zorg
Ce sa le mai schimbe...e blocat cel de pe dreapta.Inlocuieste-l.
sau pus direct la baterie si dat 2 impulsuri
se repara/reconditioneaza, nu necesita obligatoriu inlocuire.
Salut .Am urmatoarele erori la Octavia cu motor 1.6 MPI ,daca ma puteti ajuta.
16555 - Fuel Trim; Bank 1
            P0171 - 006 - System Too Lean - Intermittent
             Freeze Frame:
                    Speed: 52.3 km/h
                    Lambda Factor: 0.984
                    Voltage: 0.100 V
                    Lambda: 24.2 %
                    Speed: 54.3 km/h
                    Lambda Factor: 0.969
                    Voltage: 0.180 V
                    Lambda: 22.3 %
17987 - Throttle Actuator (J338)
            P1579 - 008 - Adaptation Not Started - Intermittent
             Freeze Frame:
                    Bin. Bits: 00000100
                    Voltage: 10.40 V
                    Load: 10.2 %
                    Load: 85.9 %
                    Bin. Bits: 00000100
                    Voltage: 10.51 V
                    Load: 10.2 %
                    Load: 86.7 %
17549 - Load Calculation Cross Check
            P1141 - 006 - Implausible Value - Intermittent
             Freeze Frame:
                    Lambda: 49.2 %
                    Lambda: -35.2 %
                    Lambda: 34.8 %
                    T.B. Angle: 5.2°
                    Lambda: 42.2 %
                    Lambda: -35.2 %
                    Lambda: 34.8 %
                    T.B. Angle: 6.6°
17972 - Throttle Actuator (J338)
            P1564 - 008 - Under-Voltage during Basic Setting - Intermittent
             Freeze Frame:
                    Bin. Bits: 00100000
                    Voltage: 7.65 V
                    Load: 17.6 %
                    Load: 82.4 %
                    Bin. Bits: 00100000
                    Voltage: 7.65 V
                    Load: 10.6 %
                    Load: 89.0 %
             Freeze Frame:
                    Speed: 52.3 km/h
                    Voltage: 0.100 V
                    Lambda: 24.2 %
                    Speed: 54.3 km/h
                    Voltage: 0.180 V
                    Lambda: 22.3 %
16685 - Cylinder 1
            P0301 - 009 - Misfire Detected - Intermittent
             Freeze Frame:
                    RPM: 576 /min
                    Mass Air / Rev.: 114.5 mg/str
                    Temperature: 91.5°C
                    Lambda: 0.0 %
                    RPM: 608 /min
                    Mass Air / Rev.: 348.8 mg/str
                    Temperature: 97.5°C
                    Lambda: 0.0 %
16686 - Cylinder 2
            P0302 - 009 - Misfire Detected - Intermittent
             Freeze Frame:
                    RPM: 576 /min
                    Temperature: 91.5°C
                    Lambda: 0.0 %
                    RPM: 608 /min
                    Temperature: 97.5°C
                    Lambda: 0.0 %
17966 - Throttle Actuator (G186)
            P1558 - 008 - Electrical Malfunction - Intermittent
             Freeze Frame:
                    T.B. Angle: 5.6°
                    RPM: 992 /min
                    Temperature: 81.0°C
                    Voltage: 13.67 V
                    T.B. Angle: 5.6°
                    RPM: 736 /min
                    Temperature: 81.0°C
                    Voltage: 13.46 V
17976 - Throttle Actuator (J338)
            P1568 - 007 - Mechanical Failure - Intermittent
             Freeze Frame:
                    RPM: 0 /min
                    Voltage: 12.24 V
                    Load: 17.3 %
                    Load: 80.4 %
17953 - Throttle Valve Controller
            P1545 - 008 - Malfunction - Intermittent
             Freeze Frame:
                    T.B. Angle: 3.3°
                    T.B. Angle: 2.8°
                    RPM: 928 /min
                    Bin. Bits: 00001100
                    T.B. Angle: 3.3°
                    T.B. Angle: 2.4°
                    RPM: 896 /min
                    Bin. Bits: 00001100
Dupa stergere  apar doar astea
             Freeze Frame:
                    T.B. Angle: 4.2°
                    T.B. Angle: 3.3°
                    RPM: 1344 /min
                    Bin. Bits: 00001100
             Freeze Frame:
                    T.B. Angle: 7.5°
                    RPM: 1280 /min
                    Temperature: 82.5°C
                    Voltage: 13.87 V
Precizez ca se aprind martori ABS ASR EPC si motorul intra in protectie.
Clapeta este schimbata de 3 luni si am facut si calibrare.
