suzu
Salutare. Sper sa nu ma intelege-ti gresit. Vreau sa cumpar si eu un cablu vcds dar nu prea stiu care este compatibil cu masina Mea(passat cc) nu stiu daca este mk5 sau mk6 si nici nu stiu unde ar trebui sa ma uit. Mulțumesc anticipat si Sper sa nu ma fac de rusine
Tocmai scrie mai sus : vcds rosstech 15.7.3
X 3 (ca parca de atatea ori ai postat) :)
Salut. Sper ca nu deranjez, exista vreo modalitate de a folosi vcds pe linux? Fara virtualbox sau alte programe pt masini virtuale...
Salutare. Am un prieten care are un golf 7 motor 2.0 cu dsg in 6 trepte si are urmatoarele erori :
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 040 A    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 3613
   Revision: 05652103    Serial number: TFK01301180657
   Coding: 0014
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 152127DFF4744DB6575-8040
10 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000010
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
21154 - Gear 2
          P072D 00 [002] - Not Selectable
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
21155 - Gear 3
          P072E 00 [002] - Not Selectable
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
21156 - Gear 4
          P072F 00 [002] - Not Selectable
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
21157 - Gear 5
          P073A 00 [002] - Not Selectable
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
21158 - Gear 6
          P073B 00 [002] - Not Selectable
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
21159 - Gear R
          P072B 00 [002] - Not Selectable
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
             Freeze Frame:
                    Fault Priority: 0
                    Fault Frequency: 82
                    Reset counter: 2
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
Aveti idee de la ce ar putea fi ? Am sters codurile de eroare, apoi am mers cu masina si iar au aparut. Inca o chestie care mi se pare ciudata e data care apare, anul 2020, ora este incorecta dar si kilometrajul e incorect. El are 160.000 de km. Ceva sfaturi/idei ? Multumesc anticipat
Vezi aici - vb de un releu sau harness sectionat. Parerea mea e ca de la ultimile 3 erori i se trage, in special ultima. Probabil se incalzeste si intra in avarie. reviziile la dsg au fost facute la timp? a fost inlocuita cutia? Km de acolo poate sa-i arate diferit. Si mie - cu interfata originala - la unele masini imi mai arata un an aiurea...dar niciodata la km.
Nu stiu daca a fost inlocuita cutia. Masina de abia a fost cumparata. Pe istoricul de la VW nu apare nimic legat de cutie schimbata. Reviziile au fost facute la timp. Ar fi costisitoare reparatia asta ? Cam ce bani ar costa ?
Si inca o chestie legata de KM si de ora. Inainte de stergerea logului azi :
                    Mileage: 10731 km
                    Date: 2010.06.16
                    Time: 16:08:00
Dupa stergerea logului si re-aparitia erorii :
                    Mileage: 21155 km
                    Date: 2020.10.18
                    Time: 00:08:00
Nu pot sa inteleg de ce a aparut asa si la KM si la data... Masina e din 2013 :)
In cazul aceste e de la interfata folosita - clona banuiesc. In genera reparatiile la DSG nu sunt deloc ieftine. Verifica inatai acel releu si conectivitatea de care vb tipul de pe forum ross tech.
1 nu ai inteles ce ti s-a spus
2 nefind VCDS nu ai ce cauta in acest topic
3. fiind o clona nu discutam despre astea pe acest forum
Salutare tuturor!
Sunt nou pe forum si as avea nevoie de ajutorul vostru ca sa stiu cum sa abordez problema cu cei de la service, care evident indiferent de ce se intampla, ei declara ca nu e de la interventia pe care au facut-o asupra masinii.
Situatia e in felul urmator:
Mi-am achizitionat un VW Polo 1.4 FSI, cod motor AXU, 2003. Am circulat o perioada cu el fara probleme, apoi intr-o zi ( din vina mea probabil pentru ca am smucit motorul mai tare intr-o panta mai abrupta) a inceput sa clantane foarte tare si am dus-o la service (cand am auzit zgomotul am oprit masina si am chemat direct tractarile). Cei de acolo au mai pornit-o de cateva ori si mi-au spus ca trebuie sa desfaca distributia sa vada despre ce este vorba. Erau rupte patinele intinzatoare, care au cedat din cauza ca pinionul de pe arbore era uzat si arunca lantul. Daca tot am am desfacut-o am schimbat si distributia + pinionul de pe arbore, care nu venea in kit-ul de distributie. Totul a fost ok, dar dupa cativa km mi s-a aprins check engine-ul in bord. Avand o diagnoza VAG COM am facut o scanare, am resetat tot in speranta ca era ceva temporar. Dupa alti cativa km aceeasi poveste asa ca m-am intors la service. Au facut si ei o scanare si mi-au zis ca nu are cum sa fie de la ce au facut ei, ca senzorul e pe volant si ei au lucrat in alta parte. Concluzia a fost ca trebuie sa schimb eu senzorul de turatie arbore cotit, evident sa platesc eu si senzorul si manopera, insa nu am facut inca acest lucru pentru ca mi se pare prea suspect ca inainte sa umble ei totul mergea ok, iar imediat dupa s-a stricat senzorul asa, din senin.
