Codari Vag-Com Skoda
Al Bundy
Teardrop=This is the delayed last wipe when you use the windshield washer.
Mai pe romaneste,dupa cat timp sa mai actioneze inca o data stergatoarele dupa ce ai folosit lichidul de spalat parbrizul/luneta.Sper sa nu gresesc.
40 18 0A B8 D0 41 B1 C0 40 08 00 80 11 00 11 24 05 70 00 AE 62 6D 89 60 5C 04 40 00 00 00 -----CHR------------SK Octavia 2 FL
46 18 0A B8 D0 41 F1 C0 40 08 00 80 11 00 91 E4 05 71 00 AE 62 6D 85 60 5C 04 40 00 00 00 ----AL BUNDY------SK Octavia 2 FL
40 99 0A B8 D8 05 08 C0 40 08 00 84 11 00 89 A4 05 71 1B AE 63 20 85 60 5C 40 40 00 00 00 ---infoschumi------SK Superb 2
40 99 0A B8 D8 41 F1 C0 40 08 00 84 11 00 81 A4 05 71 1B AE 43 20 89 60 5C 40 40 00 00 00 -----xxnelu----Superb2
La a mea..cateva optiuni:nu are alarma,senzori ploaie+lumini,DRL pe xenon(+MFD-activare/dezactivare),coming/leaving home(+MFD),lumini picioare,oglinzi rabatabile electric(inclusiv din telecomanda),auto-clock/auto-unlock la usi(+MFD),telecomanda pe cheie eventual...ce sa mai zic,se aprind avariile la franarea mai puternica.
Oricum diferentele cred ca vor fi la optiunile mai "avansate" daca pot sa le zic asa.
Modificat de xxnelu
  • Replies 471
  • Al Bundy
    129
  • infoschumi
    48
  • tutu0581
    33
  • bbpurghel
    33
40 18 0A B8 D0 41 B1 C0 40 08 00 80 11 00 11 24 05 70 00 AE 62 6D 89 60 5C 04 40 00 00 00 --CHR----------SK Octavia 2 FL
46 18 0A B8 D0 41 F1 C0 40 08 00 80 11 00 91 E4 05 71 00 AE 62 6D 85 60 5C 04 40 00 00 00 ---AL BUNDY---SK Octavia 2 FL
40 99 0A B8 D8 05 08 C0 40 08 00 84 11 00 89 A4 05 71 1B AE 63 20 85 60 5C 40 40 00 00 00 --infoschumi------SK Superb 2
40 99 0A B8 D8 41 F1 C0 40 08 00 84 11 00 81 A4 05 71 1B AE 43 20 89 60 5C 40 40 00 00 00 -----xxnelu--------SK-Superb2
40 18 0A B8 90 41 08 C0 40 08 00 80 11 00 81 F7 05 00 00 AE 42 4D 81 60 5C 04 40 00 00 00 -----bbpurghel----SK O2 FL
AM REUSIT!!!!
raman dator...
modificasem din gresala cred si byte 0
se pare ca el face inchidere daca intereseaza pe cineva
ca dotari a mea:
inchidere cu telecomanda pe cheie, oglinzi rabatabile electric, geamuri electrice fata- spate, stergator luneta, mdf, mai nou drl , cornering, :)
Modificat de bbpurghel
Exact byte o:
LOL+ZV SAFE 1 = 01000000
LOL+ZV SAFE 0 = 01100000
LOR+ZV SAFE 0 =01101000
LOR+ZV SAFE 1 =01001000
Modificat de tutu0581
LOL?
LOR?
pe romaneste ca ma pierzi... :))
zv-inchidere centralizata, dar restul?