Oare sa stricat asa repede? Cand fac adaptare cu VCDS  se calibreaza?
Salutare tuturor!
Am si eu doua scanari, una de la Golf si una de la Tiguan. La Tiguan, recent cam de 2-3 saptmani, uneori la prima cheie porneste si se opreste imediat. Ca si cum nu ai roti cheia pana la capat. La a doua cheie o ia, in rest masina merge ok, fara alte manifestari. La scanare am gasit urmatoarele erori:
Address 01: Engine (J623-CFFD)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 LK    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H28 3526
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00190032040401080000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ECM20TDI01103L906018LK 003007
   ROD: EV_ECM20TDI01103L906018LK.rod
   VCID: 7EF9E021E1EC549
1 Fault Found:
5286 - Throttle Position Sensor (G69)
          P0121 00 [096] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 0
                    Fault Frequency: 0
                    Reset counter: 0
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
Readiness: 0 0 0 0 0
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 5K0 907 044 GK    HW: 5K0 907 044 GK
   Component: Climatronic   H19 1212
   Revision: 00001004
   Coding: 0010004003
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_Climatronic_VW36.rod
   VCID: 7AF1EC31FDC4789
1 Fault Found:
9474417 - Motor for Front Air Distribution Flap
          B1091 71 [008] - Actuator stuck
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 21
                    Reset counter: 216
                    Mileage: 129963 km
                    Date: 2067.14.13
                    Time: 19:25:26
Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 4E180A3B8837F3C0408800C0310089E44BFDAB08636D8520E48CE7040041
   Shop #: WSC 01973 973 01973
   VCID: 3E792021A96C949
   Subsystem 1 - Part No: 5N1 955 119 A
   Component: WWS 060712 03  32  0010
   Coding: 009795
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 120712 05  54  0403
   Coding: 02304D
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
1 Fault Found:
03789 - Terminal 75 Limp Mode Active
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 208
                    Mileage: 131822 km
                    Time Indication: 0
                    Date: 2006.14.15
                    Time: 15:20:04
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.95 V
                        ON
                        ON
                        ON
                        OFF
                        OFF
Address 37: Navigation (J0506)       Labels: None
   Part No SW: 1T0 035 686     HW: 1T0 035 686
   Component: RNS-MID       H10 5274
   Revision: AB001001    Serial number: VWZ6Z7R3198021
   Coding: 00000400000000800000
   Shop #: WSC 13675 002 1048576
   ASAM Dataset: ------------------------- ------
   VCID: F1E34B1D28B2BB1
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V10  8049
1 Fault Found:
02877 - Digital Radio Antenna (R183)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 254
                    Reset counter: 188
                    Mileage: 129504 km
                    Time Indication: 0
Address 56: Radio (J0506)       Labels: None
1 Fault Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Reset counter: 188
                    Mileage: 129504 km
                    Time Indication: 0
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Mentionez ca RNS510 merge foarte bine pe radio/gps/card, iar la usile din spate nu am umblat niciodata, dar ele functioneaza ok - se inchid/deschid si geamurile coboara/urca
Cel mai deranjant este acea ratare la pornire. E cazul sa merg la un service pt a schimba ceva?
La Golf am de asemenea cateva erori:
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 100 907 044 GX
   Component: ClimatronicPQ35 066 0606
   Shop #: WSC 00000 000 00000
   VCID: 68D5A6795B68FA9
2 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 -  -
01274 - Air Flow Flap Positioning Motor (V71)
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 S    HW: 1K0 937 049 S*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000848037
   Coding: 008F8F0600041800001400001400000000
   VCID: 3F875D256E669D1
   Subsystem 1 - Part No: 1K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
3 Faults Found:
01331 - Door Control Module; Driver Side (J386)
            004 - No Signal/Communication - Intermittent
01506 - Bulb for Rear Fog; Right (L47)
            012 - Electrical Fault in Circuit
01518 - Bulb for Back-Up Lights; Left (M16)
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0147
   Coding: 0000051
   Shop #: WSC 00028 028 00001
   VCID: 30650E19A338729
2 Faults Found:
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 98C802087F2D8404084F01E010
   VCID: 7BFFE9353AFE411
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
1 Fault Found:
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000051
   VCID: 31630B1DA8327B1
1 Fault Found:
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Nu am manere exterioare iluminate, nici lumini sub oglinda, de unde scot optiunile astea sa nu mai imi dea erori? De asemenea eroare cu becul de la stopul de ceata a aparut azi, cand am inlocuit CANBUS-ul de la E cat aveam eu la P. Modulul P a fost montat pe o Skoda Octavia Variant cu volan pe dreapta, am schimbat cu Golf 5 Hatchback, cu volan pe stanga, am sters eroarea, dar a reaparut. Am debifat Foglights si tot a ramas eroarea, banuiesc ca trebuie bifat si schimbat ceva la bitul 2 (inainte de debifare arata 06, dupa debifare arata 04). Scuze pt calitatea fotografiei.
