Proceduri VCDS
Seby19
Ma poate ajuta si pe mine cineva cu o poza la interfata care o detine,maine merg si eu sa imi iau masina si m-ar ajuta si pe mine o interfata,dar nu stiu ce sau caut.Si nici nu imi permit una la un pret prea mare,multumesc anticipat.
Buna seara!
Am niste erori la masina, daca ma puteti ajuta?
Address 03: ABS Brakes        Labels: 3C0-614-095-C2.clb
   Part No SW: 3C0 614 095 K    HW: 3C0 614 095 K
   Component: ESP 440 C2     H014 0001
   Revision:  H014       Serial number: 0648177278
   Coding: 0029986
   Shop #: WSC 70181 136 86306
   VCID: 2A511C7185E4089
2 Faults Found:
02839 - Wake-Up Line from Control Module for Electrical Parking Brake
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 114
                    Mileage: 1048575 km
                    Time Indication: 0
00650 - Clutch Pedal Switch (F36)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 240303 km
                    Time Indication: 0
                    Date: 2016.05.14
                    Time: 18:23:50
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 K    HW: 3C0 907 044 K
   Component: ClimatronicPQ46 041 0101
   Revision: 00041003    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 2953E37D80E2031
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 -  -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 14
                    Reset counter: 103
                    Mileage: 233395 km
                    Time Indication: 0
                    Date: 2016.03.06
                    Time: 16:02:30
Address 15: Airbags        Labels: 3C0-909-605.lbl
   Part No SW: 3C0 909 605 A    HW: 3C0 909 605 A
   Component: 0B AIRBAG VW8   028 2321
   Revision: 06028000    Serial number: 0034ZSS2EM7E
   Coding: 0012354
   Shop #: WSC 05311 000 00000
   VCID: 244DF249E7C0DE9
01316 - ABS Control Module
Address 18: Aux. Heat        Labels: None
   Part No: 1K0 815 071 AD
   Component: Zuheizer        022 3907
   Revision: 00022000    Serial number: 09020188000000
   Coding: 0000011
   Shop #: WSC 66559 136 182791
   VCID: 67D7A5455676F51
02085 - Incorrect Control Module Installed
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 101
                    Mileage: 238051 km
                    Time Indication: 0
                    Date: 2016.04.25
                    Time: 12:06:54
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Part No SW: 3C0 959 433     HW: 3C0 959 433
   Component:    KSG PQ46 ELV 038 0453
   Revision: 00038000    Serial number: VWZCZ000000000
   Coding: 00900A0801860E763804941430084F09603C00
   Shop #: WSC 11362 002 1048576
   VCID: E7D72545D676751
   Component:   Sounder n.mounted
   Component:       NGS n.mounted
   Component:      IRUE n.mounted
01038 - Central Locking Thermal Protection
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 99
                    Mileage: 238139 km
                    Time Indication: 0
                    Date: 2016.05.05
                    Time: 11:25:46
Address 69: Trailer        Labels: 1K0-907-383-MY7.lbl
   Part No SW: 1K0 907 383     HW: 1K0 907 383
   Component: ANHAENGERELEKTR 003 0020
   Coding: 0000001
   VCID: EAD15C71C564489
4 Faults Found:
02563 - Trailer; Right Tail Lamps (M61)
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01111011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 239840 km
                    Time Indication: 0
                    Date: 2016.05.13
                    Time: 06:10:00
02566 - Trailer; Left Turn Signals (M62)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 239840 km
                    Time Indication: 0
                    Date: 2016.05.13
                    Time: 06:10:00
02565 - Trailer; Right Turn Signals (M63)
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 63
                    Mileage: 239840 km
                    Time Indication: 0
                    Date: 2016.05.13
                    Time: 06:10:00
02562 - Trailer; Brake Lamps
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 15
                    Reset counter: 63
                    Mileage: 239840 km
                    Time Indication: 0
                    Date: 2016.05.13
                    Time: 06:10:00
Help?!/?
Chiar nu ai citit titlul topicului? E greu sa cauti? Colegu exista deja topic existent cu probleme aparute la scanare cu vag comul
Nu te supara pe mine ptr urmatorul raspuns, dar daca nu stii sa o folosesti cu ce te-ar ajuta la verificarea masinii? Sfatul meu, ori mergi cu cineva care se pricepe ori citesti un pic despre vcds si despre codari/verificari ce se pot face. In acest mod eviti o eventuala teapa-si cu masina si cu interfata-sa iei cine stie ce clona de 2 lei. Colegul @EEXCALADE ti-a recomandat de unde poti achizitiona in siguranta. Sau direct de pe site-ul producatorului http://www.ross-tech.com/distributors.php.
http://store.ross-tech.com/shop/cat/VCDS.html.
De folosit nui bai ca nu ar fi prima interfata,am mai programat ceasuri la vechea masina(ford),montat pilot,etc.Am vazut ca difera foarte mult la touran sau passat,dar cu timpul toate se invata,am fost deja la arad,si am fost foarte dezamagit...mai caut la alte targuri,intre timp poate iau si interfata.Am intrat si pe site,am si citit de 3 luni incoace si despre interfata si despre masini etc.Scuze daca am facut si putin off topic.
vcds luata de aici: www.ross-tech.com
colegii unde gasesc 108 sau 109?
mi-a spus un coleg dar butonez vcds si nu vad unde
cred ca am prins ideea
ma duc la auto trans,de acolo la 09 single reading si la grup 108 sau 109 ar trebuie sa fie
sa incerc si la 08
inca nu am pus pe masina
Modificat de cabina
Ce vrei sa verifici?Km la masina de pe cutia automata?
