Golf 6/Jetta - Codari/activari VCDS
mark21
La mine e pus pe auto de cand am cumparat-o, dar Leaving Home tot nu merge. Si am senzor de lumina. Trebuie activat din Vag Com probabil. Imi merge doar Coming Home automat
Modificat de goguXXL
Am facut o testare si am unele erori. Pun rezultatul in word jos. Am incercat sa activez Leaving Home si nu am reusit. Imi da eroare. Oare de ce?
asv.docx
VAd ca ai senzor de ploaie, trebuie sa mearga si CH si LH automat.
Verifica din BC daca este activat sau nu.
în urmă cu 5 ore, Al Bundy a scris:
Exact asta am facut: [Select]
[09 - Cent. Elect.]
[07 - Coding]
[Long Coding Helper]
Byte 0:
- bifati Bit 5 (Assistance Driving Light - Leaving Home active)
Eventual o sa fac un print screen cu eroarea. Multumesc!
L.E.: ma lasa sa o activez(nu functioneaza) si nu ma lasa sa schimb timpul cat sa stea pornite becurile
Trebuie sa activezi pe centrala Byte 17 - Bit 6: Leaving Home active
Am reusit. Multumesc.
Puteti sa imi spuneti va rog ce inseamna erorile?
Spoiler
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 DB    HW: 03L 906 022 G
   Component: R4 2,0L EDC G000SG  6181
   Revision: 13H02---    Serial number:
   Coding: 0000072
   Shop #: WSC 78077 146 105268
   VCID: 68DF5E2B5B86005E3C3-803D
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 000 - Electrical Fault
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 208691 km
                    Time Indication: 0
                    Date: 2007.14.09
                    Time: 08:29:29
             Freeze Frame:
                    RPM: 1035 /min
                    Speed: 0.0 km/h
                    Voltage: 11.48 V
                    Temperature: 10.8°C
                    Bin. Bits: 10110000
                    Time: 1.98 s
                    Temperature: 10.8°C
Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
   Part No SW: 5K0 920 870 E    HW: 5K0 920 870 E
   Component: KOMBI         H10 0021
   Revision: V0010011    Serial number:
   Coding: 170F00
   Shop #: WSC 00066 000 00148
   ASAM Dataset: EV_KombiUDSMM9RM10 A04010
   ROD: EV_KombiUDSMM9RM10_VW36.rod
   VCID: 2F6DF53776E897663D9-807A
13701120 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 26
                    Reset counter: 126
                    Mileage: 208807 km
                    Date: 2071.14.15
                    Time: 23:37:22
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1525
   Revision: 71009005    Serial number: 00000891799006
   Coding: 0000180
   Shop #: WSC 00066 000 00000
   VCID: 71E9334F685CC1966BD-8024
2 Faults Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 16
                    Reset counter: 86
                    Mileage: 208807 km
                    Time Indication: 0
                    Date: 2007.14.15
                    Time: 23:27:13
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 7
                    Reset counter: 126
                    Mileage: 208807 km
                    Time Indication: 0
                    Date: 2007.14.15
                    Time: 23:50:33
bujia de pe cil 2 si probleme cu broasca de la sofer
Salut baieti,
Detin de doua saptamani o Jetta Highline din august 2012, cu urmatorul VIN: WVWZZZ16ZCM151469.
Dupa ce am citit toate cele 49 de pagini legate de codari, am reusit sa imi dau o parte dintre raspunsurile la unele intrebari pe care le aveam, insa ar mai fi cateva nelamuriri si anume:
1. Pe baza VIN furnizat se poate spune daca oglinzile (care au functie de rabatere electrica de pe usa) se pot rabata din cheia si daca da, care este codarea?
2. Care este codarea intreaga (pentru ca eu nul nu ma pricep deloc, asa ca voi arata ce imi dati voi unui prieten) pentru activarea "bip"-ului de confirmare la armarea alarmei (am alalarma din fabrica)?
3. Se poate afla nivelul de incarcare al filtrului de particule, starea actuala a injectoarelor, starea EGR utilizand interfata VAG-Com (care inteleg ca e VCSD acum)? Banuiesc faptul ca toate aceste valori vor aparea pe scanare, corect?
Precizez ca nu pot urca o scanare pe baza careia sa primesc raspunsuri mult mai concrete, pentru ca abia sambata voi merge cu masina la scanare si tot atunci as vrea sa "rezolv" si ceea ce am intrebat mai sus. Multumesc!
1. nu are importanta vin-ul masinii tale - ci merge, la anul tau
2. se activeaza usor cu VCDS-ul
3. se verifica in blocurile de masura, nu apare la scanare.
daca mergi la cineva care iti face toate astea, banuiesc ca stie ce si cum... si atunci recomand sa mergi pe mana lui.
Multumesc pentru raspunsul prompt!
