MOL) si am incarcat cu benzina co 95 de la omv. Am observat o imbunatatire, a inceput sa porneasca din prima, dar greoi, trebuia sa o accelerez mai tare ca sa isi fixeze turatiile de relanti. Apoi a aparut in bord senzorul de motor si senzorul EPC. Am facut o diagnoza cu VAG-com si a iesit "Manifold admission pressure" sensor, intre timp am schimbat: filtru benzina, bujii si senzorul MAP. Si tot nu a disparut eroarea. Am observat ca la relanti motorul nu are turatii uniforme, ci "tremura", iar in mers pierde din putere si "balbaie" sau se "smuceste" destul de des, ca atunci cand ridici piciorul de pe ambreiaj cand schimbi vitezele. Am curatat clapeta de acceleratie, Egr e curat, am verificat si firele care pleaca de la admisie si pana in calc(si totul e bine), dar eroarea tot nu dispare.
Nu mai stiu nr erorii, dar mai stiu ca scria ceva cu short/ intermitent si apoi la o noua diagnoza nu mai era intermitent.
Cu Vag-com am incercat sa sterg eroarea, dar reapare imediat la pornire.
Astept pareri. Multumesc
Modificat de micha87
Asta a rezultat in urma scanarii cu vag-com:
Thursday,06,October,2011,09:57:10:18594
VCDS Version: Beta 11.8.0
Data version: 20110831
Chassis Type: 9N - VW Polo
Scan: 01 02 03 08 09 15 17 19 25 37 44 45 46 56 76
VIN: WVWZZZ9NZ2D070578 Mileage: 122150km/75900miles
Address 01: Engine Labels: 036-906-034-APE.lbl
Control Module Part Number: 036 906 034 DD
Component and/or Version: MARELLI 4MV 4448
Software Coding: 00071
Work Shop Code: WSC 31414
Additional Info: WVWZZZ9NZ2D070578 VWZ7Z0B4834353
VCID: 57B682469817
2 Faults Found:
17550 - Load Calculation Cross Check: Lower Limit Exceeded
P1142 - 35-10 - - - Intermittent
17564 - Manifold Pressure Sensor (G71): Open/Short to Ground
P1156 - 35-10 - - - Intermittent
Readiness: 1010 0001
Address 03: ABS Brakes Labels: 6Q0-907-37x-ABS2.lbl
Part No: 6Q0 907 379 E
Component: ABS FRONT MK60 0103
Coding: 0001097
Shop #: WSC 31414 000 00000
VCID: 3F864AE61067
2 Faults Found:
01276 - ABS Hydraulic Pump (V64)
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
VCID: EAD04BB2BB65
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.lbl
Part No: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 25758
Shop #: WSC 31414
VCID: 3A703BF20B45
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 S
Component: 09 AIRBAG VW5 03 0007
Coding: 12345
Shop #: WSC 31414
VCID: 4796520648B7
Address 17: Instruments Labels: 6Q0-920-xxx-17.lbl
Part No: 6Q0 920 800
Component: KOMBI+WEGFAHRSP VDO V11
Coding: 00141
Shop #: WSC 00000
VCID: EAD04BB2BB65
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 31414
VCID: F0E459DA9DB9
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6Q0 423 156 AA
Component: LenkhilfeKYO V957
Coding: 10140
Shop #: WSC 00000
VCID: 6ED8C7A2078D
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 H
Component: 1G Komfortgerát 0001
Coding: 00067
Shop #: WSC 31414
VCID: 4084491A6D99
Subsystem 1 - Part No: 6Q2959802A
Component: 1G Tõrsteuer.FS TFK 0003
Subsystem 2 - Part No: 6Q2959801A
Component: 1G Tõrsteuer.BF TFK 0003
End ---------------------------------------------------------------------
Precum am mai scris, am senzorul Check engine si EPC aprinse, iar masina merge ca naiba.
Astept pareri sau cei cu experienta poate ma pot ajuta in Bucuresti.
Am schimbat senzorul, dar degeaba. Dupa ce l-am schimbat s-a aprins la 2 zile si EPC si a inceput sa balbaie. Am postat si rezultatul scanarii
Am mai montat si o inchidere centralizata, cred ca nu poate afecta asta,nu??? Desi merge defectuos, ba merge, ba se intrerupe.
Eu am un martor foarte smecher :)) Martorul de la servodirectie se aprinde dimineata,cand e frig si se inchide in timpul zilei,la caldura. Servodirectia merge brici. Eroare de la scan zice ceva de senzor temperaturii de la servo, codul erorii este 00817.
Are cineva vreo idee ? Nu vreau sa schimb pompa de servo ca merge bine :-?
Salut am si eu o eroare. Mi`a aparut acum o sapt doua odata dar mi s`a stins si nu am mai avut probleme. acum dupa ce conduc 5 minute imi apare.
LE: scuze ca am uploadat imaginea invers.
post-97843-0-53023900-1323531102_thumb.j
Modificat de nicoara.seb
Filtrul de particule. Ori mergi mai mult pe autostrada sa-si faca regenerarea, Ori o faci ci VCDS.
DAr ce masina si ce cod motor ai, din ce an e ?
  • Vizitator changed the title to Polo 9N si 9N3 - Scanarea cu VCDS - coduri de eroare si remedierea lor
