Afişează tot conţinutul publicat în ultimele 91871 zile.
Infotainment / Navigatii / Car Net (Tiguan AD1)
devis25 a postat în topic iniţiat de Eugen Popa din Tiguan AD1
Intamplator am aflat ca 3 boxe de bass cele mari nu mai merg si am erroarea la scan cu vcds: Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb Part No SW: 3Q0 035 864 B HW: 3Q0 035 864 B Component: MU-S-N-ER 840 0764 Serial number: Coding: 02730601FF0000005111000100080A231F0100E4012000008F Shop #: WSC 01357 011 00200 ASAM Dataset: EV_MUStd4CDELP 001001 ROD: EV_MUStd4CDELP_VW26.rod VCID: 306FA5C76B235A09F2-8064 Display and control head 1 for information electronics: Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606 Component: ABT_High H63 0032 Serial number: VWZ8Z9SKL06ZC3 Data carrier: Subsystem 2 - Part No SW: V03 959 823 NA HW: ----------- Component: ECE AS 26/27 --- 2610 Serial number: -------------------- 3 Faults Found: 0512 - Rear Right Bass Speaker B1067 13 [009] - Open Circuit [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 34 Mileage: 168003 km Date: 2026.02.15 Time: 14:33:02 Voltage terminal 30: 12.6 V 0517 - Front Right Bass Speaker B1062 13 [009] - Open Circuit [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 34 Mileage: 168003 km Date: 2026.02.15 Time: 14:33:02 Voltage terminal 30: 12.6 V 0527 - Rear Left Bass Speaker B1065 13 [009] - Open Circuit [New feature! Extended UDS fault detail is only supported by current gen. interfaces] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 1 Reset counter: 34 Mileage: 168003 km Date: 2026.02.15 Time: 14:33:02 Voltage terminal 30: 12.6 V Ca ma sfatuiti sunt boxele duse si trb inlocuite? Am gasit ceva le ali express I just found this on AliExpress: Auto Front or Rear Door Bass Sound Speaker Horn For VW Tiguan 2 II 2017 2018 2019 5NA035454 5NA035453 https://a.aliexpress.com/_EuBuGkk dar vad ca sunt prinse in usa cu clipsuri si nu cu suruburi cele originale. -
nu esti obisnuit cu electrica, are cuplu mare la pornire de pe loc Cred
Segmentare motor EA888 in Bucuresti - recomandare service
ggdan a postat în topic iniţiat de Shaolinul din Motoare pe benzina
Distribuția e ok,lanț,întinzătoare,mă gândesc că dacă nu era la punct nu pornea sau făcea mai urât,cat despre solenoid si valva daca îmi puteți da câteva lămuriri.... - Astăzi
Am deconectat bateria pe timpul noptii, dupa reconectare tot nu nu se activeaza semnalizarea. Insa acum modulul Central Locking are un cod de eroare: 01131 - Control Circuit for Turn Signals, 25-00 - Unknown Switch Condition ! Am verificat: sigurantele fuzibile; continuitatea firelor si butonul de avarie - totul e ok. ,, Control Circuit for Turn Signals,, - nu imi dau seama care e circuitul de control ? Problema este ca pe schema electrica nu exista circuit/ conexiune spre ,,Turn Signals,, . -
@iceman_30 bine de stiut care a fost problema... pacat ca ai avut ghinion. Exista metode de reconditionat DPF care au succes, sunt si cazuri documentate pe aici ( vezi EExcalade) si exista si aparate fabricate special pentru asta, numai ca orice reparatie vine cu riscuri. Nu stiu daca trebuia sa apara "pata sticlizata", si cum a trecut verificarile lor... cum a fost apoi aia "reparata" chiar as fi curios.
