Amortizoare
Florin M.
Oke. Astept cu nerabdare.
FanBarcelona
Borisake
post 722 - te rog sa ma ajuti.
multumesc!
Nu apare cod de suspensie in PR codes de la tine.
PRCode: 1AC = Anti-lock brake system (ABS)
PRCode: 1D0 = Without trailer hitch
PRCode: 3FE = Electric slide/tilt sunroof with sun screen/sunblind
PRCode: 3NZ = Rear seat bench unsplit backrest split folding
PRCode: 4A0 = Without seat heater
PRCode: 4F1 = Central locking system
PRCode: 4R2 = Power windows front mechanical window regulators rear
PRCode: 4UE = Air bag for driver and front seat passenger
PRCode: 4X0 = Without side air bag
PRCode: 5RQ = Right exterior mirror: convex
PRCode: 5SL = Left exterior mirror: aspherical
PRCode: 6Y0 = Without cruise control warning system
PRCode: 7AA = Electronic vehicle immobilization device
PRCode: 7Q0 = Without navigation device
PRCode: 8AA = Without radio
PRCode: 8GL = Alternator 120 A
PRCode: 8RE = 4 speakers (passive)
PRCode: 8X0 = Without headlight washer system
PRCode: 9AB = Manually controlled air conditioning
PRCode: B02 = Type approval Belgium
PRCode: E0A = No special edition
PRCode: H6R = Tires 195/65 R15 T
PRCode: J0R = Battery 380 A (80 Ah)
Puteai sa vezi asta si singur la http://prsearch.planetvag.com/ sau in alte 100 de locuri... sau puteai macar sa scrii codurile sa nu stam cu gatul flexat dupa ele. Numai zic...
FanBarcelona
top
ms de informare, insa as fi dorit sa stiu ce tip de suspensie am...nu ce dotari...oricum apreciez timpul rezervat cautarii dupa codurile respectie...Multumesc!
ideea e- sau cel putin asa consider...cred ca passatul este de fabricatie 97' ...iar suspensia e jalnica...acum vro 2 luni am mers cu un passat cu bratele- 6 la numar duse, acu vro cateva zile cu un vento din 95'.... altfel amorseaza...la mine zdrangane la gropi...parca ceva in partea de sus-unde se prinde amortizorul- transmite socurile in masina...
acest lucru se simte mai accentuat la partea din spate- insa aici nu am schimbat nimic- insa chiar si asa..socurile se transmit in masina- nu sunt preluate de mecanismele specifice...
as vrea sa schimb macar arcurile din fata, sa vad daca e vrun rezultat- dar pana nu am unele certitudini- nu investesc nimic...
o sa incerc sa vad ce zic cei de la scorpion- poate ma ajuta dupa seria de sasiu.
Modificat de FanBarcelona
In lista aia de dotari s-ar fi regasit codul de suspensie, daca era..
Probabil ai suspensie "normala" - oricum, sigur te pot ajuta la service dupa seria de sasiu.
Arcurile nu stiu daca are sens sa le schimbi, ele nu pot fi "stricate" ci doar lasate sau rupte.
Partea de amorsare e strict din amortizoare.
Daca zici ca zdrangane ceva deasupra, o fi flansa de la amortizor? La un service ar trebui sa se prinda de asta.
Nu ti-am urmarit poroblemele. Bratele in ce stare sunt?
Eu n-am scapat de fenomenul asta decat dupa ce am schimbat toate bratele si toate amortizoarele.
Abia apoi s-a facut liniste in masina. Si acum, dupa 120.000km masina e tanc.
FanBarcelona
cand am luat masina bratele erau o combinatie de optimal trw si originale...
zgranganea....am schimbat bratele toate- RTS- bieleta directie TRW...nimic...or fi amortizoarele...la 3 luni pun KYB, metahoane, aparatori praf...nimic..or fi arcurile...insa nush ce mama dracu sa pun...nu ma astept sa fie ca atunci cand era noua, insa nici chiar asa...
zdranganit= la gropi parca se loveste ceva in partea de sus...socul se simte sus, neamorsat..se simtea si pe vechile amortizoare...erau originale...odata cu schimbarea lor senzatia si-a mai pierdut din intensitate insa tot se simte...
COSMIN, mi-a zis cineva sa nu fie de la bord- partea aceea metalica de care se prinde bordul...???stii ceva?
P.S. am simtit ceva la fel, la un punto scurt 2001 sport...
Nu cunosti istoricul masinii, orice piesa poate fi suspecta...
Si a mea zdranganea in draci pana am schimbat tot. Aceeasi senzatie o aveam, ca masina se imprastie, nu e inchegata deloc. Parca si bordul trepida din toate incheieturile.
Dar arcurile au ramas tot alea. In cazul tau, eu le-as exclude. Prea putin o sa influenteze.
