Steering column defective
adrian73ran
Salutari,
Ca tot veni vorba ...
Am scanat acum Passatul meu (nu-l mai scanase de 3 luni) si iata ce de belele am intalnit ...
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 HW: 3C0 959 433
Component: IMMO 038 0347
Revision: 00038000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
Part No: 3C0 905 861 A
Component: ELV 021 0350
3C0905861A ELV 021 0350
02823 - Requirements for Locking the Steering Column Lock not met
000 - -
Freeze Frame:
Fault Status: 01110000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 26
Mileage: 42051 km
Time Indication: 0
Date: 2010.03.30
Time: 21:02:04
Am pus prima aceasta eroare pentru ca mi-a mai aparut si pana acum dar nu am gasit pe nicaieri o explicatie ...
Toate celelalte de sub sunt erori noi
Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
Part No SW: 3C0 614 095 K HW: 3C0 614 095 K
Component: ESP 440 C2 H015 0001
Revision: H015 Serial number: 0657205080
Coding: 0013569
Shop #: WSC 00028 028 00001
02840 - Wake-Up Line from Central Convenience Module
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 25
Time Indication: 0
Address 18: Aux. Heat Labels: None
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000012
01408 - Under-Voltage Shut-Off (fixed Value)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 28
Mileage: 41634 km
Time Indication: 0
Date: 2010.03.10
Time: 08:20:22
Freeze Frame:
After-Run
Temperature: 49.0
Pai aia cu steering column lock e normala, asteapta-te sa iti mai apara de cateva ori si pe urma sa o schimbi. Restu, esti cam off-topic din pacate cu ele pe aici.
Fratilor, am scapat de belea! Dupa indelungi cautari, cu ajutorul celui de sus si al unor colegi de forum, e gata! Nu mai am probleme.
Daca vreti detalii, PM la mine, sau la electricu (sa traiasca! ca e priceput si binevoitor cu noi astia mai novici)
Problema: o siguranta fuzibila in scurtcircuit.
Modificat de D@ny
Intre timp problema rezolvata, pret 100 euro.
Costul reparatiei in SERVICE AUTORIZAT VW!
Nu se mai inlocuieste coloane si imobilizatorul (compul), nu se mai plateste 4000 ron, nici 2000 ron (doar imobilizatorul) ci se inlocuieste o componenta a compului.
Cost inainte de tva marit 100 Euro fara manopera!
Modificat de D@ny
Salutare Mama Omide, poti sa imi zici si mie piesa ai care se inlocuieste? Pe PM, daca nu se poate altfel.
Vreau sa o schimb si eu la coloana de directie care a fost schimbata acum 10 luni platind ca tampitul aprox. 6 000 lei :icon_thumright: :evil: , asta ca sa refac vechea coloana si calculatorul aferent.
Ma bate gandul sa le cer banii inpoi celor de la service.
In ce tara traim :P
Habar nu am cum se numeste piesa, eu am vb cu cei de la Autogrup Cta Sud. Suna si tu si intreaba.
am intrebat si eu astazi la Serpico Craiova si cica au primit un dispozitiv care o sa il foloseasca de acum in colo sa decapseze nu stiu ce de pe coloana de directie, pretul estimat cu tot cu manopera 7-8 milioane
Am si eu problemele astea..La naiba. MamaOmide, sa inteleg ca doar la Constanta se repara cu 100 euro? Sau stiti vreun service in Bucuresti? Mii de multumiri anticipate.
pai la noi, la olteni, era si normal ca pretul sa fie dublu fata de alte reprezentante vw...si eu am problema asta, dar se intampla rar, de obicei dimineata la pornire, ma gandesc sa repar problema inainte de a ramane iarasi in drum.
Modificat de fantozzi007
modulul electronic cu functia de deblocare a volanului care este atasat pe coloana ,prin cataloagele VW are codul J764. Practic asta e prins de coloana cu doua duruburi, care nu au cap hexagonal si par nituite. In varianta romaneasca, clasica, ele se puteau desface cu o dalta mica....acu e bine daca au dispozitiv...
