zorg
Cine ma ajuta si pe mine sa scanez in Bucuresti Seatul. Am VAGcom instalat pe WIn7 (poate da eroare din cauza ca nu e cu XP?) si interfata KKL, dar nu am mai facut asta ever :) Astept un PM
Se pot rezolva foarte simplu, nu ai nevie de multa stiinta, doar sa ai localizarea lor...autodata te ajuta sau daca sapi pe forum ai sa gasesti. succes
salutare am facut o scanare si am urmatoarele erori:
Saturday,21,September,2013,14:55:11:32264
VCDS Version: Release 11.11.3
Data version: 20120401
25-Immobilizer -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
7D-Aux. Heat -- Status: OK 0000 (status ok dar are un cod de eroare am sters eroare si nu mai apare)
Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
   Part No SW: 3C0 959 799 B    HW: 3C0 959 799 B
   Component:    IMMO         067 0364
   Revision: 00067000    Serial number: VWZCZ000000000
   Shop #: WSC 00704 210 91065
   VCID: 387536394B48AA9
   Part No: 3C0 905 861 J
   Component:    ELV          029 0380
   3C0905861J     ELV          029 0380
01176 - Key
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01111000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 210
                    Mileage: 148763 km
                    Time Indication: 0
                    Date: 2013.09.20
                    Time: 15:29:41
Address 46: Central Conv.        Labels: 3C0-959-799-46.clb
   Component:    KESSY PQ46 R 067 0211
   Coding: 19910A0801C64E7638043F3F70085FCE101C0003240480
   Shop #: WSC 00157 210 50209
   Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Part No: 3C0 951 171 A
   Component: Neigungssensor  002 0508
   Component: Innenraumueberw.002 0508
5 Faults Found:
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 148194 km
                    Time Indication: 0
                    Date: 2013.09.02
                    Time: 16:17:37
00190 - Driver's Door Handle Touch Sensor (G415)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 148194 km
                    Time Indication: 0
                    Date: 2013.09.02
                    Time: 16:17:37
00191 - Passenger's Door Handle Touch Sensor (G416)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 148194 km
                    Time Indication: 0
                    Date: 2013.09.02
                    Time: 16:17:37
00192 - Left Rear Door Handle Touch Sensor (G417)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 148194 km
                    Time Indication: 0
                    Date: 2013.09.02
                    Time: 16:17:37
00193 - Right Rear Door Handle Touch Sensor (G418)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 148194 km
                    Time Indication: 0
                    Date: 2013.09.02
                    Time: 16:17:37
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1K0 959 702 K
   Component: Tuer-SG         024 2366
   Coding: 0000756
   Shop #: WSC 05311 000 00000
   VCID: 377735054656A51
00121 - Outside Warning Light/Door exit Light Passenger Side
Address 77: Telephone        Labels: 3C0-035-729.lbl
   Part No SW: 3C0 035 729 E    HW: 3C0 035 729 E
   Component: Telefon             5309
   Revision: 00008000    Serial number: 0000000636652
   Coding: 0016023
   VCID: 254BEF4DECFA271
2 Faults Found:
02791 - Telephone Baseplate (R126)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 193
                    Mileage: 148631 km
                    Time Indication: 0
                    Date: 2013.09.16
                    Time: 16:40:32
01524 - Antenna for Telephone
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 193
                    Mileage: 148631 km
                    Time Indication: 0
                    Date: 2013.09.16
                    Time: 16:40:32
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 2D5B176DB40A1F1
00361 - Heater Element for Auxiliary Heater (Z35)
mersii
00603 - Footwell/defroster Flap Positioning Motor (V85)
            37-10 - Faulty - Intermittent si
00778 - Steering Angle Sensor (G85)
            014 - Defective - Intermittent care ar fi problema? Multumesc!
Am si eu o problema, poate ma ajuta cineva. Astazi am schimbat filtrele si uleiul la masina, un audi a4 1.9 tdi 131cp. Cand am schimbat filtrul de motorina am scos mufa de la senzorul de pe tubulatura care duce din EGR in intercooler si mufa de la debitmetrul de aer. Dupa ce am schimbat toate filtrele am pus mufele la loc. Dupa aceasta masina nu mai trage de loc si am urmatoarele 2 erori:
Saturday,21,September,2013,19:29:57:37412
VCDS Version: Release 11.11.0
                Address 01: Engine       Labels: 038-906-019-AVF.lbl
Control Module Part Number: 038 906 019 LJ
  Component and/or Version: 1,9l R4 EDC 0000AG  4910
           Software Coding: 00001
            Work Shop Code: WSC 63251
           Additional Info: WAUZZZ8EX4A038124     AUZ6Z0C0203396
                      VCID: 6AD1B30C1664F6E
2 Faults Found:
17964 - Charge Pressure Control
            P1556 - 35-10 - Negative Deviation - Intermittent
19586 - EGR System
            P3130 - 35-10 - Regulation Range Exceeded - Intermittent
Readiness: 1 2 0 0 0
Mentionez ca inainte de a schimba filtrele masina mergea fara probleme.
In Engine, la measurements block, pe grupul 3 . acolo unde arata EGR, la MAF(specified) arata 260, iar la MAF (actual) arata 400-410, iar EGR duty cycle arata 85%. Aceste valori sunt aratate la relanti. Atunci cand opresc si motorul, parca oprirea este mai brusca.
