Codari Vag-Com Skoda
Al Bundy
john.gr,I tried those bits because I was hoping that the oil temp&gear shift recommendation were already there and just needing activation,that's why I said the only way to activate them is by a software/firmware upgrade.
Al Bundy,I think we already have a fully documented label file for Instruments module,and there isn't any option to activate these 2.
In conclusion,I guess there is only one way,the dealer way :P
  • Replies 471
  • Al Bundy
    129
  • infoschumi
    48
  • tutu0581
    33
  • bbpurghel
    33
Yes, but the important part, 17-Instrument doesn't appear in that autoscan. I belive that the oil temperature and gear shift recomanadation update was make in this module.
The AutoScan I provided was taken using my 805.0 Chinese clone. I can't reach several controllers on the FLs using this version.
Here's an AutoScan from the same Scout taken by the owner using 908.0:
AutoScan_ScoutFL1.8TSI_908.txt
That O2FL Scout have this update made of?
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 1Z0 920 803 C HW: 1Z0 920 803 C
Component: KOMBI H21 0110
Serial number: 00000000000000
Coding: 110B00
Shop #: WSC 73430 031 00999
No fault code found.
That is software version in what we are interested.
Yes, he has "H21 0110".
Here's an "Advanced ID" of 17 from the same Scout taken by the owner using 908.0:
AutoScan_ScoutFL1.8TSI_908_AdvancedID_17.txt
Note:
Don't ask me why my friend's controller 17 has Byte 00/bits 0-3 declared as "Yeti (5L)" (Distance Impulse Number 2 instead of 1).
I asked him and he doesn't know either...
Because the gear box ratio are diferent at diferent cars and IC is the same, IC can be coded in order to show correct distance, it divide information from speed senzor by a number, number set by the Impulse/distance number.
Din pacate nu am reusit sa rezolv problema legata de Coming Home/Leaving Home :D .Raspunsul fiind:
Coming Home
"If the vehicle is not equipped with an "Auto" headlight switch, coming home activation will likely require you to pull the high beam
stalk back briefly after shutting the vehicle off and before exiting. The description should be found in your owners manual."
Leaving Home
"Leaving home will likely require the "Auto" switch and a light sensor. The description should be found in your owners manual"
Pana acum am reusit sa activez staging-ul la urmatoarele ceasuri de bord: 5K6 920 870 D, 5K6 920 970 H si 1P0 920 850 B.Cele cu G si Q in coada nu pot fi codate ( ;) al meu este cu G).
Modificat de tutu0581
Publicat (modificat)
Stagingul merge si la 1Z0 920 843 D si la 3T1 920 841 D
Azi am fost la Avia, gasit un update la Climatronic, nu am gasit nimic pentru instruments. Deci inca nu-mi arata temperatura uleiului, Cineva de la reprezentanta, are cunostinta de vre-un update in acest sens? sa nu fi gasit deoarece la mine nu e cazul sa arate si cand trebuie sa schimbi viteza?
Am vazut ca la cele care arata versiunea de soft este 0110 sau 0111, la mine e 0106.
Modificat de Al Bundy
Dear Mr. Crismari,
via
Nici nu avea rost sa te chinui sa ii intrebi pe ei ...
Acelasi raspuns mi-au dat si mie cand am intrebat de rainclosing daca se poate activa permanent :icon_thumright:
acum am observat ca nici la mine nu mai marge cornering pe semnalizare.
probabil mai este inca un byte in afara de 14 care se ocupa de asta
trebuie sa il caut. stiu ca mergea inainte
Ai avut optiunea comandata din fabrica?
da. dar a veniut dezactivata
am activat-o eu cu VCDS-ul. stiu sigur ca a mers
DAca ai avut-o comandata nu avea cum sa vina dezactivata. Inseamna ca nu ai avut-o comandata si nu o sa mearga pe semnalizare.
o 2 FL "business"
in oferta scria ca le are; cand a venit nu mergea nimic, nici DRL nici Cornering
le am activat eu cu ajutorul la ce am gasit pe forum, si dupa asta tot m-am mai jucat prin codari. dupa ce am facut niste setari aiurea am revenit la cele de fabrica, si am codat numai se era documentat in VCDS. de atunci corneringul merge numai pe unghi volan. deci undeva mai e un bit pe care prima oara il activasem, si acu nu-l gasesc. sigur a mers inainte, doar nu sunt nebun.
DEci, revenim, corneringul este optiune suplimentara si la ELEGANCE, deci daca nu l-ai platit nu merge pe semnalizare, clar ?
optiunea este PWG.