Spuneti-mi va rog si parerea voastra? Ce ar putea fi ?
Multumesc frumos si astept cu nerabdare raspunsurile voastre ca sa stiu cum procedez in continuare. La urma urmei, schimb si acel senzor eu, doar sa nu mai fie probleme, insa ma gandesc ca poate problema e din alta cauza si nu as vrea sa arunc banii pe fereastra. Am inteles ca ar trebui sincronizat senzorul dupa ce se schimba distributia.
La o scanare completa, acestea sunt erorile pe care le primesc.
Address 01: Engine Labels: Redir Fail!
Part No: 03C 906 013 B
Component: MED7.5.11 4884
Coding: 00071
Shop #: WSC 20911
VCID: 1B3FBC99894014F99A9-5178
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 35-00 - Incor. Correlation
Readiness: 1110 0101
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Q0 820 045
Component: Klimaanlage X0840
VCID: 6AD1A95D169A3D71D1F-515A
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to Plus - Intermittent
nu pare sa fie senzor defect, ci problema la distributie - si valorile celor doi senzori, nu sunt corelate - drept pentru care iti aprinde martorul
NU este distributia bine pusa la punct, clar. Nu este niciunul dintre cei 2 senzori defecti.
Address 01: Engine        Labels: 06A-906-032-AUM.lbl
   Part No: 06A 906 032 HJ
   Component: 1.8L R4/5VT     G   0002
   Coding: 10700
   Shop #: WSC 31480
   VCID: 6DD12F3F276425764F5-5072
   TMBSL21U828570250     SKZ7Z0A1369612
2 Faults Found:
18057 - Powertrain Data Bus
            P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
18010 - Power Supply Terminal 30
            P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0000 0001
Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Part No: 1C0 907 379 H
   Component: ESP ALLRAD MK60     0101
   Coding: 0023174
   Shop #: WSC 31480 000 00000
   VCID: 2F6DF537BDE897663D9-5072
4 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left  (G47)
            008 - Implausible Signal - Intermittent
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
            012 - Electrical Fault in Circuit
01317 - Control Module in Instrument Cluster (J285)
            000 - -
Address 08: Auto HVAC        Labels: 1Ux-907-044.lbl
   Part No: 1U1 907 044 A
   Component: CLIMATRONIC     C 2.0.0
   Coding: 11000
   Shop #: WSC 31480
   VCID: 306FF64BF0D6889E243-5072
No fault code found.
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605
   Component: 0L AIRBAG VW51 0B   0004
   Coding: 12364
   Shop #: WSC 31480
   VCID: E1C9C30F6BBCF1167BD-5072
            62-00 - No or Incorrect Adjustment
Address 16: Steering wheel        Labels: 1J0-907-487-A.lbl
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0004
   Coding: 00118
   Shop #: WSC 31480
   VCID: 2F6DF537EDE897663D9-50E6
Address 17: Instruments        Labels: 1U0-920-xxx-17.lbl
   Part No: 1U0 920 821 H
   Component: KOMBI+WEGFAHRSP VDO V08
   Coding: 31122
   Shop #: WSC 31480
   VCID: 3467FA5B04CEB4BE40B-5072
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 31480
   VCID: F0EFB64BB056489EE43-5072
2 Faults Found:
01044 - Control Module Incorrectly Coded
            35-00 - -
00778 - Steering Angle Sensor (G85)
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0010
   VCID: 204F060BA036381EB43-4A3A
2 Faults Found:
01316 - ABS Control Module
            79-10 - Please Check Fault Codes - Intermittent
Address 29: Left Light        Labels: 1U0-941-651-29.lbl
   Part No: 1U0 941 651
   Component: EVG GDL + AutoLWR   0002
   Coding: 00006
   Shop #: WSC 31480
   VCID: F0EFB64BB056489EE43-4A9C
Address 39: Right Light        Labels: 1U0-941-651-39.lbl
   Coding: 00006
   Shop #: WSC 31480
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 B
   Component: 3X Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC 31480
   VCID: 3663C05312B2A6AE7EF-4A3A
   Subsystem 1 - Part No: 1U4959801D
   Component: 3X Tőrsteuer.FS KLO 0004
   Subsystem 2 - Part No: 1U4959802D
   Component: 3X Tőrsteuer.BF KLO 0004
   Subsystem 3 - Part No: 1U0959811D
   Component: 3X Tőrsteuer.HL KLO 0004
   Subsystem 4 - Part No: 1U0959812D
   Component: 3X Tőrsteuer.HR KLO 0004
00930 - Locking Module for Central Locking; Rear Left (F222)
            27-10 - Implausible Signal - Intermittent     VA ROG CEVA PARERI
Ia sterge tu toate erorile si vezi ce mai ai dupa...posibil senzorii ABS de inlocuit.
