suzu
Sal'tare la toata lumea.
Devenii posesoru' mandru al unui cablu de diagnoza (mii de multumiri dlui Voinea) si pusei si io pe masina din semnatura (Golf V GTi, 1,4TSI, 140 CP)
Si iote ce reiese:
Sunday,09,March,2008,12:36:52
VAG-COM Version: Release 607.3-UD
Address 01: Engine
Part No SW: 03C 906 032 E HW: 03C 906 032
Component: MED17.5.1 G 9740
Coding: 0000072
Shop #: WSC 01279
005697 - Please check DTC Memory of A/C Controller
P1641 - 000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 2
Mileage: 2288 km
Time Indication: 0
Date: 2000.00.00
Time: 19:12:03
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 48.0�C
Temperature: 36.0�C
Absolute Pres.: 930.0 mbar
Voltage: 12.319 V
Readiness: 0000 0000
Address 08: Auto HVAC
Part No SW: 1K0 907 044 BH HW: 1K0 907 044 BH
Component: ClimatronicPQ35 090 0909
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Address 52: Door Elect, Pass.
Part No SW: 1K0 959 702 N HW: 1K0 959 702 N
Component: Tuer-SG 005 0985
Coding: 0000436
Shop #: WSC 01279
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation
Cu G65 si cu geamu' de pe dreapta fata am inteles.
Da' ce-i cu prima eroare?
P1641 - 000 - -
Ce inseamna? Ca nici ROSS TECH nu o da explicata. :icon_thumright:
Am facut si eu o scanare. Rezultatul , iata-l :
Control Module Part Number: 06A 906 032 HJ
Component and/or Version: 1.8L R4/5VT 0002
Software Coding: 10700
Work Shop Code: WSC 13765
Additional Info: TMBSL21U328540962 SKZ7Z0A1022119
2 Faults Found:
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
16396 - Shareware Version. To Decode all DTCs
P0012 - 35-10 - Please Register/Activate – Intermittent
Cautand ce inseamna, am gasit :
1. 16804/P0420/001056 - Catalyst System; Bank 1: Efficiency Below Threshold
Possible Causes
• Oxygen Sensor(s) defective
• Oxygen Sensor(s) Control defective
Possible Solutions
• Check Oxygen Sensor(s)
• Check Oxygen Sensor(s) Control
• Perform Oxygen Sensor(s) Aging Check
Cum am mai avut aceasta eroare, cred ca trebuie schimbat senzorul de oxigen. Imi poate cineva spune unde este si cum se poate verifica ?
2. 16396/P0012/000018 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
Possible Symptoms
erratic idle
Possible Causes
• Intake Adjuster tight / stuck
• Intake Camshaft Adjuster faulty
Possible Solutions
• Check Intake Camshaft Adjuster
• Use Output Test, Meas. Value Blocks (MVB) & Basic Setting
Totusi, la a doua, nu inteleg de ce VAG COM-UL a dat "Shareware Version. To Decode all DTCs", fara alte specificatii.
in urma unei scanari am avut urmatoarele doua erori:
00281 - Vehicle Speed Sensor (G68)
35-00--
00953 - Interior Light TIme limit
25-10 Unknown switch condition - intermittent
imi puteti zice si mie ce inseamna aceste erori? mersi anticipat.
  Citat:
P1641 - 000 - -
Cand primesti eroarea asta inseamna ca ai erori la modulul de aer conditionat. (stocate in memoriea acestuia :) ). Nu este nici un motiv de panica
EDIT: la golf4 (parca!) erorile de A/C apar pe modulul de comfort. Nu stiu la golf5 cum este.
numai bine
Modificat de abuwz
Am facut o scanare la Augsburg unde din pacate mi-au gasit niste erori.
412C
412D
Din pacate nu am retinut ce explicatie era pe Vag-Com dar poate ma lamuriti voi ce-ar putea fi.
Merci!
412C - Misfire detected
412D - Cyl.1 Misfiring recognised
Verifica aprinderea la cilindrul 1.