Ai facut vreun test la noile amortizoare? Chiar daca sunt noi. Eu cred ca nu-si fac treaba.
FanBarcelona
senzatia asta de nu e inchegata -  e data de brate nu?
o sa caut prin apropiere sa vad cine se ocupa cu testarea amortizoarelor...
insa cunosc un mecanic care si-a reconditionat toate amortizoarele inclusiv pe cele de la portbagaj. tot un b5 are, doar ca e variant..ma bate gandul sa le fac pe cele ale masinii- poate nu o fi chiar asa mult ca pret, si sa vad daca e vro diferenta...
Senzatia aia... e cam 60% din amortizoare si 40% din brate/pivoti.
Cand eu le-am schimbat toate, noile amortizoare "sachs" au cazut dupa nici o luna. Iar senzatia de masina imprastiata a revenit destul de tare.
Apoi am reconditionat amortizoarele oem si le-am pus alea pe masina. Acum, dupa cei 6 ani si peste 100.000km tot tanc e.
FanBarcelona
ms COSMIN de ajutor...stiu ce am de facut...daca este realizabil voi reveni aici cu ceea ce s-a realizat.
multumesc, mult...
Asa se aude si la mine. Am schimbat bucsele de la bratele de sus, pus Lemforder, nu e de la ele. Anul trecut am schimbat amortizoarele fata, pus Bilstein, flansele cica sunt beton, cel putin asa erau cand am schimbat amortizoarele.
Voi incerca sa iau niste amortizoare dintr-o sursa sigura si sa fie Boge, KW, ceva ce nu prea se falsifica, fiind in serie de productie mai mica. Eu banuiesc ca suspensia cu totul, fiind putin obosita, amplifica aceste sunete. Putin de colo, putin de colo si rezultatul e unul "de efect" :D
Am verificat masina in fel si chip, nimic nu da semne concrete ca ar fi
Calarasiul e un oras rupt in doua, distrus, etc.. E pacat de banii mei sa fac o investitie de 6-8000 de lei deodata, doar pentru 1 an de liniste. Le voi schimba pe rand, desi ies mai scump per total. Voi face si un test de amortizoare, chit ca au un an de zile si vreo 25k km.
 Putin de colo, putin de colo si rezultatul e unul "de efect" :D.
Corect.
Iar niste amortizoare moi, numai bine amplifica acel "putin".
Care-i diferenta culorilor la etichetele Sachs? Am vazut etichete de culoare albastra si rosie.
Am vazut la un magazin online si cu rosu, mai sus ca pret, parca.
A testat cineva prin pantelimon amortizoarele?
Ma refer la ce exista oficial in catalogul Sachs. In magazin pot sa vanda ce vrea muschiul lor ca "se potriveste, sefu, garantat" dar oficial... nope.
Poti verifica aici, ca m-am uitat si la pentru BGW de curiozitate
https://webcat.zf.com/index.asp?SPR=4
My bad! Imi retrag ultimul post.
Vad ca la al meu merg 33-117a sau f pe fata, iar pe spate merg 27-c11p sau f. Am pdf-ul de la boge, cine-l vrea sa imi dea pm.
Modificat de Mishutz
FanBarcelona, in coltul din dreapta sus al cartonului este trecut "BE" - ce ar corespunde suspensiei sport. Nu vad pe carton in alt loc mentionat BA sau BB. Posibil masina sa fi avut suspensie sport de fabrica. Verifica la reprezentanta, poate te lamuresc ei.
FanBarcelona
astept raspunsul celor de la scorpion focsani.
Asa  cum spuneam revin cu impresii dupa montarea amortizoarelor Kayaba (2 bucati pe fata).Masina se comporta foarte ok mai ales in viraje,sta foarte bine pe drum fata de cum era inainte,a disparut efectul "barca",pot aborba curbele cu alte viteze.Pe drum cu gropi cam "scutura" daca pot sa zic asa :P,or fi mai tari ca alea vechi si de aceea,oricum imi place ca e mult mai stabila la viteze mari. :icon_cool:
 Astazi ,daca am eu curaj sa-le schimb ,sau saptamana viitoare am sa-le schimb toate 4 cu KYB. Am gasit un video online de la KYB cum sa-le schimb
. Le-am luat de pe un site ,din germania la 220e cu transport , Gaz/Nitrogen toate 4. Au fost scumpe?
post-65746-0-87002100-1404554446_thumb.j
Modificat de DrackulA
Atentie la surubul care strange pivotii bratelor superioare. Nu intotdeauna iese oricat spray si ciocane i-ai da. Uneori iese doar bucati, cu spirale si alte scule. Trebuie sa ai de rezerva, comandate inainte,
Uite aici cum se rupe unul.
Modificat de 42miticutza
Deh, vaselina e scumpa.
N-are treaba vaselina. Acel surub poate avea si 10 ani acolo, batut de apa, noroi, sare, etc
