EGR - probleme
botze
Cred ca am descoperit problema. Electrovalva de sub vasul de expansiune(cred ca N18) este plina de ulei. Oare daca o curat va merge ? sau trebuie alta.
Depinde pana unde a ajuns uleiul.
Incearca. Daca nu, alta.
Salutare forumiștilor,
Am nevoie de ajutorul vostru. S-a pierdut brusc puterea motorului.
Am făcut cateva masuratori la Passatul meu si nu stiu foarte bine sa le interpretez.
Group 003: EGR (Exhaust Gases Recycling)
789 /min Engine speed 740-840
643.7 mg/str MAF (specified) 180-270 mg/H
357.2 mg/str MAF (actual) 160-290 mg/H
88.4 % EGR duty cycle 40-75%
Group 011: Boost pressure limitation -Full load -3rd gear - 3500rpm
789 /min Engine speed 2900-4000
1122.0 mbar Spec. intake press. 1900-2300 mbar
999.6 mbar Actual intake press 1900-2300 mbar
85.2 % N75 duty cycle
Group 010: Intake - Full load - 3rd gear
345.4 mg/str MAF >750
989.4 mbar Atmo. press
989.4 mbar Intake press. 1900-2300
11.8 % Throttle 100%
Group 008: Injected quantity(IQ) limitation - Full load - 3rd gear
789 /min Engine speed 2800-3500
0.0 mg/str IQ driver >50
41.7 mg/str IQ rpm(torque) 42-47
23.5 mg/str IQ MAF(smoke) >48
Group 004: Start of injection - Full load-4000rpm-85*C
789 /min Engine speed 3800-4200 rpm
4.0 °BTDC Spec. start 10-14 *BTDC
4.6 °BTDC Actual start 8-16 *BTDC
37.5 % Cold start valve
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Control Module Part Number: 1C0 959 799 B
Component and/or Version: 03 Komfortgerát HLO 0001
Software Coding: 00259
Work Shop Code: WSC 05311
Additional Info: 1C1959801 03 Tõrsteuer.FS 0001
Additional Info: 1C1959802 03 Tõrsteuer.BF 0001
Additional Info: 1C0959811 03 Tõrsteuer.HL 0001
Additional Info: 1C0959812 03 Tõrsteuer.HR 0001
VCID: 36683A5C38C1
3 Faults Found:
01336 - Data Bus for Comfort System
80-00 - Single-Wire Operation
00950 - Central Locking Motor - tailgate (V53); UNLOCK
25-00 - Unknown Switch Condition
00930 - Locking Module for Central Locking; Rear Left (F222)
27-00 - Implausible Signal
Toate masuratorile sunt facute cu motorul la relanti.
Fa-i o scanare numai pe 01 Engine si vezi ce erori ai stocate.Verifica si turbina. Eventual si un log in mers daca vrei (01 engine, grupurile 03, 10, 11). Vezi in prima faza daca membrana mai tine vaccum.
Modificat de pronet
Lista de erori e urmatoarea... :)
Saturday,30,June,2012,14:59:18:36838
VCDS Version: Release 10.6.3
Data version: 20101206
Chassis Type: 3B - VW Passat B5
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
VIN: WVWZZZ3BZ1E145487 Mileage: 172190km/106993miles
Address 01: Engine Labels: 059-907-401-AKE.lbl
Part No: 3B1 907 401 B
Component: 2.5l/4VTEDC G000SG D01
Coding: 03012
Shop #: WSC 53141
VCID: 1D3AC5F0BD37
Part No: 00009059
Component: 130 106BC062_2.V70562555090
WVWZZZ3BZ1E145487 VWZ7Z0Y3086068
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04255
Shop #: WSC 00000
VCID: 356A3D5025C7
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0001
Coding: 17000
Shop #: WSC 05311
VCID: 2854E424E275
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 B
Component: 0A AIRBAG VW5 04 0006
Coding: 12353
Shop #: WSC 05311
VCID: 36683A5C38C1
Address 16: Steering wheel Labels: 1J0-907-487-A.lbl
Part No: 1J0 907 487 B
Component: Lenkradelektronik 0001
Coding: 00008
Shop #: WSC 00000
VCID: 30640C44DAA5
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 845 A
Component: KOMBI+WEGFAHRSP VDO V12
Coding: 21125
Shop #: WSC 00006
VCID: 2240F60C8449
00462 - Control Module for Seat Memory; Rear (J522)
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05314
VCID: F0E44C449A25
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 03 Komfortgerát HLO 0001
Coding: 00259
Shop #: WSC 05311
VCID: 36683A5C38C1
Part No: 1C1959801
Component: 03 Tõrsteuer.FS 0001
Part No: 1C1959802
Component: 03 Tõrsteuer.BF 0001
Part No: 1C0959811
Component: 03 Tõrsteuer.HL 0001
Part No: 1C0959812
Component: 03 Tõrsteuer.HR 0001
4 Faults Found:
25-10 - Unknown Switch Condition - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
Address 47: Sound System Labels: None
Part No: 1J0 035 456
Component: Soundprozessor 3 0006
Coding: 00551
Shop #: WSC 05311
VCID: E2C0360C44C9
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D05
Coding: 00008
Shop #: WSC 00008
VCID: 040C90943E9D
01539 - Headlights Not Adjusted
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 186 E
Component: Radio BNO 0005
Coding: 00023
Shop #: WSC 05311
VCID: 2756E718EF6B
End ---------------------------------------------------------------------
Am incercat sa gasesc ceva erori si pe 01-Engine dar lista a fost complet goala.