Multumesc anticipat pentru raspunsuri.
Salut, si eu ca majoritatea am o problema ...
daca ma puteti lamurii ce pot sau trebuie facut
Adresa 01: Motor        Eticheta:
   Numar VAG SW: 03G 906 DP    HW: 028 101
   Componenta: R4 1,9L EDC G000SG  7870
   Revizie: --H01---    Numar serial: VWZCZ000000000
   Codare: 0000071
   Atelier: WSC 05314
   VCID: 70E5BB356346C7A19FB
2  coduri de defecte:
005736 - Ventil pompa-injector [PD] cilindru 3.-N242-  defect electric
               P1668 - 000 -  - intermitent
             împrejurari cod:
                    Stare defect: 00100000
                    Priorit.defect: 0
                    Frecv. defect: 63
                    Resetare contor: 255
                    rulaj: 274491 km
                    Indicator de timp: 0
                    Data: 2018.08.06
                    timp: 06:29:10
             împrejurari cod:
                    RPM: 1596 /min
                    viteza: 0.0 km/h
                    sarcina: 28.2 %
                    tensiune: 14.52 V
                    cantitate inj.: 0.05 mg/cursa
                    temperatura: 25.2*C
                    (fara denumire): 16.0
000771 - Sesizat rateu cilindrul 3
               P0303 - 000 -  - intermitent
             împrejurari cod:
                    Priorit.defect: 0
                    Frecv. defect: 15
                    rulaj: 274685 km
                    Data: 2018.08.08
                    timp: 16:36:38
             împrejurari cod:
                    RPM: 798 /min
                    viteza: 0.0 km/h
                    sarcina: 0.0 %
                    tensiune: 14.21 V
                    cantitate inj.: 2.96 mg/cursa
                    temperatura: 30.6*C
                    (fara denumire): 128.0
Gata de functie: 0 1 0 0 0
Quote
erori
salut si revin,
am sters erori apoi doua zile vreo 200km am mers mai turat. Astazi am pus tester nu  mai indica nimic din vechile erori..
O  sa fac un log in mers la  vit 3 ...3000ture aprox 5 minute .
 Mai am o chestie pe care nu o pot duce la sfarsit:
vreau sa fac o copie la cheia masinii. Am vag eeprom 1.19.Am vag commander 1.4,am instalat pe ambele.La eeprom (ecu not found).La vag comander nu pot seta portul.. Precizez ca doresc sa realizez acest lucru cu interfata ...VCDS Version: Release 11.11.3.... Vreau raspuns clar -se poate cu aceasta interfata?(rulez win 7 32 bit)
depinde cine a facut interfata, daca era originala ross-tech mergea.
Un răspuns clar, nu poți da pe o scula chinezeasca.
Unele clone merg, altele nu - cazul tău.
Vezi totuși la opțiuni sa nu ai bifata bypass can init. Dacă nici cu aceasta De bifata nu merge... Alta. Fu clar?
ma poate lamuri si pe mie cu te trebuie facut ?
Mentiune suplimetara -
masina merge ca un magar nemancat :))
tremura motorul de parca ar merge in 3, cand sterg erorile incearca sa`si revina pt 1 secunda apoi la fel
curatat de curand clapeta aer si egr*
mai facea asa si inainte uneori pa pornire alteori in mers ... opream/porneam mot si nu mai facea - acum nici cu mot cald 90* nu mai vrea
nu scoate fum  ! curios
P.S. - am scanat-o de ... nici eu nu mai stiu si sters erori care reapar daca imediat in 3-5 minute cunt acolo
            -am luat si bornele - lasata pana a doua zi fara curent - la reconectare ... nimic , la fel
nu au legatura cu eroarea
cauze posibile ar fi cablaj injectoare defect/injector defect/probleme pe cilindrul 3
hmm ... ma pui pe gadri :(
probleme pe cil`3 ..
app. - cum sunt numerotate pistoaele ? - de la volata (cutie) 1-4 !?
am vazut pe undeva tot pe net ceva de geul  - de la volata 3-2-1-4 sau invers ... undeva pe youutu`.
am ramas ... pe ganduri ... doar nu este motor de avion
La distributie e nr 1
Modificat de EEXCALADE
eu vreau sa citesc codul pin cu interfata mea si un soft potrivit. E posibil ?
acum o oră, EEXCALADE a scris:
multumesc ;)
este posibil sa fie doar imfundat inj 4 si doar o curatare sa dea rezultate ?
aditivi de pus in rezorvor pentru curatarea injectoarelor au efecte ?!
adi.vali29@gmail.com
Buna ziua, intampin o problema la pornire si anume : apas butonul Start-Stop ,motorul se  invarte destul de rapid dar parca prea scurt , masina tinde sa porneasca  dar apoi se opreste brusc . La a doua incercare face la fel . Dupa mai multe incercari masina porneste.  Problema nu mai apare decat dupa mai multe zile.  Va multumesc.