Pe ebay ,piesa se gaseste, sh, cel mai scump cu 49 euro...(+cca 10 euro expeditia) dar nu prea aveai ce face cu ea ...trebuia corelata cu calculatorul de confort...Acum daca voi ziceti ca se pot face modificari sa fie schimbata singura....fara a mai fi necesara shimbarea calc de confort...nici nu se putea mai bine...
Era sa iau si eu teapa asta...am postat de-am inrosit topicul asta acum cateva luni....am avut noroc... a fost doar un simplu fir care nu facea contact bine....reprezentantele ma asteptau cu cca 4200 ron....cam atat estimasera la acea data...pacat ca nu "estimasera" contactul imperfect....si sunt sigur ca n-au "estimat" nici la altii ...si au furat in felul asta o gramada de bani...
Te vad cu masina asta si ce zic: "n-are oricine masina de-asta!"...ia sa il "umflam"noi putin!....Chiar trebuie dati in judecata!
Ptr cei interesati, mai jos aveti poza modulului respectiv...detasat de pe coloana de directie
Modificat de criv
pai pana la urma nimeni nu are detalile reparatiei?
" Te vad cu masina asta si ce zic: "n-are oricine masina de-asta!"...ia sa il "umflam"noi putin!....Chiar trebuie dati in judecata!"
Eu ce sa mai zic ca mi-au cerut la o vulcanizare 30lei sa imi puna un petec :)), chiar m-au intrebat inainte de a spune pretul daca masina unde o parcasem este a mea :huh:)...si m-am dus in alta parte si am rezolvat cu mult mai ieftin
OT: si mie imi mai apare eroarea aceia cu coloana de volan, dar in bord nu mi-a aparut deloc. La un vecin tot acelasi model ca al meu ii apare din cand in cand si in bord
Alinushu2007 - daca tu citesti acea eroare cu vagul sa stii ca ea este produca de faptul ca atunci cand pornesti masina nu astepti sa se stinga pictograma cu volanul ( rosu - balben )
Eroarea pe care o citesti nu cred ca are leg cu eroarea de care se plang toti pe aici, cand o sa iti apara in bord atunci sa iti faci probleme.
Si eu am citit acea eroare, de cateva ori, cu vagul insa in bord nu mi-a aparut niciodata nimic!
Very funny...si mie imi apare asta de vreo 2 luni...nu mai dau detalii ca simptomele sunt aceleasi...faza este ca initial da mi s-a spus clar:COLOANA DE VOLAN!!!!ca dupa aceea un cunoscut de la reprezentanta care si-a intrebat colegii mi-a spus"se schimba acum si numai motorasul de la coloana care are un mik calculator cu el"(sper ca se refera la acel J 754...parca asa ati scris pe aici) :Driver: asa ca sper sa se rezolve ieftin...dupa cum am fost instiintata cam 100-200 ron diagnosticarea,cam 400-500 ron piesa de schimb ...si nu mi s-a spus cat e manopera :blink: sper ca nu prea mult....deci oricum luni ajung la ei ca azi am patit-o rau de tot...a pornit acasa din prima...am mers in herastrau cu fetita mea fara probleme,apoi la intoarcere din a 2 a luat-o,dar THE BIG SURPRISE ;) conducand linistita...intr-o mare intersectie pe la grivitei m-a lasat masina in mijlocul drumului....s-a aprins tot bordul si dupa aia am scos cheia si s-a stins tot bordul...au aparut volanele ba galben clipind ,ba rosu facand ca dracii...si uite-ma in drum pe avarii cu copilul in masina....ce sa fac???intrebarea cea grea...citind mai demult ca ori o las un pik(faza care functiona in trecut cand s-a mai intamplat sa nu imi porneasca de pe loc(odata m-a lasat in cimitir...unde eram cu ceva de facut :( )dar aici nu prea timp sa o las in drum asa...deci mai citisem faza cu bornele la baterie:( care aud ca e tzeapa acum....dar de aveam cheie de 8 in masina asa ca de ce nu???ca mi-a mai mers cu bateria asa altadata sau poate doar coincidenta:S ma rog am incercat ..cativa oameni bine voitori oprise sa ma ajute dar de unde ca volanul blocat cum naibii muti masina pe dreapta????ca dupa ce am scos cheia se blocase si nu o mai lua....si in final,am scos bornele ,le-am pus...si nu a luat-o....mai apoi incercand fara speranta sa deblochez volanul SURPRIZA >>>a pornit ....si dusa am fost pana acasa:)) sa nu cumva sa ma mai lase pe undeva.deci???pana la urma ce schimb???si cat ma costa cu manopera la reprezentanta???are cineva idei???va roggggggggg pana luni raspunsssssss
Raspunsul l-ai dat singura "100-200 ron diagnosticarea,cam 400-500 ron piesa de schimb ...si manopera..."
