suzu
dupa ce am parcus topicul ... nu am gasit o solutie la problema mea..
am facut o scanare si pun aici erorile in speranta ca ma poate ajuta si pe mine cineva
VAG-COM Version: Release 704.1
Data version: 20070422
Monday,23,June,2008,17:59:27:55371
Chassis Type: 6N - VW Polo
Scan: 01 02 03 08 15 17 19 25 41 45 46 55
VIN: XXXXXXXXXXXXXXXXX Mileage: 96320km/59850miles
Address 01: Engine Labels: None
Part No: 030 906 032 AP
Component: ME7.5.10 3245
Coding: 00031
Shop #: WSC 00788
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Part No: 6Q0 909 601
Component: 15 AIRBAG VW5 0004
Coding: 12597
Shop #: WSC 00788
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 45: Inter. Monitor Labels: None
Part No: 6N0 951 171
Component: Innenraumueberw. 0002
65535 - Internal Control Module Memory Error
00-00 - -
Address 46: Central Conv. Labels: None
Part No: 6N0 959 799 B
Component: 7D Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00788
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
End --------------------------------------------------------------------------------------------------
Ce m-ar arde mai mult sa aflu ar fi: "16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal ". Eroarea asta am sters-o si deocamdata nu a mai aparut.
Ma intereseaza si celelalte daca stie cineva de unde vin.
Salut.
Am si eu un Seat Leon 1.8T 180cp.
Toate bune si frumoase pana azi cand am pus-o pe taster si a dat urmatoarele erori:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-10 - - - Intermittent
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
17536 - Fuel Trim; Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17658 - Fuel Level too Low
P1250 - 35-00 - -
Readiness: 0000 1001
Puteti sa-mi spuneti ce inseamna ? si cum s-ar putea remedia.
Ultima am remediat`o ... am bagat benzina :angry:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 036 906 034 DS
Component and/or Version: MARELLI 4MV 4466
Software Coding: 00031
Work Shop Code: WSC 59901
Additional Info: VSSZZZ1MZ3R034873 SEZ7Z0B1635276
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
P0118 - 35-10 - - - Intermittent
la ultima scanare din we :).
Cei de la service mi-au zis ca singura solutie este schimbare senzorului, nu se poate curata ;).
dupa ce am sters eroarea a inceput sa faca figuri indicatorul de apa, cateodata indiferent cat de mult as merge si nu se ridica acul de la 60 grade nici mort :P.
Are idee cineva daca se mai poate curata (si cum) sau cei de la service au dreptate si trebuie inlocuit.
Modificat de vaurel
nu ajuta daca il cureti. trebuie sa il schimbi si cu totul te va costa cam 100 ron maxim.
Este senzorul de presiune atmosferica din ECU, cel putin acolo e la mine. Ultimele 2 sunt de la senzorul de alarma de interior. Cea cu bateria , aavut vreodata tensiunea mica sau a fost solicitata la pornire.
Modificat de al bundy
2 Faults Found:
17763 - Cylinder 1 Ignition Circuit: Open Circuit
P1355 - 35-00 - -
17766 - Cylinder 2 Ignition Circuit: Open Circuit
P1358 - 35-00 - -
Stie cineva ce inseamna asa ceva? EU cred ca are legatura cu bobinele de inductie schimbate...
"16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal " eroarea asta am sters-o si eu si nu a mai aparut... darvreau sa stiu de unde a venit
Am o problema cu care ma lupt de jumatate de an...Mai precis incerc sa fac sa se stinga Check engine si sa reduc consumul (in oras aprox 11) ...intre timp am schimbat fisele, bujiile, am verificat toate furtunele sa fie ok, am curatat admisia....acum nu stiu daca pot sa fac ceva si la acel EGR sa il curat sau...?....am citit ce a facut si ceilalti cu acesta problema...in fapt am facut si eu...ce pot sa mai fac sa elimin eroarea si consumul mare ?
pe tester am urmatoarele erori
Eroare : Cod:17811
Sistem recirculare gaze, evacuare abatere reglare intre valoarea prescrisa si reala
Cod:16785
Sistem recirculare gaze, scurgere gaze evacuare prea redus
nu are nimeni nici o idee ce poate sa aiba ???
Un raspuns l-ai primit AICI.
Te rog sa citesti regulamentul si sa-l respecti:
5. Posturile monosilabice (gen bagare in seama), care nu aduc nimic bun discutiei ("cool", "de acord", "super", "rullz", "vreau si eu d-ala", si altele asemenea) sunt interzise si vor fi sanctionate cu warning. Nu suntem pe un canal de IRC ci pe un forum, daca nu va puteti abtine cautati alte comunitati
smariansilviu
dupa o scanare cu vag com au rezultat urmatoarele erori, stie cineva ce inseamna?
16556 - Fuel Trim: System Too Rich: Bank 1
P0172 - 35-10 - - - Intermittent
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 35-00 - -
Pentru prima eroare, exista mai multe cauze:
Fuel system
Excessive fuel pressure
Leaking or contaminated fuel injectors
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel
Vapor recovery system
Air leaks after the MAF
Vacuum leaks
Improper seated engine oil dipstick
Stuck EGR valve
Oil overfill
Cam timing
Cylinder compression
Exhaust leaks before or near HO2Ss.
