Polo 9N si 9N3 - Scanarea cu VCDS - coduri de eroare si remedierea lor
octav59
Si care este problema, ca eu nu m-am prins :icon_thumright:
  • Replies 506
  • Al Bundy
    95
  • ionel.d.2007
    48
  • SergiuD
    17
  • cernescui
    11
voriam sa vad comparatie pe codarile de pe calculatoare de la alte 1.2
Unde se afla mufa de diagnoza la Polo din 2009? Nu este cel ultimul model, anteriorul. Pot folosi interfata vag com 908 cu mufa aceea tip OBD sau are alt fel de conector?
Aceeasi problema am gasit-o la un A6.
17911/P1503 - Load signal from Alternator Term. DF: Range/Performance / Implausible Signal
Possible Causes
  • Alternator faulty
  • Voltage Regulator faulty
  • Wiring and/or connections faulty
<a name="Possible_Solutions" id="Possible_Solutions">
Possible Solutions
  • Check / Replace Alternator
  • Check / Replace Voltage Regulator
  • Check wiring and connections
  • Check the fuse box that is in the battery tray, it might be burnt, the fuse or the complete plastic box (pretty common failure on Sharan because it carries so much electrical load). If so, change the complete fuse box, it is not too expensive fix if this is the cause.
Am remediat problema ... am avut ambele fire rupte.
Au mai ramas erorile astea:
Address 01: Engine Labels: 045-906-019-AMF.lbl
Part No: 045 906 019 AP
Component: 1,4l R3 EDC 0000SG 1554
Coding: 00005
Shop #: WSC 31414
VCID: 63CE2A7ADB3D
WVWZZZ9NZ3D069831 VWZ7Z0B5752676
17911 - Load Signal from Alternator Term. DF: Implausible Signal
P1503 - 35-10 - - - Intermittent
Readiness: 0 0 X X X
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 09358
Shop #: WSC 31414
VCID: 3B7EB21A030D
00903 - Fuse for Heated Outside Mirrors (S196)
37-00 - Faulty
Salutare, am facut si eu aseara un auto-scan si mi-a aparut asa ceva..
VAG-COM Version: Release 311.2-N
Chassis Type: 9N1 - VW Polo
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 045 906 019 BP
Component: 1,4l R3 EDC 0000SG 7220
Coding: 00002
Shop #: WSC 31414
WVWZZZ9NZ6D015412 VWZ7Z0E1811141
No fault code found.
Address 03 -------------------------------------------------------
Controller: 6Q0 907 379 AF
Component: ABS 8.0 front H03 0002
Coding: 0002136
Shop #: WSC 31414
Address 08 -------------------------------------------------------
Controller: 6Q0 907 044 C
Component: CLIMAtronic PQ24 0301
Coding: 0000000
Shop #: WSC 00000
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 D
Component: 00AF BN-SG. 1S34
Coding: 09246
Shop #: WSC 31414
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 6Q0 920 803 D
Component: KOMBI+WEGFAHRSP VDO V02
Coding: 01131
Shop #: WSC 48305
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 0B7L GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 31414
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AE
Component: LenkhilfeKYO V957
Coding: 10110
Shop #: WSC 31414
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 H
Component: 1D Komfortger
eroarea a fost intermitenta, sterge-o si sa vezi ca nu o sa mai apara.
Modificat de tucudean
G62 se schimba
verifica sigurantele alea mari tip lamela de pe baterie, una din ele, cea corespunzatoare pompei de ABS e intrerupta
V68 trebuie schimbat dar e cam scump.
sal tuturor .
de erorile astea ce ziceti ? care stiti ?
01314 - Engine Control Module
013 - Check DTC Memory
01276 - ABS Hidraulic Pump v 64
012 - Electrical Fault Circuit
01598 - Drive Battery Voltage
07-10 - Signal to low intermitent
Tin sa precizez ca am schimbat discul de ambraiaj de curand ....
Baterie descarcata sau dusa, din cauza baterie ai si eroarea la ABS verifica sigurantele de la ABS si mufa care intra in pompa de ABS , fa o scanare la motor posibil sa ai erori, bafta.
