Codari Vag-Com Skoda
Al Bundy
According to VCDS 10.6.0 labels for Byte 18 of Controller 09 (1K0-937-087-D, 1K0937087D):
00 (0) = Light Setup: Standard/Parameter Settings (EEPROM)
04 (4) = Light Setup: VW Golf GTI (5K) Rest of World (RoW)
0E (14) = Light Setup: VW Golf Plus (52) Rest of World (RoW)
30 (48) = Light Setup: VW Tiguan (5N) Rest of World (RoW)
51 (81) = Light Setup: VW Tiguan (5N) North American Region (NAR)
3A (58) = Light Setup: VW Scirocco (13) Rest of World (RoW) Left Hand Drive
2B (43) = Light Setup: VW Scirocco (13) Rest of World (RoW) Right Hand Drive
19 (25) = Light Setup: Seat Altea (5P1) Rest of World (RoW) Right Hand Drive
1B (27) = Light Setup: Skoda Superb(3T) Rest of World (RoW)
Modificat de Al Bundy
  • Replies 471
  • Al Bundy
    129
  • infoschumi
    48
  • tutu0581
    33
  • bbpurghel
    33
With 00, the controller behaves as having the previous value (before putting 00).
Wow, this is something we should know. Until now I was sure that "playing" with the bytes is safe, as I can always came back to original (written down) values. Is this strange behavior only for byte 18 of controller 09, or there are also other bytes like this?
I really don't know...
Options mentioning "via Fixed/EEPROM value" also exist in the two combo boxes of Byte 19 (Controller 09, VCDS 10.6.0). Check it out yourself.
I don't know what this byte 19 is supposed to do though...
Any info is greatly appreciated. Thanks.
Am si eu o intrebare. Daca am versiunea VAG COM 607.3, versiune venita cu o interfata care probabil (mai mult ca sigur) nu este ROSS TECH, pot face upgrade la soft sau nu? Eu stiam ca se buleste de tot interfata, dar am zis ca nu strica sa intreb.
merci,
Modificat de xxnelu
Ramai la varianta cu care ai cumparat interfata. :)
Presupuneam...dar voi cum faceti ca sa puteti utiliza noile versiuni ale soft-ului VAG COM? Aveti toti interfete originale?
eu, kostas, turbocip, xxnelu, voinea si or mai fi, astia ii stiu eu, DA, sunt originale.
salut am activat si eu ch/lh pe o2 fl ..apare in meniul maxido-tului dar nu functioneaza fizic ..ce-i de facut ?
SA montezi senzor de lumina. CH/LH nu mai merge daca nu ai senzorul.
From attached doc file in post #212:
[select]
[09-Cent. Elect.]
[Coding-07]
[Long Coding Helper]
Byte 12, bit 2: Coming-Home (manual) active
Byte 17, bit 5: Coming Home (old mode, automatic, requires AUTO switch)
Byte 17, bit 6: Leaving-Home active (requires AUTO switch too)
[ESC-Close LCode]
[Do It!]
On cars with MaxiDOT, you can set CH/LH time by using the menu.
On cars without MaxiDOT, you can set CH/LH time by:
[select]
[09-Cent. Elect.]
[Adaptation-10]
Channel 23: 10...60 (Coming Home - seconds)
Channel 24: 10...60 (Leaving Home - seconds)
Adaptation Channel 24 (LH) shows ERROR when Leaving Home is disabled.
Even if you HAVE MaxiDOT, you may want to use these adaptation channels because the MaxiDOT menu only allows you to set the time in 10-second intervals.
"Automatic CH (old mode)" and "Leaving Home" both require a Rain-Light sensor (RLS) and an AUTO light switch. Otherwise, they do not work, even though they appear as items in the MaxiDOT.
In order to operate "Coming Home (manual)", without RLS of course, you enable it, set the time (see above), and then:
1. Remove the key from ignition. The light switch is normally at position 0 (OFF). If the switch is at any other position, more lights will illuminate when CH starts working (e.g. fog lights).
2. Pull the light lever once towards yourself. Like signalling someone with the High Beam.
3. Open the door in order to get out. You don't really have to get out; just open the door.
4. The following lights illuminate for as many seconds as we have set: Front Low Beam, Rear Lights (Red), Rear Plate. That's it! Take care of your battery!
5. If, in step 2, we already have the door open, step 4 occurs.
poti sa ma bati dar nu inteleg nimic din ultimul post :(
Colegul ti-a explicat procedura de activare folosind vag com-ul, inclusiv posibilitatea de setare a timpului pentru CH/ LH.
No, you can beat me for not speaking Romanian! :rolleyes: It's not your fault...
Perhaps someone else can attempt to translate my post. If I use Google Translation to do it myself, we'll probably end up with something even more incomprehensible...
Modificat de john.gr
ok ,am vazut ca nu va merge fara senzor de lumina ,ma voi duce sa incerc manual ..poate va merge asa ,va tin la curent
Nu a mai descoperit nimeni nimic nou?
ma intereseaza si pe mine functia cornering la masina mea, O2 FL din Feb 2010, 1,6 TDI business. pana la urma nu m-am lamurit daca e chestie doar de soft sau si ceva hard. se poate activa? de asemenea ma intereseaza si CH/LH. este cineva din Brasov care ma poate ajuta?
Este doar software modificarea. Da - se poate activa .
Nu vii la intalnire duminica ?
mersi pentru raspuns. sunt din bv, deci nu pot ajunge duminca in buc la intalnire. poti sa recomanzi pe cineva din bv care se pricepe la treaba asta?
Fiindca nu poti primi PM
Uite AICI pentru Brasov cativa colegi care posibil te vor ajuta.
Doar ramane sa ii contactezi tu.
LE - vezi ca am mai updatat lista cu inca doi baieti care colaboreaza cu TCM
Vezi ca nu o sa meargad decat CH manual. LH nu merge.
da...am observat si eu. le-am activat azi. Cornering a mers fara nici o problema insa asa cum ai sous tu merge doar CH manual. LH nu vrea. ciudat este ca atat LH cat si CH imi apar acum in maxidot cu posibilitatea de a seta si timpul. are legatura cu ceva senzorii de lumina pe care nu ii am? la fel de ciudat este ca desi Cornering merge fara probleme, acesta nu-mi apare in maxidot.
multumiri lui EsTeTicu pentru ajutorul de azi