Imi cer scuze am uitat
LOL = left hand steering
LOR = right hand steering
ZV = central locking
xxnelu,intre masinile noastre se pare ca nu sunt decat vreo 5 byte diferiti,daca am compara dotarile,poate am reusi sa le dam de cap destul de rapid.Cand ai timp sa pui cateva din optiuni pe forum.
infoschumi le-am descifrat eu :P :
Byte 5
05(infoschumi) fara alarma
41(xxnelu) cu alarma
Byte 6
08(infoschumi) fara alarma
F1(xxnelu) cu alarma
Byte 14
89 (infoschumi) xenon si cornering
81(xxnelu) proiectoare si cornering
Byte 20
63(infoschumi) spalator faruri
43(xxnelu) fara spalator faruri
Byte 25
04(infoschumi) proiectoare
40(xxnelu) ??? nu scrie nimic de el ramane acelasi intotdeauna
Sper sa fiu pe intelesul tuturor :D
@bbpurghel: Sunetul alarmei standard e scos de o sirena montata sub aripa dreapta fata care comunica cu centralina pe LIN.
OK, pana acum i se ridica cuiva geamurile dupa ce ia degetul de pe butonul telecomenzii? tutu0581: vreo mana de ajutor?
Pana acum nu am reusit sa activez aceasta functie dar este ceva specificat undeva ca masinile fabricate din 2010 au functia de ridicare automata si inchidere trapa cand ploua.Astept un update pentru asa ceva :) Daca aflu ceva va tin la curent si eu sunt interesat de activare pe masina mea ;)
tutu0581...nu am nici cea mai mica idee cum ai reusit sa descifrezi aceste coduri,dar vad ca te pricepi :P
Poate poate din intamplare ai mai putea afla si altele,precum:
-Mutarea daylight running lights de pe xenon pe proiectoare
-aparitia meniului cu luminile de la picioare in MFD(tocmai mi-a disparut)
-rabatarea oglinzilor odata cu inchiderea masinii
-fog lights as parking lights(sper ca intelegi la ce ma refer,in romana poate suna mai diferit)
Legat de ultimul tau post,este adevarat,este vorba despe rain closing.Eu am optiunea in MFD,insa am si un mic "bug la ea".O activez acum,insa cand pornesc motoru din nou se dezactiveaza.Astia de la Skoda au spus ca asa a fost facuta sa functioneze,insa pe Octavia 2 fara facelift era cam invers,tot timpul era activa,iar daca o dezactivai,la urmatoarea pornire a motorului se activa la loc.Mi se pare o prostie cum este acum,doar nu sunt meteorolog sa stiu ca va ploua daca imi las masina cu "geamurile deschise din greseala" ca sa activez optiunea.
Daca nu..tot le dam noi de cap odata si odata:P
  tutu0581 a scris:
Sper sa fiu pe intelesul tuturor :blah_:
Asta, posibil sa se traga de la o incercare de codare (pt. gasirea a ceea ce-si doreste si albundy, legat de inchiderea geamurilor) :P . Cred ca am uitat sa revin la codarea initiala :D .
Nu xxnelu asa vine din fabrica si nu se poate modifica.
Mda...stiu oricum ca am incercat diferite variante dar, intr-adevar, codingul atasat(in lista) este cel "original". L-am copiat din primul scan al masinii :angry: . Acum, cu siguranta am alte balarii pe-acolo ;) .
40990AB8D873F1C040080084110081A405715BAE432089605C4040000000 - posibil actualul :angry: -naiba stie ce-i pe-acolo.
40990AB8D841F1C040080084110081A405711BAE432089605C4040000000 - originalul
Fata de original e modificat Byte 5, ai facut update le centrala electrica la versiunea 360? Asa s-a intamplat si la mine cand am facut update, s-a schimbat din 41 in 73 dar am revenit la codarea initiala.
Cat despre Rain Closing asa e si la mine, la urmatoarea pornire nu mai e activa.
Asa functioneaza se pare.Mai multe explicatii nu am,de ce ,cum ....La carte asa scrie ca la luarea contactului se dezactiveaza.
