Kodiaq - discuții generale
Bogdan VW
On 12/24/2017 at 11:54 AM, yanq said:
In alta ordine de idei a aparut "Sleep Pack" - 165,41 eur  in configuratorul de Romania - contine: doua tetiere spate cu suport lateral pentru cap, doua paturici, Sunset si parasolare mecanice pentru geamurile laterale spate.
Avand in vedere ca Sunset era deja 129,71 eur cred ca merita diferenta de 35 eur pentru acele tetiere si paturici (parasolarele nu le iau in calcul pentru ca ele exista deja in Family Pack). Ma intreb daca mai pot modifica optiunea in comanda?
Depinde in ce stadiu e masina. Eu am adaugat un optional dupa lansarea comenzii si s-a putut fara probleme. Cel mai bine e sa vorbesti cu dealer-ul, diferenta de pret vs family pack e infima, chiar foarte bun pretul.
De pe un forum din afara:
"Transmission:
All DSG transmissions on Kodiaq (diesel and petrol) are DQ500 wet clutch rated at 600 Nm sealed for life units. This is not the DQ200 dry clutch rated at 200Nm that was VERY PROBLEMATIC at it's launch due to the clutch disc overheating which led to wear. The oil bath keeps the clutch cool even in extreme driving conditions. The DQ500 clutch was used by VW on their Transporter type van for a few years and proved very reliable. Although it's a so called sealed-for-life unit, it still requires oil change at about 70k miles (6 years), it only means that your input is not needed because it will not lose oil so you don't need to check/refill like on some torque convertors. Because the clutches are in oil, they should not wear out before 200k miles."
Confirm si la a mea (1.4 tsi 4x2) ->DSG6
Kodiaq are  DQ250 si DQ500, iar DQ250 are ambreaje in ulei. Deci fara ambreiaj uscat pe Kodiaq
Scuze dar eu cred ca omul a gresit aria sau a postat tabelul gresit. Kodiaq nu are nici 1.0 tsi si nici 1.6 tdi. Pare a fi Karoq/Ateca in tabel.
Edit: ai dreptate, mi am dat seama ulterior. Hence---> post ascuns.
Modificat de cristi511
Consider ca acest tabel ofera raspunsul disputei legate de DQ381. Ca e Karoq, Kodiaq sau Ateca, pt TDI, motorizarea si cutia sunt aceleasi.
Modificat de Marius82
Tocmai ca nu sunt aceleasi. Kodiaq merge pe combinatiile disponibile pe Tiguan, pe cind Karoq/Ateca sunt practic aceeasi masina.
A aparut manualul de utilizare (disponibil si in limba romana) pentru editia 11.2017.
http://www.skoda-auto.com/en/mini-apps/owners-manuals/kodiaq
Printre noutati am observat Panoul de bord digital (pag 40)  si existenta a 2 USB-uri in consola mediana fata (editia precedenta avea doar 1 USB) pag 99.
In rest aceeasi eroare necorectata cu mentinerea apasata a pedalei de acceleratie la pornirea motorului.
Pacat ca Display-ul digital nu e disponibil si in configurator...
Modificat de yanq
Probabil va fi disponibil in curand in configurator, la Ateca a aparut de 2 saptamani.
Anvelopele self sealing de pe Kodiaq sunt cumva Hankook Ventus S1 Evo2 ?
De asemenea, folie de protectie pentru display-ul de 9.2" se gaseste pe undeva? Pe net am vazut doar pentru cel de 8" cu decupaj pentru butoane. Multumesc.
@yanq pentru folie de protectie poti apela la aceeasi firma unde am facut eu ( pm pentru detalii). Folia e taiata & montata pe loc.
Multumesc.  O sa te intreb peste 3-4 luni cand soseste jucaria daca pana atunci nu apare ceva prefabricat :)
Mai am o nedumerire referitoare la sistemul de asistenta Lane Assist de pe Kodiaq. In manual e mentionat ca e functional si actioneaza daca recunoaste marcajul cel putin pe o parte.
