Martor "usi deschise"
Sethnakht
salut
imi puteti spune si mie daca erorile sunt de switch-ul din broasca? la deschidere usa ( stanga si dreapta fata doar) nu-mi arata in bord , nu se aprinde decat lampa de pe usa stanga si nu se aude buzzerul... multumesc
VCDS Version: Release 11.11.3
Data version: 20120401
Wednesday,17,April,2013,17:32:02:32264
Chassis Type: 1U - Skoda Octavia I
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 56 76
VIN: TMBCX41U342870613
Mileage: 149160km/92683miles
Address 17: Instruments        Labels: 1U0-920-xxx-17.lbl
   Part No: 1U0 920
841 B
   Component:
KOMBI+WEGFAHRSP VDO V10
   Coding: 19113
   Shop #: WSC
31480
   VCID:
30650E19F038729
TMBCX41U342870613
SKZ7Z0C2173720
01336 - Data Bus for Comfort System
            80-10 -
Single-Wire Operation - Intermittent
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909
901
   Component: Gateway
K<->CAN    0001
   Coding: 00006
   Shop #: WSC
31480
   VCID:
F0E54E19B0B8B29
            80-10 -
Address 46: Central Conv.        Labels: 1C0-959-799.lbl
   Part No: 1C0 959
799 B
   Component: 3X
Komfortgerát HLO 0003
   Coding: 00259
   Shop #: WSC
31480
   VCID:
36693801125C5C9
   Subsystem 1 - Part
No: 1U4959801D
   Component: 3X
Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part
No: 1U4959802D
   Component: 3X
Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part
No: 1U0959811D
   Component: 3X
Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part
No: 1U0959812D
   Component: 3X
Tõrsteuer.HR KLO 0202
2 Faults Found:
            80-00 -
00928 - Locking Module for Central Locking; Front Driver
Side (F220)
            27-10 -
Implausible Signal - Intermittent
nu este din switch.. ai ceva fire intrerupe cred. verifica in mansoanele de la usile fata...
ok...merci mult , am sa verific....
F l o r i n
Verifica cablajul precum si mufa din calculatorul de usa - vezi sa nu fie contacte oxidate/pini corodati - acolo...
AndreiVarcus
Salut, ce model de microswitch trebuie sa-mi iau ca sa schimb la ambele portiere si stanga si dreapta ca nu mi se aprinde martorul nici la stanga nici la dreapta.
La Skoda Octavia 1 tour
V4NCT7 - e bun asta??? http://www.adelaida.ro/microintrerupator-v4nct7-5a-250v-saia-burgess.html
Modificat de AndreiVarcus
F l o r i n
da, da.... e bun.
@Andrei Varcus, s-au stricat amandoua deodata? Cam mare coincidenta daca raspunsul este da.
Modificat de dic
Salut.
Am o skoda octavia tour, an fabricatie 2006, si as vrea sa aflu cum pot demonta swicth-ul de la portiera fata stanga. Daca e si un clip... ceva...
usa dreapta rezolvat... am schimbat switch-ul , doar capacelul ( 16 lei cod V4NCT7 ) , merge perfect.... a mai ramas usa stanga, dar am probleme cu suruburile de la broasca, am folosit un torx m8 cam naspa si s-au distrus ambele... trebuie sa gasesc vreo modalitate sa le desfac ... oricum datorita forumului am rezolvat o problema ...merci
daca nu reusesti sa le desfaci un torx mai mare indesat in surub, cumpara-ti un set de extractoare si le dai afara imediat
post-11532-0-93906900-1371315494_thumb.j
Multumesc pentru ajutor... Vreau sa va spun ca am reparat swicth-ul portierei stanga, in parcare... Defectul cel mai intalnit, probabil, la un swicth de la portiera, e faptul ca se roade sau efectiv se rupe, capul butonului swicth-ului. De aceea, acesta se poate repara simplu. Se ia un cablu de cupru de 2,5 mm, se taie izolatia de plastic, cu o surubelnita cu cap drept foarte putin mai mare decat diametrul izolatiei cablului (cat sa intre izolatia pe restul butonului, fara a deranja culisarea acestuia), se largeste izolatia respectiva pe o adancime de max. 0,5mm. I se toarna o picatura de PICATURA in partea care sa va atasa de butonul swicti-ului si se lasa cel putin 10 min. Se taie surplusul izolatiei de la cablu de cupru atat cat sa fie actionat de yala la deschiderea portierei. Se monteaza swicth-ul pe yala, se monteaza yala...si cam asta e... Suna cam a munca de chinez batran..., dar eu tin la piesele originale ale masinii, si va spun ca, decat sa schimbati un swicth de 10 lei cu cel pe care-l aveti deja pe masina..., mai degraba il reparati..., si astea toate, in parcare... E bine sa aveti si un minim de cunostinte sau/si imaginatie in domeniul mecanicii fine..., si foarte multa rabdare.
Multumesc inca odata domnului Al Bundy pentru ajutor... Sper sa ma pot revansa vreodata...