Explicatia celor de la fabrica:
"The rain closing function is only active in case when the setting on the Maxi-Dot information display in your car is turned on
and the car is locked. This function can be set up for one use only. It is impossible to set up that into the permanent mode.
For regeneration of this function you have to active rain closing mode again.
However, it is impossible to say through this email whether the function operates properly. Only official
Acelasi raspuns l-am primit si noi dealeri :icon_thumright:
  Al Bundy a scris:
Hmm...am fost cu ea in service doar pentru schimbarea unui difuzor, pe la inceputul lui martie; sa fi facut ei update-ul fara sa spuna nimic? In fine...de "jucat" prin l-coding, oricum, m-am jucat si ma gandeam ca am uitat sa revin la initial. Luat de valul discutiei de ieri, am mai dat o tura prin el si prin adaptari.La un moment dat, o bagasem pe maneca :rolleyes: ...nu se mai deschidea portbagajul :lol: . Bine-nteles...s-a rezolvat :mellow: . Acum, gata cu "joaca"...astept urmatoarea varianta VCDS.
LE: tutu0581 - chiar nu poti sa ne ajuti si pe noi cu inchiderea confort a geamurilor ;) ? Nu s-a lipit nimic de lopatica ta din toate sapaturile facute pana acum :unsure: ?
Update-ul a aparut acum maxim o luna deci in martie nu avea cum. Upadate-ul se face la masinile care au probleme cu martorul de bec ars.
Ok...si ce face sau, ar fi trebuit sa faca acest update? Vad ca la byte 5, este ceva legat de alarma...ma gandesc ca si bitii aferenti pot fi in legatura cu ea. Stiu ca nu-i obligatoriu :)
La mine nu am vazut modificari legate de functionarea alarmei cu codari diferite la byte 5 dar am vazut ca se aprind mai repede farurile pe auto cu 73 la byte 5. Nu stiu ce legatura are.
intrebare pentru cei cu o2:
coming home, living home, are cineva?
dupa ultima joaca, cu vagul, la mine au aparut, in MDF, dar nu fac nimic.
ceva lipseste din codare.ma asteptam sa aprinda alte becuri, gen faza scura, pozitii, cand incui/descui masina, dar ea aprinde decat, luminile din oglinzi;(asta facea si inainte) mai incerc.
se pare ca byt 5 si 6 fac alarma, dupa ce m-am jucat in amundoi am avut erori gen necomunicare cu senzor monitorizare interioarra, necomunicare cu sirena---tutu 0581 avea deptate.
de la byt 22 are leg cu motorizarea:dupa ce am "lucrat" la el am avut o eroare de genul "releu pompa combustibil defect sau intrerupt".
cam multe variabile
incerc sa vad ce mai descoper
interesul e coming home si living home.o sa postez maine ultima codare.
Daca iti apar pe Maxi-dot este imposibil sa nu faca nimic .. sa ziceam ca la comming-home ar trebui sa lasi luminile aprinse dar leaving-home ar trebui sa-ti aprinda luminile atunci cand deschizi masina indiferent pe ce pozitie este comutatorul de la lumini. Ai cumva senzor de lumina? Inca ceva intra in meniurile respective din calculatorul de bord caci se modifica durata de functionare si se pot dezactiva si de acolo functiile (desi parca tin minte ca la mine - ce-i drept nu O2FL - default erau setate pe la vreo 20 de secunde amandoua parca)
Nu am senzor de lumina;nu am pe comutator pozitia auto.
Functiile sunt activate din B.C. , pot modifica timpii de actiune, dar tot nu fac nimic, indiferent de pozitia comutatorului de lumini. Probabil tot din codare lipseste ceva; o sa incerc codarea de la noul superb. teoretic calculatorul e acelas.
A aparut noul VCDS release 908 :) . Nu stiu daca o sa am timp astazi sa vad ce imbunatatiri are.
Al bundy...esti pe receptie? :)
