Codari VCDS [Passat CC]
Sonny31
Te duci pe 46 si acolo cauti bit-ul respectiv-comfort closing active.
  On 04.06.2017 at 9:05, pronet a scris:
Expand
  On 25.05.2017 at 13:39, EEXCALADE a scris:
Calculator usa si motoras sofer  cod 1T0959701L inlocuit cu 3C8959701
Calculator usa si motoras pasager cod 1T0959702L inlocuit cu 3C8959702
Inlocuind calculatrul de la sofer am a putut activa plierea oglinzilor din telecomanda
Inlocuind si calculatorul de la pasager la scoaterea cheii din contact nu se mai lasa in jos decat geamul de la usa care a fost deschisa inainte de plecare.
Expand
Salut.
in afara de motorase, este nevoie de o codare aparte?
da, dupa inlocuire codezi in functie de optiunile masinii tale - lampa avertizare usa, etc - dupa care activezi plierea oglinzilor din telecomanda
La plierea oglinzilor din telecomanda e o codare atipica
O postez mai tarziu
Nu m-am exprimat corect. doar partea cu semideschiderea geamului la scoatere cheie din contact etc daca necesitabo codare speciala. Adica sa nu se maiblase toate cand se foloseste doar o usa.
sau stie calculatorul implicit
Modulele respective fac singure treaba asta,nu trebuie nici o codare
Pliere oglinzi din telecomanda :
1. Select "Door Elect, Driver" - module 42
2. Click on: "Security Access - 16"
3. Insert the security code: 04354 and hit "Do it!"
4. Once you are again to the previous menu, click on "Adaptation - 10"
5. Here select the following channel: (9)-System_Parameter_0-System Parameter Byte8
(be patience to find the exact channel, it's quite a long list , but as a tip : it's in the second half of the list)6. Once selected you will notice the old value which is 90Here you have to options for the new value before you click "Do it!":
a. 95 (which I've chosen) - will automatically fold your mirrors while holding the lock button and will unfold them when you turn on the engine.
b. 99 - will automatically fold your mirrors while holding the lock button and will unfold them when you open the driver door.
7. Next window simply click: "Yes".8. Click "OK"
9. Please check the new value to be there , and "Go Back" and exit the program and disconnect the interface.
Modificat de EEXCALADE
am facut la o masina si am urm comportament (masina este kessy):
1. Cu unlooking doors pe ALL, cand deschid masina se lasa toate geamurile
2. Cu unlo doors pe SINGLE cand deschid usa sofer/pasager se lasa doar geamul la usa care se deschide, DAR nu mai merge kessy pe usile spate. Nu se mai deschide masina daca ating manere spate.
3. Cu unlock dooors pe VEHICLE SIDE, masina se deschide cu toate manerele, iar geamurile se lasa (atat fata cat si spate) doar pe partea pe care deschizi usa (indiferent daca atingi manerul din fata sau spate).
da, este ok
Stie cineva, DRL-urile sunt comandate de un controller, trec prin centrala electrica sau au un circuit mult mai simplu, extern, prin releu? Au circuit comun (stanga+ dreapta) sau separat? Mi s-a ars becul DRL dreapta si dupa inlocuire s-a stins martorul de bec ars din bord dar becul (nou) tot nu merge. Cel de pe stanga functioneaza normal, faza scurta merge si stinge DRL-ul la pornire...La masurare am lipsa tensiune in soclu bec.. N-am gasit nici schema electrica  pe net...
:) Rezolvat. Am scos borna baterie  cca. 10 min si si-a revenit.
Revin si eu cu o intrebare.. calibrarea la DSG, este cea de aici http://wiki.ross-tech.com/wiki/index.php/6-Speed_Direct_Shift_Gearbox_(DSG/02E) ?
Daca da, se face in urma schimbului de ulei sau nu? Dauneaza cu ceva daca o fac si eu? Se simte vreo imbunatatire, ceva? :)
Daca cutia nu are probleme ,in timpul calibrarii o sa ai sentimentul ca nu trebuia facuta
Pai probleme am.. un zgomot ciudat, cica un rulment.
Trebuie sa ajungi la cineva care repara cutii dsg si o sa te lamureaca cu "rulmentul"
Cunosti pe cineva in Bacau care ma poate ajuta? Macar cu o parere? Am vorbit sa ma duc la Soft Tuning la Bucuresti, insa momentan sunt prins in altele, si cred ca peste 2 saptamani abia.. ajung la Bucuresti
Eu am facut din obd eleven si se pliaza din cheie si se depliaza cand bag cheia in contact sau mai era o optiune, cand deschid usa. Fara sa schimb vreun calculator sau altceva.
La anul tau de fabricatie, nu ai de ce sa schimbi calculator (de usa) pentru activarea aceste functii - merge cu VCDS-ul, etc
Am un cc din 2011, si de cateva zile am observat ca nu mai merge blocarea/deblocarea automata a usilor.
Cand depasea 10kmh sau asa ceva se blocau toate singure, cand scoteai cheia din contact se deblocau toate.
Acum doar manual. Nu am umblat la soft sau sa inlocuiesc ceva la masina. Cum pot verifica/remedia aceasta problema?
15kmh.
vezi in meniul BC-ului, daca sunt bifate functiile.
Multumesc, dar unde anume sa caut mai exact?
Cum se poate sa dispara activarea daca a functionat pana acum? Nu am inlocuit bateria sau scos contactul ori altceva!
Nu stii ce functii ai in BC-ul masinii ? cauti auto lock, auto unlock, in Convenience.
Dupa aia vedem daca au disparut, de ce, etc
Mersi, rezolvat. Erau debifate in bc/convenience, am lasat pe cineva sa vada masina... de acolo era problema, a umblat prin meniu!
  • Edy_77 changed the title to Codari VCDS [Passat CC]