Erorile stocate nu au legatura cu problema lipsei de putere. Fa-i un log in mers sa vedem exact ce valori ai.
In sfarsit am reusit sa fac un log :D
Asa dupa cum am citit in posturile anterioare am folosit clima pt a mai "fura" din puterea motorului.
LOG-01-003-010-011.xls
Modificat de a_gora
Salveaza log-ul in format csv sau xls.
LE: Verifica MAF-ul si turbina (actuator , respectiv geometria variabila) - presiunea nu este OK (spec vs actual).
Modificat de pronet
Multumesc mult pentru raspunsul prompt. Maine am sa verific toate problemele aparute. MAF-ul are valori mult mai mari decat cele normale. Turbina nu se aude deloc cum ca ar functiona.
Mersi inca odata.
Am găsit problema la lipsa puterii motorului. Actuatorul turbinei a fost defect. L-am schimbat la un service specializat GARRETT și uitați-vă ce a ieșit.
O seara frumoasa în sfîrșit... :beer:
02 iulie 2012 - 30xyz.xls
Buna ziua!
Am si eu o problema cu un golf 4 motor alh an 1999 cind pornesc citeodata motorul troncane parca nu ar avea alimentare cu aer sau motorina sau parca ar sariceva dinti de la distributie , opresc imediat motorul si cind ii mai dau o cheie o ia fara probleme , in reste functioneaza foarte bine , ce poate fi sa se blocheze cumva valva shut -off sau sa primeasca o comanda gresita la pornire? valva shut-off am vazut ca est ecomandata vacumatic nu electric sau ma insel ? distributia este schimbata recent role curea si pompa apa , dar acelasi defect il prezenta si inainte de a schimba distributia .
Imi spuneti si mie cat pot sa merg cu un EGR defect (membrana sparta din cate mi-a zis cel care mi-a facut diagnoza) si ce risc sa agravez daca aman prea mult?
Nu am probleme de pornire sau de mers, poate doar o oarecare (putin sesizabila) lipsa de putere la turatii foarte mici, plecare de pe loc in a-I-a.
Urmeaza sa plec in vacanta cu masina, ~2000 km.
Consum marit de carburant. Eventual il schimbi ca nu e un capat de tara. sau eventual in obturezi.
Modificat de pronet
Am BKD-ul pe Leon (2.0 TDI) si in oras ma invart pe undeva la 8% (Bucuresti) iar afara cam 6%. Nu am sesizat crestere a consumului de cand am problema asta cu EGR-ul. Cred ca va trebui sa obturez furtunul de comanda sa nu pierd vacuum necesar si altor comenzi.
Sa inteleg ca macar teoretic, nu ma afecteaza sa fac asta dupa ce ma intorc?
In afara de un consum marit de combustibil nu cred sa ai alte probleme. Oricum, o capsula cred ca se invarte pe la 250-300 lei. Cel putin parca atat am dat eu pe a mea cand s-a spart.
Mai intai sa fii sigur daca este membrana sparta sau este furtunul crapat. Poti verifica tragand aer cu gura direct de la capsula nu din futun (sunt patit) si daca se aude cum lucreaza membrana si tine vacuumul atunci nu membrana este de vina. Oricum daca chiar este capsula atunci fa cum ai zis si pune un surub in capatul furtunului pt ca pierderea de vacuum mai afecteaza si altele. Ca si marca te poti orienta la Pierburg, au un raport calitate pret bun (am vazut pe unele componente OEM ca scrie micut intr-un colt Pierburg).
Salut. Am tot citit pe forum si am o nelamurire si anume urmeaza sa schimb supapa egr la golful meu motor 1.9 tdi BKC. Nelamurirea consta: se mai face sau nu adaptarea cu vagcom a noului egr? la benzinare din cate am citit se face. Va rog sa ma lamuriti si pe mine. Daca se face,care este procedura?
