Muzica & Sound // Mk2-mk1/proiecte - Pe Viteza Sunetului.
zib3r
Muzica e buna in masina?
82 voturi
  1. 1. DA sau NU ?
    • DA!
      74
    • NU!
      8
Topic de prezentare al intregului sistem audio pe care il aveti in masina.De la player pana la ultimul surub de pe tub.
Obligatoriu: Poze!
Ce produse recomandati , sfaturi unui incepator in sound.Si asa mai departe.
- O sa incep eu.
un player blaupunkt San Diego MP27 sandiegoeu8.th.jpg + sub-woofer Blaupunkt GTT 300 subwooferautoblaupunktgre1.th.jpg
Urmeaza amplificator saptamana asta.
Detalii: sub-woofer Blaupunkt GTT 300
High performance 300mm bass-reflex subwoofer tube
Punchy bass thanks to high quality spun paper membrane and aluminium voice coil
600 watt max power rating. 200 watt nominal power handling capacity
Impedance 4 ohms
Approx. dimensions: Overall length 484mm, overall diameter 328mm
Max. acoustic pressure (SPL @ 100Hz) 91dB
Frequency response 35 - 500 Hz
Detalii : Blaupunkt MP 27
MP3/WMA playback from CD-R/RW
FM, MW, LW
Aux-input for external music sources (e. g. MP3 players)
4-Channel preamp out to control external amplifiers (front/rear)
4 x 45 Watts Max. power
Detachable release panel for anti-theft protection
iPod-ready: iPod connection with optional interface
As vrea sa stiu cam ce amplificator ar merge...Si cam in mare parte conteaza si pretul.(iiieftin si bun).
Modificat de zib3r
  • Replies 82
  • capone26
    16
  • zib3r
    14
  • 88BLR
    6
  • plimbaursu
    6
eu am un player sony explode cdx-gt310post-20993-1209998400_thumb.jpg , difuzoare fata blaupunkt de 87 mm 25W rms post-20993-1209998600_thumb.jpg, difuzoare spate jbl 6x9 inch 70W rms post-20993-1209998735_thumb.jpg, statie 2 canale SAL de 230W in punte post-20993-1209998907_thumb.jpg, woofer SAL 150 W rms post-20993-1209998958_thumb.jpg si kit de instalare cabluri tot SAL.... cam astea sunt jucariile, sunt f multumit de ele (fiind o pasiune de mic sunt destul de greu de multumit) astept sa vad si jucariile voastre .... misto topic colegu zib3r
eu ca prima parere zic ca modelu asta de blaupunkt e ok, nam cautat mult sa vad cear mai fi post-20993-1209999882_thumb.jpg la pretu de 289,9 lei
New_Text_Document.txt
Modificat de capone26
eu am un CD Player cu MP3 si USB SONY XPLOD CDX - GT414U si 2 boxe tot SONY XPLOD XS-F6935 :icon_thumright:
mi se pare mie sau unii iau la misto topicu asta?
mai glumam si noi ce naiba nu mai stie lumea de gluma
sa ma laut si eu cu ce am inmasina
GroundZero toata gama Plutonium
atunci scuze, si jos palaria pt ground zero... o alegere tare
o dioda ... prind si FM.
toata linia e pioneer. in afara de head unit - urmeaza sa fie inlocuit tot cu un pioneer. in spate ceva de la infinity...sa scuture putin
Revenind la subiectul topicului :
Desi sistemul nu e montat pe masina ( pentru ca masina e la tinichigiu in momentul asta si n-am pe ce sa-l montez :) ) ... fac o scurta prezentare:
Head Unit : Pioneer DEH P77
Boxe fata : Hertz DSK 165
Boxe spate : Hertz DCX 165
Subwoofer : 2 x Hertz Energy ES 250 D
O sa fac cateva schimbari ... in sensul ca o la difuzoare o sa pastrez dimensiunea de fabrica de la MK1 ...si o sa trec tot la Hertz dar de 13 si probabil ceva din gama Hi Energy + amplificare .
Amplificator si cutie pentru sub inca nu am cautat deoarece am alte prioritati .
O sa fie antifonata masina pentru rezultate mai bune :) .
Modificat de Alexius
4. a) Nu jigni, nu declansa scandaluri (asa-zisele "flame-uri"). Faptul ca esti nervos, chiar daca ai dreptate, nu
Video Unit: Psp Slim 2gb - Il folosesc pentru vizualizarea videoclipurilor si a filmelor in format mp4 cu subtitrare, montat pe un suport special, conectat prin head unit prin intrarea aux. In paralel il conectez in portul usb pentru incarcarea lui si pentru ascultarea de pe head unit a continutului cardului. Este o solutie buna mai ales la drumurile lungi pe care le-am facut. Pe viitor o sa primeasca si adaptorul de GPS dar momentan la partea software mai trebuie lucrat pentru Romania.
Head Unit: Sony GT616U 4*50w - Am ales acest player pentru portul Usb, in care am conectat memory stick-uri, hdd-uri portabile si chiar Psp-ul unde cardul este vazut ca un memory stick. Am fost placut surprins si de calitatea audio care o are acest echipament si de formatele care le citeste in plus (wma, aac, atrac).
Difuzoarele pe fata: Pioneer TS G1049 2*25w - La inceput mi s-au parut mediocre dar asta din cauza unui celofan de pe usi care l-am dat jos si situatia s-a schimbat. Ca putere sunt slabute dar totusi imi satisfac nevoia de medii si inalte pe fata.