Postul a fost pus si in sectiunea dedicata marci, imi cer scuze daca nu trebuia si acolo postat.
Va multumesc mult pentru atentie. O seara placuta.
CApsula egr sparta si de aici si problema cu presiunea in turbina, nu ai vacuum suficient, il scapa pe la capsula vacuumatica de la turbo.
Capsula vacumatica de la egr este cea neagra cu o tija care actioneaza egreul?
Se poate rezolva cumva fara a schimba aceasta capsula?
Nu imi explic cum s-a spart dupa schimbul de filtre si ulei. Multumesc mult pentru raspuns.
Problema rezolvata! La raspunsul primit de la colegul Al Bundy, am coborat jos la masina si am urmarit traseul furtunului de vacuum care intra in capsula EGR. Pe traseul furtunului exista o imbinare de plastic. Din aceasta imbinare era sarit furtunul. Pus la loc furtunul, citit valorile care erau toate in parametri, facut proba, masina trage foarte bine. Multumesc mult colegului Al Bundy pentru raspuns. O zi buna.
VAG-COM Version: Release 409.1-S
Control Module Part Number: 028 906 021 ES
  Component and/or Version: 1,9l R4 EDC  G00SG  1448
           Software Coding: 00002
            Work Shop Code: WSC 00020
3 Faults Found:
65535 - Internal Control Module Memory Error
01269 - Shareware Version. To Decode all DTCs
        31-10 - Please Register/Activate - Intermittent
00575 - Shareware Version. To Decode all DTCs
        17-00 - Please Register/Activate
Nu stiu cat ajuta aceste coduri ptr. ca sunt date cu versiune neinregistrata a softului, dar daca ma puteti dumiri si pe mine ce problema exista cu turbina ar fi super! Cade turbo cand ti-e lumea mai draga si masina nu mai urca in ture peste 3100 si nu mai trece peste 110 km/h :(
Turbina nu are nimic. Problema e din ECU si posibil N75. Ar trebui sa refaci testul cu o interfata ca lumea. Chiar si un test in mers.
Modificat de cuiuda
Adica interfata care o am nu e buna? sau te referi la soft? ce e N75, valva MAF?
Foloseste mai bine versiunea 3.11. Desfa ECU si verifica furtunasul din interior.
P.S. da-mi o adresa de email ca sa-ti trimit vagcom 3.11
Nu te apuca să desfaci bordul că nu este ăla ECU (de fapt şi scrie în denumirea clipului că este vorba despre imobilizator).
Este în compartimentul motor, vezi unde scrie ECM în pdf.
Alhambra mea e model vechi, motor AHU, 1997-8, esti sigur ca e aceeasi schema cu ANU? Oricum o sa ma uit acolo poate am noroc, dar m-as mira sa fie neamtu atat de geniu in secolul trecut  :)
Modificat de luck33ro
La Alhambra din anul asta ECU este in spatele ceasurilor foooarte bine fixat. Se scoate putin mai greu...dar se scoate :D. Chiar zilele trecute am avut unul cu aceeasi problema ca a ta.
Modificat de cuiuda
Scuze de dezinformare, da la AHU este acolo unde zice cuiuda.
Revin cu un rezultat pozitiv ,eroarea de la postul cu nr #5561, cea privitoare la airbag-uri s-a rezolvat prin inlocuirea senzorului de pe traversa de sub scaun(multumesc Al) si am mai ramas cu asta de pe climatronic:
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 H
   Component: CLIMATRONIC B5GP    0002
   Coding: 17000
   Shop #: WSC 00230
   VCID: 2647F2ABEA27
2 Faults Found:
            35-00 -  -
01198 - Comfort Data Bus; Incorrect Software Version
            35-00 -  -
Eroarea reapare imediat dupa stergere, dar functioneaza toate la climatronic.Acest V71 e cumva cel care deschide clapeta pe unde intra aerul prin filtrul de polen?
Referitor la cea de a doua eroare (01198) nu o gasesc pe wiki ross-tech.Ce poate fi?
Si referitor la adoua eroare ce părere ai?
De ceva timp auzeam motorasul de la inchidere ca face un zgomot ciudat, in urma unei scanari cu vag-ul mi-a dat urmatoarea eroare
Tuesday,24,September,2013,18:54:13:13314
VCDS Version: Release 908.0
Data version: 20090911
                Address 46: Central Conv.       Labels: 1K0-959-433-MIN.clb
Control Module Part Number: 1K0 959 433 AK
  Component and/or Version:    KSG              0401
           Software Coding: 00C802487F2D8404084F01E010CC
            Work Shop Code: WSC 00000 785 00200
           Additional Info:               Sounder n.mounted                          NGS n.mounted
           Additional Info:                  IRUE n.mounted
00930 - Locking Module for Central Locking; Rear Left (F222)
  Intrebarea mea este daca trebuie cumparat motorasul sau doar cablajul este de vina?
In general se duce motorasul, dar nu il gasestio separat, e impreuna cu broasca.
... da, dar il poate curata... colectorul. Si isi revine.
  • Aerofan pinned this topic
