zorg
CAN-ul e codat corespunzator? Codarea o faci in functie de ce iti apare in acel balon de pop-up.
Sent from my GT-I8190 using Tapatalk 2
http://wiki.ross-tech.com/wiki/index.php/VW_Navigation_System_(RNS-MFD2_DVD)
http://wiki.ross-tech.com/wiki/index.php/VW_Radio_System_(RNS-MFD2_DVD)#Coding
scuza ma ce vrei sa spui prin  balon de pop-up.??
intrii pe adresa 56 Radio, mergi la Coding, si acolo o sa ai un numar, care trebuie sa corespunda specificatiilor radio si navigatiei.
Coding
00?xxxx: Treble Speaker Monitoring
1 = Front and Rear Monitoring inactive
2 = Front Monitoring active / Rear Monitoring inactive
3 = Front Monitoring inactive / Rear Monitoring active
4 = Front and Rear Monitoring active
00x?xxx: Radio Configuration I
+2 = CAN-Telephone Control
00xx?xx: Speaker Channels
0 = Sound System (active Speakers)
2 = 2 passive Speakers (Front)
4 = 4 passive Speakers
00xxx?x: Sound System Correction
0 = No Sound System (No Correction)
4 = Sound System (Volkswagen Sound)
7 = Sound System (Dynaudio)
00xxxx?: Radio Configuration II
+2 = CD-Changer
+4 = Digital Satellite Radio (SDARS)
Modificat de andrei_221
Asta nu stiu. Nu am verificat. Pot verifica cu o lampa normala de control? Sau trebuie un aparat special de masura?
Salutare ma poate ajuta cineva cu erorile acestea:
   Part No SW: 3C0 959 799 B    HW: 3C0 959 799 B
   Component:    KESSY PQ46 R 067 0211
   Revision: 00067000    Serial number: VWZCZ000000000
   Coding: 19910A0801C64E7638023F3F70085FCE101C0003240480
   Shop #: WSC 00157 210 50209
   VCID: 387536394B48AA9
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 3C0 951 171 A
   Component: Neigungssensor  002 0508
   Component: Innenraumueberw.002 0508
4 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 150605 km
                    Time Indication: 0
                    Date: 2013.11.30
                    Time: 20:48:10
00190 - Driver's Door Handle Touch Sensor (G415)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 150605 km
                    Time Indication: 0
                    Date: 2013.11.30
                    Time: 20:48:10
00192 - Left Rear Door Handle Touch Sensor (G417)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 150605 km
                    Time Indication: 0
                    Date: 2013.11.30
                    Time: 20:48:10
00193 - Right Rear Door Handle Touch Sensor (G418)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 150605 km
                    Time Indication: 0
                    Date: 2013.11.30
                    Time: 20:48:10
mersii
ceva interventii la masina la data si km aia ?
baieti, (si fete daca sunt)
spuneti-mi si mie de unde imi cumpar o interfata pentru diagnoza ceva "ieftin & bun" si ce anume varianta, ca am auzit ca sunt destule pe piata...
Multumesc x 100 !
...nici-un sfat..multumesc
Citeste topicul pe la pag 51, Vezi ca s-a mai discutat aici , trebuie sa ia cineva la mana serios climatronicul sau pentru ca apar multe erori de natura electrica s-ar putea sa fie toate legate intre ele, un istoric la masina ai ? accident, inundata, sau soareci ?
Modificat de 42miticutza
salutare
imi poate sopune cineva unde se afla aceasta piesa la passat:
Address 46: Central Conv.        Labels: 3C0-959-799-46.clb
1 Faults Found:
Va prezint si eu un scan, in speranta ca ma puteti lamuri in privinta erorilor.
Thursday,02,January,2014,17:55:11:37412
VCDS Version: Release 11.11.0 (x64)
Data version: 20111111
Chassis Type: 7N0
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 55 56
          61 62 72
VIN: WVWZZZ3CZBE397569
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
Address 01: Engine (J623-CFFB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BG    HW: 03L 907 309 N
   Component: R4 2,0L EDC   H24 8243
   Revision: 47H24---    Serial number: 00000000000000
   Coding: 001D0012042401080000
   Shop #: WSC 00015 115 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BG 003007
   ROD: EV_ECM20TDI01103L906018BG.rod
   VCID: 70E5A164ABB80CE
4483 - Function Restriction due to Received Malfunction Value
          U1113 00 [047] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 206
                    Mileage: 118824 km
                    Date: 2000.14.01
                    Time: 09:51:44
Readiness: 0 0 0 0 0
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 052     HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1918
   Revision: 04844002    Serial number: 00000910240938
   Coding: 0000020
   Shop #: WSC 05311 000 00000
   VCID: D1A384E048F2A56
No fault code found.