davidut5 a postat în topic iniţiat de Shaolinul din Motoare pe benzina
Distributie aiurea/uzata, variator, solenoid, valva vvt blocata cine stie ce o fi acolo. -
- nu mai ai electromotor de pornire, pornirea se face cu alternatorul reversibil ( care se transforma in electromotor de pornire) prin cureaua de alternator. - ajuta doar la acceleratii cu 2-3 cp, nimic concret - avand compresor de AC mecanic, actionat de motor... este logic ca la semafor cand se opreste motorul, nu mai face rece. Insa daca cerinta de caldura / rece este suficient de mare, clima va cere repornirea motorului, fara sa intervii tu - nicio masina normala nu vine din fabrica cu aparatori de noro, insa la Skoda sunt relativ ieftine cele originale, deci cel mai bine sa optezi pentru montarea lor la livrarea masinii ( 100 lei fata si 75 lei spate , parca asa retin) -
Liviu1000 a postat în topic iniţiat de cristi511 din Octavia 4
Salut tuturor, Ca si sfaturi financiare pt achiziție daca luati în rate ar fi urmatoarele: 1. Credit auto, nu leasing , este aceeasi dobanda oricum,avans cat mai mare daca ai ...50%. La predare auto primești si cartea, ești proprietar. 2.In prima luna după credit refinanțare cu dobânda mai mica în alta parte si închizi creditul anticipat cu 1%. 3. Dupa 3 luni, cat ai casco obligat la porsche, faci în alta parte la jum de preț. În loc de 1200e pe an vei plăti 600e cu franciza 100e în loc de 50e la porsche. 4. Parte negativa, vei pierde revizia inclusa de 2 ani, dar tot este mai rentabil sa o plătești...câștigi diferența din casco pe 1 an si 9 luni, cat nu plătești la porsche. 5. Pui opțiuni care nu se pot pune ulterior, fără jante, geamuri fumurii etc. Later edit : chiar daca ai cash, trebuie luat cu credit ,ramai cu vreo 1800e din cei 2200e care se acorda la finantare 😀 Succes. -
Buna ziua. Skoda Kodiaq PHEV. Cand accelerez in oras sa plec in demaraj, bineinteles ca in oras merg full electric, imi patineaza tot timpul rotile de pe fata fiind 4x2. Asa face si la voi? acest lucru il facea si cu anvelopele de vara de la ei si cu cele de iarna hankook noi noute ambele seturi. Daca vreau sa intru in sens giratoriu si tai calea la cineva si apas pedala mai tare imi patineaza rotile inainte de a pleca de loc in demaraj. Multumesc anticipat pentru raspunsuri.
laur71 a postat în topic iniţiat de cristi511 din Octavia 4
multumesc de pareri la toti 🙏 masina este Model: Octavia Selection 1.5 TSI/150CP + DSG mHEV este mild hibrid, nu stiu daca mildul asta participa la tractiune, am vazut ca la Hyundai/Kia participa pt cateva sec la acceleratie, are chiar si o grafica in bord in acest sens. La Octavia am inteles ca doar suplineste utilitatile pe perioada cand motorul se opreste din functionare gen start/stop sau coasting. De asemenea am vazut pe alte forumuri pe unii care ziceau ca in momentul opririi motorului in situatia descrisa anterior, aerul conditionat se opreste si merge doar ventilatia fara AC. Este adevarat? Care este diferenta intre parbrizul incalzit prin inductie si cel cu firicelele alea prin interior? Care e mai ok? A montat cineva aparatori de noroi fata/spate? am vazut ca masina vine fara aparatori. -
Si la mine inspectia era si este la 2 ani sau 30k km, iar schimbul de ulei la fel, 2 ani sau 30k km. La al doilea schimb de ulei am optat ptr interval de schimb fix 15k km
dnysterian a postat în topic iniţiat de popica17 din Golf VIII
Salutare, de curand mi-a sistemul SOS mi-a intrat in eroare. Am fost la reprezentanta si mi-au spus ca va trebui sa inlocuiasca modulul deoarece este mort. Dar ciudatenia este ca, cam tot din aceeasi perioada a inceput sa faca figuri si Android Auto, care nu se conecteaza tot timpul. In urma cu o saptamana mi-au inlocuit camera spate pe motiv ca nu mai comunica cu calculatorul, a mers fix 3 zile apoi tot sistemul view360 este iar in eroare. -
