Salutare, Am si eu urmatoarele erori, masina intra in limp mode, iar mai nou imi ramane Check Engine-ul aprins. Cand intra in limp mode nici nu mai "trage". Am schimbat EGR (nou de la Pierburg), actuator, solenoid (N75), curatat DPF, pompa de vaccum (Pierburg), refacere geometrie turbina si tot degeaba. Am fost si la cei de la AVIA, dar nu le comunica serverul de la diagnoza cu cea de la reprezentanta. Daca s-a mai intalnit cineva cu aceasta problema sau daca mi-ati recomanda un specialist pe diagnoza mi-ati fi de mare ajutor. Ma gandesc sa nu fie si de la comunicarea dintre senzori si ECU (cablurile vizual, iar unele masurate, par ok) Acestea sunt erorile: 3 Faults Found: 7937 - Turbocharger Boost Control Position Sensor Circuit P2563 00 [040] - Implausible Signal Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 4 Mileage: 313402 km Date: 2025.09.02 Time: 12:43:13 Engine RPM: 830.00 /min Normed load value: 40.0 % Vehicle speed: 0 km/h Coolant temperature: 89 C Intake air temperature: 50 C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.320 V Unlearning counter according OBD: 40 Charge Pressure Actuator: activation: 100.00 % Charge air pressure actuator: acknowledgment: -12.63 % Turbocharger boost control: offset closed: -4.55 % High press turbocharger actuator: status-Bits 0-7: 0 High press turbocharger actuator: status-Bits 0-7: 0 High press turbocharger actuator: status-Bits 0-7: 63 High press turbocharger actuator: status-Bits 0-7: 0 High press turbocharger actuator: actual uncond volt value: 4843.4 mV Accelerator pedal travel: 0.00 % 7934 - Turbocharger Boost Control Position Sensor Circuit P2563 00 [032] - Implausible Signal Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Mileage: 313415 km Date: 2025.09.02 Time: 14:27:36 Engine RPM: 876.00 /min Normed load value: 36.9 % Vehicle speed: 44 km/h Coolant temperature: 89 C Intake air temperature: 54 C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.360 V Unlearning counter according OBD: 40 Charge Pressure Actuator: activation: 100.00 % Charge air pressure actuator: acknowledgment: -12.63 % Turbocharger boost control: offset closed: -4.55 % High press turbocharger actuator: status-Bits 0-7: 0 High press turbocharger actuator: status-Bits 0-7: 0 High press turbocharger actuator: status-Bits 0-7: 55 High press turbocharger actuator: status-Bits 0-7: 5 High press turbocharger actuator: actual uncond volt value: 4846.4 mV Accelerator pedal travel: 0.00 % 9127 - Actuator Module for Turbocharger 1 P00AF 00 [032] - Stuck Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 5 Mileage: 313402 km Date: 2025.09.02 Time: 12:43:47 Engine RPM: 1312.50 /min Normed load value: 0.0 % Vehicle speed: 32 km/h Coolant temperature: 89 C Intake air temperature: 54 C Ambient air pressure: 1000 mbar Voltage terminal 30: 14.360 V Unlearning counter according OBD: 40 Charge Pressure Actuator: activation: 95.72 % Charge air pressure actuator: acknowledgment: -12.63 % Turbocharger boost control: offset closed: -4.55 % High press turbocharger actuator: status-Bits 0-7: 0 High press turbocharger actuator: status-Bits 0-7: 0 High press turbocharger actuator: status-Bits 0-7: 55 High press turbocharger actuator: status-Bits 0-7: 5 High press turbocharger actuator: actual uncond volt value: 4844.4 mV Accelerator pedal travel: 0.00 % Readiness: 0 1 0 0 0 La drum intins nu am probleme, doar in oras. Inainte o opream si dupa ce o reporneam disparea eroarea. Acum ramane aprins check engiene-ul, iar in limp mode imi intra la un interval de timp scurt de mers (10 km), apoi imi dispare doar semnul de la limp mode dupa repornire. Multumesc!!
WVWZZZ3CZBP334930.pdf -
Nu stiu care este denumirea exacta, dar acesta este cea din masina, in care introduci cardul de navigatie.
Super bună experiența cu Fuchs Titan GT1 Longlife III 0W-30. Totuși, întrebarea e inutilă, motorul nu consumă ulei din cauza uleiului dacă e norma corectă.
CID off la unitate, dar care e unitatea, ca nu ai spus. Nu putem ghici
Si uite-asa devine topic pentru consumuri.
Hai ca postez si eu un consum de la masina din semnatura (Karoq 1.5 tsi dsg) ca sa vedeti ca e un motor economic. AC ON, SS OFF, masina full, trafic greu de tot, stat mult in coloana (inclusiv la 2 accidente in lant pe A2), etc.