Address 03: ABS Brakes        Labels: 3AA-614-109.clb
   Part No SW: 3AA 614 109 N    HW: 3AA 614 109 N
   Component: J104   C2 450M VDEB 0005
   Revision: --H07---    Serial number: 00000004118352
   Coding: 0006579
   Shop #: WSC 77777 111 12345
   VCID: 387559444B4894E
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000003
   Shop #: WSC 00028 028 00020
   ASAM Dataset: EV_Climatronic A01010
   VCID: 6ED9BF1CB18C1AE
9481200 - Coolant Pressure
             B10AB F0 [009] - Unknown Error Elaboration
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 217
                    Mileage: 119541 km
                    Date: 2000.14.05
                    Time: 13:53:02
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 000000000000000000180080540029F463D569E860218560E480C7A40049
   VCID: 39735C40B0428D6
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419
   Component: Wischer 06041  10  0603
   Coding: 00B795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 030511 05  54  0403
   Coding: 033028
3 Faults Found:
01502 - Bulb for Rear Fog; Left (L46)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 11
                    Mileage: 119052 km
                    Time Indication: 0
                    Date: 2000.14.01
                    Time: 14:11:43
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.45 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
01504 - Bulb for License-Plate Light (X)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 11
                    Reset counter: 15
                    Mileage: 119002 km
                    Time Indication: 0
                    Date: 2000.14.01
                    Time: 00:30:33
             Freeze Frame:
                        Term 15 On
                    Voltage: 14.45 V
                        ON
                        ON
                        ON
                        OFF
                        ON
02391 - Terminal 30 Reference
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 4
                    Fault Frequency: 6
                    Reset counter: 212
                    Mileage: 118824 km
                    Time Indication: 0
                    Date: 2000.14.01
                    Time: 09:52:21
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.55 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels: None
   Part No SW: 3AE 919 475     HW: 7N0 919 475
   Component: PARKHILFE 8K  H04 0009
   Revision: --------    Serial number: 77631111103111
   Coding: 108101
   ASAM Dataset: EV_EPHVA18VW47X0000 001003
   ROD: EV_EPHVA18VW47X0000.rod
   VCID: FCFD055477F0F8E
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0P884N5A
   Coding: 0012337
   VCID: 4C9D15942FD008E
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BF    HW: 5K0 953 569 S
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110421301095
   Coding: 198A250002
   ASAM Dataset: EV_VW360SteerWheelUDS A03004
   ROD: EV_VW360SteerWheelUDS_VW46.rod
   VCID: 6AD1B30C8D64F6E
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-TK6  H06 0022
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 880 A    HW: 3AA 920 880 A
   Component: KOMBI         H02 0206
   Coding: 161F01
   Shop #: WSC 05314 115 00000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_VW46.rod
   VCID: 316364606032456
10485833 - Internal Control Module Memory Check Sum Error
          B2000 49 [137] - Internal electronic failure
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 260411F1001838
   Coding: 462006
   Shop #: WSC 05314 000 00000
   VCID: 346D6D74972070E
2 Faults Found:
00470 - Combination comfort Databus in Single Wire
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 91
                    Reset counter: 235
                    Mileage: 118824 km
                    Time Indication: 0
                    Date: 2000.14.01
                    Time: 09:52:23
03927 - Function Restriction due to Driver Fatigue Recognition
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 119687 km
                    Time Indication: 0
                    Date: 2000.14.06
                    Time: 14:09:42
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0399
   Revision: 00043000    Serial number: VWZCZ000000000
   Shop #: WSC 131071 1023 2097151
   VCID: F6E9177C81DCA2E
   Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
   Part No SW: 3C0 035 279     HW: 3C0 035 279
   Component: RNS315        H05 0010
   Serial number: VWZAZ2L3335241
   Coding: 000004310400000000011000
   ASAM Dataset: EV_RNS315VWEUV1UDS A01005
   ROD: EV_RNS315VWEUV1UDS_VW46.rod
   VCID: E0C55124FB583CE
1048594 - Right Front Bass Speaker
          B1062 13 [008] - Open Circuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 251
                    Mileage: 119105 km
                    Date: 2000.14.01
                    Time: 00:00:03
Address 42: Door Elect, Driver (J386)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0529
   Revision: 12110009    Serial number: 0002728041
   Coding: 0200B7
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 356B5070945A696
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 3C0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000002124688
   Coding: 000090
Address 44: Steering Assist        Labels: 5N1-909-144.clb
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.311 0802
   Revision: 1AH03729    Serial number: 00111010329401
   Coding: 0000258
   Shop #: WSC 00028 028 00001
   VCID: 3B7F46487A7EBF6
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 043 0631
   Coding: 0091020052830E76300494157C084F0B607801
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
2 Faults Found:
00332 - Control Circuit for Tank Flap
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 4
                    Fault Frequency: 254
                    Reset counter: 212
                    Mileage: 118824 km
                    Time Indication: 0
                    Date: 2000.14.01
                    Time: 10:24:52
01038 - Central Locking Thermal Protection
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 5
                    Reset counter: 250
                    Mileage: 119105 km
                    Time Indication: 0
                    Date: 2000.14.01
                    Time: 00:01:20
Address 4F: Centr. Electr. II (J520)       Labels: 1K0-907-532.clb
   Part No SW: 7N0 907 532     HW: 1K0 907 951
   Component: EZE_2         H41 1614
   Coding: 00000008
   VCID: EFE722183E86936
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
Address 52: Door Elect, Pass. (J387)       Labels: 3C0-959-70X-GEN4.clb
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0529
   Revision: 14110009    Serial number: 0002774011
   Coding: 0200B6
   Shop #: WSC 05311 115 00000
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
   ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
   VCID: 3669577C895C62E
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 3C0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002119233
   Coding: 000090
Address 53: Parking Brake        Labels: 3AA-907-801.clb
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000307602
   Coding: 0022067
   VCID: 336F6E68522E776
Address 55: Xenon Range (J745)       Labels: 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0080
   Revision: --------    Serial number: --------------
   Coding: 029A00104F000200
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
   ROD: EV_HeadlRegulVWAFSPt.rod
13705479 - Databus
          U1121 00 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 205
                    Mileage: 118824 km
                    Date: 2000.14.01
                    Time: 09:52:03
Address 61: Battery Regul. (J840)       Labels: 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H41 1614
   Coding: 030B185A
   VCID: F1E3246028B2856
   Subsystem 1 - Part No SW: 1K0 915 181 F    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0150
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00110001
                    Fault Priority: 7
                    Fault Frequency: 11
                    Reset counter: 16
                    Mileage: 119230 km
                    Time Indication: 0
                    Date: 2000.14.02
                    Time: 03:27:58
salutare
In spatele torpedoului.
