razdan
  • Administrator
World premiere of the ID.3 Neo: new name, new design, new interior and new technologies
Everything is new in the ID.3 Neo! The successor to the ID.3 is celebrating its world premiere with a new name and has been extensively enhanced and upgraded. The exterior features include a new vehicle front design based on Volkswagen’s “Pure Positive” design language and a new light design. The interior impresses with a redesigned cockpit landscape with intuitive controls, embedded in interior materials at the level of the next-higher class. The new efficient drive system of the ID.3 Neo – combined with the largest of the three available batteries – additionally enables ranges of up to 630 km (WLTP). Pre-sales of the electric compact model will start in Germany and many European markets tomorrow, Thursday, 16 April 2026.
Martin Sander, Member of the Board of Management responsible for Sales, Marketing and After Sales: “We have developed the new vehicle generation based on the motto ‘True Volkswagen’ and have consistently placed the benefits for our customers at the centre of our actions. In addition to the long range, models such as the ID.3 Neo impress with a superior, timeless design that provides long-lasting pleasure, high quality for a noticeably first-class driving experience and technical perfection that can always be relied on. This is complemented by particularly intuitive operation, which makes everyday driving easier and more convenient”.
In addition to many standard assist systems (such as Lane Assist, Front Assist and the turning brake function), the electric compact model has been given a bandwidth of new functions thanks to the latest software generation. These include, for example, the enhanced Connected Travel Assist with traffic light recognition (optional) as well as one-pedal driving, where the vehicle recuperates until it comes to a standstill. In addition, as with all new ID. models, it is now possible to supply power to external devices – from electric barbeques to e-bikes – with an output of up to 3.6 kW directly from the high-voltage battery using the vehicle-to-load function.
New design clarity. The exterior of the ID.3 Neo reflects the True Volkswagen philosophy in the form of newly designed vehicle front end with a continuous light strip and illuminated logo. The design reflects the Volkswagen “Pure Positive” design language defined by Andreas Mindt, Chief Designer of the brand and Group. As with classic Volkswagen compact models, the roof, rear spoiler and boot lid are painted in the vehicle colour, which makes the ID.3 Neo appear longer, flatter and more dynamic.
High-quality, clear, intuitive operation – 100% Volkswagen. As soon as the doors of the ID.3 Neo are opened, it is obvious that the new model is characterised by a completely new level of quality and clarity. This can be seen in the high-quality materials that have a pleasant feel, the clear horizontal layout of lines and surfaces, new ergonomic and self-explanatory controls, easy-to-grip buttons and intuitive controllers for central functions. The multifunction steering wheel has also been completely redesigned with a rim that is flattened at the top and bottom and clearly structured button panels. The new Infotainment system (Innovision) with 26.0-cm (10.25-inch) Digital Cockpit and a 32.8-cm (12.9-inch) central display impresses with its fluid graphics and easy operation.
New high-efficiency drive. The drive system of the ID.3 Neo is a new development. It offers higher torque and lower consumption than the previous motors. As a result, ranges of up to 630 km (WLTP) are possible in the ID.3 Neo. At the launch, the new model will be available in three equipment lines (Trend, Life and Style) and with three power outputs, as well as three different battery sizes. The three electric drive motors develop an output of 125 kW (170 PS), 140 kW (190 PS) and 170 kW (231 PS). The 125-kW version is paired with a battery with an energy content of 50 kWh (net). It is the standard configuration of the ID.3 Neo Trend. The ID.3 Neo Life and ID.3 Neo Style will also be optionally configurable with a 58-kWh battery (net) and 140 kW as well as a 79- kWh battery (net) with 170 kW. The batteries with an energy content of 50 and 58 kWh have a DC charging capacity of up to 105 kW at a constant high level at DC quick-charging stations, while the 79 kWh version has a charging capacity of up to 183 kW.
Additional services. The new ID. models have the new Innovision Infotainment system on board. A new app store has also been integrated into the In-Car Shop of the new infotainment system, which allows functions and services to be activated or extended digitally, flexibly and on a vehicle-specific basis. As with a smartphone, popular apps from areas such as audio, video streaming, parking, charging and gaming are available for download here.
Many equipment options. The optional equipment includes an augmented reality head-up display, a large panoramic sunroof, 360-degree Area View, a massage and memory function for the front seats, a premium sound system from Harman Kardon, the memory function for Park Assist Pro and a removable bracket for mounting a bicycle carrier for tow bars (up to 75-kg tow bar load).
E f misto stilul retro al ceasurilor de bord digitale. Nice job!
Cand ne vor lovi cu preturile, presimt ca o sa fie misto, da' nu prea..