Log-WVWZZZAUZFP516164-189431km-117706mi.txt
Log-189431km-117706mi.txt
Wednesday,10,October,2018,14:39:16:37535
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.9.0.2 (x64)  HEX-V2 CB: 0.4436.4
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: WVWZZZAUZFP516164   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A5
VIN: WVWZZZAUZFP516164   Mileage: 189431km-117706miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7545
   Revision: 83H22---
   Coding: 111D0032036405083000
   Shop #: WSC 00028 028 00078
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002007
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AAD0E0B8C567027D01-802E
No fault code found.
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 041 P    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4507
   Revision: 05852204    Serial number: TFK01405130564
   Coding: 0014
   Shop #: WSC 00028 028 00066
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 25170D7755682FDFCD3-8070
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 M    HW: 5Q0 907 379 H
   Component: ESC           H31 0571
   Revision: 00000000    Serial number: 61734000001037
   Coding: 04FA62A1242109720378060641C72920462490C0608294F3F862507AC202
   Shop #: WSC 00028 028 00243
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
   VCID: 46D5AAFB882EC4C7E49-8012
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 5Q0 959 435 A    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0604
   Revision: 00021000    Serial number: 0338554495
   Coding: 030C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002011
   ROD: EV_KessyHellaMQBAB_002.rod
   VCID: 3A2DCE0BCCD6B027901-806E
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 02020104202400011105004200101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003018
   ROD: EV_ACClimaBHBVW37X_003_VW37.rod
   VCID: 73B3232FAB3C016F937-8026
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86582606141495
   Coding: 00011A66C24122FB4BE44000011C07081800000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79AF110789507B3FD9B-802C
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    140612  043 0551
   Serial number:         140620185758
   Coding: 0E4DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S4Y14M06D30H09M37S47
   Coding: 06A8EE
   Relative Air Humidity Interior Sender:
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431418201667
   Coding: 0031161051
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 42DDB6EBA406F8E7C81-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 25061403210443
   Coding: 001C1500FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001015
   ROD: EV_ACCMRRBoschVW372_VW26.rod
   VCID: 3829D403F2DAA237665-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR06HVTR
   Coding: 98CCC000000000005C0000CF004800000065
   Shop #: WSC 00028 028 00053
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5BFF1F9774550FE7F-802A
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169667B20061471003
   Coding: 333135
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169668B23061471547
   Coding: 333135
   Side Sensor Driver Front:
   Subsystem 3 - Part No SW: -----------    HW: 480 002 506 14
   Component: SideSensor_Df  001 0887
   Serial number: 35767000000AE449301U
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 506 14
   Component: SideSensor_Pf  001 0887
   Serial number: 358670000001C469301M
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 402 006 14
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502A916975225383
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 006 14
   Component: SideSensor_Pr  001 6149
   Serial number: 35265029F156E9E4402K
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 006 14
   Component: FrontSensor_D  001 6149
   Serial number: 3556502B51617D24C237
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0155
   Revision: FF028028    Serial number: 20140625500354
   Coding: 0C10
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 741     HW: 5G1 920 741
   Component: KOMBI         204 4270
   Coding: 07A511186F94000800886A031400000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009037
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 649150731ED296D71AD-8030
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2186
   Revision: --------    Serial number: 23061410800205
   Coding: 030100040B087300EF00025C1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewConti 011017
   ROD: EV_GatewConti_011_VW37.rod
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29140001209900124233
   Coding: 2DFFFF
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 1204163703
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 5Q0 905 861 A    HW: 5Q0 905 861 A
   Component: ELV-MQBA      H01 0120
   Revision: 00000000    Serial number: 14000160482003
   Coding: 5D00000000000000
   ASAM Dataset: EV_ELVMarquMQB 004111
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E033EEB246574AD-8060