Ce presupune verificarea aprinderii si cum s-ar putea remedia? :icon_redface:
Merci
Incepi cu ce-i mai usor...bujie, fisa....
Parcheaza noaptea la intuneric si inspecteaza sub capota cu motorul pornit. Nu trebuie sa vezi nici cea mai mica scanteie.
Daca ai fisele sub capacul motorului, scoate-l inainte.
Problema este ca la service dupa ce am schimbat filtrele si mecanicul a pornit motorul am vazut o scanteie in partea dreapta a motorului. Dupa accelerari succesive nu s-a mai repetat si mi s-a spus ca ar putea fi de la bobina de inductie. M-am hotarat sa schimb bujiile. Am inteles ca bobina de inductie se poate testa cu Vag-Com. Sper sa se rezolve dupa schimbul bujiilor. Masina merge "lesinata rau"..nu trage :)
salut!
dupa ce m-am doxat citind topicul cu erori la diesel si la banzina m-am decis sa postez log-ul scos din proc-ul masinii mele:
Address 01 -------------------------------------------------------
Controller: 036 906 034 BB
Component: MARELLI 4LV 3408
Coding: 00031
Shop #: WSC 23833
4 Faults Found:
16786 - EGR System: Excessive Flow
P0402 - 35-00 - -
16710 - Knock Sensor 1 (G61): Implausible Signal
P0326 - 35-00 - -
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
Readiness: 0010 0001
am urmatoarele rugaminti pt cei care recunosc erorile mai sus mentionate:
1) sa-mi explice fiecare eroare
2) eventual sa imi spuna, care ar fi simptomele la fiecare eroare (pentru a sti daca sa corectat ulterios).
3) unde sunt localizati, EGR, Senzor G62, Knock Sensor 1 (G61).
eroarea 16955 era de la becurile de frana, pe care le-am inlocuit (ambele fiind arse). restul nu stiu cum sa le explic.
multumesc!
16786- posibil sa fi ramas deschisa valva EGR sau o problema cu potentiometrul EGR-ului. Ai incercat sa-i faci setarea de baza?
16502- verifica pentru inceput conexiunile de pe circuitul senzorului; daca totul este Ok, trebuie inlocuit senzorul
Rezolva-le pe acestea doua si este posibil sa scapi si de 16710.
multumesc xxnelu! :)
nu stiu cum anume se face acea resetare, te rog sa imi detaliezi.
nu stiu unde este senzorul :lol:, de asemenea nici egr.
mai fa un pustiu de bine si ajuta-ma si cu astea.
simptome - uneori porneste greeeeuu invarte de inebuneste electromotorul, iar dupa ce porneste se duce in 1200rot/min. nu este o regula, poate fi cald/rece motorul simptoma este total aleatoare, de asemenea tot uneori, fluctuatii la relanti.
multumesc! :)
LE pentru senzorul de temperatura, pot folosi indicatiile din acest link?
http://www.wak-tt.com/tempsensor/tempsensor.htm
Modificat de dem3ntor
Adaptarea/setarea de baza a EGR-ului.... 01 (engine)/074 in Basic Settings => in campul 4 trebuie sa scrie in final Adap. OK
Pentru identificarea EGR-ului, am mai pus o poza AICI. O mai pun o data....poza :P
Ca sa localizezi usor EGR-ul la AZD, poza lui xxnelu e elocventa. Daca nu, vezi ca in EGR intra o teava din aluminiu cred care provine de la clapeta de acceleratie. Este foarte usor sa localizezi acea teava dupa care ai gasit intr-o parte clapeta de acceleratie (in partea de sus a motorului) si in partea de jos (adica mai in fata) EGR-ul.
salut
primesc eroarea aceasta si nu stiu ce e cu ea...
01358 - Internal Central Locking Switch: Driver Side (E150)
am sters-o si a reaparut, nu am nici o simptoma, becurile se aprind cand deschid usa, de incuiat se incuie fara probleme.... :beerchug:
multumesc!