Salut. Vreau sa cumpar si eu o interfata vcds, am gasit ceva cu versiunea 14.10 si spune ca are versiune noua de LCode. Inseamna ca suporta long coding ? Si am mai gasit o interfata vcds ver 11.11 si cica are chipset complet. Va rog sa ma lamuriti si pe mine ce inseamna LCode si daca merita sa iau ver 14.10 sau 11.11.
Long coding - poti face codarile pe diverse module, etc
din pacate, nu avem voie sa discutam despre clone, pe forum - iti putem recomanda o interfata originala Ross Tech - costa undeva in jurul la 1600 lei.
ACUM APARAE ASTA:Address 03: ABS Brakes        Labels: 1C0-907-37x-ESP-A.lbl
   Coding: 0023174
2 Faults Found:
01486 - System Function Test Activated
            000 - -
            012 - Electrical Fault in Circuit          --------------------------------------------------------------------
   Coding: 12364
   Shop #: WSC 31480
            62-10 - No or Incorrect Adjustment - Intermittent        precizez ca acum se aprind martori in bord am reusit sa fac din program asta din CAN GATEway
Senzor spate dus si ai inceput testul pe ABS dupa care nu l-ai terminat..
Am urmatoarele erori dupa clear all si scanare:
Address 01: Engine        Labels: 03G-906-021-BLS.clb
   Part No SW: 03G 906 021 RQ    HW: 03G 906 021 AB
   Component: R4 1,9L EDC G000SG  1843
   Revision: --H09---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 05311 000 00000
   VCID: 7F071BBC2E03BDE6ED9-802A
2 Faults Found:
000280 - Engine Coolant Temp. Sensor (G62)
               P0118 - 000 - Signal too High - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.17 V
                    Bin. Bits: 00001100
                    Temperature: -6.3°C
                    Temperature: 12.6°C
005488 - Engine Start Blocked by Immobilizer
               P1570 - 000 -  - Intermittent
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 244123 km
                    Time Indication: 0
                    Date: 2015.12.30
                    Time: 07:30:04
             Freeze Frame:
                    RPM: 1218 /min
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 11.32 V
                    Bin. Bits: 00001100
                    Bin. Bits: 11000000
                    (no units): 33.0
Readiness: 0 0 0 0 0
Ce inseamna eroarea de la Engine Coolant Temp. Sensor (G62)? Este defect senzorul?
un coleg sa imi spuna si mie ce inseamna erorile dupa o scanare golf 4 1.9 tdi pd
   4 Faults Found:
17965 - Charge Pressure Control
            P1557 - 35-10 - Positive Deviation - Intermittent
19557 - Motor for Intake Manifold Flap (V157)
            P3101 - 35-00 - Open or Short to Ground
18074 - PD Unit Injector; Cylinder 1 (N240)
            P1666 - 35-10 - Electrical Malfunction - Intermittent
16685 - Cylinder 1
            P0301 - 35-00 - Misfire Detected
Probleme la turbina,posibil geometrie blocata.
Clapeta v157 defecta sau cablaj intrerupt
Injectorul 1 ,contact imperfect la mufa sau trebuie inlocuit
Modificat de EEXCALADE
multumesc EEXCALADE, dar despre ce clapeta este vorba? v157 sau mai bine spus unde este clapeta? o sa merg maine sa vad mufa de la injector poate scap doar cu ea si nu trebuie alt injector.
Primul element de dupa furtunul prin care intra aerul in galeria de admisie
Salutare. Am eroarea urmatoare pe masina din semnatura: 18051 - please check DTC memory of electric load controller. Masina are uramtoarea simptoma: uneori, turatia la relanti creste la 1000 rpm. Nu conteaza daca este rece sau cald motorul. Ce trebuie verificat? Multumesc
Pai masina te roaga se verifici erorile de pe centrala si tu ne intrebi ce sa faci?
  • Aerofan pinned this topic
