Montare Instrument Cluster cu BC
oaspetele
la diagonza a iesit  00810 senzor1/2brake pressure sporadic 005 no  or incorrect  basic setting/adaptation,00810 sterring angle  sensor g85 no  or  incorrent basic  setting/adaptation ,01423lateral acceleration sensor sensor  g200 no  or  incorrent basic setting/adaptation. CAM asta este  tot  . daca  ma  mancat  sa pun  ceasurile sa  le probez...
faci procedurile de adaptare la g200 si g85
uite procedura pt fiecare operatiune care trebuie sa o faci
Lateral acceleration sensor (G200)
Requirements:
Minimum voltage of 12.0 V car
[select]
[03 - Brake Electronics]
[Measuring Blocks - 08]
Group 004
[Go!]
Check the box, the value must be between -1.5 and 1.5 m/s2.
[Done, Go Back]
[Coding-II - 11] or (if unavailable Coding-II)
[security Access - 16]
Enter 40168, provides access to the basic setting.
[Do it!]
[basic Settings - 04]
Group 063
[Go!]
Activate the Basic Setting.
[ON / OFF / Next]
When properly performed basic setting, field 2 should indicate "OK".
[Done, Go Back]
To make sure that the basic setting done correctly, check the sensor again.
Group 004
[Go!]
Check box 2, the value must be between -1.5 and 1.5 m/s2.
[Done, Go Back]
[Close Controller, Go Back - 06]
Steering angle sensor (G85)
Requirements:
Start the engine.
Rotate the wheel one turn to the right and then a turn to the left.
Drive a short distance in a straight line on level ground no faster than 20 km / h (just a few meters).
As soon as you stop the wheel easily without changing the position of the steering wheel (wheel straight).
Keep the steering wheel is not turned on.
Do not extinguish the engine.
Voltage in the system at least 12.0 V.
[select]
[Do it!]
Group 060
[Go!]
[ON / OFF / Next]
[Done, Go Back]
Group 004
[Go!]
Check box 1, the value must be between -1.5 and 1.5 °.
[Done, Go Back]
Marginal adaptation of the steering
(The engine still in motion)
Hold the steering wheel to the straight ahead position (± 10 °) for a minimum of 5 seconds.
Turn the wheel to the left until it stops and hold at the end of the second.
Turn the wheel to the right until it stops and hold at the end of the second.
Straighten the steering wheel and stick to the straight ahead position (± 10 °).
Turn off the engine and ignition.
Turn on the ignition.
Wait 5 seconds.
Steering light should go out. If not, do a short test drive.
Multumesc pentru  procedurii dar ce a blocat acei  senzori. Ceasurile noi sunt  vinovate  sau asta este efectul  cand  se probeaza alte ceasuri. Acum  sa  vad  pe  cine gasesc sa-mi faca adaptarile , monteze ceasurile si  maneta bc.
este vreo problema  daca  circul  cu  masina  pana  remediez erorile.
E o intrebare sau o afirmatie ?
Dar e criza de caractere...
s-au pierdut setarile, cand ai pus noile ceasuri. Nu e o problema.... se refac foarte usor setarile de baza.
daca pe tine nu te deranjeaza, nu e o problema
salut , am montat si eu pe un seat leon 1.9 tdi ceasuri de passat 1,9 tdi si am urmatoarea problema la viteza afisata pe ceasuri este mai mica decat trebuie sa indice adica (120Km/140Km) ma puteti ajuta si pe mine sa rezolv problema.
VEzi la codarile ceasului, acolo unde una din cifre indica factorul de demultiplicare pentru viteza.
Ai schimbat folia ceva ?
In output test cum e ?
Am icercat din codarile ceasului dar dupa salvare revine inapoi la codare, daca imi dai o ideie precum sa pastreze codarea.
Nu am schimbat nimic la ceasuri asa le-am cumparat .
La output test,testul este corect.
trebuie sa le pastreze , altfel , modificare in soft
C00, Instrument Cluster (J285) de codificare
C01, Xxx:?? Optiuni
C02, 01 = placute frana Purtați de avertizare activă
C03, 02 = avertizare centura de siguranță activă
C04, Avertisment 04 = Nivelul de lichid de spălare activ
C05, +16 = display secundar (radio / navigație) activ
C06, XX XX:? Tara
C07, 0 = Germania | 1 = Europa | 2 = Statele Unite ale Americii
C08, 3 = Canada / Mexic / America Latină | 4 = Anglia
C09, 5 = Japonia | 6 = Arabia Saudita | 7 = Australia
C10, xxx X: intervalele de service
C11, 0 = fix intervalelor de service w / o nivelului de ulei și senzorul de temperatură (PR-QG0)
C12, 1 = flexibil intervalelor de service cu nivelului de ulei și senzorul de temperatură (PR-QG1)
C13, 2 = fix intervalelor de service cu nivelului de ulei și senzorul de temperatură (PR-QG2)
C14, 3 = intervalelor de service memento inactive (SUA / Canada)
C15, xxxx:? Distanță Impulse Number (K-Value)
C16, 1 = semnal de viteză prin CAN (23400)
C17, 3 = 6 cilindri Light Armored vehicule (4134)
C18, 5 = Toate celelalte variante de motorizare (4182)
C19, 6 = 8 cilindri (W8 - 4128)
Ceasurile de bord indica eronat vcds indica viteza reala.
Care rulează 195/65R15 ' și 205/55R16'  (care sunt aproximativ același diametru) ar trebui să fie folosind codificare cifre 3 pentru un contor de parcurs precis.
Ce cod au ceasurile ? cel cu 3B0...
Si cum ai incercat sa il codezi ?
Ce codding
1)  17 -instruments si coding 07 codding 0011x
2)  17-instruments  login-11 13861 coding-07  codding 0011x
eu sa fiu sincer am folosit prima varianta dar cred ca era corect  sa  folosesc a doua varianta.
Pai spui ca ai codat si nu retine codding
la prima varianta nu retine coding dupa salvare tot coddingul cel vechi il am, nu stiu cum sa fac sa-mi retina coddingul ?
Nu e vorba ca nu retine , tie nu ti-l accepta pe cel ce doresti tu sa il pui :)
Fa si un printscreen cu "baloon" sa vedem exact ce ai acolo , ataseaza apoi aici
Nu trebuie sa te loghezi sa modifici codding 07