Din cate stiu eu corneringul este si pe byte 17 bit 0.
se pare ca merge cornering pe semnalizare si la cele care nu au fost activate din fabrica
stiam ca reusisem o data
in afara de byte 14 trebuie sa se bifeze si in byte 17 bit o (trebuie sa se modifice direct in el pentru ca nu e documentat) -- tutu0581 avea dreptate, ms baiete
Modificat de bbpurghel
A aparut vcds 10. 02 parca, abia astept seara sa vad ce stie sa faca... :icon_thumright:
Poate 10.6 ca 10.3 a fost beta.
Asta e , insemna ca am luat o teapa de 89 euro.
Intrebare: stie cineva ce inseamna 20, 22, 5 de pe canalele din blocurile de masura de pe centrala electrica, acolo unde spune cine declanseaza alarma?
de ex azi a pornit, se poat vedea ultimile 5 declansari ale alarmei, dar nu stiu ce inseamna acele cifre din prima casuta.
Am gasit ce inseamna , cu ajutorul celor de la AVIA MOTORS. 22 e generat de tensiunea scazuta pe centrala electrica, eroare care o aveam de cand am luat masina.
Astept sa mai apara din nou si ma duc din nou cu ea, sa vedem cum o rezolva.
Am citit pe www.briskoda.net cum ca cineva, in germania la un dealer a activat 2nd fog light la FL. Stie cineva cum?
Din ce am citit pana acum, se pare ca byte 18 e cel care se ocupa de astea.
VW360 VW360 halogen RdW TFL_0 ROM 2
VW360 VW360 halogen NAR TFL_0 ROM 3
VW360 GTI halogen "VW360 RdW TFL_0_LED + LED_SBBR" ROM 4:00
VW351 VW351 halogen RdW TFL_0 ROM 5
VW351 VW351 halogen NAR TFL_0 ROM 6
VW351C halogen VW351 CHN TFL_0 ROM 7
VW362 VW362 halogen RdW TFL_0 ROM 8
VW362 VW362 halogen NAR TFL_0 ROM 9
VW364 VW364 halogen LL LL ROW TFL_0 ROM 10
VW364 VW364 RL halogen RdW TFL_0 RL ROM 11
VW367 halogen VN337 RdW TFL_0 ROM 12
VW368 halogen VN337 RdW TFL_0_Ska ROM 13
VW369 VW369 halogen RdW TFL_0 ROM 14
SE350 / SE352 XENON Xenon 2 / 7 NAR TFL_0 XE ROM 15
SE351 / SE351 XENON Xenon 9 / 9 TFL_0 NAR XE ROM 16
SE350 / SE352 2 Halogen Halogen / 7 NAR TFL_S ROM 17
SE351 / SE351 9 Halogen Halogen / 9 NAR TFL_S ROM 18
VW428 VW428 halogen RdW TFL_1 ROM 19
VW428 VW428 RdW TFL_1 XENON XE ROM 20
VW360 GTI halogen "VW360 RdW TFL_0 + LED SBBR" ROM 21
SE350 / SE352 XENON Xenon 2 / 7 ROW TFL_0 XE ROM 22
SE351 / SE351 XENON Xenon 9 / 9 ROW TFL_0 XE ROM 23
SE350 / SE352 2 Halogen Halogen / 7 ROW TFL_S ROM 24
SE351 / SE351 9 Halogen Halogen / 9 ROW TFL_S ROM 25
Halogen SK462 ohneTFL / TFL-ABL ROM 26
SK461 SK461 halogen without TFL / DRL-ABL ROM 27
SK461 SK461 halogen RdW sep.TFL_1 ROM 28
SK461 SK356 XENON ASUV TFL_Sep ROM 29
VW360 halogen "VW351 NAR TFL_0 + SMR on SL-back" ROM 30
VW360 halogen "VW360 NAR TFL_0 + LED SBBR" ROM 31
VW360 VW360 halogen NAR TFL_0_LED ROM 32
VW360 halogen "VW360 NAR TFL_0_LED + LED_SBBR" ROM 33
VW360 halogen "VW360 ROW / Japan + LED_SBBR" ROM 34
AU350PA halogen "VW360 NAR TFL_0_LED + LED_SBBR" ROM 35
AU350PA halogen VW362 RdW TFL_1 ROM 36
AU350PA Halogen VW364 RdW TFL_0 LL_Ska ROM 37
AU350PA XENON VW364 RdW TFL_0 RL_Ska ROM 38
AU350PA XENON VW316 RdW TFL_1_Ska ROM 39
AU350PA XENON VW465 RdW TFL_1_Ska ROM 40
AU353PA halogen VW362 RdW TFL_0_Ska ROM 41
AU353PA halogen "TFL rear, AB2 PA 5Doors ECE" ROM 42
