suzu
florin_racanel
Revin cu impresii ! Am schimbat supapa canistrei de carbon . Nu a mai aparut eroarea . Multumesc inca o data colegului "spido " pentru ajutorul dat . Cu stima !
Salut!Sunt putin confuz am eroaarea la modulul  Climatronic si nu gasesc unde e,tot ma indrume la G28,sau la mine tot aia e sau nu inteleg.Tot am probleme cand se incalzeste motoru,se opreste din cand in cand daca apas ambreajul si vreau sa bag din 2 in 1 si daca se opreste nu pot sa repornesc numai dupa 45 de minute dupa ce se raceste.Ori patesc ca dau la automat pana se descarca bateria.Golf 4 1.6 16v ATN.
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 0.7.0
   Coding: 01000
   Shop #: WSC 01317
   VCID: 2149030FAB3C3116BBD-515A
2 Faults Found:
00281 - Vehicle Speed Sensor (G68)
            37-10 - Faulty - Intermittent
Modificat de xabika
Schimbă G68. Ai să rămâi de căruță la mama naibii...
Astea sunt primele simptome...
Ar trebui să ai eroare și pe motor...
Modificat de Moog
Wednesday,15,March,2017,16:07:24:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
Mileage: 255820km-158959mi   Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   Mileage: 255820km/158959miles
Address 01: Engine        Labels: Redir Fail!
   Part No: 036 906 034 AM
   Component:  MARELLI 4LV       3290
   Coding: 00031
   Shop #: WSC 01317
   VCID: 5DB17FFFD7C455F6DF5-4A9C
2 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating; B1 S2
            P1118 - 35-00 - Open Circuit
17513 - Oxygen (Lambda) Sensor Heating; B1 S2; Heating Circuit
            P1105 - 35-00 - Short to Plus
Readiness: 1010 0101
Address 03: ABS Brakes        Labels: 1J0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379
   Component: ESP     20    CAN  V005
   Coding: 10241
   Shop #: WSC 01317
   VCID: E7DDDD1785988F26B59-4A3A
No fault code found.
   Coding: 01000
   Shop #: WSC 01317
2 Faults Found:
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 02 AIRBAG VW5       0004
   Coding: 12338
   Shop #: WSC 01317
   VCID: 3561C75F0FB4ADB6775-4A3A
00532 - Supply Voltage B+
            07-10 - Signal too Low - Intermittent
Address 17: Instruments        Labels: 1J0-920-xx0-17.lbl
   Part No: 1J0 920 822 A
   Component: KOMBI+WEGFAHRS. BOO V28
   Coding: 01143
   Shop #: WSC 00000
   VCID: 23450907B1202306A91-5072
   Subsystem 1 - Part No: Ident
   Component: Nr. WEGFAHRS.:VWZ6Z0Y1690742
   Ident.-Nr. WEGFAHRS.:VWZ6Z0Y1690742
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0EFB64BB056489EE43-5072
Address 35: Centr. Locks        Labels: 1C0-962-258-II.lbl
   Part No: 1C0 962 258 N
   Component: 1A Zentr.Verriegel. 0001
   Coding: 04097
   Shop #: WSC 01317
   VCID: 326BFC43FEDABA8E527-4A9C
End   ---------------------------------------------------------------------
 Acest log am facut azi,si numai la sonda im-i da eroare.
Curios eu am avut eroarea pe motor nu AC...am vazut-o si la altii tot pe engine...
Pe Wiki:
00281 - Vehicle Speed Sensor (G68): No Signal
Possible Causes
Wiring/Connectors faulty
Vehicle Speed Sensor (G68) faulty
Possible Solutions
Check Wiring/Connectors
Check Vehicle Speed Sensor (G68)
See Measuring Value Blocks (MVB)
Special Notes
When found in the 4-Speed Automatic Transmission (01M) transmission check for any applicable TSBs for overlay wiring harnesses as mentioned on the 01M page.
De aceea sant confuz, nu inteleg.........de ce oare acolo..
Nebănuite sunt căile domnului :)
Parcă citește și ala turația... Și ii da cu virgula...
salut,
La un vw golf 5 la scanarea cu vcds am eroarea de mai jos:
Address 56: Radio
   Part No SW: 1K0 035 186 AD    HW: 1K0 035 186 AD
   Component: Radio BVX       034 0046
   Revision: 00034000    Serial number: VWZ1Z2G3105567
   Coding: 0022201
   Shop #: WSC 51152 143 90753
   VCID: 68DFDE855BA2480261-803C
2 Faults Found:
01044 - Control Module Incorrectly Coded
De la ce ar putea fi? cum se pot corecta?
            000 -  -
01303 - Telephone Transceiver (R36)
            004 - No Signal/Communication
de la o codare incorecta, incearca sa codezi fara telefon
Salutare baieti.
Un amic a cumparat recent un golf gti din 2006.
Cand l-a cumparat a fost pus testerul, n-a dat nici o eroare.