Eu pot spune ca, consumul lui 1.5 TSI 150cp manuala, este foarte bun. In conditii de incarcare maxima, 4 pers. si bagaje peste tot. Si ca sa nu uit, am peste 20k km si inca nu am vazut ACT+ in functiune😅
Buna ziua, La un passat cc 2009 CBAB fara start stop, baterie varta cu o vechime de aprox ani am urmatoarea dilema/problema: - de vreo 2 sap am observat ca masina sta turata la 1100-1050 ture pe acolo, in special dimineata cand am farurile aprinse sau seara pt ca pe auto farurile au interval orar cand se aprind automat sau in functie de senzor pbb. initial credeam ca e regenerare, insa nu este. Am masurat bateria dupa 2h de la oprire si avea 12.8 V. Am masurat si cu masina pornita, incarcare este de 13.8 si cu si fara consumatori ( am oprit navigatie, faruri, clima, alti consumatori, tensiunea a ramas constanta), in aceleratie se duce in maxim 13.9. Aveti idee daca incarcarea este ok? din cate stiu ar fi trebuit sa fie peste 14V insa nu sunt sigur. Credeti ca ar fi alta problema? Multumesc
george324tdx a postat în topic iniţiat de qwk din Motoare pe benzina
Deci care sunt diferentele, aprindere, fise, bujii, pompe benzina, ulei....? Cand caut piese(bobina, fise, pompa benzina), pe toate scrie ca sunt pt versiunea CBZA sau pentru versiunea CBZB, pentru CBZ nu am gasit niciuna. Deci se potrivesc? Difera? Multumesc! -
Cand din 580km ai 520km de autostrada nu e nimic iesit din comun. Trafic intens, cu multe portiuni in lucru, mers bara la bara, in coloana in unele zone.
Aglomerația se refera la densitate nu la viteza.
Se Pot Amesteca 2 Uleiuri De Motor?
andrei_221 a postat în topic iniţiat de Daniel M din Uleiuri si Carburanti
in 2005 inca erau fara DPF Doar 0w30 506.01 la aceste motoare -
Voi cum puteti merge pe drum aglomerat cu o viteza medie de 95km/h ? Sau ce intelegeti prin drum aglomerat ? Ca apare uneori cineva in fata pe care il depasiti ?
Jsk a postat în topic iniţiat de Kostas din Intrebari Frecvente
Buna seara! Va rog frumos, daca se poate, o decodare pentru WVWZZZ3CZBP334930. Multumesc! -
În cinci ani și patru luni nu am simțit nimic pentru nu e nimic. Am urmărit cu atenție după ca am citit pe forum ca unii simt ceva. Martorul din bord este singurul care îmi da de știre ca motorul lucrează cu doi sau patru cilindri. Asa ca îmi pare rău pentru cei care au aceasta problema.
Va salut si va solicit atentia cu urmatoarele : 1. Imi puteti confirma ca CID-urile de mai jos sunt cele originale ? Discover Media mib1 0941504d49425354102d702df000d700 Discover Media mib2 0941504d49425354102d5033b000d501 Dar pentru Discover Media Pro ? 2. Cardurilor de mai jos le pot rescrie CID-ul ? Samsung 32GB (MB-MSBGB) Samsung EVO 16 GB (MB-MP16D) Samsung EVO 32 GB (MB-MP32D) Samsung EVO 64 GB (MB-MP64D) Samsung EVO 32 GB (MB-SP32D) Samsung EVO 64 GB (MB-SP64D) Samsung EVO PLUS 32 GB (MB-MC32D) Samsung EVO PLUS 64 GB (MB-MC64D) Samsung EVO PLUS 32 GB (MB-SC32D) Samsung EVO PLUS 64 GB (MB-SC64D) Samsung PRO 32 GB (MB-MG32EA) Samsung PRO 32 GB (MB-SG32E) Samsung PRO 64 GB (MB-MG64EA) Samsung PRO PLUS 32 GB (MB-MD32D) Samsung PRO PLUS 64 GB (MB-MD64D) 3. Exista posibilitatea sa fac CID off la unitate si sa pot apoi folosi orice card ? 4. A achizitionat cineva un card blank cu CID-ul corespunzator din China ? Dar un card full navigatie ? Multumesc pentru timpul acordat si astept raspunsurile voastre !
Se simte ca o vibratie rapida, dar de mica intensitate. Cel putin asa e la Golf 7 si este perceptibila din prima zi, dar trebuie atentie, nu e ceva evident.
Nu ma pricep cum e cu echilibrul dar la mine, după cum am mai spus, nu sunt vibrații, zgomote, etc. Mersul în doi cilindri se activează și la viteze mai mari de 130 dacă se merge constant.
Trepidatiile se simt la mersul in doi cilindrii, intrucat motorul nu mai e la fel de bine echilibrat, iar acea mica smucitura se simte cand intra in modul normal. Nu stiu cum e la automata, insa pe cutie manuala, pe autostrada, sunt momente in care motorul merge in 2 cilindrii la 130km/h, cu ACC folosit sau nu. Eu folosesc masina doar in modul Sport, intrucat nu sunt diferente de consum fata de Normal si nici in Eco nu vad ceva notabil si e enervant. Ca idee, mers pana in Budapesta cu 130km/h pe ACC, viteza medie 112km/h (40km de drum national plus capitala, din 580km in total) consumul a fost de 5.6%. La intoarcere mers in general cu 120km/h, medie de 95km/h 5.2%, drum aglomerat,
Deci zgomotele și trepidații provin din cutie?
Pai da,ma gindeam si eu,motor CR parca insemna motor common rail.Nu prea are cum sa mentina 2050 bar in chiulasa,de unde se alimenteaza injectoarele PD,nici macar 300bar necesari pentru pornire.Si ce fel de regulator are pompa tandem? -
pronet a postat în topic iniţiat de hallucinogen din TDi Forum
Da, este pd. -
Octavia 1,9 tdi?ce sistem de injectie are,cumva PD?