AU353PA XENON "LED TFL without Heck, PA AB2 5Doors ECE" ROM 43
AU353PA XENON "LED TFL rear, AB2 PA 5Doors ECE" ROM 44
AU356PA halogen AU356PA RdW TFL_0 ROM 45
XENON XE AU356PA AU356PA RdW TFL_0 ROM 46
VW316 Halogen / Xenon VW316 RdW TFL_0 ROM 47
VW316 XENON Halogen / Xenon VW316 RdW TFL_S ROM 48
SK462 SK462 halogen separately ROM TFL_1 49
SK350 SK35x halogen-RS-RL TFL_LED from TFL 50 ROM
SK350 SK35x halogen-RS-LL TFL_LED ROM from TFL 51
SK350 SK351 TFL_1sep halogen. RL ROM from TFL 52
SK350 SK351 halogen TFL_1.sep LL ausTFL ROM 53
SK350 SK351 halogen RL TFL-ABL (P) ROM 54
Halogen SK350 SK351 LL TFL-ABL (P) ROM 55
SK350 SK351 halogen TFL_SH RL ROM 56
SK350 SK351 halogen TFL_SH LL ROM 57
AU210 halogen VW364 TFL_S ROW 58 LL ROM
XENON account VW364 RdW TFL_S RL ROM 59
VW360 VW360 RdW XENON XE TFL_S ROM 60
VW360 VW360 NAR XENON XE TFL_S ROM 61
VW360 VW360 halogen NAR ROM 62
VW360 XENON "VW360 Ska XE TFL_S LED_SBBR" ROM 63
VW360 VW360 halogen ROW ROM 64
VW360 VW360 RdW XENON XE PO_LED ROM 65
VW360 VW360 Ska XENON XE TFL_S_LED ROM 66
VW360 halogen "VW360 Ska TFL_S LED_SBBR" ROM 67
VW360 XENON "VW360 RdW XE LED_SBBR" ROM 68
VW360 VW360 halogen Ska TFL_0_S ROM 69
VW369 VW369 halogen Ska TFL_0_S ROM 70
VW369 VW369 RdW XENON XE PO_LED ROM 71
VW369 VW369 RdW XENON XE TFL_LED ROM 72
VW369 VW369 halogen Ska TFL_S ROM 73
VW351 VW351 RdW XENON XE PO_LED ROM 74
VW351 VW351 XENON RdW TFL _LED ROM 75
VW351 VW351 XENON NAR TFL _LED ROM 76
VW362 VW362 RdW XENON XE PO_LED ROM 77
VW362 VW362 RdW XENON XE TFL_LED ROM 78
VW362 VW362 NAR XENON XE TFL_LED ROM 79
VW316 Halogen / Xenon VW316 NAR TFL_1 ROM 80
VW316 Halogen / Xenon VW316 NAR TFL_S ROM 81
VW465 Halogen / Xenon VW465 RdW TFL_1 ROM 82
VW465 Halogen / Xenon VW465 NAR TFL_1 ROM 83
VW465 Halogen / Xenon VW465 RdW TFL_S ROM 84
VW465 Halogen / Xenon VW465 NAR TFL_S ROM 85
AU354 halogen VW465 RdW TFL_S 2R ROM 86
AU354 halogen VW465 NAR TFL_S_II ROM 87
AU354 XENON "AU354 TT NF LED TFL Choming + H SL" ROM 88
AU354 XENON "AU354 TT NF LED TFL POL + + SL + + KZL Choming H SL 89 ROM
SK35x Halogen / Xenon SK35x-RS-RL-LED TFL Shutter ROM from 1990
SK35x Halogen / Xenon SK35x LL-RS-LED TFL-ROM from shutter 91
VW465 FL halogen "VW465FL RdW TFL_1 8TA" Rome 1992
VW465 FL XENON "VW465FL RdW TFL_1_LED 8TA" Rome 1993
VW465 FL halogen "VW465FL RdW TFL_1 8TC_8TD" Rome 1994
VW465 FL XENON "VW465FL RdW TFL_1_LED 8TC_8TD" Rome 1995
VW465 FL halogen "VW465FL NAR TFL_1 8TA" Rome 1996
VW465 FL XENON "VW465FL NAR TFL_1_LED 8TA" Rome 1997
VW465 FL halogen "VW465FL RdW TFL_1_Ska 8TC_8TD" Rome 1998
VW465 FL XENON "VW465FL RdW TFL_1_LED_Ska 8TC_8TD" Rome 1999
R8 Halogen / Xenon "LED TFL without tail, R8 ECE" ROM 100
R8 Halogen / Xenon "LED TFL rear, R8 ECE" ROM 101
R8 USA (SM 0W) "ROM 102
R8 USA (SM 0W) "ROM 103
R8 Halogen / Xenon "Complete LED, LED TFL without a tail, R8 ECE" ROM 104
R8 Halogen / Xenon "Complete LED, LED TFL m. Heck, R8 ECE" ROM 105
R8 Halogen / Xenon "Complete LED, LED tail without TFL,
R8 USA (SM 0W) "ROM 106
R8 Halogen / Xenon "Complete LED, LED rear TFL,
R8 USA (SM 0W) "ROM 107
