Problema la pompa secundara de racire - motor CR
doctorul
buna seara.
dupa aprinderea martorului de check engine,s a efectuat o scanare,si au rezultat urmatoarele probleme:
Monday,10,October,2011,22:35:14:13557
VCDS Version: Beta 11.8.0
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Control Module Part Number: 3C0 959 433 R HW: 3C0 959 433 R
Component and/or Version: IMMO 042 0383
Software Coding:
Work Shop Code: WSC 131071 1023 2097151
Additional Info: 3C0905861G ELV 027 0380
Additional Info: Geraet 2097151
VCID: 3972C64C0E43
02823 - Requirements for Locking the Steering Column Lock not met
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 190
Mileage: 32594 km
Time Indication: 0
Date: 2011.10.09
Time: 22:56:39
Monday,10,October,2011,22:35:47:13557
Address 01: Engine Labels: 03L-906-022-CBA.clb
Control Module Part Number: 03L 906 022 EM HW: 03L 907 309
Component and/or Version: R4 2,0L EDC G000SG 3502
Software Coding: 0000172
Work Shop Code: WSC 84224 792 674566
VCID: 74EC377869A1
009754 - Coolant Pump 2: Open Circuit
P261A - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Mileage: 32583 km
Time Indication: 0
Date: 2011.10.09
Time: 22:24:08
Freeze Frame:
RPM: 1564 /min
Speed: 21.0 km/h
Voltage: 13.83 V
Lambda: 95.5 %
Bin. Bits: 10011111
Bin. Bits: 00000000
Temperature: 89.1°C
Readiness: 1 1 0 0 0
daca s a discutat rog mutarea topicului,am cautat,dar nu imi e familiara sectiunea de B6!
astept parerile voastre!
multumesc!
Referitor la codul de eroare de pe motor, in fata motorului in partea de jos ( accesibil dupa ce dai scutul jos) ai o pompa de recirculare. Schimb-o.
are si pompa de apa electrica si mecanica,sau cum?o idee de pret?
Motoarele CR de la VW mai au o pompa suplimentara de recirculare pentru racitorul EGR. Pret pe original aprox 800 Ron.
aaa,ce frumos.si imi poti spune ca idee daca as mai putea sa merg cu ea asa cateva sute de km?ce se poate intampla?
si b. cu a doua eroare ma poate ajuta cineva?
Cu eroarea 2, sunt destule pagini si pe forum. pe scurt: modulul de blocare a coloanei de volan are probleme.
Nu are probleme cu acel modul. Acel cod de eroare poate aparea daca a scos cheia din contact, in parcare, si masina rula ( un exemplu). Cu pompa mai poti circula, nu se realizeaza racirea gazelor egr.
deci ca idee,pt steerin column nu aparea nici o eroare pe bord.am sa vad daca reapare eroarea.
daca nu se realizeaza racirea gazelor egr, si din cate stiu eu egr lucreaza mai mult in ora,pot face un drum in afara de cateva sute de km?
am de ajuns undeva si de intors zilele astea....
si da,genial, am scoscheia din contact cu masina ruland,la putina vreme dupa aprinderea check engine ului,ma gandeam ca poate se stinge!
Modificat de doctorul
Daca te uiti la km cand au aparut erorile o sa vezi ca prima a fost cea cu pompa si apoi cea cu cheia. ;)
stiu.asta am si zis!!:))
deci:se poate iesi cu masina din oras la drum lung?
rog un moderator sa schimbe titlul in ceva gen "problema la pompa secundara de racire"!
rezolvarea:inlocuire!
am inteles ca pe 2,0 cr sunt 3 tipuri de asemenea pompe,a trebuit demontata pt identificare!
cost device in reprezentanta:870 roni!
  • 11 months later...
sunt 2 tipuri de pompe,care nu merg identificate decat dupa demontare,a mea era pirburg si a costat 677 ron
post-12281-0-15326900-1350721119_thumb.g
post-12281-0-07285400-1350721170_thumb.j
Modificat de dann778
  • 10 months later...
t
de curand am achizitionat un Passat CBAB din 2010 caruia i-am schimbat distributia odata cu achizitia(acum 3 saptamani). Dupa un drum mai lung(200 km) am avut aceeasi problema cu pompa in urma scanarii. Am inlocuit pompa( nu era pierburg insa de la brady am cumparat un adaptor si am montat pierburg) am facut un drum de 500 de km si nu am mai avut problema. Insa am facut apoi un drum de 1200 de km si cand am repornit a doua zi am primit aceeasi eroare. am oprit motorul si am repornit si a disparut martorul si eroarea din bord. am mai facut apoi drumuri de maxim 50 de km fara eroare insa apoi am facut iar un drum de 1000 de km si a doua zi am reavut eroarea. La fel am oprit am repornit si la o scanare apare aceeasi eroare cu coolant pump 2. Pompa a fost testata si functioneaza , si totodata primeste si semnal. Stiti unde as putea merge? Am fost la serviceul "La Service" si nici nu stiau de existent pompei a zis sa merg asa cu ea, la un Ad Garage am schimbat-o baietii fiind ok insa acum nu mai stiu ce sa ii faca.
posteaza eroarea cum iti apare la scanare.
nu am tester si nu sunt la service:( insa mi-a dat si in dimineata asta si ar trebui sa fie in history
Salut aceeasi problema o am si eu pe un golf 6 model 2009 2.0 tdi.. Mi s-a aprins martorul "robinet galben" si am facut o scanare dupa care mi-a afisat eroarea 009754 coolant pump nr 2.. Am tot intrebat pe la diverse magazine de piese si mi s-a spus ca nu au auzit de piesa asta.. Stiti care ar putea fi problema si daca da ce trebuie inlocuit si la ce pret??
ce cod motor ai? posteaza eroarea excat asa cum apare pe tester. Interfata era OEM?
pentru ca nu se pricep.... este vb de pompa suplimentara de racire - se afla in fata, intre radiator si motor, ca locatie.
costa in jurul a 500 lei, dar trebuie data jos inainte sa o comanzi, sa vezi care este.
Am inteles! Intrebarea mea este urmatoarea: cam cati km pot sa mai merg cu aceasta problema?
nu e panica cu ea.... poti merge.
Ar trebui sa-mi fac griji?
Acum am 174962 km si din cate stiu, nu s-a aprins nici un indicator in bord.
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QG    HW: 03L 907 309
   Component: R4 2,0L EDC G000AG  3736
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000078
   Shop #: WSC 84224 939 673478
   VCID: 7AFB1463352A82CEDA7-802F
               P261A - 000 - Open circuit - Intermittent
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 174362 km
                    Time Indication: 0
                    Date: 2055.14.28
                    Time: 13:04:39
             Freeze Frame:
                    RPM: 736 /min
                    Speed: 0.0 km/h
                    Voltage: 12.16 V
                    Lambda: 79.7 %
                    Bin. Bits: 10011011
                    Bin. Bits: 00000000
                    Temperature: 29.7°C
Readiness: 0 0 0 0 0
Nu, poti merge linistit dar sa te pregatesti de 730 lei de una noua sau 100-150 sh.
Trebuie sa vezi codul la cea care o ai tu pe masina 5N0 965 561 A sau 5N0 965 561.
Salut tuturor,
Exista si o alta solutie decat inlocuirea pompei secundare de recirculare a apei in cazul acestei erori:
Va multumesc
Nu exista alta solutie.
