suzu
Salutare
Intrebare: este normal sa oscileze valorile citite in ABS Brakes,Meas.blocks/Basic settings, adica atunci cand masina sta pe loc, Rotation rate si Transverse acceleration, oscileaza intre 0.00 si -1.50.
Multumesc anticipat
post-20257-0-60733500-1443024270_thumb.j
salut! ce probleme sunt aici ? Golf 4 1.6fsi an 2004 luna 12
VIN: WVWZZZ1JZ3W196975 License Plate:
Mileage: 168760km-104862mi Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: WVWZZZ1JZ3W196975 Mileage: 168760km/104862miles
Address 01: Engine Labels: Redir Fail!
Part No: 036 906 013 D
Component: MED7.5.11 G 5129
Coding: 00031
Shop #: WSC 12345
VCID: 102F56CB5096A89E043-5072
WVWZZZ1JZ3W196975 VWZ7Z0B5818411
4 Faults Found:
19498 - Heater Regulation
P3042 - 35-00 - Implausible Signal
17441 - Sensor for NOx (G295)
P1033 - 35-10 - Signal too Low - Intermittent
17701 - Map Controlled Engine Cooling Thermostat (F265)
P1293 - 35-10 - Short to Plus - Intermittent
18322 - Pressure Sensor for Brake Boost (G294)
P1914 - 35-10 - Implausible Signal - Intermittent
Readiness: 0010 0001
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 M
Component: ESP FRONT MK60 0102
Coding: 0011266
Shop #: WSC 01271 785 00200
VCID: 3467FA5B54CEB4BE40B-5072
No fault code found.
Address 08: Auto HVAC Labels: 3Bx-907-044.lbl
Part No: 3B2 907 044 C
Component: CLIMATRONIC C 0.7.0
Coding: 01000
Shop #: WSC 10547
VCID: 224B0C03AE3A2A0EA27-51D0
00792 - A/C Pressure Switch (F129)
35-00 - -
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 A
Component: 27 AIRBAG VW51 01 0004
Coding: 12855
Shop #: WSC 01271
VCID: 224B0C03AE3A2A0EA27-5000
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J5 920 826 G
Component: KOMBI+WEGFAHRSP VDO V13
Coding: 01110
Shop #: WSC 00000
VCID: 326BFC43FEDABA8E527-5000
2 Faults Found:
01039 - Coolant Temperature Sensor (G2)
64-10 - Not Currently Testable - Intermittent
00667 - Ambient Temperature Signal
29-10 - Short to Ground - Intermittent
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01271
VCID: F0EFB64BB056489EE43-5000
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 B
Component: 1C Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 01271
VCID: 3663C05312B2A6AE7EF-4A3A
Subsystem 1 - Part No: 1C1959801A
Component: 1C Tőrsteuer.FS KLO 0004
Subsystem 2 - Part No: 1C1959802A
Component: 1C Tőrsteuer.BF KLO 0004
Subsystem 3 - Part No: 1C0959811A
Component: 1C Tőrsteuer.HL KLO 0004
Subsystem 4 - Part No: 1C0959812A
Component: 1C Tőrsteuer.HR KLO 0004
00928 - Locking Module for Central Locking; Front Driver Side (F220)
CAm multe pe motor, senzorul Nox, senzorul de vacuum, terostatul electronic, pe ceasuri senzor temp exterioara si cel de pe motor si o problema cu usa sofer.