Modificat de liviuplaton
off ...pai bateria e noua. are 2 luni . pompa de Abs unde e localizata ? si sigurantele sunt alea de pe baterie ?
Modificat de adrian0404
Am facut si eu o scanare vag-com la masina mea VW POLO din 2003, motor 1,2 AZQ. La clima imi apar succesiv o serie de coduri de eoare, astfel:
Sunday, 07 November 2010, 11:18:57
VAG-COM Version: Release 409.1-S
Control Module Part Number: 6Q0 820 045
Component and/or Version: Klimaanlage X0840
Software Coding:
Work Shop Code:
7 Faults Found:
65535 - Internal Control Module Memory Error
00-00 -- -
01272 - Positioning Motor for Central Flap (V70)
30-10 -- Open or Short to B+ - Intermittent
01609 - Cooling Fan in Control Module
01275 - Rear Side Airbag Shut-Off Key Switch (E280)
28-00 -- Short to B+
01285 - Side Airbag: Passenger Side: Disabled
29-10 -- Short to Ground - Intermittent
01601 - Sensor for Rotor-Position in Electric Motor
41-10 -- Blocked or No Voltage - Intermittent
01610 - Switch for Drive-Type (E228)
Sunday, 07 November 2010, 11:26:47
Software Coding:
Work Shop Code:
01271 - Positioning Motor for Temperature Flap (V68)
30-00 -- Open or Short to B+
Sunday, 07 November 2010, 11:29:15
Software Coding:
Work Shop Code:
3 Faults Found:
01597 - Drive Battery Pre-Charge Circuit
01284 - Side Airbag: Drivers Side: Disabled
29-00 -- Short to Ground
Sunday, 07 November 2010, 11:33:34
Software Coding:
Work Shop Code:
3 Faults Found:
Sunday, 07 November 2010, 11:46:40
Software Coding:
Work Shop Code:
4 Faults Found:
41-00 -- Blocked or No Voltage
Sunday, 07 November 2010, 11:48:27
Software Coding:
Work Shop Code:
Sunday, 07 November 2010, 11:54:43
Software Coding:
Work Shop Code:
2 Faults Found:
28-10 -- Short to B+ - Intermittent
Ma poate ajuta si pe mine cineva cu un sfat. Multumesc
Salut. Cand am cumparat masina acum vreo 2 ani am avut urmatoarea eroare:
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 B HW: 028 101 147 8
Component: R4 1,9L EDC 0200SG 5645
Revision: 12345678 Serial number: VWZ7Z0D9472895
Coding: 0000071
Shop #: WSC 00028 028 00001
1 Fault Found
19463 - Camshaft Position Sensor (G40): No Signal
P3007 - 000 - -
Freeze Frame:
RPM: 840 /min
Torque: 32.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.14 V
Bin. Bits: 11000000
Idle Stabilization: 0.0
16725/P0341/000833 - Camshaft Position Sensor (G40): Implausible Signal
Possible Symptoms
Malfunction Indicator Light (MIL) active
Possible Causes
Wiring from/to Camshaft Position Sensor (G40) faulty
Timing misaligned
Possible Solutions
Check Wiring from/to Camshaft Position Sensor (G40)
Check Camshaft Position Sensor (G40)
Check Timing
Modificat de Moog
MAi pe romaneste verifica daca distributia este bine pusa la punct.
Cea dea doua eroare sa pastrat la fel si inainte si dupa ce am facut distributia. Distributia am facut-o la un prieten care are service, si a folosit cale dedicate acestui tip de motor (conform manualelor de reparatie). Mentionez ca atunci cand motorul are vreo 40-50 de grade, merge de rupe asfaltul, dar chiar si in mers daca stergi eroarea, reapare instantaneu, deci senzorul nu are momente cand merge si cand nu merge. Consumul este foarte bun (0,5 l/h la relanti, 4% la 100 km/h, 4,7% la 125km/h, 5,1% la 150km/h , cam 7-8% in bucuresti). Am incercat sa-i modific avansul in + si - din cele 3 suruburi de la volant axei cu came dar nu am avut rezultate mai bune. Concluzia mea este ca distributia este pusa bine. Sa inteleg ca nu se poate sa fie sensorul defect din fabricatie?