:( Te rog sa redactezi posturile a.i. sa fie mai usor de citit!!
AM O INTREBARE...De ce de multe ori...isi revine pentru zile intregi,daca acel J754 este defect???De exemplu,dupa ce m-a lasat in intersectie,acum 2 zile...de atunci am mai plecat de acasa de vreo 3-4 ori...drumuri in care am oprit de mai multe ori si a mers de fiecare data de cum am pus cheia(cartela) in contact.
So...exista posibilitatea sa fie doar un contact imperfect???la mufe???
cum era la CRIV???
Si cei de la reprezentanta...am vreo sansa sa recunoasca daca ar fi doar atat?
daca ai fost si ai rezolvat, spune-ne si noua te rog care a fost pretul si ce a fost baiul, thanks
salut,
Si eu am avut aceeasi problema si am rezolvat-o la Autoworld Cluj - 750 de lei operatia de diagnosticare, piesa si manopera 2 ore. Am fost multumit de timpul de rezolvare. Sper sa nu mai apara problema. Cel putin in cazul meu nu era o eroare foarte frecventa, insa pentru siguranta mea am zis ca prefer sa o rezolv din timp.
merci mult, si la mine apare odata la cateva saptamani, o sa-mi fac si eu "curaj" sa merg la baieti de la noi de aici odata sa rezolv sa fiu sigur :lol:
Pana acum nu am avut nici o problema cu pornirea masinii
Dar acum 1saptamana cand am vrut sa pornesc masina nu vroia sa faca contact, iar dupa vreo 3-4 incercari mi-a aparut si mie eroarea respectiva (steeering column lock defective), iar apoi am scos/bagat cheia dinnou si a pornit neramanand nici un senzor sau eroare la bord. Totusi daca pornesc masina si tin apasat pe butonul de service imi apare mesajul "service now". Probabil ca o sa ma duc si eu totusi saptamana asta la un service-check.
chestia asta o stiam, si de fiecare data astept sa se stinga in prima treapta a chei volanul galben si apoi in cealalta treapta toate pictogramele, posibil ca sa mai imi scape chestia asta si sa pornesc masina in graba si d`atsa sa imi apara eroarea cateodata pe VAGCOM
Stie cineva va rog :
1.care este codul piesei de la blocajul volanului care se inlocuieste in prezent (aia care costa 450 ron) precum si daca se poate face inlocuirea in garajul propriu sau in alt service neautorizat VW? :P
2.scula aceea cu care decapseaza este neaparat necesara sau se poate decapsa si cu altceva? :rolleyes:
3.mai este necesara resoftarea vreunui computer sau chestii de felul acesta in conditiile actuale? :rolleyes:
mi-au cerut azi 800 ron la Protos pentru toata afacerea , ma gandesc ca s-ar putea sa gasesc piesa mai ieftin in alta parte si sa o inlocuiesc singur..
OVIDEOS Alba acea scula pentru decapsare este una speciala, din cate am inteles este una realizata de cei de la Volkswagen, deci exclus sa te duci in alt service care nu dispune de aceasta, chiar un prieten de al meu s-a programat joi acum si mi-a zis ca il costa in jur de 6,5 7mil
cica pt scoaterea suruburilor se folosete o dalta mica :)) si daca o montezi singur nu ai cum sa programezi cheile.... trebuie niste hacking facut
Defectiunea descrisa in acest topic - nu porneste, opriri in mers, avertizari in BC... -au fost rezolvare la reprezentanta VW din Cluj cu 750 lei. Reprezentanta VW din Oradea au cerut 2650 lei. Sa le fie rusine.
Multumesc celor de pe forum pt postari. m-au ajutat si indrumat.
Modificat de nicucalin
