Proceduri VCDS
Seby19
Puteti sa ma ajutati si pe mine cu speta mea de mai sus?
Incearca cu o interfata originala.
Modificat de Al Bundy
  On 02.02.2016 at 17:47, Hayate a scris:
AC Compressor First Run-In
Note: If Basic Settings reports Error the module may need to see an Adaptation change before this can be completed. Go to Adaptation and change "Driving time for compressor run in" from 120 -to- 120 and save it followed by repeating the procedure.
Expand
  On 03.02.2016 at 7:11, F l o r i n a scris:
daser - intra in adaptari si trece 120 in campul aferent - do it - si vezi daca te lasa - ti-a scris si Hayate mai sus
Expand
Multumesc pt reply, am rezolvat prin 'actualizarea' campului cu 120 s .
Dar mi-a mai ramas aceasta eroare :
  Afişează conţinutul ascuns
Address 08: Auto HVAC (J255)       Labels: 5K0-907-044.clb
   Part No SW: 561 907 044 AG    HW: 561 907 044 AG
   Component: Climatronic   H03 0707
   Revision: 00001K02
   Coding: 0000000008
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACClimaBHBVW411 A01001
   ROD: EV_ACClimaBHBVW411_VW41.rod
   VCID: 5CB00C5F573820DE61-8008
1 Fault Found:
13701424 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 224
                    Mileage: 164443 km
                    Date: 2016.02.06
                    Time: 22:56:09
Modificat de Daser
  On 06.02.2016 at 14:29, Daser a scris:
Multumesc pt reply,
Hidden Content
Expand
Modificat de Scorpionul
si mai am urmatoarea probleme
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DG    HW: 3C0 907 044 DG
   Component: ClimatronicPQ46 133 0909
   Revision: 00133024    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 69D95B2F408C395623D-803C
2 Faults Found:
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 3
                    Fault Frequency: 10
                    Reset counter: 66
                    Mileage: 160820 km
                    Time Indication: 0
                    Date: 2013.14.09
                    Time: 11:00:00
01810 - Actuating Motor for Temperature Flap; Right (V159)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 65
                    Mileage: 160834 km
                    Time Indication: 0
                    Date: 2013.14.09
                    Time: 14:25:03
Daca stie cineva cum se remediaza
Hidden Content
Expand
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 10
                    Reset counter: 66
                    Mileage: 160820 km
                    Time Indication: 0
                    Date: 2013.14.09
                    Time: 11:00:00
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 65
                    Mileage: 160834 km
                    Time Indication: 0
                    Date: 2013.14.09
                    Time: 14:25:03
Hidden Content
Expand
Incerca in prima faza o recalibrare a clapetelor . Daca tot reapare, vor necesita inlocuire.
Pai am inlocuit motorasul v159 care imi facea probleme.
Acum am inlocuit climatronicul, am rezolvat erorile aferente dar mi-a ramas asta:
  Citat:
1 Fault Found:
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 224
Salut, cum se face recalibrarea clapetelor ?
Din vcds basing seting sau apesi tasta econ+recirculare(parca recirculare era) concomitent.Poti sa incerci econ+recirculare sau alt buton din cele 4 de sus....va aparea un icon pe display si incep clapetele procedura.
sa rezolvat cu combinatia ac si ventilatie de mijloc
  On 07.02.2016 at 9:08, Daser a scris:
Expand
Cel mai probabil iti lipseste un senzor-posibil cel de calitate aer si de aceea nu poate raporta valoarea ceruta. Sau ai can de generatie mai veche care nu stie valoarea raportata. Nu e stres cu eroarea respectiva atata timp cat unitatea functioneaza normal.
Versiunea de CAN la mine este L, masina fiind '09.
can-ul este compatibil.
Salut.Am un vw sharan 2001 si vreau sa stiu daca pot active functia coming home/leaving home.Multumesc.
Cu parere de rau dar nu se poate. In plus ai cam gresit sectiunea - aici se discuta de Passat B6.
nu este vorba ca nu este prevazut din fabrica - la multe modele, nu au functii prevazute din fabrica, dar le putem activa.
din pacate, aceasta platforma nu permite activarea unor astfel de functii - singura solutie fiind adaugarea unui modul aftermarket
Stupid question: exista vreo procedura prin care se seteaza data curenta? In meniul din bord nu pot seta decat ora iar cu VCDS-ul nu tin minte sa fi vazut pe undeva. "Problema" este ca unele din freeze-frame-uri au data asociata 2012 or sunt sigur ca intre timp s-au intamplat multe...
sters
Modificat de kinzo_2004
double post
Passat b6 2006, BKC mi-au aparut erorile din pozele de mai sus, plus mai are un tremurat puternic atunci cand dau drumul ambreiajului (cam pe la jumate) la vitezele 1 si 2 , dupa viteza 3 nu mai tremura, tremuratul a aparut cam la 2 zile dupa aparitia erorilor. Precizez ca nu s-a umblat la masina recent, am verificat nivelul uleiului si este normal.
Ce poate fi ?
Pai care sunt erorile? Nu se vad decat acei martori aprinsi - combustibil, placute frana, lichid parbriz etc. Fa o scanare si posteaza erorile, altfel nu putem sa formulam un raspuns.
Scuze nu am stiut cum sa explic, multumesc de promptitudine, problema este cheita aceea cu 7800 si 18 cu ceasul acela ce nu imi apareau inainte si habar nu am de ce au aparut asa dintrodata, cand pun contactul general prima data apare acea cheita cu 7800 apoi 18 si ceasul, dupa ce pornesc motorul dispar si apare data, temperatura (ecranul normal)...plus simptomele aparute ulterior..speram ca cineva sa cunosca motivul ptr care au aparut acele insemne
Modificat de ramelo4ever
Este intervalul de service. Nu are treaba cu pb mentionate. Tremuratul poate fi de volant, ambreiaj-pe parte mecanica, sau de la vreun injector etc.
Revizie in 7800 km sau 18 zile-care din conditii intervine prima.
Buna seara puteti sa ma ajutati si pe mine cu aceasta eroare?
Address 53: Parking Brake        Labels: 3C0-907-801-53.clb
   Part No SW: 3C0 907 801 B    HW: 3C0 907 801 B
   Component: EPB  VC8HC001   013 0001
   Revision:   013
   Coding: 0000012
   Shop #: WSC 05311 000 00000
   VCID: 2149030FF83C3116BBD-8074
1 Fault Found:
02844 - Lamp for Automatic Parking Function
            009 - Open or Short to Ground - Intermittent
             Freeze Frame:
                    Fault Status: 00101001
                    Fault Priority: 4
                    Fault Frequency: 3
                    Reset counter: 63
                    Time Indication: 0
             Freeze Frame:
                    Voltage: 12.32 V
                    Count: 64
  • Marian a închis acest topic
