zorg
Salutare.
Am facut o scanaza cu VCDS-ul si am primit urmatoare eroare:
Address 37: Navigation (J794)       Labels: 3C0-035-270.clb
   Part No SW: 3C0 035 270 B    HW: 3C0 035 270
   Component: RNS310        H19 0357
   Revision: 11000000    Serial number: VWZ1Z2L7276471
   Coding: 000500010100000000000000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: VW_RNS310 A02007
   ROD: EV_VWRNS310UDS.rod
   VCID: 19384E6718F5AE890E-804C
1 Fault Found:
1048632 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 49
                    Mileage: 141291 km
                    Date: 2018.01.11
                    Time: 08:44:29
Imi merge radio, nu am niciun fel de problema, am sters eroarea dar nu se sterge si nu stiu ce sa ii fac sau ce ar trebui sa schimb. A mai intalnit cineva problema asta?
Pentru eroarea de mai jos trebuie schimbata sonda lambda? Se pot face verificari/teste suplimentare cu VCDS? Nu au aparut alte erori. Passat 2009, CBAB
Address 01: Engine       Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 QD    HW: 03L 907 309
  Component and/or Version: R4 2.0l TDI G000AG  9982
           Software Coding: 0000078
            Work Shop Code: WSC 26955 001 1048576
                      VCID: 77FD0D5706389FA6A59-8022
1 Fault Found:
008598 - Oxygen (Lambda) Sensor B1 S1
               P2196 - 000 - Signal too High (Rich) - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 28
                    Reset counter: 255
                    Mileage: 219565 km
                    Time Indication: 0
                    Date: 2044.14.21
                    Time: 16:33:43
             Freeze Frame:
                    RPM: 1656 /min
                    Speed: 37.0 km/h
                    Lambda: 54.4 %
                    Mass Air / Rev.: 515.0 mg/str
                    Voltage: 0.825 V
                    (no units): 16.0
                    Voltage: 0.975 V
Modificat de Gelu
Se poate incerca imtai un update soft al ecu si poate scapi de inlocuire.Daca nu,se schimba.
eroarea nu spune nimic despre sonda lambda, ci doar ca amestecul este prea bogat, deci altele sunt cauzele....
Da..raporteaza eronat.In unele cazuri se rezolva cu update soft..in altele nu.
Salut! Ma poate ajuta cineva cu niste informatii despre urmatoarea eroare:
005633 - Releu clema 30 -J317- semnal neplauzibil
               P1601 - 000 -  - intermitent
             împrejurari cod:
                    Starea defectului: 00100000
                    Priorit.defectului: 0
                    Frecv. defectului: 14
                    rulaj: 0 km
                    Indicator de timp: 0
             împrejurari cod:
                    RPM: 0 /min
                    viteza: 0.0 km/h
                    sarcina: 0.0 %
                    tensiune: 12.69 V
                    valori binare: 00000000
                    valori binare:        0
Mentionez ca masina porneste foarte greu dimineata .
Golf V 1.9 2006
Modificat de marcutm
Ce înseamnă pentru mine faptul că am valoarea asta la cilindrii 1 și 2? Uneori dimineața mai trepidează.
Presupun că se coroborează cu eroarea de mai jos. Este altă soluție în afară de înlocuire injector?
Salutare de la mare. Am urmatoarea problema..
La scanarea cu vcsd-ul imi da eroare oe faza scurta pe ambele becuri. Si mai apare si pe MFD-ul(sper sa nu gresesc) din bord iconita cu bec. Faza scurta functioneaza fara probleme.
Aveti ceva idei de remediere?
Mulțumesc!
P. S.. Dau hamsie si ?
Spido, buna intrebare. O sa ma uit mai tarziu si revin. Ce ar trebui sa fie ??
Salut spido. Pe masina becurile din imagine.
salut, am scanat masina ,si a aparut:
Wednesday,03,October,2018,09:11:06:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
          76
   Mileage: 320730km/199292miles
Address 01: Engine        Labels: 038-906-019-AJM.lbl
   Part No: 038 906 019 AM
   Component: 1,9l R4 EDC G000SG  0813
   Coding: 00002
   Shop #: WSC 01317
   VCID: 62C1B451EE54909
3 Faults Found:
17978 - Engine Start Blocked by Immobilizer
            P1570 - 35-10 -  - Intermittent
17958 - Charge Pressure
            P1550 - 11-10 - Control Deviation - Intermittent
17552 - Mass Air Flow Sensor (G70)
            P1144 - 35-00 - Open or Short to Ground
Readiness: 0 0 X X X
Address 03: ABS Brakes        Labels: 1J0-907-37x-ESP-F.lbl
   Part No: 1C0 907 379
   Component: ESP     20    CAN  V002
   Coding: 18945
   Shop #: WSC 01317
   VCID: E7D725458576751
1 Fault Found:
00812 - Brake Pressure Release Solenoid (F84)
            35-10 -  -  - Intermittent
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 6Q0 909 605 A
   Component: 02 AIRBAG VW5       0003
   Coding: 12338
   Shop #: WSC 01317
   VCID: 356B3F0D0F5A571
No fault code found.