"Sistemul poate acționa numai prin îndeplinirea următoarelor condiții de bază: Sistemul este activat. /Viteza de deplasare depășește aprox. 65 km/h /Se recunoaște linia de demarcație cel puțin pe o parte a benzii de circulație. /Mâinile șoferului sunt pe volan. /Banda de circulație este mai lată decât de aproximativ 2,5 m."
Ar fi interesant sa fie asa pentru ca majoritatea drumurilor de la noi au doar marcaj central. Pe de alta parte nu inteleg cum ar putea functiona doar cu marcaj recunoscut pe o singura parte intrucat sistemul nu stie sa pastreze o distanta constanta fata de marcajul recunoscut ci doar corecteaza traectoria in sens opus cand masina se apropie de marcaj (nu si cand se indeparteaza de marcaj).
"Dacă autovehiculul se apropie de o linie de demarcație recunoscută, sistemul execută o mișcare ușoară a volanului în sens opus liniei de demarcație."
Sa fie doar o descriere eronata a sistemului in manual?
Logica sistemului banuiesc ca e destul de simpla. Singura provocare este identificarea si interpretarea marcajului.
In primele secunde face o identificare a marcajului si-l gaseste pe stanga, pe dreapta sau pe ambele parti.
Ulterior aplica o corectie a directiei sa se incadreze in parametri.
Presupun ca daca identifica un contur valid se ghideaza dupa acei 2,5m si centreaza masina intre linia identificata si o banda virtuala la 2,5m, adica mijlocul masinii sa fie la 1,25m de conturul vizibil.
Sistemul nu opune rezistenta cand semnalizezi ceea ce inseamna schimbare de banda sau directie.
Salutare.
Astazi am primit o veste buna de la Avia Motors.
Kodiaq-ul pe care l-am comandat pe 8.08.2017 cu termen de predare intre 33-55 sapt., va fi livrat in sapt. 9 din 2018. :wub:
Veștile pot fi doar bune. Și eu am confirmarea ca s-a putut adăuga Sleep Pack iar săptămâna de intrare în fabricație rămâne ...13 ?
CCImageProxy.ashx?imt=ExtraEquipments%26
Si-a facut aparitia pe configuratorul de Cehia... 8900 coroane deci aproximativ 350 eur.
frumos si mai ieftin fata de varul primar...numai ca indicatoarele de benzina si temp apa, desi mai practice in forma asta, parca aduc aminte de ceva... autohton
In principiu ar trebui sa fie customizabil, doar e digital.
Indicatoarele din lateral nu sunt customizabile.
Se pare ca a scazut pretul in configurator cu aproximativ 170 eur la style 2.0 tdi 190 cp de la 34219 eur la 34047 eur...
Stie el Thomas ceva de ambreiajele uscate si umede, dar nu cred ca a nimerit-o la Kodiaq.
Am luat primul contact live cu Kodiak Scout...
In sfarsit mi se pare ca arata cum trebuie...
La interior avem un decor nou, texturat, mat, foarte calitativ si da la marele fix pe Scout, iar scaunele sunt excelente.
Big Like din partea mea, astept si un TD ca sa inteleg setarea trenului de rulare.
Noutati la Kodiaq L&K:
- filtru de particule la benzinare
- 1.4TSI 150CP se transforma in 1.5TSI 150CP
- 2.0TSI 180CP creste la 190CP
- 4x4 standard la 2.0TSI si 2.0TDI ambele cu 190CP
- in rest, optiuni in plus adaugate la echipare
@75NOR, intr-adevar este altceva. La exterior, cele doua elemente de pe bara fata si spate ii schimba mult aspectul. Sa nu mai zic de interiorul cu Alcantara si insertii imitatie lemn.
Parca as mai fi asteptat un pic la comanda dar toate astea salta si pretul.
La Scout dupa ce analizezi lista optiunilor incluse o sa constati ca ai multe lipsuri fata de Style....de vreo 2000 eur.
Avem si o culoare metalizata noua  la Kodiaq in configurator - verde smarald ce si-a facut mai intai debutul pe Karoq ( pacat ca nu au procedat la fel si cu scaunele sport)...
Modificat de yanq
  • Bebeee a deschis acest topic