Masina are facut tuning revo s2.
Mentionez ca in loc sa puna benzina de 100 ce altfel a i-a spus si fostul proprietar a pus de 95, apai acum nu stiu daca are sau nu vreo legatura dar i-a aparut ceck engine in bord. Am pus testerul , i-a aparut ceva erori pe care am uitat sa le salvez multiple missfire la cilindrii 1 si 4 si ceva erori la ceva valva . O sa postez mai tarziu codurile pentru ca le-am sters si am facut e rescanare sa vad daca reapar dar n-au mai reaparut decat acestea:
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000001128884
   Coding: E58D0F0600041814001400001400000000
   Shop #: WSC 12345 123 12345
   VCID: 408FA68B1376181ED43-8015
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 12345
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00218142
   Shop #: WSC 12345
5 Faults Found:
00834 - Signal for Activation of Heated Rear Window
            009 - Open or Short to Ground
02394 - Parking Light Left Front (M1)
            012 - Electrical Fault in Circuit
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
00061 - Footwell Lights
02395 - Parking Light Front Right (M3)
Astea erai si inainte dar nu e defect nici un bec (apare si in bord computer cand da contactul front right parking light defective)
As dori in primul rand sa stiu daca benzina are vreo legatura cu erorile aparute cu missfire?
Masina tremura din cand in cand cum ai si la golf/bora cand are probleme cu egr-ul doar ca nu fluctueaza relanti-ul.
Da, erorile de care vorbesti (nu cele afisate mai sus), pot avea o legatura cu benzina - calitatea acesteia.
Salut florin. Aici e codul pentru eroarea data pe lângă cele 2 missfire.
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Celalalte cu becurile nu mă prea interesează pentru că am aflat că acelea pot fi de la leduri. In afară de alea de la picioare, acelea nu se aprind. Poate să fie de la siguranțe.
verifica/schimba supapa de la canistra de recuperare vapori.
buna vin si eu cu o mica porblema legata de masina din titlu. mi s-a aprins initial becul de "check engine" si dupa scanarea cu vcds au rezultat vreo 9 erori. ma poate ajuta cineva cu ceva mai multe detalii legate de undele coduri? mentionez ca masina dupa pornire trepideaza enervant de tare insa fara oscilatii in turatii...cel putin nu in primele secunde, apoi par sa varieze un pic.
P0304
P0420
P0201-02
P1178
P1181
P1196
Multumesc anticipat.
Weekend placut tuturor!
VAG-COM Version: Release 409.1-S
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01,02,03,08,16,15,17,19,22,35,46,56
Address 01: Engine
   Controller: 06A 906 019 AK
   Component: 1.6l 2V/R4 SIMOS HS2554
   Coding: 04000
   Shop #: WSC 00046
Readiness: N/A
   Controller: 1J0 907 379 G
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00046
   Controller: 3B1 907 044 B
   Component: CLIMATRONIC     V 1.0.0
   Coding: 01000
   Shop #: WSC 68314
2 Faults Found:
01206 - Signal for Duration of Ignition: OFF
            35-10 - - - Intermittent
Address 15: Airbags
   Controller: 1J0 909 609
   Component:  A AIRBAG VW3 SG   0002
   Coding: 00065
   Shop #: WSC 00046
   Controller: 1J0 919 881 B
   Component: KOMBI+WEGFAHRS. MM0 V14
   Coding: 00143
   Shop #: WSC 00046
   Ident.-Nr. WEGFAHRS.:VWZ6Z0W0486414
Address 46: Central Conv.
   Controller: 1J0 959 799 N
   Component: 4E Zentral-SG Komf. 0002
   Coding: 04097
   Shop #: WSC 00046
5 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
00943 - Heated Exterior Mirror: Driver Side (Z4)
            35-00 - -
00944 - Heated Exterior Mirror: Passenger Side (Z5)
            35-00 - -
00930 - Locking Module for Central Locking: Rear Left (F222)
            27-00 - Implausible Signal
00931 - Locking Module for Central Locking: Rear Right (F223)
End   --------------------------------------------------------------------------------------------------
Ma ajuta cineva sa inteleg care-i treaba cu erorile acestea? :)
cosmin - ce probleme are masina ?
oricum, pare ca nu iti merge incalzirea la oglinzi (posibil probleme la sticle/rezistente - sa necesite inlocuire) si probleme la yalele spate stanga/dreapta - necesita reconditionare
Salutare, vin si eu cu o problema legata de masina a unei cunostinte, care are un golf 4  1.9 diesel. Masina nu porneste, electromotorul invarte pana se descarca acumulaorul.