Asta daca nu gasesti tamburusul ala rupt.
merge si cu daltita/surubelnita si un ciocan mic.....
pe viitor incearca sa folosesti chei bune, ca sa nu mai strici suruburile
merci mult... le-am desfacut ieri, initial am dat gaura in ele cu un spiral mic si putin pe marginea surubului (cea mai bombata), dupa care cu o surubelnita am batut usor si gata... am pus altele noi...am schimbat si microcontactul (doar capacul) , becul se aprinde in usa dar tot nu vrea sa-mi arate in bord... trebuie sa mai verific odata cablajul si mufa din usa cu aparatul...
vezi ca nu toate masinile arata in bord, usa deschisa.... portbagajul cand il deschizi, iti arata ?
display-ul e maxidot... a aratat inainte, acum arata tot ( capota, portbagaj, usi spate si dreapta fata) , numai usa sofer nu mai vrea...
post-45061-0-87130100-1371541198_thumb.j
Modificat de tony3626
da, clar - daca ai maxidot immo 3 - trebuie sa-ti arate.... verifica pinii din mufa calculatorului de usa, verifica cablajul.
da, merci mult, am rezolvat...era exact un pin de la calc din usa, era retezat...l-am pus pe direct (decupat din plastic sa am acces la placa, lipit , izolat) ...acum functoneaza perfect...
Exact aceeași problema am și eu la portiera dreapta. Clipește doar o secunda lumina din portiera si pe MaxiDot nimic.
Marti merg la service.
LA service o sa-ti schimbe broasca cu totul. poti schimba doar switchul din broasca.
buna ziua, urmaresc de mult timp postarile legate de probleme la usi, de cind am inceput sa am tot felul de probleme marunte, insa acum s-au cam adunat ..
la mine, la octavia 1 (tour) 1,9tdi alh 2006, uneori cind inchid din telecomanda de la alarma, se inchid usile si usa de la sofer si dreapta spate se descuie singure, de la sofer din cheie se actioneaza doar usa de la sofer si atit, din interior, din butonul de pe usa are acelasi simptom, se deschid in secunda urmatoare usa de la sofer si dreapta spate, martorul din bord nu mai indica uneori, si nici nu mai piuie cind las lumini aprinse, plafoniera uneori se aprinde alteori nu,
precizez ca usile din stinga amindoua au fost schimbate la reprezentanta in urma unui accident, cu 5 ani in urma,  si de atunci am avut probleme cu apa intrata in usa, mi-au lipit din nou folia si nu a mai intrat apa, acum 2 ani am schimbat macaraua din usa sofer, si de atunci nu sa mai umblat la usa, si in ultimul an au inceput problemele mai sus mentionate adunindu-se una cite una. mai de curind am observat ca iar a intrat apa in usa de la sofer,ca ramane pe cheder jos ..
problema cea mai grava se pare ca este la usa din dreapta spate care nu se mai deschide nici de la clapeta interioara, ci  numai din butonul de inchis/deschis de la usa soferului, insa de inchis se inchide si din telecomanda alarmei.
as vrea daca puteti sa-mi ziceti cu ce sa incep, am inteles ca sint lipituri reci, si switchul de inlocuit, am gasit de cumparat, dar numai cu butonul in forma cilindrica, si se apasa din lateralul cilindrului difera de cele vazute prin postari, in rest are aceleasi dimensiuni.
de asemenea nu am inteles exact care din suruburi de sustinere nu trebuie desfacute de tot din cele 2 cu capacele de la incuietoare.
incepi cu desfacutul yalelor, pe rand - verifica mufa la calculatorul de usa de la sofer - sa nu ai si pe acolo contacte oxidate.
yalele le reconditionezi total, daca tot le dai jos - refacut lipituri, curatat colectoare motorase, inlocuit switch-urile.
 am verificat mufa la calculatorul de usa de la sofer, era perfect curata, si nici un pin oxidat
, am dat preventiv cu un spray de contact, nu stiu daca e bine, am sters cu un servetel si dupa ce sa uscat am pus la loc.
din pacate sa rupt acel izolator de usa,din folie, si l-am lipit cu banda adeziva, cum de alfel se mai intimplase si inainte.
sper sa gasesc exact switch ca cel de pe masina, din pacate am gasit ceva, cred chinezesc la 3 lei, cu3 pini de legatura, nu stiu daca merge schimbat cu asta, mai departe sper sa ajung sa desfac si incuietoarea, sper sa ma descurc, inca nu mi-e clar exact ordinea suruburilor care trebuie desfacute.
recunosc ca am avut ceva bataie de cap, doar in faza asta, cu greu am reusit sa pun totul la loc, mai ales cablul de la clapeta interioara si butonul de pe tija de incuiat usa, cel care intra in usa cind se incuie ... macar stiu ce ma asteapta data viitoare, si sper sa am mai mult timp la dispozitie
. daca a pus cineva altfel de switch decit cel original,va rog sa-mi spuneti, daca nu de unde gasesc exact de cumparat .
va multumesc!
Modificat de laur71
altfel, gasesti la magazinele de electronice.