Am constatat că problema a fost dpf.Structura ceramică interioară s-a topit și s-a vitrificat din cauza temperaturii excesive, transformând filtrul într-un dop etanș care a pierdut definitiv capacitatea chimică de a mai arde funinginea. După ce am făcut postarea de mai sus, dpf-ul a fost demontat de pe mașină și constatat că are în partea centrală o pată sticlizata.Am luat legătura telefonic, cu cei de la Odorheiu Secuiesc, discutat cu un domn foarte amabil, le-am retrimis dpf, așa cum mi s-a spus să o fac, dpf a fost din nou curățat de ei , acea pată dispărând, a fost remontat pe autoturism, făcute toate setările și ulterior constatat, după ce s-au verificat tot ce se putea verifica și seta , că de fapt dpf este problema.Cel mai probabil a fost deteriorat în procesul de curățire, prima dată.A fost supus în cuptor la o temperatură mai mare decât a fost fabricat să reziste și s-a degradat După ce am mai citit și discutat cu diverse persoane, am ajuns la concluzia că este doar o amăgire pentru clienți, curățirea dpf, indiferent că a fost curățat la cuptor, prin ardere sau prin spălare, că există posibilitatea să fie distruse metalele prețioase din dpf așa că temperatura nu poate creste suficient pentru a se face regenerarea, iar cei care și-au curățat dpf , atât la Odorheiu Secuiesc cât și în alte părți, prin spălare, și avut noroc că nu a fost deteriorat, își fac regenerarea la același număr de km ca înainte să îl trimită la curățat. Pe scurt, este o amăgire că un dpf prin curățire va funcționa mai bine ca în trecut, există riscul să fie distrus cu ocazia curățirii sale și să cauzeze în prejudiciu mult mai mare clientului, este doar o sursă de venit pentru cei care fac așa ceva.Dpf se înlocuiește cu alt dpf, nou s-au folosit dar în stare tehnică cel puțin bună. Dacă aș da timpul înapoi nu as mai trimite dpf la curățat, nicăieri iar când este terminat fizic, înlocuit cu altul.
2025 BMW X5 xDrive 50e (PHEV)
voinea a postat în topic iniţiat de CristiM din Mașina mea, alte mărci
+1 despre Bavaria Baneasa. Doar sa cumperi masina de la ei sunt ok. In rest nu as calca in service la ei. Cat am avut masina in garantie s-au purtat urat cu mine. Nici Cobalcescu nu au fost de nota zece dar macar au rezolvat problemele pentru care m-am programat. -
Salutare, nou nu am gasit, dar vazusem ceva preturi de aprox 6000 lei
Sistemul de răcire - Probleme & Discuții (Touareg 7P)
Baxxon a postat în topic iniţiat de FakeTaxi din Touareg 7P
Se pare ca si radiatorul se cere schimbat , il schimb si pe asta sa vedem ce mai cere masinuta -
akon a postat în topic iniţiat de cristi511 din Octavia 4
Am avut O1 1.9 101 ultimul an de fabricatie 2010. Nu ai ce sa compari cu O4 la motor/zgomot/consum. Poti merge si pe cel de 115cp ca tot o sa fie mai bine. Imi aduc aminte ca ii pusesem carton in bot pt ca se racea in mers daca nu mergeai f turat si facea asta de la 0km. In schimb ca si constructie e mult mai tinichea O4. Daca o iei pe credit oricum te obliga la casco deci nu vad problema cu parbrizul cel putin primii ani. -
Am un traseu pe care il fac de zeci de ori pe an in munte cu Golful, curbe de mare viteza, ace de par samd, unde trag tare de masina, pentru ca nu e nimeni la orele in care merg. Stiu cum trebuie sa se comporte masina si se simte anvelopa mai veche. Plec cu ele reci si ajung cu ele calde bine, la temperaturi variate. Nu e nimic stiintific, evident. Hankook-urile originale au fost nesperat de bune, de aceea le-am pastrat, iar de doi ani le-am inlocuit cu Eagle F1. Astea sunt excelente, dar trimit limitele sasiului catre suspensii si frane, mai mult decat o faceau Hankook-urile.