Stii cumva un cod la piesa respectiva ca sa-l pot comanda inainte sa desfac pe acolo
mersii
vezi ca la tine eroarea este pe antena pentru keyless, nu pe unitatea acesteia
mai exact spus tu ai probleme cu manerul de la usa soferului
eu asa stiu ca in maner este doar un senzor (poate ma insel)
keyless-ul imi funtioneaza doar in spate la portbagaj
este senzorul de touch, si tot la maner mai este si antena
Help me! Golf 4 1.9TDI ASZ 2003!
Scaneaza pana la adresa 19 CAN-GateWay unde da urmatoarea eroare:
01336 - Data Bus for Comfort System
            80-10 - Single-Wire Operation - Intermittent
Pe restul adreselor nu se poate conecta! Nici pe Auto-Scan, nici manual pe fiecare! Im zice "No comunication with controller"
Am vrut sa intru pe 46-Central conv.   si la fel!  De la adresa 19 in sus nu se conecteaza pe nimic!
Mentionez ca asta vara in urma unor ploi torentiale am avut foarte multa apa in masina infiltrata pe la capacul ala de sub stergatoare, pe partea soferului, pe unde ies firele din habitaclu spre motor!!
Ce sa fie? Modulul de confort?
Passat 3B 5.5 1.9 96 kw
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959 799 A
   Component: 0H Komfortgerát HLO 0003
   Coding: 00067
   Shop #: WSC 05311
   VCID: 356A238A631B60B4
   Part No: 1C1959801
   Component: 0H Tõrsteuer.FS KLO 0003
   Part No: 1C1959802
   Component: 0H Tõrsteuer.BF KLO 0002
2 Faults Found
01044 - Control Module Incorrectly Coded
            35-00 -  -
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            27-00 - Implausible Signal
Care ar fi codarea corecta?
  incalzirea auxiliara se opreste dupa 10-20 de secunde de functionare, mai jos aveti codul de eroare, ma poate ajuta cineva cuun sfat ?
Friday,10,January,2014,18:19:59:32264
VCDS Version: Release 11.11.3
                Address 18: Aux. Heat       Labels: Redir Fail!
Control Module Part Number: 5K0 963 272 A
  Component and/or Version: Standheizer     043 4707
           Software Coding: 0031012
            Work Shop Code: WSC 10174 599 125114
                      VCID: 2E591061B90C649
01406 - No Flame
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 190521 km
                    Time Indication: 0
                    Date: 2121.14.28
                    Time: 17:55:02
             Freeze Frame:
                        Start
                    Temperature: 70.0°C
                    Temperature: 68.0°C
                    Voltage: 13.95 V
NU se aprinde flacara sau nu se mentine. Posibil sita arzatoare infundata sau arsa.
Am inteles ca ar trebui curatat, mie-mi merge acum cam 3 minute. e cineva care ma poate ajuta cu aceasta curatare sau sa mi recomande un service unde as putea face aceasta operatiune?
cauta un dealer Webasto, ca ei se baga sa desfaca Thermotop-ul.  gasesti si in bucuresti si in Targoviste parca. Ar trebui sa fie si in Ploiesti
Salut, în legătura cu eroarea:
16352 - Control Module - Electrical Error
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 134
Mileage: 148892 km
Time Indication: 0
Freeze Frame:
Count: 17472
Count: 32768
Count: 12800
Count: 96
Count: 46867
Count: 3
Count: 254
Count: 3840
ceva concret, vreo rezolvare?
Modificat de samat
In primul rand trebuie sa postezi pe ce modul ai gasit eroarea, mai multe date legate de masina - un autoscan era bun.... altfel, generic - aceasta eroare iti da modulul respectiv ca fiind defect.
e adevarat ca poti sa o regasesti si pe module care functioneaza perfect sau partial....
deci, te astept cu date suplimentare
  • Aerofan pinned this topic
    • shumy_mk2