AU210 Halogen / Xenon "TFL without Heck, AU210 Halogen / Bulb 8:08:08" ROM 108
AU210 Halogen / Xenon "TFL rear, halogen AU210 / Bulb 8:08:08" ROM 109
AU210 Halogen / Xenon "TFL without Heck, AU210 halogen / LED 8:08:08" ROM 110
AU210 Halogen / Xenon "TFL rear, AU210 halogen / LED 8:08:08" ROM 111
AU210 Halogen / Xenon "Heck no TFL, TFL AU210 LED / Bulb 8:08:08" ROM 112
AU210 Halogen / Xenon "TFL rear, AU210 LED TFL / Bulb 8:08:08" ROM 113
AU210 Halogen / Xenon "Heck no TFL, TFL AU210 LED / LED 8:08:08" ROM 114
AU210 Halogen / Xenon "TFL rear, AU210 LED TFL / LED 8:08:08" ROM 115
SK461 China Halogen / Xenon "SK461-China without TFL, SL, BL-function LED SBBR" ROM 116
SK461 China Halogen / Xenon "SK461-China without TFL / DRL SL-ABL without BL-function LED SBBR" ROM 117
AU354 halogen "AU354 TT NF NAR sep TFL without SL in CHO" ROM 118
AU354 XENON "AU354 TT NF NAR LED TFL CHO + SL" ROM 119
VW364 LL Halogen / Xenon VW364 RdW TFL_S LL ROM 120
VW364 RL Halogen / Xenon VW364 RdW TFL_S RL ROM 121
AU354 Halogen / Xenon "sep TFL rear, TTNF, NAR" ROM 122
AU354 Halogen / Xenon "LED TFL rear, TTNF, NAR" ROM 123
AU210 Halogen / Xenon "TFL without Heck, AU210 Halogen / Bulb (ged. TFL as SL)" ROM 124
AU210 Halogen / Xenon "TFL without Heck, AU210 halogen / LED (ged. TFL as SL)" ROM 125
AU316 Halogen / Xenon VW351 S
MAine ma apuc de codari.
trebuie sa caut din lista ceva cu SK in fata, cu XENON si TFL_1
From what I've read, in order to "play" with Byte 18 you have to know the ***existing*** coding for your car.
If you don't know the existing coding (NOT 00!) you might not be able to code it back.
Putting 00 in Byte 18 doesn't change anything! It leaves the original coding intact.
On two Superb II, I've noticed that Byte 18 is 1B. On all other cars I've scanned, Byte 18 was 00 (including mine).
If you have a coding of 1B and change it to 00, it doesn't do anything! The car behaves exactly like 1B. In this case, you can start "playing" with other values. If you fail, you can always go back to 1B.
But if you have 00 and start "playing", what will you do if you fail?
1b in hexa means 27 in dec, it's a good coding.
I understood that: if you put 00, you reset byte 18 to factory coding.
Of course it's good. It's what these two cars had from the factory.
No, I believe this is not true. If you put 00, you "leave it unchanged". With 00, the controller behaves as having the previous value (before putting 00).
So, if you have 1B, you can test any value and see what happens. You can always change it back to 1B. Then, if you put 00 again, it still behaves like 1B.
But if you initially have 00, you don't know what the "previous" (actual coding) is.
edit (example):
1. You have 1B. The car behaves like 1B.
2. You put 00. The car behaves like 1B.
3. You put, let's say, 1C. The car behaves like 1C.
4. You put 00. The car behaves like 1C.
5. You put 1B. The car behaves like 1B.
6. You put 00. The car behaves like 1B.
Modificat de john.gr
Ok, i understood. Tomorrow i will go to the dealer to have 30kk service inspection done. Maybe VAS 5051 will see the real coding of byte 18.