Deja din toamna asta apar pe piata din UE primele modele chinezesti cu baterii semi-solid state, nu cred ca VAG o sa ceara 40+ pe un ID3. Practic vei avea de ales intre "o baterie istorica si una din viitor"
Nu stiu daca vor aparea atat de repede acele baterii, dar DA!, eu cred ca va costa foarte mult ! Parca vad ca vor da entry level ( 50 kWh Trend) cu 35k gen :)) si ceva ok-ish la 40k+
Eu prevad ca o sa fie astea mici gen ID Polo/Cross bunicel 35k, dar ID3 Neo..
Sunt deja in oferta...
Mg4
Modificat de cristi511
Dupa vitezele maxime este clar ca sunt gandite doar pentru oras si maxim zona metropolitana.
Cred ca e doar o chestie pshihologica limitarea la 160km/h. De cate ori mergem cu aceste viteze, chiar si pe autostrada? Vrei sa depasesti pe unul ce merge legal pe autostrada, sigur diferenta de 30km/h e suficienta pentru a face acest lucru.
Cel putin eu asa as folosi-o. Cine sta in Germania intr-o zona cu multe autostrazi fara limita de viteza probabil o sa se gandeasca la viteza maxima a masinii, in rest nu o vad ca pe un impediment in a cumpara o masina.
Viteza maxima la EV este foarte importanta, daca maxim este 160 inseamna ca la 130Km/h nici nu poti spera la 60-70% range WLTP (pentru care viteza media este 46km/h, pe 25km, in 30min).
Daca o conduci ca o termica poti sa nici nu ajungi la Mamaia, de la Bucuresti.
Sau producatorii se pregatesc de o limitare oficiala a vitezei maxime, in numele consumului (indiferent de combustibil) si a sigurantei pe sosele.
Sa nu ne miram ca in cativa ani nu vei mai putea depasii limitele citite de camerele ce deja echipeaza masinile.
Edit: eu depasesc in mod constant la drum lung viteza respectiva si nu pt ca sunt vreun vitezoman.
@Dolfin foarte de acord cu tine.
marius1982.11
Limitare la cat? 130?
Ai trecut pe reno, sau doar acum am vazut eu semnatura? :))
Nu a postat nimeni de GT3-u cabriolet 😁, acum este si de ala.
Modificat de marius1982.11
E limitat la 180, inca :)).
Am trecut pt ca VAG mi a dat cu lamaie cand am vrut sa le dau banii.
Dialog intre mine si un consilier de vanzari:
" Eu: aveti masina x care ma intereseaza. Vreau sa discutam pretul final sa va fac plata.
Vanzatorul: aaa, stati asa ca e defapt vanduta, tocmai ce am semnat actele acum 1h.
Eu: ok, nicio problema. Vreau una la fel.
Vanzatorul: aaaaa pai nu se poate. Dar mai avem ceva asemanantor dar cu 3k mai.scump.
Eu: ok, multumesc dar nu multumesc."
Era vorba de o cupra formentor.
Asa ca le-am dat banii alora care i au vrut, adica renault in cazul de fata.
marius1982.11
Cum fac aia de la tesla, aa, avem discount de țșpemii de euro. Doar caaa....vine mai chel.
tzuicomicina
E o limitare tehnica. Lipsa unei cutii de viteze sau a altei transmisii conventionale face ca masina sa fie limitata de turatia motorului electric.
Motorul meu preferat, dar e fara induction  noise :). L-am condus pe o automata (ii iert asta) si era o simfonie de sunet, se auzea inclusiv transmisia. Am mers doar cu gura pana la urechi :)))
marius1982.11
Pe GT4 RS cumva?
1 hour ago, marius1982.11 said:
Pe GT4 RS cumva?
Daa. Schimbam vitezele din padele nonstop :)
UBER DRIVERS LIKE THIS POST! :))
Modificat de corad0
Ajung cu ID3 pana la Mamaia cu 130kmh pe CCS.
  • Administrator
Golf GTI Edition 50 Chasing a Record
La noi Nurvil a eliminat Showroom-ul SEAT si il inlocuieste cu BYD
Au spus ca nu e rentabil , nu se vinde
Au pastrat doar Cupra ca showroom
pai asta era directia de cand a aparut Cupra in 2018, nu e niciun mister aici .
Doar ca au mai tras de Seat cat timp a mai vandut ceva masini si au mai amortizat diverse......
Asa este. La un moment dat se punea problema ca SEAT sa ramana companie de mobilitate (trotinete and co)...dar acum a venit momentul in care s-a pus stop. Ramane Cupra, un subbrand devenit main stream, ceva mai upmarket. Same same, dar ceva mai scump decat SEAT.
    • Baxxon
    • joeperry