Address 17: Instruments        Labels: 1J0-920-xx0-17.lbl
   Part No: 1J0 920 802 G
   Component: KOMBI+WEGFAHRS. BOO V23
   Coding: 01144
   Shop #: WSC 00000
   VCID: 2757E545C5F6351
   Subsystem 1 - Part No: Ident
   Component: Nr. WEGFAHRS.:VWZ6Z0X1231383
   Ident.-Nr. WEGFAHRS.:VWZ6Z0X1231383
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: Gateway K<->CAN    0001
   Coding: 00006
   Shop #: WSC 01317
   VCID: F0E54E19B0B8B29
Address 46: Central Conv.        Labels: 1J0-959-799.lbl
   Part No: 1J0 959 799 Q
   Component: 2H Zentral-SG Komf. 0001
   Coding: 04097
   Shop #: WSC 01317
   VCID: 4C9D7AE97CD0369
   Subsystem 1 - Part No: 1J1959801C
   Component: 2H Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 2H Tõrsteuerger. BF0002r
   Subsystem 3 - Part No: 1J4959811C
   Component: 2H Tõrsteuerger. HL0002r
   Subsystem 4 - Part No: 1J4959812C
   Component: 2H Tõrsteuerger. HR0002r
1 Fault Found:
00943 - Heated Exterior Mirror; Driver Side (Z4)
            35-00 -  -
Va rog niste lamuriri.
ce trebuie facut si  ce trebuie verificat.Va multumesc anticipat.
Buna seara.
Alhambra mea nu mai porneste.
Erorile ar fi:
Chassis Type: 7M - Seat Alhambra
Scan: 25 01 02 03 08 09 15 16 17 18 19 22 29 36 37 39 45 46 55 56
          76
VIN: VSSZZZ7MZ4V504191   Mileage: 280830km/174499miles
Address 25: Immobilizer        Labels: 7M3-953-257.lbl
   Part No: 7M3 953 257
   Component: IMMO                0008
   Coding: 00003
   Shop #: WSC 10138
   VSSZZZ7MZ4V504191     VWZ1Z0C2561924
3 Faults Found:
00750 - Warning Lamp
            28-10 - Short to Plus - Intermittent
01176 - Key
            07-00 - Signal too Low
01176 - Key
            65-10 - Unauthorized - Intermittent
   Part No: 038 906 019 LQ
   Component: 1,9l R4 EDC 0001SG  1594
   Coding: 00002
   Shop #: WSC 00020
1 Fault Found:
            P1570 - 35-10 -  -  - Intermittent
Address 17: Instruments        Labels: 7Mx-920-xxx-17.lbl
   Part No: 7M7 920 800 J
   Component: KOMBIINSTRUMENT VDO V59
   Coding: 01121
   Shop #: WSC 00012
1 Fault Found:
01314 - Engine Control Module
            49-10 - No Communications - Intermittent
   Coding: 00006
   Shop #: WSC 00000
1 Fault Found:
CE TREBUIE FACUT?
Multumesc pentru sfaturi.
@marcellinosv- ceva probleme cu actuator turbo(spart sau lipsa vacuum) si  senzorul Maf defect sau cablaj deteriorat.
@popflorin72- sterge erorile si incearca din nou o pornire.Pare o lipsa comunicare intre ceasuri si Ecu.
Revino cu autoscan dupa stergere erori si incercare pornire.
Modificat de spido
7 hours ago, popflorin72 said:
Buna seara.
Erorile ar fi:
          76
   Coding: 00003
   Shop #: WSC 10138
3 Faults Found:
01176 - Key
01176 - Key
   Coding: 00002
   Shop #: WSC 00020
1 Fault Found:
   Coding: 01121
   Shop #: WSC 00012
1 Fault Found:
   Coding: 00006
   Shop #: WSC 00000
1 Fault Found:
CE TREBUIE FACUT?
fa-i immo off, dupa care remediati problema
On 9/18/2018 at 7:57 PM, spido said:
Nu ai ambele antene bagate in aparat..
Am vazut ca eroarea a aparut in 11.01.2018. Eu am cumparat masina in noiembrie 2017 si nu a umblat nimeni la masina, deci putin probabil sa nu fie bagata.
Trebuie verificat conectorul..si modulul de antena din hayon.Mai intra apa,umezeala..
Azi am fost la verificare.
CIP-ul din cheie fusese pozitionat direct pe contact, cheia avind rolul doar de cheie simpla mecanica.