Salutare. Va cer ajutorul in legatura cu urmatoarea scanare:
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
          75 76
   Mileage: 131090km/81455miles
   Part No: 036 906 034 BB
   Component:  MARELLI 4LV       3549
   Coding: 00031
   Shop #: WSC 31414
   VCID: 53A599C7A1009386791-4A9C
Readiness: 1110 0101
Address 03: ABS Brakes        Labels: 1J0-907-37x-ABS.lbl
   Part No: 1J0 907 379 P
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 31414
   VCID: 3E73D8733A826EEEA6F-4A3A
   Part No: 3B1 907 044 C
   Coding: 01000
   Shop #: WSC 31414
   VCID: 2149030FAB3C3116BBD-50E6
00779 - Outside Air Temp Sensor (G17)
            30-00 - Open or Short to Plus
   Part No: 6Q0 909 605 A
   Component: 0F AIRBAG VW5  01   0004
   Coding: 12358
   Shop #: WSC 31414
   VCID: 3561C75F0FB4ADB6775-4A3A
01217 - Side Airbag Igniter; Driver Side (N199)
            32-10 - Resistance Too High - Intermittent
   Part No: 1J0 920 825 A
   Component: KOMBI+WEGFAHRS. BOO V01
   Coding: 05123
   Shop #: WSC 00000
   VCID: 26431013C212D62ECEF-5072
   Subsystem 1 - Part No: Ident
   Component: Nr. WEGFAHRS.:VWZ6Z0Y2082523
   Ident.-Nr. WEGFAHRS.:VWZ6Z0Y2082523
2 Faults Found:
01176 - Key
            07-10 - Signal too Low - Intermittent
01314 - Engine Control Module
   Coding: 00006
   Shop #: WSC 31414
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 AH
   Component: 4E Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 31414
   VCID: 8407EA9B94EE443E30B-49D8
   Subsystem 1 - Part No: 1J1959801C
   Component: 4E Tőrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 4E Tőrsteuerger. BF0002B
   Subsystem 3 - Part No: 1J4959811C
   Component: 4E Tőrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 4E Tőrsteuerger. HR0002r
3 Faults Found:
00953 - Interior Light Time limit
            25-10 - Unknown Switch Condition - Intermittent
01331 - Door Control Module; Driver Side (J386)
00915 - Window Regulator Switch; Rear Right; Driver (E55)
End   ---------------------------------------------------------------------
Cel mai tare ma ingrijoreaza:
Precizez ca masina nu mai trage ca inainte si erori in bord nu am.
Ai senzorul de temperatura exterioara cu probleme,conectorii de airbag scaun sofer ,ceva probleme cu switchurile usa.Cu eroarea de comunicare engine-sterge erorile si vezi daca mai apare ceva pe Can sau instrumente.Daca apare trebuie luat cablajul la verificat,conectori....
Modificat de spido
Merci pt raspuns.
Senzorul de temperatura, am verificat si nu-l am deloc, martorul de la airbag se aprinde atunci cand misc scaunul de la sofer si trebuie sa verific cablajul de sub scaun.
Ce ma intereseaza insa este aceasta eroare:
Primul lucru pe care l-am facut a fost sa intru pe Ross-Tech insa nu inteleg explicatia de acolo. Ma gandesc ca poate a mai intalnit cineva eroarea asta si i-a dat de cap de aceea intreb aici.
Modificat de Marius888
Am inteles ca dacă pui rezistență pe circuitul de airbag nu-ti mai sta aprins martorul din bord și nici nu-ți apare la scanare cu vcsd-ul. La mine nu-mi este aprins martorul în bord dar la scanare îmi apare eroarea de arbag. Care este explicația? Cred ca nu am siguranță pe circuit atata timp cat imi apare la scanare. Dar totuși în bord nu am martorul aprins.
Se pare ca la mine martorul din bord este acoperit/scos cu intentie..
Mai exact cum a fost facut aceasta "operatiune" , eventual sa refac cum a fost initial.
Rog un moderator daca considera ca nu trebuie tinuta aceasta discutie legat de airbaguri aici, sa mute unde este mai potrivit.
Pai daca rezolvi cu martorul-vei ramane cu el aprins pina la rezolvarea problemei cu airbagul.
Mercy de info, numai ca nu prea m-as baga la asa ceva.