TMBAJ7NXXLY018964.pdf -
in sec 21 se spune my .02 "in mod normal". Da, doar ca in lumea asta nu e doar "normal". Ce mi se pare mie normal poate la altul i se pare deplasat, pana la urma normalitatea e ceva dat de majoritate dar nu intru in filizofii de astea. Asta cu metrul acela se traduce in aderenta mai buna in orice situatie, adica si lateral, intr-o curba. Primacy-urile mele de noi am zis wtf, dar era si masina noua deci doar dupa 60k km am aflat ca erau anvelopele si nu suspensia. Conteaza si overall feelingul unor anvelope pt unii care deh, nu folosesc masina din pct a in b batraneste ci se mai si bucura ocazional de ea. @dercoscum ai constatat concret ca nu mai ai aceeasi aderenta dupa 4 ani? masurat sau bazat pe feeling, "cu degetul" cum se zice? Adica stii exact cu cat sunt mai nasoale sau doar ca sunt mai nasoale? E normal sa fie asa, dar cum ai "masurat"? Cu ele reci, calde, in ambele situatii?
Buna ziua,dețin aceeași mașină,am executat o segmentare în regie proprie,mecanicul care a făcut a constatat că doar chiulasa trebuie schimbate unele supape+scaune,segmenți,diverse garnituri,Semmering . După finalizarea motorul a funcționat normal primele sute de km, apoi la o diagnoza banală cu un obd da eroare p0017. Am mers la cineva pentru diagnoza mai serioasă,aceeași eroare. Arborele cotit nu se corelează cu axa cu came pe evacuare. Cum remediez aceasta eroare. Am privit atent pozele postate și fiind același motor, la distribuție totul a fost pus și mă mine la fel. Semnele pe pinioane cu semnele pe lanț. -
@acidone77 Diferența între un parbriz încălzit și webasto este de 1500 euro, ori, suma asta poate face diferența între a achiziona o mașină și a nu o achiziționa. E cam cât un tichet "rabla". Eu am parbriz încălzit și îl găsesc foarte util atunci când acesta e înghețat pentru că nu mai dau la racletă să-l zgârii, plus că este eficient. Nu înțeleg de ce spui că e ineficient. Se dezgheață repede, inclusiv în zona ștergătoarelor. Nu dezgheață instant, dar în câteva minute (până-n 5 minute) ai parbrizul dezghețat. O fi bun și webasto, nu zic nu că n-am și nu mă pot contrazice, dar la o benzinară de buget, nu îi prea văd rostul că ridică prețul. Am fost și eu tentat să-l iau, dar mi-am dat seama că nu merită și am renunțat în favoarea altora opționale "de iarnă", după cum urmează. Parbrizul încălzit, volanul încălzit plus scaunele încălzite față/spate duc mai ieftin decât webasto, iar benzina se încălzește repede. În maxim 10 minute aeroterma bagă aer cald în habitaclu. De asta i-am și spus celui care cere informații că părerile altora sunt subiective și denotă gusturile sau dorințele lor, însă alegerea îi aparține. Omul a spus că bugetul îl încorsetează un pic și nu prea are multe de bifat, ori webasto e scump în cazul ăsta. Părerea mea, evident. Mașina o poți încălzi și stând în ea câteva minute cu motorul pornit cât să se "rupă" uleiul, după care în mers, cum spune și în manual, pornind volanul și scaunele încălzite și ai rezolvat-o cu webasto. -
Este foarte bine ca ai curiozitati dar in cazul de fata stii ca e irelevanta, nu? Cand sunt noi, baselineul este acelasi. Dupa 1 2 ani de utilizare intervin factorii de mediu: - depozitare - utilizare - clima in care circula masins - greutatea/puterea - etc etc etc. De asta citim pe aici povesti despre anvelope uhp rulate 50-60-70k km sau 10-15-20k km acelasi model. De asta citim pe aici cum ca anvelopele de 6 7 ani "cu carne" sunt bune si ca de ce sa le schimbam? Mno, alegerea anvelopelor este un exercitiu de logica individuala. Argumentul de genul "1m la franare este esential" nu tin apa pentru ca, in mod normal, NU ar trebui sa ajungi in situatia de avea nevoie de metrul ala. Eu l-am pupat pe unul in bara spate plecand de pe loc. O secunda de neatentie si cu toate michelinurile mele fizica a zis "pas". De asta am tot insistat pe aici ca in mod normal nvh-ul conteaza mai mult decat orice la o anvelopa noua. Parerea mea, cum s-ar spune.
A reusit sa-ti activeze ceasurile de RS? La mine la reprezentanta, pe langa update la MIB, s-au facut update la tot.