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 B    HW: 5Q4 959 593 B
   Component: TSG FS        009 0014
   Serial number: 0000107729456
   Coding: 003B1320D000028000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 44D1B0F3BE12F6D7FAD-8010
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  007 0002
   Serial number: 00000000000005862774
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 P    HW: 5Q0 909 144 P
   Component: EPS_MQB_ZFLS  123 1043
   Coding: 1303
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41DFB9E7A100E3FFD1B-8014
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 B    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0014
   Serial number: 0000105658750
   Coding: 003B1120DE00028000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 43D3B3EFBB1CF1EFC37-8016
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  007 0002
   Serial number: 00000000000005775508
   Coding: 090000
Address 55: Headlight Range (J431)       Labels:| 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 069A000001010000
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB.rod
   VCID: 75B71D37A5481F5FBD3-8020
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 044 B    HW: 5G0 035 044 B
   Component: MU-H-TN-EU    H43 0362
   Serial number: A329F0EB003922
   Coding: 02730201FF00000011110001000800101F020094010001009F
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1E65229B703EFC078C9-804A
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G0 919 606     HW: 5G0 919 606
   Component: ABT_High  H60 0030
   Serial number: VWZ8Z9PS1005XL
   Data medium:
   Subsystem 2 - Part No SW: V03 959 801 QN    HW: -----------
   Component: ECE 2018/2019  --- 0169
   Serial number: --------------------
   Compact Disc Database:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 1010
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0052
   Serial number: 00000192544
   Coding: 0101000001020303020300000100000100
   ASAM Dataset: EV_MFKBoschAU370 001001
   ROD: EV_MFKBoschAU370.rod
   VCID: 3B23CB0FC3EC892F8B7-806E
End----(Elapsed Time: 01:48, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
Wednesday,10,October,2018,15:11:50:37535
www.Ross-Tech.com
13-Auto Dist. Reg -- Status: Malfunction 0010
   Revision: 83H22---
   Coding: 0014
4 Faults Found:
21153 - Gear 1
          P072C 00 [002] - Not Selectable
21159 - Gear R
          P072B 00 [002] - Not Selectable
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
10906 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
   Coding: 030C0C
   Revision: 00001K08
   Air quality sensor:
   Coding: 0E4DDD
   Coding: 06A8EE
   Coding: 0031161051
1 Fault Found:
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VMON_VZ_LOW]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 19
                    Mileage: 189431 km
                    Date: 2018.10.10
                    Time: 15:05:43
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 11.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 0C10
   Alternator:
   Coding: 2DFFFF
   Coding: 010000
   Coding: 1303
   Coding: 090000
   Data medium:
End----------(Elapsed Time: 01:47, VBatt start/end: 14.3V/14.4V)-----------
Wednesday,10,October,2018,15:15:54:37535
www.Ross-Tech.com
                Address 02: Auto Trans       Labels: 0D9-927-770.clb
Control Module Part Number: 0D9 300 041 P    HW: 02E 927 770 AQ
  Component and/or Version: DQ250-6F MQB  H52 4507
           Software Coding: 0014
            Work Shop Code: WSC 00028 028 00066
              ASAM Dataset: EV_TCMDQ250021 001001 (VW37)
4 Faults Found:
21153 - Gear 1
21159 - Gear R
Modificat de lupo_bv
QUOTE INUTIL POSTARE ANTERIOARA
Salut! Aveți idee de la ce provine eroarea asta? Degeaba o șterg, că tot reapare. Totul funcționează bine, nici o altă eroare la mașină.
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb    Part No SW: 3C8 035 730 B    HW: 3C8 035 730 B    Component: Telefon       011 0723     Revision: --------    Serial number: 35909603380133    Coding: 020000000000000000000000    Shop #: WSC 00015 115 00000    ASAM Dataset: EV_UHVPremi A02003    ROD: EV_UHVPremi_SE36.rod    VCID: 2252FA3B64CF08922934ACD-8076 1 Fault Found: 13893888 - Function Restricted due to Exessive Voltage           U1401 00 [008] - -           Intermittent - Confirmed - Tested Since Memory Clear              Freeze Frame:                     Fault Status: 00000001                     Fault Priority: 6                     Fault Frequency: 254                     Reset counter: 143                     Mileage: 211331 km                     Date: 2018.04.25                     Time: 11:00:16
Ptr ca are o tensiune de alimentare prea mare.Verifica incarcarea alternatorului sa nu depaseasca 14.2v .La fel-poate fi cauzata de o interpretare defectuasa a  interfetei/clona.
Multumesc  <spido>  pentru raspuns . Am sa verific alternatorul, cat despre interfata nu se pune problema. Am originala cu 3 licente.
ce model de  cip  are cheia pt mas din semnatura
  • Aerofan pinned this topic
    • alt.d4c