Da km inregistrati pe cutie
F l o r i n
la ce masina, ce an fabricatie ?
Un passat 2009
Am incercat aseara pe un passat 2008 si la campul 09 single reading parca aparea altceva si la 08 cand ma duceam pe 109 la km aparea 18 310 km,si masina in bord avea in jur de 200 k
F l o r i n
da, intra pe 02-cutie, in blocurile de masura si pe acolo este.... pana in blocul 110 - daca masina are mecatronicul schimbat sau au umblat la km... nu apare ce trebuie.
Mc colegu
Sa vad la asta care vreau s-o iau ce imi apare
Ma poate ajuta si pe mine cineva cu versiunea 15.7.4 pentru VCDS de pe site de la ross-tech nu reusesc sa o iau...Multumesc anticipat.
Edit,am incercat si cu chrome si nu merge.....
Modificat de claumedel
Incearca cu un browser updatat la zi
F l o r i n
clau -  banuiesc ca vrei sa folosesti o interfata originala Ross Tech... si nu o clona - caz in care se va strica, daca incerci sa o folosesti cu soft-ul original
Salut, are cineva idee in legatura cu High Bram Assist ce trebuie codat.
Mentionez ca doar ce am finalizat cu succes retrofitul de camera lane assist pe Passat  B7 2011...neavand navigatie nu imi functioneaza sign assist, dar cum fac sa activez high beam assist?
Am activat-o in camera, dar in BCM nu gasesc nimic legat de asa ceva...asa ca nu imi apare nimic pe IC...
Modificat de djzoom
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000005959408
   Coding: E1888F0700041A00470A00000F00000000095D435C0001
   VCID: 6CD7223B4F7E2C7E58B-8039
   Subsystem 1 - Part No: 3C1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 141106 022  0601
   Coding: 00046997
   Shop #: WSC 05311
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     151106 014  1201
   Coding: 00208933
   Shop #: WSC 05311
3 Faults Found:
01064 - Terminal 58d; Interior Dimming
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 4
                    Fault Frequency: 7
                    Reset counter: 212
                    Mileage: 194491 km
                    Time Indication: 0
                    Date: 2016.05.21
                    Time: 15:45:00
             Freeze Frame:
                        ON
                    Voltage: 13.95 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
01333 - Door Control Module; Rear Left (J388)
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 194621 km
                    Time Indication: 0
                    Date: 2016.05.24
                    Time: 12:02:00
             Freeze Frame:
                        OFF
                    Voltage: 12.45 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 201
                    Mileage: 194621 km
                    Time Indication: 0
                    Date: 2016.05.24
                    Time: 12:02:00
             Freeze Frame:
                        OFF
                    Voltage: 12.45 V
                        OFF
                        OFF
                        OFF
                        OFF
                        OFF
Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
   Part No SW: 3C0 920 871     HW: 3C0 920 871
   Component: KOMBIINSTRUMENT VD1 1614
   Revision: X0006000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 00011 888 96745
   VCID: E1C9C30F38BCF1167BD-80B4
00771 - Fuel Level Sensor (G)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 180
                    Mileage: 194205 km
                    Time Indication: 0
                    Date: 2016.05.13
                    Time: 14:03:28
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 C    HW: 3C0 959 760 C
   Component: Sitzverstellung     1001
   Revision: 00004000    Serial number: 00000000000000
   VCID: 2D51EF3FB4E4E5760F5-8078
02344 - Seat Position Memory Store Switch (E447)
            003 - Mechanical Failure
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1123
   Revision: 31008001    Serial number: 00000040469114
   Coding: 0000439
   VCID: 3C77D27B7F9E7CFE88B-8069
00100 - Drivers Interior Locking Button (E308)
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 194
                    Mileage: 194571 km
                    Time Indication: 0
                    Date: 2016.05.21
                    Time: 20:47:08
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1114
   Revision: 11005001    Serial number: 00000000935623
   Coding: 0000144
   VCID: 3E73D87369826EEEA6F-806B
00938 - Switch for Electric Window; Rear Right (E54)
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 172
                    Mileage: 193482 km
                    Time Indication: 0
                    Date: 2016.04.17
                    Time: 16:59:20
daca ma poate ajuta cineva cu interpretarea codurilor  si o posibila rezolvare .......mi-am luat vcds -sul  dar nu prea ma descurc cu el
Si nici nu ai cautat pe forum unde se posteaza aceste erori banuiesc
as fi multumit daca m-ai indruma unde se posteaza  aceste erori  desi am cautat dar nu am gasit nimic
scuze daca am facut off topic
Sigur
Salutari, as vrea sa stiu daca se poate modifica relantiul la un passat 2.0 din 2010 si cum anume ca am cautat dar nu am gasit nimic.
ca, intra pe Engine - Security Acces : cod 12233
la Long Adaption,  din lista selectezi Idle Speed Adjustment si introduci valoarea turatiei.
Multumesc Florin, e vreo problema daca-l duc pe la 850-900 rpm acum e la 790 si cand dau sa plec se tureaza singur pe la 850-900 si e inervant, vreau sa stea mereu asa mai turat daca nu afecteaza ceva.
  • Marian a închis acest topic