Modificat de Aditu
Este posibil sa dea aceasta eroare de la un alt senzor pe care il foloseste calculatorul pentru a regla avansul? Adica stiu ca atunci cand nu functioneaza camshaft sensor, calculatorul regleaza avansul dupa crankshaft sensor. Este posibil sa fie eroarea in alta parte? :(
Modificat de BillyMKV
Salut ma poate ajuta si pe mine cineva cu erorile astea in special cea cu ABS
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
VIN: XXXXXXXXXXXXXXXXX Mileage: 221550km/137664miles
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 8D0 907 401 P
Component: 2.5l/4VTEDC 0000SG D66
Coding: 02015
Shop #: WSC 30937
VCID: 3162179A97734C94
4 Faults Found
01442 - Misfire due to Lack of Fuel
00550 - Start of Injection Regulation
17-10 - Control Difference - Intermittent
00523 - Intake Air Temp Sensor (G42)
30-10 - Open or Short to Plus - Intermittent
00553 - Mass Air Flow Sensor (G70)
31-10 - Open or Short to Ground - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D36
Coding: 04255
Shop #: WSC 06435
VCID: 356A238A631B60B4
2 Faults Found
18265 - Load Signal: Error Message from ECU
P1857 - 35-00 - -
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 M
Component: A4 KLIMAAUTOMAT D57
Coding: 00063
Shop #: WSC 06325
VCID: 2A5000F6BAA53F4C
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 J
Component: Airbag Front+Seite 1001
Coding: 00106
Shop #: WSC 06325
VCID: 3D7A3BAA5B2BB8F4
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 931 TX
Component: B5-KOMBIINSTR. VDO D13
Coding: 00060
Shop #: WSC 19410
VCID: 9024321EBC39E59C
XXXXXXXXXXXXXXXXX AUZ7Z0C2381243
1 Fault Found
00771 - Fuel Level Sensor (G)
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D12
Coding: 12865
Shop #: WSC 06325
VCID: 2C5C06EEB051217C
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06325
VCID: E5CA33CA133B5034
1 Fault Found
00776 - Level Control System Sensor; Left Front (G78)
31-00 - Open or Short to Ground
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186 E
Component: Radio 0001
Coding: 00205
Shop #: WSC 06325
VCID: 2240E8D6C295E70C
Address 76: Park Assist Labels: 4B0-919-283.lbl
Part No: 4B0 919 283
Component: Parkingsystem A4 RDW D18
Coding: 00114
Shop #: WSC 06325
VCID: E6C834C6EE3D5B2C
End ---------------------------------------------------------------------
Nu sunt sigur 100% dar erorile de la ABS sunt datorate erorilor stocate in ECU. Cum majoritatea erorilor sunt intermitente eu recomand stergerea lor si vezi care reapar. Pe mine m-ar ingrijora mai mult eroarea cu MAF-G70/G42. Eventual verifica(curata) contactele la mufe. :icon_thumright:
Salut leam sters o data si au reaparut din nou da stiu ca am si debitmetru defect si egr ramas pe deschis ,abs merge lam incercat acum pe zapada se poate sa fie un contact oxidat pe undeva ,si mersi mult pentru raspuns
LA MULTI ANI ,SANATATE SI FARA EVENIMENTE NEPLACUTE TUTUROR UTILIZATORILOR FORUMULUI!!!
Lantul a fost schimbat,dar din cauza ca masina a fost lovita(destul de tare)inca nu am pornit-o.
Ieri a fost testata si a scos o gramada de erori.Daca le postez poate cineva sa ajute cu interpretarea codurilor si ce este de facut mai departe?Multumesc,edit
Posed un wv polo 9n.Am scanat si am depistat urmat.erori:
16955 brake -switch (F) implausibile signal P0571-35-10 intermittent 16955 P0571 Cruise/Brake Switch (A) Circ Malfunction
17664 engine cooland sensor (G62)open or short to plus P1256-35-10 intermittent.
Stie careva sa-mi traduca ce semnifica aceste erori?Multumesc anticipat
  • Vizitator changed the title to Polo 9N si 9N3 - Scanarea cu VCDS - coduri de eroare si remedierea lor