Difuzoarele pe spate: Pioneer TS A6921 2*80w - La inceput aici am avut impresia ca sunt supra-dimensionate pentru playerul auto, pe vremea aceea un Pioneer DEH2900mpb. Dupa ce am trecut pe noul player situatia s-a schimbat destul de mult.
Statia audio: Magnat Xcite 560w - O statie cu 4 canale si multe setari pe care le-am gasit pe ea. Am ramas placut impresionat de filtrul de inalte si cel de joase cu care este echipata. In momentul de fata o tin pe filtrul de joase. Inca un detaliu destul de important pentru mine este consumul de curent. Desi am avut probleme cu sistemul de incarcare pe masina, am putut sa ascult si 4 ore la nivel destul de mare fara sa imi afecteze acumulatorul destul de subdimensionat (55aH). Preventiv am dotat masina cu un buton de comanda care opreste statia (butonul intrerupe firul de comanda care pleaca de la head-unit catre statie) pentru a economisi energia din acumulator cand stationez.
Tub bass: Jbl CS 1200t 125w - Pot sa zic despre acest tub de bass, ca desi are doar 125w, poate si mai mult. Bass-ul este clar si nu distorsioneaza la volum mare. Spatiul ocupat nu este destul de mare deci pot sa folosesc portbagajul la fel ca inainte.
Pentru mine este un sistem audio decent, facut cu bani putini, iar calitatea audio mi se pare destul de buna pentru mine. In fond asta conteaza, sa ma multumeasca pe mine.
In concluzie pentru mine conteaza sistemul audio foarte mult, ma relaxeaza mai ales in zilele in care e un calvar in trafic. Deci am raspuns cu un DA! categoric. Sper sa nu fi exagerat cu descrierea sistemului adio. Ciao.
Modificat de _APoLLo_
foarte marfa topicul asta :angry: deocamdata am decat acest mp3 pe masina,mai tarziu o sa urmeze si restul sculelor :o
alexius designu la player e f tare, clasic da bine cu liniile interioare ale masinii, si linia hertz e cred ca suna frumos , imi place ce vad pe topic, sunt curios sa le aud la vara....
suna hertz dar alea scumpe
total de acord cu tine, da poate si astea suna bine daca luam raportat la calitate/pret
Am ales un Blaupunkt GTA4 MKII 800 watts 4 canale.O sa urmeze poze cat de curand.
Am ales playerul asta din 2 motive . Primul a fost ca suna foarte bine si l-am luat si la pret bun , iar al 2-lea a fost designul clasic care, cum spuneai si tu, se potriveste perfect cu masina .
Boxele abia astept sa le pun pe masina . Mai dureaza, momentan am masina la tinichigiu ...se taie , se sudeaza, se inlocuieste ... mai e pana la partea de sound :blink: .
Suna si hertz-urile ieftine bine daca masina e pregatita bine .
Cum spuneam si in postul anterior vreau sa vand difuzoarele astea( 150 ron DCX-urile si 200 ron DSK-urile in caz ca sunt amatori ) si sa iau alte difuzoare mai scumpe(tot Hertz) .
in general e bine sa iei lucruri care se potrivesc masinii din punct de vedere fonic, daca nu amplici, dieci sunt cele mai potrivite, dar nu te baza pe pretul cu care le iei tu, pt ca adaosul pt hertz, audison si in general tot ce vine de la elettromedia, e cam 100%.
si difurile de 16 pt fata in ce le infigi?
  • 5 weeks later...
m-am scapat de blaupunkt. Motivul (trec pe hertz). Revin cu poze cand primesc "sculele" .
orice ai pune in mk2 nu suna pentru ca nu e facuta masina sa sune. trebuie pregatita altfel poti baga si difuri de 1000 eur ca tot rahatu ala e. fetele alea de usi de carton de 2 lei strica tot meciu. plus ca nu e antifonata masina cu ce trebuie etc. fara 2000 eur nu ai cum sa faci sa sune calumea un mk2
Modificat de plimbaursu
la asta ma gandeam si eu.
Ai putea sa faci un lucru f.frumos.Sa uploadezi poze , explicatii si asa mai departe.Cam ce si cum ar trebui sa facem. :lol: Sa sune cat mai frumos.La mine se auzea un barait urat din usi ... Cred din cauza izolarii... :D
eu am niste baraieli in portbagaj dela bass, da nu ma las pana nu le descopar, cred ca hayonu are ceva zurgalai, desi plasticu cel imbraca pe interior lam lipit cu cauciuc ce sub presiune lipeste
din cate am inteles ... trebuie sa izolezi partile cu ceva spuma...daca am inteles eu bine de pe vortex.
oricum , trebuie multa rabdare sa faci asa ceva.Eu cu blaupunktu am simtit basii in stomac.Dar era baraiala mare... :|
oricum nu ma pot plange tinand cont cai masina de 20 de ani, am pus wooferu asa de proba si la alte masini mult mai noi , si spre surprinderea mea, unele scoteau distoriuni in habitaclu mai mari si chiar deranjante, deci mk2 chiar sta bine
muzica daca e montata corect nu are voie sa distorsioneze. ca vibreaza un plastic 2 e alta mancare de peste. dar ce scot difurile trebuie sa fie sunet curat.