E complicat ? Dupa, trebuie recodate, etc
Am vazut ca ar fi suficient daca desfaci cele 2 suruburi care tin ceasurile si clemele si il tragi afara, apoi cele 2 mufe din spate eventual....
Si bineinteles daca scoti borna nu isi pierde adaptarea...
Codarea nu si o pierde daca dai ceasurile jos.....cand pui contactul iti apare martorul de la airbag? Daca nu ti apare clar acoperit
La punerea contactului nu apare martorul airbag.
Mai mult decat atat, nici atunci cand scanez airbagul cu VCSD-ul nu palpaie (am verificat chiar acum asta).
Deci martorul este acoperit/scos.
O sa desfac sa vad cum a fost "rezolvat" (acoperit cu ce?, martor spart, pin/-uri desfacute; ma gandesc).
Si inca ceva. Am obsevat ca nici mufa de la butonul airbag, de pe mijlocul bordului (cel de langa butonul de avarii si incalzire luneta) nu este introdusa. Cand bag mufa palpaie acel buton si atat, nimic altceva.
Modificat de valerian Cj-napoca
Se dezlipesc lipitutile ledului de pe placa sau se acopera cu banda izolatoare neagra. Am vazut ambele variante cu ochii mei.
Salutare.
Astazi am patit o chestie nasoala: cablul sondei lambda 1 s-a desprins din colier, a ajuns pe evacuare, s-au topit firele si s-au unit intre ele, masina a inceput sa tremure, martorul de motor lumina intermitent si am venit cu ea asa vreo 2 km.Dupa ce am rezolvat problema cu firele topite(le-am izolat pe fiecare), masina face la fel, tremura si martorul de motor ramane aprins.Dupa scanare, imi tot da urmatoarele erori:
Control Module Part Number: 3B0 906 018 F
  Component and/or Version: 1,6l/2V SIMOS3  00HS0002
           Software Coding: 06031
            Work Shop Code: WSC 05311
           Additional Info: WVWZZZ3BZ1E161178     VWZ7Z0Y3216653
                      VCID: 23450907B1202306A91-5000
4 Faults Found:
16685 - Cylinder 1
            P0301 - 35-00 - Misfire Detected
16688 - Cylinder 4
            P0304 - 35-00 - Misfire Detected
16684 - Random/Multiple Cylinder Misfire Detected
            P0300 - 35-00 -
17805 - Sensor Wheel for Engine Speed
            P1397 - 35-00 - Adaptation Limit Reached
Readiness: 0010 1001
Intrebare: ce a putut sa se mai intample in urma lipirii firelor de la sonda lambda?
Se poate defecta ECU sau sonda, deconecteaz-o vezi daca motorul merge mai bine, ar trebui sa dispara erorile. Daca nu dispar si inainte nu le aveai cred ca ai prajit si ECU.
Va trebui sa rezolvi misfire de pe cilindrul 1 si 4. Bobina la motorizarea ta este monobloc, deci pentru a verifica care este situatia cu bobina plus fisele de pe cilindrii 1 si 4 va trebui sa o demontezi, altfel nu ai cum sa  inversezi fisele(sunt prea scurte)  sa vezi daca erorile se vor muta pe cilindrul 2 si 3. Verifica si bujiile.
Daca rezolvi cele 2 erori (misfire), cea de pe senzorul turatie arbore nu va mai apare. Sonda nu apare in lista, deci este in regula. Poti sa o verifici cu vcds-ul sa vezi exact. Un scurt in conexiunea sondei, cred ca ar ,,praji" siguranta alocata sondei, nu ECU.
Modificat de carmina
Multumesc pentru sfaturi, ma tot gandesc ca beleaua cu firele sondei lambda lipite nu prea are legatura cu misfire-ul, cred ca este o coincidenta nefericita.Oricum trebuie sa chem un mecanic sa vada/verifice monoblocul, bujiile, fisele.
  • Aerofan pinned this topic