Dupa ce am postat mai sus mi-am dat seama ca am uitat sa intreb un lucru care mi se pare ciudat la masina mea si anume faptul ca la descuierea masinii din cheie, daca apasarea butonului este FOARTE scurta (gen sub o secunda), se face descuirea pentru toate cele 3 usi, mai putin a soferului... daca apasarea se face ceva mai lug de o secunda, se deschid toate cele 4 usi. Imi poate spune cineva daca trebuie verificat ceva in vreo codare sau de la ce a aparut aceasta anomalie?
Cum pot sa vad nivelul de umplere al filtrului de particule cu vag com? Multumesc!
te uiti la blocurile de masura.
20 hours ago, b23840 said:
Salut baieti,
1. Aici gasesti tot ce ai nevoie:
2. Daca ai computer de bord plus, activarea / dezactivarea beep-ului pentru alarma se face din meniul ceasurilor:
La fel, daca ai computer de bord plus, gasesti setarile in meniul din ceasuri Settings - Convenience - Central Locking - Door Unlocking
@Hayate Multumesc si tie pentru informatii.
Totusi, in CB nu imi apare meniul ATA ca sa bifez/debifez bip-ului alarmei. Incepe submeniul Convenience cu Central Locking. La Central Loking am bifat ambele casute din submeniul Automatic si am selectat si daca vreau sa se armeze/dezarmeze doar usa soferului sau toate la apasarea pe cheie.
Simptomele sunt asa:
1. daca bifez sa se descuie doar usa soferului, la apasarea foarte scurta a cheii, nu se deschide nicio usa, la apasarea peste o secunda se deschide usa soferului;
2. daca bifez sa se descuie toate usile, la apasarea foarte scurta se deschid toate mai putin usa soferului, la apasarea peste o secunda se deschid toate cele 4, inclusiv usa soferului;
Tind sa cred ca este ceva in neregula cu o codare, dat fiind ca mi se pare anormal sa se descuie celelalte usi, dar a soferului nu...
Cat despre rabatarea oglinzilor, o sa ii arat clipul celui care ma va ajuta. Multumesc!
Pentru problema cu deschiderea usilor, incearca sa dai un Factory reset la setarile din ceasuri. Multe din setari sunt pe ceasuri adresa 17-Instruments in Adaption (nu pe 09-Centr. El.)
Cat despre alarma, este din fabrica sau este aftermarket?
Daca poti sa pui aici o scanare cu VCDS de la adresa 09-Centr. El. ar fi foarte bine.
Alarma este din fabrica.
O sa incerc o resetare.
Scanarea nu pot face prea curand... am aflat ca cel care ma putea ajuta sambata are VAG 12.12, ceea ce pentru rabatare oglinzi nu ajuta, asa ca o sa merg la altcineva care sa imi codeze oglinzile, dar sambata cealalta. :(
Daca alarma e din fabrica si ai si probleme cu deschiderea usilor din telecomanda, sigur s-a jucat cineva cu VCDS-ul pe 09-Centr. El. si a bifat niste biti aiurea.
Modificat de Hayate
Tot ce este posibil, de aici cred ca si eroarea pe usa.
Restarea din fabrica se face din meniul BC? Ultima optiune: FACTORY RESET (sau asa ceva), corect?
Dupa resetare ar trebui sa revina totul la normal, inclusiv ATA?
Da, de acolo. Teoretic, da. Cu conditia sa nu fie bifati niste biti aiurea pe centrala electrica. Ti-am zis, la masinile cu BC+ ca a ta, multe setari legate de inchiderea centralizata si alarma sunt in 17-Instruments pe Adaption, nu pe centrala electrica.
Am rezolvat aseara cu anomalia din usa, in sensul ca am aflat ca este de vina un motoras din broasca de pe usa soferului. Nimic grav. De altfel a fost si singura eroare rezultata.
Am rezolvat si cu rabatarea oglinzilor din cheie si cu bip-ului la armare/dezarmare alarma (ATA Confirm), lucruri care din punctul meu de vedere, chiar merita.
Multumesc pentru sfaturi si ajutor!
ATA Confirm apare si in MFD? Filmul de mai sus se refera la modelel livrate pe piata americana.
Da. Acum imi apare si pe computerul de bord plus. La mine se "jucase" cineva si debifase optiunea cu VCDS. Acum e exact ca in clipul de mai sus.
  • 6 months later...
Buna,
Cazul meu: Jetta Mk6 2014 fara Auto Switch si fara Senzor. Am activat atat CH (manual - flash la coborare si functioneaza ok) cat si LH care mi-a aparut in bord cu meniul complet (ON/Off si timpul care sa stea aprins)
In VCDS nu-mi da niciun fel de eroare, dar sincer nu stiu cum sa aprind farurile pentru LH, daca stie careva, va rog sa-mi spuneti si mie.....practic as spune ca nu functioneaza LH-ul pe manual
Astept feedback-ul vostru
Merci
  • Aerofan pinned this topic