Possible Causes
Wiring and/or Connectors faulty
Possible Solutions
Check Wiring and/or Connectors
Check Measuring Blocks
Postez si eu aici problema mea. Poate ma poate ajuta cineva. Am un Golf 4, 1.6 16 V si de 2 zile a inceput sa imi palpaie martorul de Gaze de Evacuare. Am dus-o la service si mecanicul a zis ca merge in 3 cilindrii. A inlocuit o bobina si a zis ca ii tot la fel. Aseara am facut o scanare VAG COM si au iesit urmatoarele probleme:
P0402 - 35-00 - -
17961 - Barometric / Manifold Pressure Signals: Implausible Correlation
P1553 - 35-10 - - - Intermittent
17566 - Manifold Pressure Sensor (G71): Implausible Signal
P1158 - 35-10 - - - Intermittent
Mecanicul zice ca trebuie schimbata valva EGR si senzorul G71, insa nu as vrea sa le cumpar si sa vad ca tot nu s-a rezolvat problema. Ideal ar fi sa fac un test dc are cineva asa ceva pt testare inainte sa le cumpar :Driver: . A mai avut cineva erorile astea la VAG COM? Si cum anume s-au rezolvat? Trebuie neaparat schimbate?
Mersi!
Eu zic sa incerci in prima faza o adapatre/setare de baza a EGR-ului. Daca nu se rezolva asa, faci o curatare urmata de adaptare. Stergi erorile si vezi care/daca mai apar. Inlocuirea lui o faci daca nu s-a rezolvat in conditiile mentionate mai inainte.
Pentru MAP (G71), incepi prin verificarea contactelor/firelor de pe circuitul lui, daca nu cumva dispar si erorile lui(17961/17566) dupa rezolvarea EGR-ului. Se mai verifica, sa nu traga aer fals.
Cam acestia ar fi, in mare, pasii de urmat pana la inlocuirea pieselor. :Driver:
nicolasnyck
am fost ieri si am pus masina la tester si mi sa spus ca sant probleme la 2 senzori
1 senzorul de admisie galerie
2 senzorul de acceleratie
acum cel care se ocupa de masina a spus ca nici unul din ei nu ar fi, astept parerea voastra.
ps au fost resetate cele 2 erori dar masina face la fel parca din ce in ce mai des
e vb de un vw bora 2001 14 16v benzina
multumesc mult
nicolasnyck
am revenit cu detaliile exacte cele spuse de program
1 senzorul presiune galerie admisie G71
2 senzorul turatie motor G28
acum cel care se ocupa de masina a spus ca nici unul din ei nu ar fi, astept parerea voastra cat mai repede.
multumesc mult
1. Nu avem codurile de erori...vezi cateva post-uri mai sus, cum ar trebui prezentat un rezultat al diagnozei.
2. Ar trebui sa ghicim pana si problema pe care o ai la masina, pentru ca nu vad nimic legat de acest aspesct.
Daca vrei un raspuns in baza datelor prezentate de tine, eu spun ca trebuie sa schimbi senzorii respectivi. Crezi ca este o informatie corecta? :)
nicolasnyck
multumesc mult azi am sa mai fac o diagnoza si am sa pun rezultatul oricum am sa schimb si cei 2 senzori si am sa curat si clapeta de acceleratie pt orice siguranta.
oricum multumesc mult si astept sfaturi dupa ce revin cu diagnoza
nicolasnyck
  xxnelu a scris:
am revenit cu singura eroare care a aparut acum dupa ce am diagnosticat-o din nou
asta e ceea ce apare
"Miercuri,07,Mai,2008,19:11:57:23792
Versiune: VAG-COM- ROJ 704.1
Adresa 01: Motor
Numar VAG: 036 906 014 AN
Componenta si/sau versiune: MARELLI 4CV 3151
Codare soft: 00031
Numar atelier: WSC 01317
1 cod de defect:
00513 - Senzor turatie motor (G28)
27-10 - semnal implauzibil - intermitent
Starea -Gata de functie-: N/A
astept un raspuns multumesc mult
  • Aerofan pinned this topic