Diagnostic : CIP-ul da erori. Din cauza pozitiei  ( desi nu stiu daca s-a miscat - era acolo de cel putin 8 ani ) sau din alta cauza ( nu am inteles foarte exact ).
Remediu provizoriu : A fost repus CIP-ul in cheie. Momentan functioneaza.
Sugestie : Sa fac o a doua cheie cu CIP nou, deoarece CIP-ul original ar putea ceda.
Va salut prieteni, de curand mi am achizitionat o skoda superb, 2000-tdi, an 2011. Va atasez si eu urmatoarele erori:
   Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 1K0 937 087 P    HW: 1K0 937 087 P
  Component and/or Version: BCM PQ35  H+  104 0615
           Software Coding: 40990AB8E80508C040080080110089E4427000AE7320A5605C0040000040
            Work Shop Code: WSC 33361 790 00055
                      VCID: 3E792021A96C949
2 Faults Found:
00984 - Left Tail Light (M4)
            014 - Defective - Intermittent
             Freeze Frame:
                    Fault Status: 00101110
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 148
                    Mileage: 198522 km
                    Time Indication: 0
                    Date: 2026.14.08
                    Time: 17:40:41
             Freeze Frame:
                        Term 15 On
                    Voltage: 13.65 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 147
                    Mileage: 198523 km
                    Time Indication: 0
                    Date: 2026.14.08
                    Time: 20:04:02
             Freeze Frame:
                        Term 15 Off
                    Voltage: 12.00 V
                        OFF
                        ON
                        Term 50 Off
                        OFF
                        OFF
Inteleg ca aici ar fi niste becuri de schimbat stanga-spate? ce becuri am acolo? P21? sau....
  Address 01: Engine       Labels: 03L-906-018-CFF.clb
Control Module Part Number: 03L 906 018 CK    HW: 03L 906 018 BR
  Component and/or Version: R4 2,0L EDC   H22 7826
           Software Coding: 0019001A042600080000
              ASAM Dataset: EV_ECM20TDI01103L906018CK 003005 (SK46)
                      VCID: 75EBFF0DD4DA171
1 Fault Found:
4986 - Cylinder 3 Glow Plug Circuit (Q12)
          P0673 00 [101] - Electrical Fault
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 198523 km
                    Date: 2090.14.09
                    Time: 06:00:27
Aici ar fi o bujie/fisa de schimbat? Sau recomandarea este sa le schimb pe toate?
     Mai am un mic necaz. Geamurile de pe fata nu  merg pe functia auto, doar o coborare si o urcare. cele de pe spate merg. Am incercat memorarea prin metoda clasica tinut apasat sus sau jos dar nimic. Am dat o borna jos dar nimic. ce as putea sa mai incerc? Calculatorul din usa?
     Si mai am functia set de la scaune care nu functioneaza, nu pot memora pozitia scaunului. Are vreo influenta daca din adaptari e pus pe basic entry sau easy entry?
Buna ziua,in urma scanarii cu VCDS-ul am gasit urmatoarele coduri :
02433 - Tensiune de alimenatre pentru motorul pentru frânã de parcare dreapta -V283-
            012 - defect circuit electric - MIL aprins
             împrejurari cod:
                    Stare defect: 11111100
                    Prioritate defect: 1
                    Frecventa defect: 1
                    Resetare contor: 104
                    rulaj: 174688 km
                    Data: 2018.09.24
                    timp: 18:04:59
             împrejurari cod:
                    tensiune: 12.53 V
                    contor: 87
02429 - Motor pentru frâna de parcare dreapta -V283- forta de blocare nu este atinsã
            000 - - - intermitent
             împrejurari cod:
                    Stare defect: 00110000
                    Prioritate defect: 4
                    Frecventa defect: 2
                    Resetare contor: 144
                    rulaj: 174664 km
                    Data: 2018.09.24
                    timp: 07:31:25
             împrejurari cod:
                    tensiune: 12.32 V
                    contor: 15
02431 - Motor pentru frânã de parcare dreapta -V283- rezistent la miscare
            003 - defect mecanic - MIL aprins
             împrejurari cod:
                    Stare defect: 11110011
                    Prioritate defect: 3
                    Frecventa defect: 7
                    Resetare contor: 101
                    rulaj: 174560 km
                    Data: 2018.09.21
                    timp: 20:30:54
             împrejurari cod:
                    tensiune: 14.39 V
                    contor: 19.
Sa fie de vina butonul ce actioneaza frana electrica,sau trebuie curatat,verificat motorasul si mufa,legatura electrica ?
vw passat 1,6 fsi,115 cp.
frane.txt
nu e de la buton...schimba motorasele intre ele si vezi daca merge
  • Aerofan pinned this topic
    • alt.d4c