          76
   Mileage: 243390km/151235miles
Address 01: Engine        Labels: 038-906-012-AGR.lbl
   Part No: 038 906 012 M
   Component:  1,9l R4 EDC 0100SG  2813
   Coding: 00002
   Shop #: WSC 01317
   VCID: 1A3B34E3866A62CE7A7-4A3A
3 Faults Found:
17664 - Engine Coolant Temp Sensor (G62)
            P1256 - 35-10 - Open or Short to Plus - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
            P1654 - 35-10 -  - Intermittent
16955 - Brake Switch (F)
            P0571 - 35-00 - Implausible Signal
Readiness: N/A
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 P
   Coding: 03304
   Shop #: WSC 01317
   VCID: 3E73D8733A826EEEA6F-4A3A
2 Faults Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            35-00 - -
            16-10 - Signal Outside Specifications - Intermittent
   Component: 02 AIRBAG VW5       0003
   Coding: 12338
   Shop #: WSC 01317
   Part No: 1J0 920 802 E
   Component: KOMBI+WEGFAHRS. BOO V21
   Coding: 01142
   Shop #: WSC 00000
   VCID: 2541171FBF14DD36C75-5072
   Component: Nr. WEGFAHRS.:VWZ6Z0X1159682
   Ident.-Nr. WEGFAHRS.:VWZ6Z0X1159682
00534 - Engine Oil Temperature Sensor (G8)
            30-00 - Open or Short to Plus
   Coding: 00006
   Shop #: WSC 01317
   Part No: 1C0 962 258 J
   Component: 01 Zentr.Verriegel. 0002
   Coding: 04097
   Shop #: WSC 01317
   VCID: 2E53E833EAE29E6E36F-4A9C
00947 - Trunk Lid remote Control Switch (E188)
Pana acum am schimbat la ea;
1.senzorul de telperatura, (G62)
2. intrerupatorul de frana
3. releul 109
4, VALVA EGR
5.verificat Hall senzor,/Senzor arbore cotit,
6.pompa combustibil functioneaza
7. injectoare schimbate
Daca cineva printre voi are vreo idee unde ar fi problema please tell us. MULTUMIM!
Buna ziua,
Am scanat Passat 3C din 2006 , 178.000 KM , motor 2.0 FSI si am gasit urmatoarele erori:
La motor :
000152 - Intake Air Temperature Sensor 2 (G299)
               P0098 - 002 - Signal too Low
             Freeze Frame:
                    Fault Status: 01100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 178695 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:46:10
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 38.0°C
Readiness: 1110 0101
Si o eroare la partea electrica care a ramas dupa ce am sters erorile:
01117 - Generator Terminal DF Load Signal
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 36
                    Mileage: 178695 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.30 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Imi puteti explica putin erorile si ce ar trebui facut/inlocuit !?
Va multumesc anticipat.
Problema la senzorul Intake Air Temperature Sensor 2 ,si verifica daca incarca  alternatorul
Alternatorul incarca , a fost verificat cand s-a schimbat bateria probabil mai da rateuri :( ...Air temperature Sensor 2 (G299) unde se gaseste si care ar fi codul sau pentru a cauta piesa de schimb?
Multumesc pentru feedback.
este incorporat in debitmetru
Multumesc de ajutor , ce afecteaza daca nu functioneaza!? Care ar fi simptomele nefunctionarii corespunzatoare al Air temperature Sensor 2 (G299)?
Modificat de SelesanD
Buna seara, va rog sa ma ajutati si pe mine cu urmatoarea eroare la Golf 5, 1.6 102hp:
19617 - Linear Oxygen (Lambda) Sensor B1 S1; Pump Current Wire
            P3161 - 008 - Open Circuit - Intermittent - MIL ON
             Freeze Frame:
                    RPM: 3040 /min
                    Bin. Bits: 00001000
                    Voltage: 4.720 V
                    Voltage: 0.000 V
                    RPM: 1696 /min
                    Bin. Bits: 00100000
                    Voltage: 5.060 V
                    Voltage: 0.000 V
De asemenea am facut si acest test:
               Address 01: Engine  (06A 906 033 CA)
02:34:48 Group 030: Lambda Control (Sensor Status)
       110  Bank 1 Sensor 1
       100  Bank 1 Sensor 2
02:34:48 Group 032: Lambda Control (Mixture Adaptation)
  0.8 %  Adaptation (Idle) Bank 1 Sensor 1
  1.6 %  Adaptation (Partial) Bank 1 Sensor 1
02:34:48 Group 033: Lambda Control
  0.0 %  Lambda Control Bank 1 Sensor 1
  2.19 V  Sensor Voltage Bank 1 Sensor 1
Daca sterg eroarea, reapare in 15-20km, am curatat contactele mufei, ce altceva s-ar mai putea face, sau trebuie neaparat schimbata? Precizez ca masina nu a trecut testul de noxe la relanti, dar la 2000/3000rpm noxele erau in limita. Va multumesc mult!
Salut. Am o eroare si nu reușesc sa scap de ea:
01087- basic setting not performed
    35 - 00 --
Am adaptat clapeta si tot nu dispare.
Daca poate cineva sa ma ajute. G4 1.4 16v cod AKQ. Mulțumesc.
Vezi sa nu fie cablul de acceleratie prea intins.
  • Aerofan pinned this topic