A doua eroare, desi ar semnala "sonda defecta", ar putea fi generata in urma primei erori (de cauzele acesteia).
smariansilviu
am fost la service si dupa o scanare si o verificare au gasit o bobina de inductie arsa .sa vedem dupa ce o schimb cum se comporta,
Intre timp mi-a mai aparut o eroare
004248 - Intake Manifold Tuning Valve Position Sensor (G336): Open or Short to Plus
P1098 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 25376 km
Time Indication: 0
Date: 2008.06.25
Time: 20:52:48
Freeze Frame:
RPM: 2496 /min
Load: 50.2 %
Speed: 35.0 km/h
Temperature: 87.0
Am scanat motorul si am dat de urmatoarea eroare de la AC care nu functioneaza:
16916 - A/C Refrigerant Pressure Sensor (G65) Circuit Low Input
P0532 - 35-00 - -
Precizez ca am schimbat senzorul G65 si tot degeaba :D Cred ca e ceva cu mufa care intra in el sau pe circuit...
Ai verificat daca ai refrigerant in instalatie? Este la presiunea corespunzatoare?
Dupa o scanare la un G4 1,4 16v au rezultat urmatoarele:
Address 01 -------------------------------------------------------
Controller: 036 906 032 D
Component: ME7.5.10 3398
Coding: 00031
Shop #: WSC 31414
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Readiness: 1000 0000
Address 03 -------------------------------------------------------
Controller: 1C0 907 379
Component: ESP 20 CAN V005
Coding: 10753
Shop #: WSC 31414
00812 - Brake Pressure Release Solenoid (F84)
Sa inteleg ca la 01 este vorba de sonda lambda iar la 03 de switch-ul de frana? Sau sunt alte explicatii?
Va multumesc.
.....iar la 03 de switch-ul de frana? Sau sunt alte explicatii?
Switch-ul de frana nu este...ar putea fi vorba despre senzorul de presiune de pe unitatea hidraulica.
Am si eu o scanare si as dori sa o interpreteze cineva.
Saturday,05,July,2008,22:18:42:59303
Chassis Type: 1J - VW G/J/B Mk4
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 121940km/75770miles
Part No: 036 906 034 BH
Component: MARELLI 4MV 3773
Coding: 00031
Shop #: WSC 01317
17961 - Barometric / Manifold Pressure Signals: Implausible Correlation
P1553 - 35-10 - - - Intermittent
Part No: 6Q0 909 605 A
Component: 27 AIRBAG VW5 01 0006
Coding: 12855
Shop #: WSC 01317
Address 46: Central Conv. Labels: 1J0-959-799.LBL
Part No: 1J0 959 799 Q
Component: 2H Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
Part No: 1J1959801C
Component: 2H T
Modificat de xxnelu
Pe viitor, incearca sa postezi doar adresele cu erori.
Nu merge incalzirea oglinzilor retrovizoare si senzorul de presiune exterioara de valori eronate.
Deci aia 17961 ii de la senzorul de temp exterioara?Dar aia de la airbag ce semnificatie are?mersi
e senzorul de PRESIUNE atmosferica situat in general langa ECU. Aia de airbag arata ca ai avut tensiunea scazuta a bateriei.
1. Problema de la airbag: daca nu ai probleme cu bateria (contacte/borne) sau, cu alternatorul, verifica mufa/contactele de la unitatea de airbag.
2. Senzorul barometric nu este senzor de temperatura exterioara. Informatiile celor 2 senzori (barometric + MAP) sunt folosite pentru determinarea cantitatii de aer din admisie. Eroarea respectiva poate avea mai multe cauze: aer fals/contacte imperfecte in mufele celor 2 senzori(sau, a unuia dintre ei)/probleme cu clapeta/unul din senzori defect....
LE: hmm...scriu mai incet decat al bundy :wub:
mersi de ajutor
Am scanat si au iesit erorile :
Address 01: Engine
Controller: 03E 906 033
Component: 1,2l/4V SIMOS3 00HS7000
Coding: 00071
Shop #: WSC 46612
WVWZZZ9NZ2Y026642 VWZ7Z0A4384831
2 Faults Found:
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
Address 08: Auto HVAC
Controller: 6Q0 820 045
Component: Klimaanlage X0840
3 Faults Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-00 - Open or Short to B+
29-00 - Short to Ground
28-10 - Short to B+ - Intermittent
Address 09: Cent. Elect.
Controller: 6Q1 937 049 B
Component: BORDNETZ-SG. 1S31
Coding: 17566
Shop #: WSC 00788
01317 - Control Module in Instrument Cluster (J285)
Address 19: CAN Gateway
Controller: 6N0 909 901
Component: Gateway K<->CAN 1S31
Coding: 00014
Shop #: WSC 00788
Address 44: Steering Assist
Controller: 6Q0 423 156 M
Component: LenkhilfeTRW V210
Coding: 00140
Shop #: WSC 00788
Ce fel de spray de contacte sa cumpar ? cred ca asta e primul lucru care trebuie sa-l fac, sa desfac contactele la rand si sa le verific...
Si legat de consumul de benzina prea mare: 16556- fuel trim: system too rich ... care sunt cauzele ?
Modificat de xxnelu
Am facut si eu un test cu VAG-COM si mi-au aparut urmatoarele erori:
00511 - Selector Level (E313) - No Communications
00778 - Steering Angle Sensor (G85) - No Communications
01324 - Control Module for AWD (J492) - No Communications ???
Din cate am inteles, o maneta/buton de pe bord nu functioneaza cum trebuie....imi poate spune cineva mai exact despre ce maneta ar fi vorba? Ca mie mi se pare ca merg toate...
Despre 00778, chiar nu am idee care ar fi cauza, dar ultima eroare mi se pare chiar hilara....AWD la un Polo???
Daca ma puteti ajuta cu un sfat, va rog sa nu stati pe ganduri...:)
Numai bine!
  • Aerofan pinned this topic