Modificat de Pedy_golf 5
La TDI-uri nu se face nici o adaptare, numai la benzinare.
Salut.
De 2 zile citesc forumul asta si vad ca multa lume a anulat EGR-ul sau l-au inlocuit.
La mine problema sta putin altfel. Am si clapeta de SHUT-OFF si supapa EGR electric comandate, deci nu au furtunase de vacuum pe ele.
Problema mea e urmatoarea: cand accelerez si cand decelerez (deci nu la pedala constanta) se aude un fasait ca si cum s-ar desumfla o minge, sunet de furtun spart.
Am pus VAG-COM pe masina si am efectuat testele de comanda EGR si de comanda turbosuflanta (output test din VCDS) si vad ca daca EGR este 0% fasaie daca e 29% nu mai fasaie! La fel si cu comanda turbosuflantei (dar nu mai retin exact valorile). Ca observatie in plus, cand dau test de comanda la turbo sunetul motorului se schimba.
Masina trage, poate ceva mai slab ca alta data, dar este ok. Ma enerveaza fasaitul ingrozitor, mai ales daca am geamul deschis si trec pe langa orice ce poate reflecta sunetul (masini, cladiri, garduri din beton, etc) se aude groaznic.
Ma poate indruma cineva ce pot face in continuare?
Motorul meu este BMM.
Modificat de Catalinu
Cum e mai corect sa anulezi EGR-ul? sa Scoti furtunul de pe supapa egr si sa il obturezi cu un surub ca sa nu pierzi vacuumul sau sa scoti mufa de la N18,electrovalva responsabila functionarii EGR?
sa il blindezi cu o saiba oarba dedesubt sau pe galerie
Am descoperit obiectul care "fasaie". Este racitorul de gaze recirculate care intra in EGR, are o clapeta de bypass comandata de un cilindru de vacuum (ciuperca in denumirea populara). Pe langa axul clapetei de bypass, din cauza uzurii, scapa gaze de esapament si fasaie, afuma tot in jur si baga gaze in habitaclu. Este de la 300 de euro in sus nou fara montaj. Acum caut un racitor sa-l inlocuiesc, dar deocamdata am sa incerc si alte variante (sh, eventual, reconditionat, etc).
Daca as blinda acest racitor as bloca debitul de gaze prin acest racitor, ceea ce ar rezolva multe probleme, dar din cate am inteles citind pe forum, calculatorul de motor isi va da seama (nu am inteles exact cum) ca nu este debit de gaze si va aprinde "check engine". Daca cineva a blindat EGR-ul la motoare cu EGR electronic si filtru de particule (DPF) si n-a avut probleme sa imi zica, ca sa stiu daca ii fac felul, sau il las asa...
cel Wahler cam dup 7-8 luni o sa functioneze un pic in trepte nu mai culiseaza lin dar isi face treaba
dar despre acel distibuitor de vacuum care tine loc de n75, n18 si ... ce stiti ca eu nu am vacuum deloc pe egr s turbo decat daca opturez furtunul care se duce la filtrul de aer, daca il las opturat nu pot ca se accelereaza in suturi, am inteles ca foloseste la reglarea geometriei turbo, ce tensiuni sunt in acea mufa eventual ( adica 1-2 este 12v si comanda ciuperca aia mica de langa galeria de admisie, 3-5 cam 7-8v si parca comanda turbo si 4-6 tot cam 7-8v si comanda egr-ul sau invers) nu am tester dar vine in cateva zile, ceea ce stiu e ca am presiune maxima pe turbo 2200mbari (din lipsa vacuumului nu se modifica geometria) in mers abea se duce pana la 2000-2200 si rar ajunge la 100km/h, sa schimb oare cutia, acel distribuitor de vacuum a carui denumire nu o gasesc pe nicaieri si nici un magazin (sh e cam 200-400ron dar oare cat duce?) va rog frumos macar o parere cat de mica, ca nu stiu ce sa ii mai fac sa schimb cutia neagra sau sa verific firele
Salutare si scuze ca repet intrebarea dar am cautat ca disperatul vreo 2 ore pe forum si cu SEARCH si cu GOOGLE si nu am gasit raspunsul la intrebarea mea si stiu ca exista pe undeva numai ca nu am gasit raspunsul,ca l-am mai citit:
Cum functioineaza EGR, intre ce turatii e inchisa/deschisa , la relanti cum se comporta?Parca e ceva cu 1800-3000 rpm????
Nu e nevoie sa explicati rolul ei sau principiul de functionare ci doar ce am intrebat mai sus,ms anticipat.
Si inca ceva,vacuumul de la furtunul ce intra in EGR si vine de la N18 ar trebui sa-l simt cu gura,nuh?
Modificat de terminatoru
