Proceduri VCDS
Seby19
Bifezi - Turn Signal as parking Light - setezi 25-35%
Bafta
In 09- Central Electric - Long Codding Helper.
Trebuia sa mearga cum e in poza 2.
DAR Byte 07 Bit 5 Comfort closing power windows via remote control active este bifat ?
Da , este bifat(din fabrica).
Am bifat byte 07 bit 5 si merge, dar pot acum doar sa inchid geamurile din telecomanda, nu sa le si deschid. trapa nu are nicio treaba, nici nu se inchide, nici nu se deschide. alte sugestii?
Imi spune si mie cineva cum activez din vag com lumina din oglinzi atunci cand deschid masina mentionez ca nu am senzori de lumina desigur daca se poate fara senzori!! ms anticipat!
Asta se numeşte "Activare Coming Home & Leaving Home" şi se găseşte
CE treaba are comming home cu lumina din oglinzi? :icon_thumright:
Dar ai lumini in oglinzi ?
Pentru TAMANGO:
e asa greu sa alegi singur ce biti trebuie bifati?
Byte 06 Bit 0 debifat Comfort function inactive
Byte 06 Bit 1 debifat Comfort function power windows/sunroof via door lock drivers door inactive
Byte 06 Bit 2 debifat Comfort function power windows/sunroof via door lock passengers door inactive
Byte 06 Bit 3 debifat Comfort function power windows/sunroof via door lock rear lid inactive
Byte 06 Bit 4 debifat Comfort function power windows/sunroof via power window switch in drivers door inactive
Byte 06 Bit 5 debifat Comfort function power windows/sunroof via remote control inactive
Byte 06 Bit 6 bifat Comfort function autom. closing
Byte 06 Bit 7 debifat Power windows/sunroof disabled after door opening
Byte 07 Bit 0 bifat Comfort opening power windows via door lock active
Byte 07 Bit 1 bifat Comfort opening power windows via power window switch active
Byte 07 Bit 2 bifat Comfort opening power windows via remote control active
Byte 07 Bit 3 bifat Comfort closing power windows via door lock active
Byte 07 Bit 4 bifat Comfort closing power windows via power window switch active
Byte 07 Bit 5 bifat Comfort closing power windows via remote control active
Byte 07 Bit 6 Comfort function after authorized access only in a limited time
Byte 07 Bit 7 not relevant/unused
Byte 08 Bit 0 bifat Comfort opening sunroof via door lock active
Byte 08 Bit 1 bifat Comfort opening sunroof via power window switch active
Byte 08 Bit 2 bifat Comfort opening sunroof via remote control active
Byte 08 Bit 3 bifat Comfort closing sunroof via door lock active
Byte 08 Bit 4 bifat Comfort closing sunroof via power window switch active
Byte 08 Bit 5 bifat Comfort closing sunroof via remote control active
Byte 08 Bit 6 not relevant/unused
Byte 08 Bit 7 not relevant/unused
ALea cu BOLD sunt importante. IA vezi, merge?
Nu ştiu la dumneavoastră la Octavia cum o fi dar la Passat chiar ai lumini
Modificat de Ottoflo
(...) activez din vag com lumina din oglinzi atunci cand deschid masina (...)
Cred ca colegul nostru se refera la urmatorul sistem ->
Acest tip de oglinzi sunt disponibile doar daca se cumpara un anumit pachet care include oglinzi pliabile electric + coming/leaving home OEM :beer:
Deci daca masina ta nu are una din ele, NU merge activat nimic pt ca NU exista fizic :)
@ Al Bundy: sunt si eu incepator...
merge acum, mergea si ieri cand am postat dar nu am avut rabdare sa vad si trapa inchizandu-se, ea se inchide dupa ce s-au inchis ferestrele :rolleyes: .
oricum ma mai dus o data sa verific daca e totul ca in lista ta.
multumesc mult!
salut, am fazut faza asta la stopuri la un coleg pe forum, cum se face?
@ kelu2001 - citeste primul post din acest topic si ai sa vezi cum se activeaza respectiva optiune.
Daca activez coming home si leaving home pe o masina fara senzori de ploaie/lumina, dar cu BC+, pot sa modific timpii din computerul de bord? Sau trebuie tot prin intermediul vag-com.
mie mi-a aparut in meniu -> in light & Vision coming home si leaving home dupa ce am activat prin Vag-com ,si pot sa modific timpi sau sa activez/dezactivez functiile. tot Bc+ am si fara senzori de lumina si ploaie
Salut.Stie cineva de ce nu ma lasa sa modific sa se auda si bip la inchidere? am incercat si am schimbat doar regiunea si nimic in rest nu pot modifica.
Am incercat si eu sa modific. Imi scria ca terbuie sa pun parca 3 pt blink si bip, dar nu a luat.
Se pare ca la unele modele nu se poate.
Daca totusi reuseste cineva, sa ne scrie.
Da - Unele B6 nu accepta codarea !
La fel si unele G5
Codarea pentru fog cornering o poate pune cineva? Multumesc anticipat.
Modificat de TheOne06
Functia "cornering" pe proiectoare!
NOTA: Aceasta functie merge activata doar la masiniile produse DUPA iulie 2007!
[Select]
[09 - Cent. Elect.]
[10 - Coding]
[Long Coding Helper]
Byte 23:
- bifati Bit2 (Internal Turn Light Control Algorithm active)
- selectia la Bit-ul 3-4: 08 Turn Lights via Fog Lights
[Transfer Coding!]
[Do It!]
Cam asa trebuie sa arate Long Coding Helper-ul pe byte-ul 23 :Driver:
Front Fog Lights Cornering - Octavia 2
:D safe
P.S.: Din cauza ca nu-mi pot activa functia pe masina mea, am folosit un video demonstrativ al colegului nostru Calin si a lui Octavie 2 :P
Modificat de Riddler
Deci a mea fiind din 2005 cred ca nu o sa o pot activa.Dar macar incerc :icon_thumright:
In legatura cu cornering:
la mine la Byte 23 pot sa modific numai in binar si trebuie sa fie 0b00001100 in loc de 0000000000.
In general, daca stiu bine, se foloseste VAG-ul si VAS-ul, ultimul stie mai multe....
DE unde ai scos acel b in coding, ca binar e doar 1 si 0?
NU exista program VAG. A fost VAG-COM si mai nou este VCDS, e doar alta denumire.
naigen79 la tine merge 100% activat corneringul ! - daca asta ne intrebi
si lasa binarul ala ca ne bagi in ceata de nu mai iesim never
  • Marian a închis acest topic
